power problem
02-10-2007, 02:29
power problem
Joe and Kay Losh have the coach that was right after mine on the assembly line.
As others have said- the differences are amazing. Ernie Ekberg 83PT40 Livingston,Montana ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Friday, February 09, 2007 10:07 PM Subject: Re: [WanderlodgeForum] power problem Not only the differences in these coach between years. At the Quartzsite rally several of us found it interesting the differences between coaches of the same model and year. We came to the conclusion that Bluebird did not build any two coaches the same. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Leroy Eckert wrote: > And, it is amazing the differences in these coaches between years. > That is what makes it tough sometimes. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville,FL > > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > > Sent: Friday, February 09, 2007 10:50 PM > Subject: Re: [WanderlodgeForum] power problem > > Paul, > Interesting...I've never heard of a partical kill switch. I do have to > admit that every day that I spend working on our 'Bird it is > enlightening...always something new to discover. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > PRWillms@... > > > Hi I have an 88 XXV. Did you happen to put glasses or dishes in the > > cabnet over the sink to the right? I have a partical kill switch in > > there. It turns off the front side of the coach, 110v only. Do both > > volt guages in the overhead front right panel show 110? > > > > Paul Williams 88XXV 8V92 > > In South Lake Tahoe > > -----Original Message----- > > From: chaunceyboyblu@... > > > > To: WanderlodgeForum@yahoogroups.com > > > > > Sent: Fri, 9 Feb 2007 8:31 PM > > Subject: [WanderlodgeForum] power problem > > > > I am checking the breaker at the wire going to it, or from it. it is a > > bryant breaker, doesnt the power come into the breaker behind it where > > it clamps onto the box? and the big wire connecting to the breaker is > > going out from the breaker? Anyway, I checked all the breakers and they > > all had 110 volts. Wher could the problem be after that? > > > > Robert Rahn > > 88 pt 40 > > Kalispell, Mt. > > > > > > __________________________________________________________ > > Check out the new AOL. Most comprehensive set of free safety and > > security tools, free access to millions of high-quality videos from > > across the web, free AOL Mail and more. > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
02-10-2007, 13:35
power problem
Starting the generator with shore power plugged in might not work
right -- the "safe line" switch may continue to receive power from the shore connection. Don't know, for sure, 'cause of the different electrical setup from year to year. Before you go nuts taking things apart on your coach, unplug the line from shore power, and use your tester in the shore power socket. It looks some thing like this: 0 I I I The semi-round at top is Ground, the center, bottom is neutral. Left and right are red or black. Use your tester to check from left to bottom (=110?), right to bottom (=110?), left to right (=220?), and top to bottom (=0?). (Left or right to top should also = 110). If the shore power is anything other than this, then it's wired wrong. Do you have a polarity light in your coach? It should indicate "normal" polarity, otherwise, the shore power is wired wrong and there's a risk of serious or fatal shock when you step off the coach to the ground. Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Feb 9, 2007, at 9:31 PM, Robert & Teri Rahn wrote: > when i started the gen and switched the selector to gen from 50 amp, i > did not turn off or disconnect the shore power. Does that matter? > Robert [Non-text portions of this message have been removed] |
