Up graded fresh water pump
02-26-2007, 13:11
On the street side nite stand is a bunch of water lines. All have been patched
with clamps and clear/ webbed tubing. It has been a constant source of mini leaks and these new to me connectors should make this jon not such a chore. i still have the red and blue pex tubing left over from last year. One place I really don't want to mess with is the water tank compartment. Ernie Ekberg 83PT40 Livingston,Montana ----- Original Message ----- From: Pete Masterson To: WanderlodgeForum@yahoogroups.com Sent: Monday, February 26, 2007 6:04 PM Subject: Re: [WanderlodgeForum] Up graded fresh water pump Go ahead and order the little tool they offer if you have very many fittings. I used channel-lock pliers, but that tears up the 'grips' on the outside of the threaded ends. Since I only had 4 fittings I didn't bother with their tool, but it would have made for a better looking installation. (Actually, I didn't notice their tool until after I'd submitted my order.) Pete Masterson aeonix1@... '95 Blue Bird Wanderlodge WBDA 42' El Sobrante, CA On Feb 26, 2007, at 4:44 PM, ernieekberg@... wrote: > Thanks, Pete, they look a whole lot easier to use in my tight, > cramped spaces. I was going to give up finishing the job because of > the cramped spaces. > Ernie Ekberg > 83PT40 > Livingston,Montana > ----- Original Message ----- > From: Pete Masterson > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, February 26, 2007 4:55 PM > Subject: Re: [WanderlodgeForum] Up graded fresh water pump > > > Ernie, > > Exactly what I've heard about PEX crimper tools ... hard to use > especially in tight spaces. The fittings are called "Flair-It" and > can be viewed at PEX Connection at > <http://www.pexconnection.com/categories.php?catID=2> > > Flair-It also has a web site, but it isn't nearly as useful as the > PEX Connection site. The 'birds with the Polybutyl plumbing also use > the Flair-It fittings. > > Pete Masterson > aeonix1@... > '95 Blue Bird Wanderlodge WBDA 42' > El Sobrante, CA > > On Feb 26, 2007, at 2:50 PM, ernieekberg@... wrote: > >> Pete- last year, when replacing my copper lines I used PEX with the >> crimper tool. It was murder to get it to work in small spaces. I >> didn't know there were other fittings available. >> Ernie Ekberg >> 83PT40 >> Livingston,Montana > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > > > > ------------------------ Yahoo! Groups Sponsor -------------------- > ~--> > Something is new at Yahoo! Groups. Check out the enhanced email > design. > http://us.click.yahoo.com/kOt0.A/gOaOAA/.../pkiolB/TM > ---------------------------------------------------------- > ~-> > > > Yahoo! Groups Links > > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
02-26-2007, 13:28
Ernie, I think the PEX with the Flar-It connectors may be the ticket to
our water line issues. I'm thinking that is the next "BIG" project once I paint it. Thanks to Pete for sharing his experience. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T ernieekberg@... wrote: > On the street side nite stand is a bunch of water lines. All have been > patched with clamps and clear/ webbed tubing. It has been a constant > source of mini leaks and these new to me connectors should make this > jon not such a chore. i still have the red and blue pex tubing left > over from last year. One place I really don't want to mess with is the > water tank compartment. > Ernie Ekberg > 83PT40 > Livingston,Montana > ----- Original Message ----- > From: Pete Masterson > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, February 26, 2007 6:04 PM > Subject: Re: [WanderlodgeForum] Up graded fresh water pump > > Go ahead and order the little tool they offer if you have very many > fittings. I used channel-lock pliers, but that tears up the 'grips' > on the outside of the threaded ends. Since I only had 4 fittings I > didn't bother with their tool, but it would have made for a better > looking installation. (Actually, I didn't notice their tool until > after I'd submitted my order.) > > Pete Masterson > aeonix1@... > '95 Blue Bird Wanderlodge WBDA 42' > El Sobrante, CA > > On Feb 26, 2007, at 4:44 PM, ernieekberg@... > > > > Thanks, Pete, they look a whole lot easier to use in my tight, > > cramped spaces. I was going to give up finishing the job because of > > the cramped spaces. > > Ernie Ekberg > > 83PT40 > > Livingston,Montana > > ----- Original Message ----- > > From: Pete Masterson > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Monday, February 26, 2007 4:55 PM > > Subject: Re: [WanderlodgeForum] Up graded fresh water pump > > > > > > Ernie, > > > > Exactly what I've heard about PEX crimper tools ... hard to use > > especially in tight spaces. The fittings are called "Flair-It" and > > can be viewed at PEX Connection at > > <http://www.pexconnection.com/categories.php?catID=2 > <http://www.pexconnection.com/categories.php?catID=2>> > > > > Flair-It also has a web site, but it isn't nearly as useful as the > > PEX Connection site. The 'birds with the Polybutyl plumbing also use > > the Flair-It fittings. > > > > Pete Masterson > > aeonix1@... > > '95 Blue Bird Wanderlodge WBDA 42' > > El Sobrante, CA > > > > On Feb 26, 2007, at 2:50 PM, ernieekberg@... > > > > >> Pete- last year, when replacing my copper lines I used PEX with the > >> crimper tool. It was murder to get it to work in small spaces. I > >> didn't know there were other fittings available. > >> Ernie Ekberg > >> 83PT40 > >> Livingston,Montana > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > ------------------------ Yahoo! Groups Sponsor -------------------- > > ~--> > > Something is new at Yahoo! Groups. Check out the enhanced email > > design. > > http://us.click.yahoo.com/kOt0.A/gOaOAA/.../pkiolB/TM > <http://us.click.yahoo.com/kOt0.A/gOaOAA/.../pkiolB/TM> > > ---------------------------------------------------------- > > ~-> > > > > > > Yahoo! Groups Links > > > > > > > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
