Swing out radiator, antifreeze color, compressor belt, and . . .
12-15-2006, 10:44
Brent,
Do you plan to make the chassis heaters work? Or do you plan to go without them? To make them work...all the chassis hose should be replaced. A tough job. The little radiators can be rebuild if needed. If you plan to go without the chassis heaters...plug off the lines at the block and the radiator using new short sections of hose, inside diameter plug and a hose clamp. To make the radiator swing out without draining the coolant...the radiator tanks need to be modified (the location of the inlet and outlet), and longer hoses are needed. The wanderlodge sites have good information on all this. Good luck. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Brent Swartzentruber wrote: >This question just occured to me after reading one of Tom's old >posts about draining the coolant - do I have to open some valves >somewhere (heaters?) in order to get all the coolant out. > >The previous owner said the engine heaters don't work, but that >could mean anything coming from him. Are there valves for these >heaters that could be trapping coolant? > >Brent >77FC31 >Ventura, CA > > >--- In WanderlodgeForum@yahoogroups.com, "Brent Swartzentruber" ><swartzentruber1@...> wrote: > > >>I'm in the process of pulling apart the front of my 77FC31 for the >>first time. I was pleasantly surprised to find that it has a >> >> >swing- > > >>out radiator (the previous owner didn't know what that was when I >>asked, but the original owner must have been on top of things). >>None of the hoses are long enough to allow it to swing out, so I'm >>guessing I will have to drain the coolant and remove the hoses to >>properly inspect the front of the engine and the belts. Any >>recommendations on hose and/or hose length for this setup. >> >>I drained a small amount of coolant from the radiator. It was >> >> >very > > >>clean and a yellow color. Any ideas on the brand of coolant? >> >>The dash AC is out of commission, so I'm tempted to remove the >>compressor. How big of a job is this? Is there a drain for the >>freon or whatever? >> >>Oh, and I figured out too late that the bumper swings down. What >> >> >a > > >>great idea. >> >>thanks in adance for the help . . >>Brent >>77FC31 >>Ventura, CA >> >> >> > > > > > >Yahoo! Groups Links > > > > > > |
12-15-2006, 10:53
Maybe the hoses don't need to replaced. I had a 71 Travco before I got my Bird.
The heater hoses were original so last year I decided to replace them. I was shocked that there was absolutely nothing wrong with them. No cracks and still flexible after 35 yrs. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Brent, > > Do you plan to make the chassis heaters work? Or do you plan to go > without them? > > To make them work...all the chassis hose should be replaced. A tough > job. The little radiators can be rebuild if needed. > > If you plan to go without the chassis heaters...plug off the lines at > the block and the radiator using new short sections of hose, inside > diameter plug and a hose clamp. > > To make the radiator swing out without draining the coolant...the > radiator tanks need to be modified (the location of the inlet and > outlet), and longer hoses are needed. The wanderlodge sites have good > information on all this. > > Good luck. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > Brent Swartzentruber wrote: > > >This question just occured to me after reading one of Tom's old > >posts about draining the coolant - do I have to open some valves > >somewhere (heaters?) in order to get all the coolant out. > > > >The previous owner said the engine heaters don't work, but that > >could mean anything coming from him. Are there valves for these > >heaters that could be trapping coolant? > > > >Brent > >77FC31 > >Ventura, CA > > > > > >--- In WanderlodgeForum@yahoogroups.com, "Brent Swartzentruber" > ><swartzentruber1@> wrote: > > > > > >>I'm in the process of pulling apart the front of my 77FC31 for the > >>first time. I was pleasantly surprised to find that it has a > >> > >> > >swing- > > > > > >>out radiator (the previous owner didn't know what that was when I > >>asked, but the original owner must have been on top of things). > >>None of the hoses are long enough to allow it to swing out, so I'm > >>guessing I will have to drain the coolant and remove the hoses to > >>properly inspect the front of the engine and the belts. Any > >>recommendations on hose and/or hose length for this setup. > >> > >>I drained a small amount of coolant from the radiator. It was > >> > >> > >very > > > > > >>clean and a yellow color. Any ideas on the brand of coolant? > >> > >>The dash AC is out of commission, so I'm tempted to remove the > >>compressor. How big of a job is this? Is there a drain for the > >>freon or whatever? > >> > >>Oh, and I figured out too late that the bumper swings down. What > >> > >> > >a > > > > > >>great idea. > >> > >>thanks in adance for the help . . > >>Brent > >>77FC31 > >>Ventura, CA > >> > >> > >> > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > |
12-15-2006, 10:59
Well, I'd like the heaters to work because it would be nice to keep
my feet warm while driving. Also, they could add to the cooling capacity of the radiator if need be (e.g. going up a long hill in the middle of summer). I currently use the engine coolant to heat the water heater, so I definetly want that much of it to work. Why do I need to replace the water lines. Aren't they copper? Just too old? I did notice one small valve that used a cable-rod for actuation. It was toast. It looked like something that would control hot water flow to a heater. --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Brent, > > Do you plan to make the chassis heaters work? Or do you plan to go > without them? > > To make them work...all the chassis hose should be replaced. A tough > job. The little radiators can be rebuild if needed. > > If you plan to go without the chassis heaters...plug off the lines at > the block and the radiator using new short sections of hose, inside > diameter plug and a hose clamp. > > To make the radiator swing out without draining the coolant...the > radiator tanks need to be modified (the location of the inlet and > outlet), and longer hoses are needed. The wanderlodge sites have good > information on all this. > > Good luck. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > Brent Swartzentruber wrote: > > >This question just occured to me after reading one of Tom's old > >posts about draining the coolant - do I have to open some valves > >somewhere (heaters?) in order to get all the coolant out. > > > >The previous owner said the engine heaters don't work, but that > >could mean anything coming from him. Are there valves for these > >heaters that could be trapping coolant? > > > >Brent > >77FC31 > >Ventura, CA > > > > > >--- In WanderlodgeForum@yahoogroups.com, "Brent Swartzentruber" > ><swartzentruber1@> wrote: > > > > > >>I'm in the process of pulling apart the front of my 77FC31 for the > >>first time. I was pleasantly surprised to find that it has a > >> > >> > >swing- > > > > > >>out radiator (the previous owner didn't know what that was when I > >>asked, but the original owner must have been on top of things). > >>None of the hoses are long enough to allow it to swing out, so I'm > >>guessing I will have to drain the coolant and remove the hoses to > >>properly inspect the front of the engine and the belts. Any > >>recommendations on hose and/or hose length for this setup. > >> > >>I drained a small amount of coolant from the radiator. It was > >> > >> > >very > > > > > >>clean and a yellow color. Any ideas on the brand of coolant? > >> > >>The dash AC is out of commission, so I'm tempted to remove the > >>compressor. How big of a job is this? Is there a drain for the > >>freon or whatever? > >> > >>Oh, and I figured out too late that the bumper swings down. What > >> > >> > >a > > > > > >>great idea. > >> > >>thanks in adance for the help . . > >>Brent > >>77FC31 > >>Ventura, CA > >> > >> > >> > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > |
12-15-2006, 11:11
A significant portion of the chassis heater runs are done in rubber hose. I'd
check their condition before going through the work of replacing them. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Brent Swartzentruber" <swartzentruber1@...> wrote: > > Well, I'd like the heaters to work because it would be nice to keep > my feet warm while driving. Also, they could add to the cooling > capacity of the radiator if need be (e.g. going up a long hill in > the middle of summer). > I currently use the engine coolant to heat the water heater, so I > definetly want that much of it to work. > > Why do I need to replace the water lines. Aren't they copper? Just > too old? > > I did notice one small valve that used a cable-rod for actuation. > It was toast. It looked like something that would control hot water > flow to a heater. > > > > > > --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > > > > Brent, > > > > Do you plan to make the chassis heaters work? Or do you plan to go > > without them? > > > > To make them work...all the chassis hose should be replaced. A > tough > > job. The little radiators can be rebuild if needed. > > > > If you plan to go without the chassis heaters...plug off the lines > at > > the block and the radiator using new short sections of hose, > inside > > diameter plug and a hose clamp. > > > > To make the radiator swing out without draining the coolant...the > > radiator tanks need to be modified (the location of the inlet and > > outlet), and longer hoses are needed. The wanderlodge sites have > good > > information on all this. > > > > Good luck. > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > > > Brent Swartzentruber wrote: > > > > >This question just occured to me after reading one of Tom's old > > >posts about draining the coolant - do I have to open some valves > > >somewhere (heaters?) in order to get all the coolant out. > > > > > >The previous owner said the engine heaters don't work, but that > > >could mean anything coming from him. Are there valves for these > > >heaters that could be trapping coolant? > > > > > >Brent > > >77FC31 > > >Ventura, CA > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "Brent Swartzentruber" > > ><swartzentruber1@> wrote: > > > > > > > > >>I'm in the process of pulling apart the front of my 77FC31 for > the > > >>first time. I was pleasantly surprised to find that it has a > > >> > > >> > > >swing- > > > > > > > > >>out radiator (the previous owner didn't know what that was when > I > > >>asked, but the original owner must have been on top of things). > > >>None of the hoses are long enough to allow it to swing out, so > I'm > > >>guessing I will have to drain the coolant and remove the hoses > to > > >>properly inspect the front of the engine and the belts. Any > > >>recommendations on hose and/or hose length for this setup. > > >> > > >>I drained a small amount of coolant from the radiator. It was > > >> > > >> > > >very > > > > > > > > >>clean and a yellow color. Any ideas on the brand of coolant? > > >> > > >>The dash AC is out of commission, so I'm tempted to remove the > > >>compressor. How big of a job is this? Is there a drain for the > > >>freon or whatever? > > >> > > >>Oh, and I figured out too late that the bumper swings down. > What > > >> > > >> > > >a > > > > > > > > >>great idea. > > >> > > >>thanks in adance for the help . . > > >>Brent > > >>77FC31 > > >>Ventura, CA > > >> > > >> > > >> > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > |
12-15-2006, 11:34
Brent,
Chassis heater system is mostly 1" rubber hose. I agree that the added coolant capacity is a good thing. Right, that small valve controls the flow/no-flow for the chassis heaters. Your local parts store should have it. The cat engine should keep your right foot warm. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Brent Swartzentruber wrote: >Well, I'd like the heaters to work because it would be nice to keep >my feet warm while driving. Also, they could add to the cooling >capacity of the radiator if need be (e.g. going up a long hill in >the middle of summer). >I currently use the engine coolant to heat the water heater, so I >definetly want that much of it to work. > >Why do I need to replace the water lines. Aren't they copper? Just >too old? > >I did notice one small valve that used a cable-rod for actuation. >It was toast. It looked like something that would control hot water >flow to a heater. > > > > |
12-15-2006, 13:08
I see an amazing journey of discovery and awareness in your immediate future.
Flushing lines, changing hoses and clamps, learning about the mysteries of Sporlan valves and the interesting problem solving of the South Georgia work force, since retired. The AC can be brought back to life with a larger condenser and replacement pump. I didn't flush the system adequately on the first go round and got to change the expansion valve on vacation last year. You want to change over to 134A of course. MH ----- Original Message ----- From: Brent Swartzentruber To: WanderlodgeForum@yahoogroups.com Sent: Friday, December 15, 2006 4:16 PM Subject: [WanderlodgeForum] Re: Swing out radiator, antifreeze color, compressor belt, and . . . This question just occured to me after reading one of Tom's old posts about draining the coolant - do I have to open some valves somewhere (heaters?) in order to get all the coolant out. The previous owner said the engine heaters don't work, but that could mean anything coming from him. Are there valves for these heaters that could be trapping coolant? Brent 77FC31 Ventura, CA --- In WanderlodgeForum@yahoogroups.com, "Brent Swartzentruber" <swartzentruber1@...> wrote: > > I'm in the process of pulling apart the front of my 77FC31 for the > first time. I was pleasantly surprised to find that it has a swing- > out radiator (the previous owner didn't know what that was when I > asked, but the original owner must have been on top of things). > None of the hoses are long enough to allow it to swing out, so I'm > guessing I will have to drain the coolant and remove the hoses to > properly inspect the front of the engine and the belts. Any > recommendations on hose and/or hose length for this setup. > > I drained a small amount of coolant from the radiator. It was very > clean and a yellow color. Any ideas on the brand of coolant? > > The dash AC is out of commission, so I'm tempted to remove the > compressor. How big of a job is this? Is there a drain for the > freon or whatever? > > Oh, and I figured out too late that the bumper swings down. What a > great idea. > > thanks in adance for the help . . > Brent > 77FC31 > Ventura, CA > [Non-text portions of this message have been removed] |
12-15-2006, 13:48
spin it by hand, free? Any pressure? Pump a vacuum, see if it holds
(after tightening the clamps at the pump). If it holds a vacuum, I'd add some oil and recharge with R-12. R-134a will work, but it will leak faster and cool less, and I'm not sure it is that much cheaper than R-134a anymore after changing the oil and flushing. Oh, also change the filter/dryer (in overhead). - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Brent Swartzentruber" <swartzentruber1@...> wrote: > > Tom, > That's not a bad idea, but I'm not sure if the working fluid is the > only problem. As far as I know, the A/C hasn't been used in 10 > years (the heaters too). I'm guessing that means it would need at > least a compressor rebuild. > thanks for the pics. |
12-15-2006, 14:03
The coolant in your front heater (ahead of co-pilot) has one gate-
valve (regular handwheel/faucet type) behind the curbside front bumper step. That, and a cable-operated valve from the steering- column right side, like a lawnmower throttle cable. The rear heater loop is a little more complicated: There are two more gate valves beneath the pilot's seat floor, slide under to see them. Open them and there should be flow to the loop. If the two rear push-pull cables (in bed base (side-double bed) or nightstand base (twin-beds) are set to winter, the flow will be through all three heater cores: RR corner under vanity or bed as equipped; Under forwardmost dinette seat next to safe (safe optional); under streetside sofa; and also through the motoraid / heat-exchanger in the domestic water heater. With the two valves in summer mode the water is diverted through the domestic water heater only, then through the return line to the engine. In both cases the supply side goes through a brass-body "auxiliary pump" behind the rear bumper on the street side which is intended to boost coolant flow at idle RPM on school buses, should come on with the switch on the dash. The water flow and thus temperature to the front heater (the one in front of the co-pilot) including defrost can be varied by the position of the "front heat" cable on the steering column, the water flow and temperature of the rear chassis heaters can be varied also with the "rear heat" knob/cable which operates a valve under the driver's floor. The Right Vent can also be varied with the knob at the pilot's right knee, allows fresh air into the front heat system instead of recycled air. Believe it or not, this is (in my opinion) the best heat system that Wanderlodges ever had, it was eventually replaced with an open/close vent and open/close valves (two state only) which tended to make everyone too hot or too cold all of the time. The rear heat switch on the dash/overhead controls power to the three rear "chassis heaters", another way to vary heat. Typically I ran with all three rear heater blowers set to low speed (chrome knob at each heater location, out was high, in was off, middle is low just like the front switches), and varied the temperature/water flow to suit comfort. Never needed high blower or the aux. pump on my '77 FC, even in ice and snow storms. Good luck, - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Brent Swartzentruber" <swartzentruber1@...> wrote: > > This question just occured to me after reading one of Tom's old > posts about draining the coolant - do I have to open some valves > somewhere (heaters?) in order to get all the coolant out. > > The previous owner said the engine heaters don't work, but that > could mean anything coming from him. Are there valves for these > heaters that could be trapping coolant? > > Brent > 77FC31 > Ventura, CA > |
12-15-2006, 15:01
Yeah, it's like the lion, the witch, and Wanderlodge. There's a
whole mysterious adventure in this thing once you get past the doors. Thanks to all and to Jeff for the thorough layout. I'll have to check on that. I really need a steam clean to start. Sounds like the heating system is worth recovering. I'm thinking of just leaving all the valves as is until after Baja, as I don't want to open another can of Wander Worms just yet. I have tonight and two days to spend on the bird, and my list is long enough already. I bought CAT antifreeze and plan to recapture it ($100) next time I break into the lines. I wonder how many gallons total is in the whole cooling system - I drained out 10 gal. I guess I will have to water my neighbor lawn with it - the neighbor that called the cops twice because I had it parked on the street in front of MY house. I wonder if I could put a big gate valve on the bottom radiator hose to enable the radiator to swing? I would still have to disconnect the top hoses, but maybe a good compromise. --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > I see an amazing journey of discovery and awareness in your immediate future. Flushing lines, changing hoses and clamps, learning about the mysteries of Sporlan valves and the interesting problem solving of the South Georgia work force, since retired. The AC can be brought back to life with a larger condenser and replacement pump. I didn't flush the system adequately on the first go round and got to change the expansion valve on vacation last year. You want to change over to 134A of course. > MH > ----- Original Message ----- > From: Brent Swartzentruber > To: WanderlodgeForum@yahoogroups.com > Sent: Friday, December 15, 2006 4:16 PM > Subject: [WanderlodgeForum] Re: Swing out radiator, antifreeze color, compressor belt, and . . . > > > This question just occured to me after reading one of Tom's old > posts about draining the coolant - do I have to open some valves > somewhere (heaters?) in order to get all the coolant out. > > The previous owner said the engine heaters don't work, but that > could mean anything coming from him. Are there valves for these > heaters that could be trapping coolant? > > Brent > 77FC31 > Ventura, CA > > --- In WanderlodgeForum@yahoogroups.com, "Brent Swartzentruber" > <swartzentruber1@> wrote: > > > > I'm in the process of pulling apart the front of my 77FC31 for the > > first time. I was pleasantly surprised to find that it has a > swing- > > out radiator (the previous owner didn't know what that was when I > > asked, but the original owner must have been on top of things). > > None of the hoses are long enough to allow it to swing out, so I'm > > guessing I will have to drain the coolant and remove the hoses to > > properly inspect the front of the engine and the belts. Any > > recommendations on hose and/or hose length for this setup. > > > > I drained a small amount of coolant from the radiator. It was > very > > clean and a yellow color. Any ideas on the brand of coolant? > > > > The dash AC is out of commission, so I'm tempted to remove the > > compressor. How big of a job is this? Is there a drain for the > > freon or whatever? > > > > Oh, and I figured out too late that the bumper swings down. What > a > > great idea. > > > > thanks in adance for the help . . > > Brent > > 77FC31 > > Ventura, CA > > > > > > > > [Non-text portions of this message have been removed] > |
