Follow up: 89-97 clearance lights and tail lights
10-10-2006, 13:28
Question....since the old Peterson lights are single wire, and self
grounding, what is the fix for the two wire lights? Where do you attach the ground since there is no original ground wire at each light fixture? Hmmm Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] |
10-11-2006, 00:07
You have two choices on the grounding
1 run ground wires back to light switch a large job but the most dependable and politicaly correct 2 make a small loop and ground through the mounting screw of the lights this is the way that it was originaly done on the one wire lights even though there was only onr wire this base of the light grounded the ground completeing the circuit one thing to watch out for with leds is that the light must be connected in the correct polarity or it will not work Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > Question....since the old Peterson lights are single wire, and self > grounding, what is the fix for the two wire lights? Where do you attach the ground > since there is no original ground wire at each light fixture? > > Hmmm > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > > > [Non-text portions of this message have been removed] > |
