1978 Wanderlodge, a few questions
04-16-2007, 23:20
Good deal: Just a double check.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville,FL
Sent: Monday, April 16, 2007 10:41 PM
Subject: Re: [WanderlodgeForum] Re: 1978 Wanderlodge, a few questions
I don't know if mine has one or not, but if it does, yes, it was before it. In
the forward compartment (outside, above the generator) on mine there are
multiple busses. Constant on, Filtered Constant, Master Switched, Filtered
Master Switched, and two that are Ignition Switched. The camera shared a 15-amp
breaker in a Constant On bus with the driver's seat controls. I removed that
wire and re-routed it to an open location on an Ignition Bus, and used a spare
15-amp breaker.
On 4/16/2007 at 8:54 PM Leroy Eckert wrote:
>I presume you did that before the power pak which reduces 13.5v to 12.0v
>constant voltage for the camera system? If you have one, as I do.
>Leroy Eckert
>Niceville, FL
> From: Don Bradner
> Sent: Monday, April 16, 2007 8:32 PM
> I was thinking about that yesterday as I rewired the backup camera from
>a constant-on circuit to an ignition-switched circuit. I annotated my
>schematic, but that won't necessarily mean anything. Rich Ducci told me he
>had extensively documented changes he made to this coach, and none of that
>documentation carried forward through the next two owners.
> In terms of the change itself, I really hate noticing a couple of hours
>after stopping that the camera is still on, but I want it on always while
>driving.
> On 4/16/2007 at 8:44 PM erniecarpet@... wrote:
> >One of the mysteries of Bluebird ownership is ---" What has the
>previous
> >owners installed that has no label or documentation??" To me- that's
>part
> >of the
> >pleasure of ownership.
> Don Bradner
> 90 PT40 "Blue Thunder"
> Eureka, CA
>[Non-text portions of this message have been removed]
>Yahoo! Groups Links
Don Bradner
Eureka, CA
04-21-2007, 12:50
Hey Guys,
Thanks for the replies, but it doesn't seem to do any of that. The
duel rocker type standard 110v light switches (common in household
bathrooms, found throughout my Wanderlodge) are dead center at the
very rear of the bus. They are right above the twin bed facing down.
One operates the 110v power outlet that is above the small desk area
in the bedroom. I assume this was so you could turn on and off a TV
before TV's with remotes? I use it for my computer now. The second one
doesn't seem to do anything though. I have no lights that are
unaccounted for that I'm aware of. I thought I had read somewhere that
it turned on and off the 12v outlet in the same area of the 110v one,
but it doesn't. Perhaps I have to leave the overhead lights on at the
usual switch for it to turn them off? I'll give that a shot when I get
home...otherwise I guess it's time to start tracing wires!
Joshua
User(s) browsing this thread: 8 Guest(s)
