Air step mercury switches
03-30-2007, 10:57
Don: I haven't looked at my 92 step, but my 83 had two mercury
switches that were held in place by a simple little pipe clamp made of plastic. They can be found at a good hardware store. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > The light which indicates that my step is extended began staying on last week. A bit of investigation shows that the part which should contact the mercury switches has broken off. It is attached to the end of the air piston rod, and a small piece of it remains on the other side. > > I don't think it should be too hard to fabricate, but I don't know at all what it looked like - flat piece of metal, z-pattern, or whatever. > > After studying the air step wiring diagram until my eyes want to cross I think it looks like, with neither switch working, I may be having continous power to the step solenoid in both extended and retracted positions. Not a good thing. > > I put in a call to Earl, but didn't get a callback. Anybody have any idea what that part looks like? > > Don Bradner > 90 PT40 "Blue Thunder" > Eureka, CA > |
03-30-2007, 12:36
There are parts of the electrical drawing that simply don't compute. Calling the
switches "mercury" is only part of it. I went ahead with a fabrication, and it is working fine. http://www.arcatapet.net/travel/bluebirds/steel.jpg The original was about 20 gauge, and I replaced with 12 gauge. I had to make two attempts at it to get the length just right; after that it was just a matter of releasing the switches and moving them to make a solid contact with the plate at each end of travel. On 3/30/2007 at 3:45 PM Leroy Eckert wrote: >I printed off the picture. I honestly do not remember seeing that kind >of set up on mine but I will tell you for sure tomorrow night. Those look >more like travel limit switches than mercury switches to me. The drawing >on my system is difficult to understand, for me anyway. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA |
03-30-2007, 13:52
I know, the drawing goes around in circles and has different functions with
that switch in the footwell in different positions. My stepwell light has very faint feedback with the step extended when the switch on the dash is in the extended position and the small step light outside never goes off until the bulb burns out. It has been burning for 1 1/2 years, the last time I changed the bulb. Hey, I can't see it in the daytime anyway. Other than that, my only problem has been with the wiring inside the upholstery strap in the door. When a wire lets loose in there nothing works right. I'm still gonna look at mine tomorrow and see if it is configured the same. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Don Bradner To: WanderlodgeForum@yahoogroups.com Sent: Friday, March 30, 2007 6:36 PM Subject: Re: [WanderlodgeForum] Air step mercury switches There are parts of the electrical drawing that simply don't compute. Calling the switches "mercury" is only part of it. I went ahead with a fabrication, and it is working fine. http://www.arcatapet.net/travel/bluebirds/steel.jpg The original was about 20 gauge, and I replaced with 12 gauge. I had to make two attempts at it to get the length just right; after that it was just a matter of releasing the switches and moving them to make a solid contact with the plate at each end of travel. On 3/30/2007 at 3:45 PM Leroy Eckert wrote: >I printed off the picture. I honestly do not remember seeing that kind >of set up on mine but I will tell you for sure tomorrow night. Those look >more like travel limit switches than mercury switches to me. The drawing >on my system is difficult to understand, for me anyway. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA [Non-text portions of this message have been removed] |
03-31-2007, 07:55
Don,
Those are mini cherry switches. I do not think there is any Mecury in them. they can be seen in the Wanderlodge quick reference catalog. I had problems with these and replaced them both. had to adjust the contact mmetal strips so that they hit but didn't bend. I assume that combined with sutting off air this will fix the light problem! Jim Riordan 88 WBWL XXV Stuart, FL. Don Bradner Where I'm parked, I had trouble getting in to see the backside, so just now I used a camera to give me a view: http://www.arcatapet.net/travel/bluebird...tended.jpg It looks like the metal may have been forked, with two different pieces to hit the switches, since they are not in line with each other. That would allow separate bends to match up. On 3/30/2007 at 11:55 AM Leroy Eckert wrote: >Don: I'll be at my coach this weekend. I have had a couple of gremlins >in my step but have not looked closely at the mercury switch set up. I'll >do so this weekend and let you know how mine works, and what the brackets >look like. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA --------------------------------- Need Mail bonding? Go to the Yahoo! Mail Q&A for great tips from Yahoo! Answers users. [Non-text portions of this message have been removed] |
03-31-2007, 08:05
I'm happy you got her going. My setup does not look anything like yours.
03-31-2007, 11:06
They are not mercury switches. The original switches were made by
Micro switch and were model # BZ-2RDS5551-A2. You can buy comparable ones at grainger , model # #XG30 for $10.59 or model # 3XG49 at about $12.88. Go to http://www.grainger.com Tom warner vernon center,ny 1985 PT 40 At 03:55 PM 3/31/2007, you wrote: >Don, > > Those are mini cherry switches. I do not think there is any > Mecury in them. they can be seen in the Wanderlodge quick reference > catalog. I had problems with these and replaced them both. had to > adjust the contact mmetal strips so that they hit but didn't bend. > I assume that combined with sutting off air this will fix the light problem! > > Jim Riordan > 88 WBWL XXV > Stuart, FL. > >Don Bradner > Where I'm parked, I had trouble getting in to see the > backside, so just now I used a camera to give me a view: >http://www.arcatapet.net/travel/bluebird...tended.jpg > >It looks like the metal may have been forked, with two different >pieces to hit the switches, since they are not in line with each >other. That would allow separate bends to match up. > >On 3/30/2007 at 11:55 AM Leroy Eckert wrote: > > >Don: I'll be at my coach this weekend. I have had a couple of gremlins > >in my step but have not looked closely at the mercury switch set up. I'll > >do so this weekend and let you know how mine works, and what the brackets > >look like. > >Don Bradner >90 PT40 "Blue Thunder" >Eureka, CA > > > > > > >--------------------------------- >Need Mail bonding? >Go to the Yahoo! Mail Q&A for great tips from Yahoo! Answers users. > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > |
