What are these switches?
05-01-2007, 03:20
Thanks everyone. I'll play with the controls more when the engine is
running, if they draw heat from there it would make sense that they wouldn't do anything with it off. -Ryan '86 PT-40 8v92 On 5/1/07, jim riordan > > Ryan, > > Remember to put the year and model of your coach on your posts. The switches I have been told are for the heating system, apparently when the coach is running and you have switched over to winter operation you would turn these on and recieve heat from the engine being curculated through the entire coach. Since I have a Florida coach I have not needed to use them but that is what I have been told > > Jim Riordan > 88 WBWL XXV > |
05-01-2007, 04:06
Ryan:
Another criteria for the chassis heat, besides the valves in the engine compartment being on and Coach with the winter summer switch to winter and the black switches being turned to the on position, is there is a thermostat for chassis heat that must be on and calling for heat. The chassis heat fans in some of the Coaches were also on a separate thermostat not operator controlled and will not turn on until the water temp gets to a certain degree F. You should also have a switch next to the summer/winter switch that says AUX Pump and that pump helps to circulate the coolant faster to the chassis heater cores. Safe travels, Ralph and Charolette Fullenwider '84 FC35 Duncan, Oklahoma Ralph's RV Solutions At 08:20 AM 5/1/2007 -0700, you wrote: >Thanks everyone. I'll play with the controls more when the engine is >running, if they draw heat from there it would make sense that they >wouldn't do anything with it off. > >-Ryan >'86 PT-40 8v92 > >On 5/1/07, jim riordan > > > > Ryan, > > > > Remember to put the year and model of your coach on your posts. The > switches I have been told are for the heating system, apparently when the > coach is running and you have switched over to winter operation you would > turn these on and recieve heat from the engine being curculated through > the entire coach. Since I have a Florida coach I have not needed to use > them but that is what I have been told > > > > Jim Riordan > > 88 WBWL XXV > > > > |
