Update - Thermostat and radiator service, with 6,000 pound in tow.
03-20-2007, 02:51
Curt, Deja Vu , I must have inhaled brakeCleaner or read this
someother place. After Captn' KevinMc, my bus is next. GregoryO'Connor 94PTRomolandCa > Update...The past few days I ran the bus about 400 miles, 6,000 pounds > > > in tow, outside temperature in the 80's. On the flat the coolant > > > temperature run 180-185, oil temperature 220. Climbing Whitewater Grade > > > out of Palm Springs, 40 mph head wind, the coolant temperature got up to > > > 190 degrees, oil just over 230. I'd say changing the thermostats and > > > clean/rodding the radiator was a good thing to do. > > > > > > -- > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > |
03-20-2007, 04:33
Greg,
Deja Vu...that posting is about the same as my short trial run after all the work. You have a good memory. After Captn' KevinMc, my bus is next. That works for me. Haven't heard anymore from Kevin. Did Derek get the hyd fan problem resolved? Did dad & mom get to go on their trip? Hope all worked out. Did you hear any more from Rob Robinson, dates he plans to be at your place, etc? Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Gregory OConnor wrote: > Curt, Deja Vu , I must have inhaled brakeCleaner or read this > someother place. > After Captn' KevinMc, my bus is next. > > GregoryO'Connor > 94PTRomolandCa > > > Update...The past few days I ran the bus about 400 miles, 6,000 > pounds > > > > in tow, outside temperature in the 80's. On the flat the coolant > > > > temperature run 180-185, oil temperature 220. Climbing > Whitewater Grade > > > > out of Palm Springs, 40 mph head wind, the coolant temperature > got up to > > > > 190 degrees, oil just over 230. I'd say changing the > thermostats and > > > > clean/rodding the radiator was a good thing to do. > > > > > > > > -- > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > |
03-20-2007, 14:45
Evening Curt,
My guess is the correlation for much of the cooling system repairs on these Detroits would be best expressed in terms of years rather than miles. Most automotive heating/cooling hoses have a "safe" life around maybe 5-7 years in my opinion. These are all original hoses etc that I am replacing so feel am pushing my luck in running them any longer on the coach. The rad core was shot, maybe it would have lasted another 5,000 miles but I seriously doubt it. I pulled the turbo & blower off for better access to all the other parts. Figured I might as well rebuild them & replace all the bearings while at it. Also had a gasket failure at the blower mounting flange. I do have a history for all the work on the coach & it was pretty complete when I purchased it. The coach is parked at my Land Rover shop in Billings. Plugged into 240-50 amp service & water & sewer hookups. I have done some of the work on it myself but also have employees that work on it when time permits. It's also getting stripped and is about ready for repaint when it warms up some. Plan to be able to use it quite a lot when it's all finished. Mexico is calling...The report is that they have some beer & tequila left down there. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Curt Sprenger wrote: > Terry, > I wonder if a correlation could be established between engine miles and > the coolant/fuel hose, pump, maintenance requirements. Would be useful > to other 'Bird owners for sure. > > You are doing a lot of work on your engine. What is the rational for the > blower and turbo work? Do you have the maintenance history on your coach? > > You must have a shop to park your bus and work on it. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > Terry Neal wrote: > > > Curt, it has 171,000 on it which appears pretty close from the Hobbs > > hour meter. Went through all the upper part of the engine. Rebuilt or > > replaced the blower, turbo, water pump, fuel pump, Charge air cooler, > > etc. Resetting the fuel rails now & putting it all back together. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > Curt Sprenger wrote: > > > > > Terry, > > > Please keep us posted. > > > How many miles on your engine? > > > > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > Terry Neal wrote: > > > > > > > Sounds like you did the right thing replacing all of those parts. > > > > That's what I did on mine too. Plus new water pump & new rad core > > > > (increased cooling capacity 15%). When it warms up some, will > take it > > > > out on I90 to see what it runs at now. > > > > > > > > Terry Neal > > > > Bozeman, MT > > > > 82PT40 6V92TA > > > > 74FC34 6V53T > > > > > > > > Curt Sprenger wrote: > > > > > > > > > Update...The past few days I ran the bus about 400 miles, 6,000 > > pounds > > > > > in tow, outside temperature in the 80's. On the flat the coolant > > > > > temperature run 180-185, oil temperature 220. Climbing Whitewater > > > Grade > > > > > out of Palm Springs, 40 mph head wind, the coolant temperature got > > > up to > > > > > 190 degrees, oil just over 230. I'd say changing the > thermostats and > > > > > clean/rodding the radiator was a good thing to do. > > > > > > > > > > -- > > > > > Curt Sprenger > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] |
03-20-2007, 14:57
Thanks for the tips Jimmy. I will try & remember to check everything
periodically. Figure the hoses that are silicone will last a few years but the normal coolant stuff will get replaced every couple of years. My shop guys just really hate to see me bring something else through the door. Between all my toys, cars, trucks & the boat, they have a pretty wide variety of iron to keep running. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T James Harvie wrote: > Terry, I'd say change your hoses every other year, If you drive it or > not. Also don't be afraid to use a nutdriver and go over your hose > clamps often. Those Detriots vibrate a lot so I used to throw a wrench > on all of the engine bolts, on the ones I used to own, expecially the > oil cooler. I use Permetex #2 non hardening goo goo on all of my > connections. One thing to remember is always put it on the male end, > so none gets inside Good luck! > Jimmy Harvie > Curt Sprenger > I wonder if a correlation could be established between engine miles and > the coolant/fuel hose, pump, maintenance requirements. Would be useful > to other 'Bird owners for sure. > > You are doing a lot of work on your engine. What is the rational for the > blower and turbo work? Do you have the maintenance history on your coach? > > You must have a shop to park your bus and work on it. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > Terry Neal wrote: > > > Curt, it has 171,000 on it which appears pretty close from the Hobbs > > hour meter. Went through all the upper part of the engine. Rebuilt or > > replaced the blower, turbo, water pump, fuel pump, Charge air cooler, > > etc. Resetting the fuel rails now & putting it all back together. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > Curt Sprenger wrote: > > > > > Terry, > > > Please keep us posted. > > > How many miles on your engine? > > > > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > Terry Neal wrote: > > > > > > > Sounds like you did the right thing replacing all of those parts. > > > > That's what I did on mine too. Plus new water pump & new rad core > > > > (increased cooling capacity 15%). When it warms up some, will > take it > > > > out on I90 to see what it runs at now. > > > > > > > > Terry Neal > > > > Bozeman, MT > > > > 82PT40 6V92TA > > > > 74FC34 6V53T > > > > > > > > Curt Sprenger wrote: > > > > > > > > > Update...The past few days I ran the bus about 400 miles, 6,000 > > pounds > > > > > in tow, outside temperature in the 80's. On the flat the coolant > > > > > temperature run 180-185, oil temperature 220. Climbing Whitewater > > > Grade > > > > > out of Palm Springs, 40 mph head wind, the coolant temperature got > > > up to > > > > > 190 degrees, oil just over 230. I'd say changing the > thermostats and > > > > > clean/rodding the radiator was a good thing to do. > > > > > > > > > > -- > > > > > Curt Sprenger > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > --------------------------------- > We won't tell. Get more on shows you hate to love > (and love to hate): Yahoo! TV's Guilty Pleasures list. > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
03-20-2007, 15:04
I would call it preventative maintenance George. The engine runs real
strong. Ernie has driven it & says it is in top shape. After buying the coach, I wanted to have a comfort level for the condition of all systems and major components so I have a base line to work from. No major problems with anything, just started out replacing things such as the original battery charger/boilers & kept going from there. We're remodeling the interior & repainting the exterior too. It's kind of in my blood I guess to bring old things back to life. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T gnburke@... wrote: > Terry, I have missed some posts here. What happened that you had to go > into a DD6V92TA with only 171000 miles. Those engines are barely > broken in at that point. I have not known of many failing with what > would be considered low milage for that engine. On my part, since > joining this forum in Dec., I have been more alarmed at the failure > rate of the Cats, at fairly low milage. Good luck with the repairs, > George Burke, 1977FC31 Charlotte > ----- Original Message ----- > From: Terry Neal > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, March 19, 2007 8:33 PM > Subject: Re: [WanderlodgeForum] Update - Thermostat and radiator > service, with 6,000 pound in tow. > > Curt, it has 171,000 on it which appears pretty close from the Hobbs > hour meter. Went through all the upper part of the engine. Rebuilt or > replaced the blower, turbo, water pump, fuel pump, Charge air cooler, > etc. Resetting the fuel rails now & putting it all back together. > > Terry Neal > Bozeman, MT > 82PT40 6V92TA > 74FC34 6V53T > > Curt Sprenger wrote: > > > Terry, > > Please keep us posted. > > How many miles on your engine? > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > Terry Neal wrote: > > > > > Sounds like you did the right thing replacing all of those parts. > > > That's what I did on mine too. Plus new water pump & new rad core > > > (increased cooling capacity 15%). When it warms up some, will take it > > > out on I90 to see what it runs at now. > > > > > > Terry Neal > > > Bozeman, MT > > > 82PT40 6V92TA > > > 74FC34 6V53T > > > > > > Curt Sprenger wrote: > > > > > > > Update...The past few days I ran the bus about 400 miles, 6,000 > pounds > > > > in tow, outside temperature in the 80's. On the flat the coolant > > > > temperature run 180-185, oil temperature 220. Climbing Whitewater > > Grade > > > > out of Palm Springs, 40 mph head wind, the coolant temperature got > > up to > > > > 190 degrees, oil just over 230. I'd say changing the thermostats and > > > > clean/rodding the radiator was a good thing to do. > > > > > > > > -- > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
03-20-2007, 15:30
Terry,
I like your way of thinking...same as mine. You are doing it right. Please take before/after pictures of your coach. We'd all like to see them. "The report is that they have some beer & tequila left down there"..Let's get a group party going. It doesn't need to take place soon, but some day, just needs planing. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Terry Neal wrote: > Evening Curt, > > My guess is the correlation for much of the cooling system repairs on > these Detroits would be best expressed in terms of years rather than > miles. Most automotive heating/cooling hoses have a "safe" life around > maybe 5-7 years in my opinion. These are all original hoses etc that I > am replacing so feel am pushing my luck in running them any longer on > the coach. The rad core was shot, maybe it would have lasted another > 5,000 miles but I seriously doubt it. > > I pulled the turbo & blower off for better access to all the other > parts. Figured I might as well rebuild them & replace all the bearings > while at it. Also had a gasket failure at the blower mounting flange. > > I do have a history for all the work on the coach & it was pretty > complete when I purchased it. > > The coach is parked at my Land Rover shop in Billings. Plugged into > 240-50 amp service & water & sewer hookups. I have done some of the > work on it myself but also have employees that work on it when time > permits. > > It's also getting stripped and is about ready for repaint when it warms > up some. > > Plan to be able to use it quite a lot when it's all finished. > > Mexico is calling...The report is that they have some beer & tequila > left down there. > > Terry Neal > Bozeman, MT > 82PT40 6V92TA > 74FC34 6V53T > > Curt Sprenger wrote: > > > Terry, > > I wonder if a correlation could be established between engine miles and > > the coolant/fuel hose, pump, maintenance requirements. Would be useful > > to other 'Bird owners for sure. > > > > You are doing a lot of work on your engine. What is the rational for the > > blower and turbo work? Do you have the maintenance history on your > coach? > > > > You must have a shop to park your bus and work on it. > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > Terry Neal wrote: > > > > > Curt, it has 171,000 on it which appears pretty close from the Hobbs > > > hour meter. Went through all the upper part of the engine. Rebuilt or > > > replaced the blower, turbo, water pump, fuel pump, Charge air cooler, > > > etc. Resetting the fuel rails now & putting it all back together. > > > > > > Terry Neal > > > Bozeman, MT > > > 82PT40 6V92TA > > > 74FC34 6V53T > > > > > > Curt Sprenger wrote: > > > > > > > Terry, > > > > Please keep us posted. > > > > How many miles on your engine? > > > > > > > > Curt Sprenger > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > Anaheim Hills, Calif. > > > > > > > > Terry Neal wrote: > > > > > > > > > Sounds like you did the right thing replacing all of those parts. > > > > > That's what I did on mine too. Plus new water pump & new rad core > > > > > (increased cooling capacity 15%). When it warms up some, will > > take it > > > > > out on I90 to see what it runs at now. > > > > > > > > > > Terry Neal > > > > > Bozeman, MT > > > > > 82PT40 6V92TA > > > > > 74FC34 6V53T > > > > > > > > > > Curt Sprenger wrote: > > > > > > > > > > > Update...The past few days I ran the bus about 400 miles, 6,000 > > > pounds > > > > > > in tow, outside temperature in the 80's. On the flat the coolant > > > > > > temperature run 180-185, oil temperature 220. Climbing > Whitewater > > > > Grade > > > > > > out of Palm Springs, 40 mph head wind, the coolant > temperature got > > > > up to > > > > > > 190 degrees, oil just over 230. I'd say changing the > > thermostats and > > > > > > clean/rodding the radiator was a good thing to do. > > > > > > > > > > > > -- > > > > > > Curt Sprenger > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > > |
03-20-2007, 16:49
Tom,
This is what we know going into the purchase of these BlueBirds... I think I can say for a number of us we have a stash in place for this event, if it so happens... Its only rhetoric, after... Sea Ya Larry NYC 84 35FCSB ----- Original Message ---- From: warbucks13477 To: WanderlodgeForum@yahoogroups.com Sent: Monday, March 19, 2007 10:10:54 PM Subject: [WanderlodgeForum] Re: Update - Thermostat and radiator service, with 6,000 pound in tow. I doubt there is any correlation between maintenance on an engine used in RV service on one coach relative to any other coach and/or on an RV engine versus one used in over the road class 8 truck service. After talking to diesel mechanics, coach owners and truck owners there appears to be a vast difference in the way the engines are regularly driven and serviced which I believe is the main reason so many of our engines are overhauled or replaced at such low mileages. From what I have seen it is not unusual for our coaches to sit for months at a time between uses which is not good. If you look over the various internet sites where RVs are sold it is not unusual to see engines replaced long before the average service life of the engines detailed in the manufacturers manuals. The same appears to be consistent with transmissions, radiators etc. Two things you can do to minimize the problems with your coach, first use it as much as possible, and/or start it up and drive it a few miles at least once a month EXCEPT if it is stored for the winter. Secondly do the regularly scheduled maintenance, including filters, air dryers etc and dont over stress the engine by lugging it. tom warner now in florida 1985 PT 40 running perfectly because of the --- In WanderlodgeForum@ yahoogroups. com, Curt Sprenger > > Terry, > I wonder if a correlation could be established between engine miles and > the coolant/fuel hose, pump, maintenance requirements. Would be useful > to other 'Bird owners for sure. > > You are doing a lot of work on your engine. What is the rational for the > blower and turbo work? Do you have the maintenance history on your coach? > > You must have a shop to park your bus and work on it. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Terry Neal wrote: > > > Curt, it has 171,000 on it which appears pretty close from the Hobbs > > hour meter. Went through all the upper part of the engine. Rebuilt or > > replaced the blower, turbo, water pump, fuel pump, Charge air cooler, > > etc. Resetting the fuel rails now & putting it all back together. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > Curt Sprenger wrote: > > > > > Terry, > > > Please keep us posted. > > > How many miles on your engine? > > > > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > Terry Neal wrote: > > > > > > > Sounds like you did the right thing replacing all of those parts. > > > > That's what I did on mine too. Plus new water pump & new rad core > > > > (increased cooling capacity 15%). When it warms up some, will take it > > > > out on I90 to see what it runs at now. > > > > > > > > Terry Neal > > > > Bozeman, MT > > > > 82PT40 6V92TA > > > > 74FC34 6V53T > > > > > > > > Curt Sprenger wrote: > > > > > > > > > Update...The past few days I ran the bus about 400 miles, 6,000 > > pounds > > > > > in tow, outside temperature in the 80's. On the flat the coolant > > > > > temperature run 180-185, oil temperature 220. Climbing Whitewater > > > Grade > > > > > out of Palm Springs, 40 mph head wind, the coolant temperature got > > > up to > > > > > 190 degrees, oil just over 230. I'd say changing the thermostats and > > > > > clean/rodding the radiator was a good thing to do. > > > > > > > > > > -- > > > > > Curt Sprenger > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > <!-- #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0;} #ygrp-tpmsgs{ font-family:Arial; clear:both;} #ygrp-vitnav{ padding-top:10px;font-family:Verdana;font-size:77%;margin:0;} #ygrp-vitnav a{ padding:0 1px;} #ygrp-actbar{ clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;} #ygrp-actbar .left{ float:left;white-space:nowrap;} .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana;font-size:77%;padding:15px 0;} #ygrp-ft{ font-family:verdana;font-size:77%;border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px;} #ygrp-vital{ background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;} #ygrp-vital #vithd{ font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\ ercase;} #ygrp-vital ul{ padding:0;margin:2px 0;} #ygrp-vital ul li{ list-style-type:none;clear:both;border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\ ght:.5em;} #ygrp-vital ul li .cat{ font-weight:bold;} #ygrp-vital a { text-decoration:none;} #ygrp-vital a:hover{ text-decoration:underline;} #ygrp-sponsor #hd{ color:#999;font-size:77%;} #ygrp-sponsor #ov{ padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;} #ygrp-sponsor #ov ul{ padding:0 0 0 8px;margin:0;} #ygrp-sponsor #ov li{ list-style-type:square;padding:6px 0;font-size:77%;} #ygrp-sponsor #ov li a{ text-decoration:none;font-size:130%;} #ygrp-sponsor #nc { background-color:#eee;margin-bottom:20px;padding:0 8px;} #ygrp-sponsor .ad{ padding:8px 0;} #ygrp-sponsor .ad #hd1{ font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\ ;} #ygrp-sponsor .ad a{ text-decoration:none;} #ygrp-sponsor .ad a:hover{ text-decoration:underline;} #ygrp-sponsor .ad p{ margin:0;} o {font-size:0;} .MsoNormal { margin:0 0 0 0;} #ygrp-text tt{ font-size:120%;} blockquote{margin:0 0 0 4px;} .replbq {margin:4;} --> ________________________________________________________________________________\ ____ TV dinner still cooling? Check out "Tonight's Picks" on Yahoo! TV. http://tv.yahoo.com/ [Non-text portions of this message have been removed] |
03-20-2007, 18:00
Curt, I dont think dad wanted us working on the bus. Someone pointed
out that we started drinking when we showed up and we both took off when the fridg was empty. BB said the fan motor could be removed without pulling the rad??? I think they are still in YorbaLinda. Rob and Sue will be here around April 6. We should have a mini rally. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Greg, > Deja Vu...that posting is about the same as my short trial run after all > the work. You have a good memory. > > After Captn' KevinMc, my bus is next. That works for me. Haven't heard > anymore from Kevin. > > Did Derek get the hyd fan problem resolved? Did dad & mom get to go on > their trip? Hope all worked out. > > Did you hear any more from Rob Robinson, dates he plans to be at your > place, etc? > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > Gregory OConnor wrote: > > > Curt, Deja Vu , I must have inhaled brakeCleaner or read this > > someother place. > > After Captn' KevinMc, my bus is next. > > > > GregoryO'Connor > > 94PTRomolandCa > > > > > Update...The past few days I ran the bus about 400 miles, 6,000 > > pounds > > > > > in tow, outside temperature in the 80's. On the flat the coolant > > > > > temperature run 180-185, oil temperature 220. Climbing > > Whitewater Grade > > > > > out of Palm Springs, 40 mph head wind, the coolant temperature > > got up to > > > > > 190 degrees, oil just over 230. I'd say changing the > > thermostats and > > > > > clean/rodding the radiator was a good thing to do. > > > > > > > > > > -- > > > > > Curt Sprenger > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > |
03-21-2007, 10:04
Hi Curt,
I will put the before/after pictures together for the forum. I vote for a Mexico group party too! As you say, planning may take a while but if we start now, sure that it can work out so many can attend. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Curt Sprenger wrote: > Terry, > I like your way of thinking...same as mine. You are doing it right. > Please take before/after pictures of your coach. We'd all like to see > them. > > "The report is that they have some beer & tequila left down > there"..Let's get a group party going. It doesn't need to take place > soon, but some day, just needs planing. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > Terry Neal wrote: > > > Evening Curt, > > > > My guess is the correlation for much of the cooling system repairs on > > these Detroits would be best expressed in terms of years rather than > > miles. Most automotive heating/cooling hoses have a "safe" life around > > maybe 5-7 years in my opinion. These are all original hoses etc that I > > am replacing so feel am pushing my luck in running them any longer on > > the coach. The rad core was shot, maybe it would have lasted another > > 5,000 miles but I seriously doubt it. > > > > I pulled the turbo & blower off for better access to all the other > > parts. Figured I might as well rebuild them & replace all the bearings > > while at it. Also had a gasket failure at the blower mounting flange. > > > > I do have a history for all the work on the coach & it was pretty > > complete when I purchased it. > > > > The coach is parked at my Land Rover shop in Billings. Plugged into > > 240-50 amp service & water & sewer hookups. I have done some of the > > work on it myself but also have employees that work on it when time > > permits. > > > > It's also getting stripped and is about ready for repaint when it warms > > up some. > > > > Plan to be able to use it quite a lot when it's all finished. > > > > Mexico is calling...The report is that they have some beer & tequila > > left down there. > > > > Terry Neal > > Bozeman, MT > > 82PT40 6V92TA > > 74FC34 6V53T > > > > Curt Sprenger wrote: > > > > > Terry, > > > I wonder if a correlation could be established between engine > miles and > > > the coolant/fuel hose, pump, maintenance requirements. Would be useful > > > to other 'Bird owners for sure. > > > > > > You are doing a lot of work on your engine. What is the rational > for the > > > blower and turbo work? Do you have the maintenance history on your > > coach? > > > > > > You must have a shop to park your bus and work on it. > > > > > > Curt Sprenger > > > 1987 PT38 8V92 "MacAttack Racing" > > > Anaheim Hills, Calif. > > > > > > Terry Neal wrote: > > > > > > > Curt, it has 171,000 on it which appears pretty close from the Hobbs > > > > hour meter. Went through all the upper part of the engine. > Rebuilt or > > > > replaced the blower, turbo, water pump, fuel pump, Charge air > cooler, > > > > etc. Resetting the fuel rails now & putting it all back together. > > > > > > > > Terry Neal > > > > Bozeman, MT > > > > 82PT40 6V92TA > > > > 74FC34 6V53T > > > > > > > > Curt Sprenger wrote: > > > > > > > > > Terry, > > > > > Please keep us posted. > > > > > How many miles on your engine? > > > > > > > > > > Curt Sprenger > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > Anaheim Hills, Calif. > > > > > > > > > > Terry Neal wrote: > > > > > > > > > > > Sounds like you did the right thing replacing all of those > parts. > > > > > > That's what I did on mine too. Plus new water pump & new rad > core > > > > > > (increased cooling capacity 15%). When it warms up some, will > > > take it > > > > > > out on I90 to see what it runs at now. > > > > > > > > > > > > Terry Neal > > > > > > Bozeman, MT > > > > > > 82PT40 6V92TA > > > > > > 74FC34 6V53T > > > > > > > > > > > > Curt Sprenger wrote: > > > > > > > > > > > > > Update...The past few days I ran the bus about 400 miles, > 6,000 > > > > pounds > > > > > > > in tow, outside temperature in the 80's. On the flat the > coolant > > > > > > > temperature run 180-185, oil temperature 220. Climbing > > Whitewater > > > > > Grade > > > > > > > out of Palm Springs, 40 mph head wind, the coolant > > temperature got > > > > > up to > > > > > > > 190 degrees, oil just over 230. I'd say changing the > > > thermostats and > > > > > > > clean/rodding the radiator was a good thing to do. > > > > > > > > > > > > > > -- > > > > > > > Curt Sprenger > > > > > > > 1987 PT38 8V92 "MacAttack Racing" > > > > > > > Anaheim Hills, Calif. > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] |
