hydrogen in tires
01-10-2007, 03:39
hydrogen in tires
Pete,
If you're going to quote Wikipedia verbatim, at least credit the source. David Brady '02 LXi, Smoke NC Pete Masterson wrote: > From Wikipedia: > > Nitrogen is a nonmetal, with an electronegativity of 3.0. It has five > electrons in its outer shell and is therefore trivalent in most > compounds. The triple bond in molecular nitrogen (N2) is the > strongest in nature. The resulting difficulty of converting (N2) into > other compounds, and the ease (and associated high energy release) of > converting nitrogen compounds into elemental N2, have dominated the > role of nitrogen in both nature and human economic activities. [In > other words, many nitrogen compounds are quite explosive, but > elemental nitrogen is quite stable.] > > > > > |
01-10-2007, 04:42
hydrogen in tires
My humblest apologies Pete. I'm now removing foot firmly wedged
in mouth. I must be blind, I truly didn't see your Wikipedia credit. Again, my mistake. David Brady '02 LXi, Smoke NC Promise to lighten up in the future... David Brady wrote: > Pete, > > If you're going to quote Wikipedia verbatim, at least credit the source. > > David Brady > '02 LXi, Smoke > NC > > Pete Masterson wrote: > >> From Wikipedia: >> >> Nitrogen is a nonmetal, with an electronegativity of 3.0. It has five >> electrons in its outer shell and is therefore trivalent in most >> compounds. The triple bond in molecular nitrogen (N2) is the >> strongest in nature. The resulting difficulty of converting (N2) into >> other compounds, and the ease (and associated high energy release) of >> converting nitrogen compounds into elemental N2, have dominated the >> role of nitrogen in both nature and human economic activities. [In >> other words, many nitrogen compounds are quite explosive, but >> elemental nitrogen is quite stable.] >> >> >> >> >> >> > > > > > Yahoo! Groups Links > > > > > > [Non-text portions of this message have been removed] |
01-11-2007, 06:43
hydrogen in tires
I thought the nitrogen article was in FMCA. I just did a serch at FMCA
and my memory failed me again. Where ever it was, the article focused on carrying a small tank of N to top off the tires to the correct pressure. I have found a tire dealer in Harlingen, Tx that will fill my 8 tires with N for $100. The big "gas" company will sell me a tank and regulator for $250. The tank will have 2,200psi and 100's of cubic feet of N. I am thinking it might be worth it. Jack in Mich. 05 450Lxi --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > There are at least two advantages to nitrogen. > > The first is that it should have little or no moisture because it is > produced at a specialized facility where there should be certain > levels of quality control. Compressed air from in-house compressors > contains water, the amount depends on the current humidity. > > Second, nitrogen is an inert gas, that is to say it does not > react chemicaly with anything. Oxygen, as you know, reacts with most > everything. So filling with nitrogen will prevent oxidation of the > inner tire as well as the rim. > > Is it worth the extra cost, if any? I don't know. But if you > decide to go that way you need to continue to use it wen you adjust > tire pressure or you will end up contaminating the atmosphere inside > the tire. So carry a tank of nitrogen or seek out local suppliers. > > Gardner > 78FC33 > > > --- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote: > > > > I think the main advantage of nitrogen vs. compressed air is that > the > > nitrogen is dry, and has no moisture in it, which is bad for > tires. Costco, who is > > now becoming one of the nation's largest passenger car and light > truck tire > > retailers, now use nitrogen when installing their new tires. > that's what > > they told me anyway...FWIW.... > > > > Kevin > > Yorba Linda, CA > > 1986 38' PT > > > > > > [Non-text portions of this message have been removed] > > > |
01-12-2007, 00:58
hydrogen in tires
Clearly too much time on your hands, looking at the length of this
thread. Jim --- In WanderlodgeForum@yahoogroups.com, David Brady wrote: > > My humblest apologies Pete. I'm now removing foot firmly wedged > in mouth. I must be blind, I truly didn't see your Wikipedia credit. > Again, my mistake. > > David Brady > '02 LXi, Smoke > NC > > Promise to lighten up in the future... > > David Brady wrote: > > Pete, > > > > If you're going to quote Wikipedia verbatim, at least credit the source. > > > > David Brady > > '02 LXi, Smoke > > NC > > > > Pete Masterson wrote: > > > >> From Wikipedia: > >> > >> Nitrogen is a nonmetal, with an electronegativity of 3.0. It has five > >> electrons in its outer shell and is therefore trivalent in most > >> compounds. The triple bond in molecular nitrogen (N2) is the > >> strongest in nature. The resulting difficulty of converting (N2) into > >> other compounds, and the ease (and associated high energy release) of > >> converting nitrogen compounds into elemental N2, have dominated the > >> role of nitrogen in both nature and human economic activities. [In > >> other words, many nitrogen compounds are quite explosive, but > >> elemental nitrogen is quite stable.] > >> > >> > >> > >> > >> > >> > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > |
