More lighting 84FC35
05-11-2007, 06:26
--- In WanderlodgeForum@yahoogroups.com, "Jon" wrote:
> --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle"
> > Not that I don't have enough stuff to keep me busy. But has
anyone,
> > besides me, noticed that dark area (unlighted)in front of the
fridge
> on
> > the 84FC35SB? And has anyone installed a light there to
eliminate
> > it?
> > Stephen, thanks for your help and I'll be in touch.
> > Keith
> > 84FCSB
> Keith I installed this halogen lights a few years ago and they work
> great! Very reasonable to buy and easy to install. The only draw
back
> in that they are 110 volts and so you either haft to have your
> generator on or pluged into shore power.
> http://i2.photobucket.com/albums/y4/1942...C01984.jpg
http://i2.photobucket.com/albums/y4/1942...C01985.jpg
> Jon
> 78 Wanderlodge
> Bremerton Washington
05-11-2007, 07:36
Many of the Wanderlodges had the kitchen exhaust fan, that included
the metal tin roof. These can be replaced with a fantastic fan,
allowing the day light to shine. This helps during the day light
hours & lightens up this area.
Bill 88 FC Michigan
> anyone,
> fridge
> > on
> eliminate
> > > it?
> > > Keith
> > > 84FCSB
work
> back
> > Jon
> > 78 Wanderlodge
05-11-2007, 08:39
Good one Stephen. I "think" the light goes out but only extensive
scientific research (open the door, get the beer) will confirm that as a
fact.
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
Stephen Birtles wrote:
> I just open the fridge and the light comes on so I can see the beer
> Then I close the door and sit and contemplate life or what I have to
> do next in the neverending Saga of Keeping up with Bird
> Everyone have a great weekend
> By the way does anyone know when you close the fridge door does the
> light go out
> Stephen 77fc35
> , msecoolcal@... wrote:
> > Keith,
> > I went to Houston and picked up several lamps from a forum member
> salvaging
> > out an 84 for that very reason. My 79 is dark in front of the frig
> and the
> > sink. I have installed original lamps in both ceiling areas, what a
> change. I
> > have also noticed looking at other birds that later coaches have
> them in front
> > of the sink in the ceiling.
> > Matthew
> > 79fc35sb
> > So Cal
> > ************************************** See what's free at
> http://www.aol.com. <http://www.aol.com.>
05-11-2007, 10:09
why not wire them for 12 volts the bulbs themselve are 12 volt
Also I have some led light bars that would mount in the corner the
leds are tipped at 45 degress They may be pretty bright they are
aprroximately 20 inches long
Stephen 77fc35
> > Not that I don't have enough stuff to keep me busy. But has anyone,
> > besides me, noticed that dark area (unlighted)in front of the fridge
> on
> > the 84FC35SB? And has anyone installed a light there to eliminate
> > it?
> > Keith
> > 84FCSB
> great! Very reasonable to buy and easy to install. The only draw back
> Jon
> 78 Wanderlodge
05-14-2007, 01:24
Keith,
BB parts has the same original style lights you have in the coach. There
replacement lights are no longer made by RGM so they are just a tad shorter and
will not fit properly in your original light openings. They have the original
bezel and the plastic lens & takes the same bulb. Since you are going to
install a new one and cut a new hole then it doesn't matter if it is shorter. I
have installed one in my ceiling above the dinette across from the sink,
works great. I have noticed in pictures of later fc BBs that there is such a
light in this area.
Matthew
1979 fc35cb
So Cal
05-14-2007, 05:08
Thanks for all the replies about the lack of lighting. There is no
fixture in the hallway. One in the bedroom and one in the kitchen.
Nothing in between. I saw some LED lights at Costco and almost
bought them but I hate using temporary lighting. It almost never
works as intended. Soooooo, I guess I'll look for an original style
fixture to install with a local switch?
Does that light in the fridge work for diet coke also?
Keith
84FC35SB
--- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs
> Keith:
> Not at home right now, but is there not a flourescent light in the
hallway??
> Bill 84 FC 35 SB "$quanderlodge"
> Terrace, B.C. Canada
> ----- Original Message ----
> From: Keith Strehle
> Sent: Thursday, May 10, 2007 3:40:46 PM
> Subject: [WanderlodgeForum] More lighting 84FC35
fridge on
> it?
> Keith
> 84FCSB
> Ask a question on any topic and get answers from real people.
Go to Yahoo! Answers and share what you know at
http://ca.answers.yahoo.com
