eBay PT 40 - Anyone familiar?
09-01-2006, 10:35
Thanks to all for your responses. I am now much more educated on the A/C
options - I'd initially assumed the coach was a fixed "shell" with the A/C location being an "after the fact" type of choice. Looks like the entire coach is more or less built to order instead and I can now see where it would be virtually impossible to change this. Certainly cheaper to sell the coach and buy a different one if that's what a person wanted. I've also decided that I'm not terribly picky about the A/C location, there are apparently upsides and downsides to both configurations, so I won't worry about it. Thanks again to each of you. -Ryan On 9/1/06, Tom Warner > > The 1985 PT 40 with cruiseairs does not have much less exterior > storage then one with roof airs. The two 1985 PT 40s that I looked > when looking for a PT both had 300 gallon fuel tanks including the > one that I bought. Both the 1982 FC35 that I had and the 1985 PT 40 > that I now have were equipped with cruiseairs and that was something > that I specifically looked for in the 1985 PT 40. I would not have > bought it if it had roof airs. Cruiseairs mean 3 less roof > penetrations, clean ceilings since the air from the cruiseairs exits > on the sides of the rooms, are quieter and in my opinion a better A/C > option. Properly maintained they provide true 3 section A/C for the > bedroom, kitchen and front room. > > > Tom Warner > Vernon Center,NY > 1985 PT 40 > > At 01:08 PM 9/1/2006, you wrote: > >After further thought, the smaller capacities closely match those of > >the FC and may have been incorrectly used because of ignorance of > >the seller who is probably not familiar with BB. Just another possibly. > > > >Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > ----- Original Message ----- > > From: Richard Hayden > > To: > > WanderlodgeForum@yahoogroups.com > > > > > Sent: Friday, September 01, 2006 9:57 AM > > Subject: Re: [WanderlodgeForum] eBay PT 40 - Anyone familiar? > > > > > > I'm sure someone with first hand knowledge will come in here. > > However, my guess is that the smaller capacities are due to the > > amount of space that the 3, Cruise Air A/C units take up. Just a > > guess. I once looked at a coach for my brother that had that kind > > of A/C and it seemed to me that it took up considerable amount of > > basement space. As far as converting is concerned, it probably > > isn't at all particle and would cost far more than it was worth. I > > wouldn't consider doing it at all. You'll need that money for more > > important things such as deferred maintenance and upgrades if you > > get this coach. A far as the second couch is concerned - that > > wouldn't be too difficult. We had such an arrangement in our last > > coach but have the couch/2 chairs arrangement in our present one. > > We much prefer the latter. > > > > Good luck > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > ----- Original Message ----- > > From: Ryan > > Wright > > To: > > WanderlodgeForum@yahoogroups.com > > > > > > > > > Sent: Friday, September 01, 2006 8:58 AM > > Subject: Re: [WanderlodgeForum] eBay PT 40 - Anyone familiar? > > > > I have some other concerns on this, wondering if someone can help > > clear them up. I've got a dialog going with the seller but it appears > > to be a consignment thing with an RV dealership - the seller is not > > the owner - so I'm not sure he knows much about this coach. > > > > 1. Big concern is the capacities. Seller says 100 gal fresh, 40 black, > > 60 grey, and 210 fuel. Vintagebirds.com tells me an '85 PT should have > > 136g fresh, 82 grey, 82 black, and 300 fuel. I'm guessing either the > > seller is misinformed (most likely) or the coach has had significant > > modifications for a reason I probably don't want to hear. Since you > > folks know much more about these Birds than I, can you think of any > > normal reason this coach would have smaller capacities? > > > > 2. I already asked my A/C question but I'll put it here again: Would > > converting to roof mounted units be a reasonable weekend project, or a > > huge undertaking? Any thoughts on the cruise-air systems from someone > > who has owned them? > > > > 3. I love how some of these coaches have a pair of sofas up front. I'm > > guessing it would be trivial to replace the two front chairs & > > mini-table with another sofa? > > > > Thanks to all for your time, > > > > -Ryan > > > > On 9/1/06, Ryan Wright > > > > wrote: > > > > > > Interesting - I was wondering about the A/C units, as the > > description said 3 but I couldn't see 3 on the roof. Now I know why. > > > > > > Would it be possible to convert to roof mount units without > > extraordinary effort - is it likely the bus came pre-wired for > > that? Or would this be a major undertaking? > > > > > > > > > -Ryan > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > [Non-text portions of this message have been removed] |
09-01-2006, 16:37
Hi Ryan,
Our 84 PT 36 has 3 Cruise Air's and a roof air forward. Keep in mind the Cruise's will pick up road heat if run while going down the road. We just run the roof air and close off the back half of the bus and it keeps us veru cool! Bob Lawrence 84 PT36 Tacoma, Wa. > > Thanks to all for your responses. I am now much more educated on the A/C > options - I'd initially assumed the coach was a fixed "shell" with the A/C > location being an "after the fact" type of choice. Looks like the entire > coach is more or less built to order instead and I can now see where it > would be virtually impossible to change this. Certainly cheaper to sell the > coach and buy a different one if that's what a person wanted. > > I've also decided that I'm not terribly picky about the A/C location, there > are apparently upsides and downsides to both configurations, so I won't > worry about it. > > Thanks again to each of you. > > -Ryan > > On 9/1/06, Tom Warner > > > > The 1985 PT 40 with cruiseairs does not have much less exterior > > storage then one with roof airs. The two 1985 PT 40s that I looked > > when looking for a PT both had 300 gallon fuel tanks including the > > one that I bought. Both the 1982 FC35 that I had and the 1985 PT 40 > > that I now have were equipped with cruiseairs and that was something > > that I specifically looked for in the 1985 PT 40. I would not have > > bought it if it had roof airs. Cruiseairs mean 3 less roof > > penetrations, clean ceilings since the air from the cruiseairs exits > > on the sides of the rooms, are quieter and in my opinion a better A/C > > option. Properly maintained they provide true 3 section A/C for the > > bedroom, kitchen and front room. > > > > > > Tom Warner > > Vernon Center,NY > > 1985 PT 40 > > > > At 01:08 PM 9/1/2006, you wrote: > > >After further thought, the smaller capacities closely match those of > > >the FC and may have been incorrectly used because of ignorance of > > >the seller who is probably not familiar with BB. Just another possibly. > > > > > >Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > > > ----- Original Message ----- > > > From: Richard Hayden > > > To: > > > WanderlodgeForum@yahoogroups.com > > > > > > > > Sent: Friday, September 01, 2006 9:57 AM > > > Subject: Re: [WanderlodgeForum] eBay PT 40 - Anyone familiar? > > > > > > > > > I'm sure someone with first hand knowledge will come in here. > > > However, my guess is that the smaller capacities are due to the > > > amount of space that the 3, Cruise Air A/C units take up. Just a > > > guess. I once looked at a coach for my brother that had that kind > > > of A/C and it seemed to me that it took up considerable amount of > > > basement space. As far as converting is concerned, it probably > > > isn't at all particle and would cost far more than it was worth. I > > > wouldn't consider doing it at all. You'll need that money for more > > > important things such as deferred maintenance and upgrades if you > > > get this coach. A far as the second couch is concerned - that > > > wouldn't be too difficult. We had such an arrangement in our last > > > coach but have the couch/2 chairs arrangement in our present one. > > > We much prefer the latter. > > > > > > Good luck > > > > > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > > > ----- Original Message ----- > > > From: Ryan > > > Wright > > > To: > > > WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > > > Sent: Friday, September 01, 2006 8:58 AM > > > Subject: Re: [WanderlodgeForum] eBay PT 40 - Anyone familiar? > > > > > > I have some other concerns on this, wondering if someone can help > > > clear them up. I've got a dialog going with the seller but it appears > > > to be a consignment thing with an RV dealership - the seller is not > > > the owner - so I'm not sure he knows much about this coach. > > > > > > 1. Big concern is the capacities. Seller says 100 gal fresh, 40 black, > > > 60 grey, and 210 fuel. Vintagebirds.com tells me an '85 PT should have > > > 136g fresh, 82 grey, 82 black, and 300 fuel. I'm guessing either the > > > seller is misinformed (most likely) or the coach has had significant > > > modifications for a reason I probably don't want to hear. Since you > > > folks know much more about these Birds than I, can you think of any > > > normal reason this coach would have smaller capacities? > > > > > > 2. I already asked my A/C question but I'll put it here again: Would > > > converting to roof mounted units be a reasonable weekend project, or a > > > huge undertaking? Any thoughts on the cruise-air systems from someone > > > who has owned them? > > > > > > 3. I love how some of these coaches have a pair of sofas up front. I'm > > > guessing it would be trivial to replace the two front chairs & > > > mini-table with another sofa? > > > > > > Thanks to all for your time, > > > > > > -Ryan > > > > > > On 9/1/06, Ryan Wright > > > > > > wrote: > > > > > > > > Interesting - I was wondering about the A/C units, as the > > > description said 3 but I couldn't see 3 on the roof. Now I know why. > > > > > > > > Would it be possible to convert to roof mount units without > > > extraordinary effort - is it likely the bus came pre-wired for > > > that? Or would this be a major undertaking? > > > > > > > > > > > > -Ryan > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > |
09-02-2006, 02:02
I believe that the cruiseairs are getting a bad rap when it comes to
not cooling if the road temperature is high etc, much along the same lines as "The chassis air does not work very well so we fire up the generator when we travel and power the roof airs"). Both statements in my opinion many be true in some cases but why? The design of the cruiseairs in my opinion is better then a roof top A/C, since the condenser is mounted in a protected area under the coach and the evaporator separated by several feet (unlike a rooftop A/C) and mounted inside the coach. The cruiseair unit has a much larger pump and evaporator radiator. I believe that in those cases where the owner is not getting good cooling from the cruiseairs it is because they need servicing after so many years. All three of the cruiseairs in my previous 1982 FC35 (even in very hot southern weather) and the present PT 40 work very well and have never failed to cool the coach down very quickly. Normally we only use one of the cruiseairs either in the back bedroom area during the day if we are in the front of the coach or vice versa during the night if A/.C is necessary. I would suggest that anyone that has cruiseairs where the exit air is above 40 degrees have them checked by a person that knows how to properly service them. tom warner Vernon center,NY 1985 PT40 At 12:37 AM 9/2/2006, you wrote: >Hi Ryan, >Our 84 PT 36 has 3 Cruise Air's and a roof air forward. Keep in mind >the Cruise's will pick up road heat if run while going down the >road. We just run the roof air and close off the back half of the >bus and it keeps us veru cool! >Bob Lawrence >84 PT36 >Tacoma, Wa. |
09-02-2006, 03:21
I agree with Mike.....5-20K add to any bird u buy...unless u buy one
from a guy thats been thru it all and then sells.. I just put new rear brakes and seals on my "new" 80 fc31 and am heading to florida..in Kentucky now. regards, Hank Hannigan 90SP36 80FC31 In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Very major. Keep the cruise airs. Don't over look the rule of thumb, ad $15/20k to any used BB for things that will need attention. Most reliable shops will charge around $100 an hour to work on a bird. > MH > ----- Original Message ----- > From: Ryan Wright > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, September 01, 2006 10:39 AM > Subject: Re: [WanderlodgeForum] eBay PT 40 - Anyone familiar? > > > Interesting - I was wondering about the A/C units, as the description said 3 > but I couldn't see 3 on the roof. Now I know why. > > Would it be possible to convert to roof mount units without extraordinary > effort - is it likely the bus came pre-wired for that? Or would this be a > major undertaking? > > -Ryan > > On 8/31/06, Pete Masterson > > > > It looks fairly clean in the photos. The actual mechanical condition > > would be the most important aspect. Of course, with a 21-22 year old > > coach, you can expect several maintenance items to be an issue so > > don't blow your budget buying the coach... > > > > An observation about the cruise air AC units ... they leave the roof > > 'clean' ... but take up a fair amount of basement storage space. I > > note that this coach has a roof pod for storage ... so it's trading a > > "clean" roof (no ACs) for a roof-pod storage ... not much gain there > > -- and the roof pod is far less convenient to access than is basement > > storage (IMHO). I've heard others criticize the cruise airs on > > operational grounds, but I have no personal experience on that point. > > > > Pete Masterson > > aeonix1@... > > '95 Bluebird Wanderlodge WBDA 4203 > > El Sobrante, CA > > > > > > On Aug 31, 2006, at 4:17 PM, Ryan Wright wrote: > > > > > Does anyone have insight into this coach located in Tampa, FL? > > > > > > http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll? > > > ViewItem&item=190024521209&indexURL=3 > > > > > > I have a dialog going with the seller (owner's agent). Curious if > > > anyone is familiar with this one, or can offer any advice. (I've > > > bought multiple vehicles over the Internet before and am familiar with > > > common sense practices regarding money transfers, etc). > > > > > > Thank you, > > > > > > -Ryan > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > |
09-02-2006, 05:42
Hank,
Don't know your route south but I live just off US Hwy 19 abt. 2 miles South of Camilla, Ga. We are abt. 50 miles south west of Tifton, Ga.. I have a nice place for visitors to park only water available. I would certainly recommend you consider a stop in Thomasville, Ga. 30 miles south of me. Check out Thomasville on the web. Many old Victorian homes very quaint downtown section with old original brick paved streets famous Pebble Hill Plantation open for tours. There is a very nice camp ground just north of town on Hwy 19 with all aminities named Sugar Mill Campground. Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: Henry Jay Hannigan To: WanderlodgeForum@yahoogroups.com Sent: Saturday, September 02, 2006 11:21 AM Subject: [WanderlodgeForum] Re: eBay PT 40 - Anyone familiar? I agree with Mike.....5-20K add to any bird u buy...unless u buy one from a guy thats been thru it all and then sells.. I just put new rear brakes and seals on my "new" 80 fc31 and am heading to florida..in Kentucky now. regards, Hank Hannigan 90SP36 80FC31 In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Very major. Keep the cruise airs. Don't over look the rule of thumb, ad $15/20k to any used BB for things that will need attention. Most reliable shops will charge around $100 an hour to work on a bird. > MH > ----- Original Message ----- > From: Ryan Wright > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, September 01, 2006 10:39 AM > Subject: Re: [WanderlodgeForum] eBay PT 40 - Anyone familiar? > > > Interesting - I was wondering about the A/C units, as the description said 3 > but I couldn't see 3 on the roof. Now I know why. > > Would it be possible to convert to roof mount units without extraordinary > effort - is it likely the bus came pre-wired for that? Or would this be a > major undertaking? > > -Ryan > > On 8/31/06, Pete Masterson > > > > It looks fairly clean in the photos. The actual mechanical condition > > would be the most important aspect. Of course, with a 21-22 year old > > coach, you can expect several maintenance items to be an issue so > > don't blow your budget buying the coach... > > > > An observation about the cruise air AC units ... they leave the roof > > 'clean' ... but take up a fair amount of basement storage space. I > > note that this coach has a roof pod for storage ... so it's trading a > > "clean" roof (no ACs) for a roof-pod storage ... not much gain there > > -- and the roof pod is far less convenient to access than is basement > > storage (IMHO). I've heard others criticize the cruise airs on > > operational grounds, but I have no personal experience on that point. > > > > Pete Masterson > > aeonix1@... > > '95 Bluebird Wanderlodge WBDA 4203 > > El Sobrante, CA > > > > > > On Aug 31, 2006, at 4:17 PM, Ryan Wright wrote: > > > > > Does anyone have insight into this coach located in Tampa, FL? > > > > > > http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll? > > > ViewItem&item=190024521209&indexURL=3 > > > > > > I have a dialog going with the seller (owner's agent). Curious if > > > anyone is familiar with this one, or can offer any advice. (I've > > > bought multiple vehicles over the Internet before and am familiar with > > > common sense practices regarding money transfers, etc). > > > > > > Thank you, > > > > > > -Ryan > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.1.405 / Virus Database: 268.11.7/433 - Release Date: 8/30/2006 [Non-text portions of this message have been removed] |
