Safe
09-18-2006, 01:53
Safe
RObert,
There is some info on the safe in the Files section. The combo can be changed if the safe is open, If it is locked shut, this could be expensive.$$$$ Do you know a safe cracker or a friendly Burglar??? Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "chapelhill2901" > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > wrote: > i found the safe under the seat, but i don't have the combination, > so i guess i need to go to the lock smith. > thanks,robert > 1989 pt40 > oklahoma city, ok. > > > > > chapelhill2901, > > > > Typically in the PT40 of that age, it is located under the rear > > dinette seat. Hope you also got the combination in your records, > as > > the key only unlocks the tumbler spinner dial. > > > > Please sign your posts. > > > > Thanks, > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "chapelhill2901" > > > > > > > > i just bought a 1985 pt40, and i found info., including a key, > in the > > > paprwork about a safe. i have looked every place i can think of, > but > > > to no avail. any suggestions from anyone as to where one might > be. > > > > > > |
09-18-2006, 02:16
Safe
Mine was unlocked but since I didn't have the special key to reset the
combination I took it to a locksmith. It took a week or so since he himself had to order the special key, but he reset it for $50. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "chapelhill2901" wrote: > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > wrote: > i found the safe under the seat, but i don't have the combination, > so i guess i need to go to the lock smith. > thanks,robert > 1989 pt40 > oklahoma city, ok. > > > > > chapelhill2901, > > > > Typically in the PT40 of that age, it is located under the rear > > dinette seat. Hope you also got the combination in your records, > as > > the key only unlocks the tumbler spinner dial. > > > > Please sign your posts. > > > > Thanks, > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "chapelhill2901" > > > > > > > > i just bought a 1985 pt40, and i found info., including a key, > in the > > > paprwork about a safe. i have looked every place i can think of, > but > > > to no avail. any suggestions from anyone as to where one might > be. > > > > > > |
01-18-2007, 18:18
Safe
How would I get the safe combination, previous owner never got it to
open. Dale Cooper 85FC35sb |
01-19-2007, 02:36
Safe
Dale: I just went through this problem. Do you have the original safe
manual? Try using the factory setting. The mfr. also told me that if that does not work try going just over the #. For instance if it calls for left 40 4 times, try 41. Hope this helps. Bruce 1988FC35 |
01-19-2007, 03:25
Safe
Dale, If all else fails, I can walk you through removing the safe and opening it
from the back. A little involved, but it will work. Best Wishes, Doug Engel, Gunnison, CO, 1981 FC35SB "Pokey" dbcooper98 combination, previous owner never got it to open. Dale Cooper 85FC35sb Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" --------------------------------- Never miss an email again! Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out. [Non-text portions of this message have been removed] |
01-19-2007, 05:26
Safe
Hi, I'm new here. I've been lurking about reading posts for a couple
days and posted some pix in the photo gallery last night. I don't own a bird, but have been hired to help restore and upgrade one. I'm on a quest to eventually be an expert on these, so reading through these informative posts is very helpful. My customer has the same problem with his safe. I'd love to be the hero and get it open for him. Neither one of us have any info on this unit & don't even know how many number sequences to look for, nor do we know whether to start by turning CW or CCW. If I remove and open from the back, can the tumblers be observed & correct combination be figured out then? Who knows, maybe I'll find a million dollars in there & can retire early . Tim--- In WanderlodgeForum@yahoogroups.com, Doug Engel wrote: > > Dale, If all else fails, I can walk you through removing the safe and opening it from the back. A little involved, but it will work. Best Wishes, Doug Engel, Gunnison, CO, 1981 FC35SB "Pokey" > > dbcooper98 combination, previous owner never got it to > open. > > Dale Cooper > 85FC35sb > > > > > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" > > --------------------------------- > Never miss an email again! > Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out. > > [Non-text portions of this message have been removed] > |
01-19-2007, 05:55
Safe
Tim,
There is some info. on the safe in the files section of this forum. Try this link. cut & paste http://f1.grp.yahoofs.com/v1/EPmwRYm6SJZ...6nipehs0b7 FotuxusKFXtpZBV1qvg1dGFZN6UoNKn8mm5TJ8G88hlN5RTUnzvekgf/Safe_Combinati on_doc.pdf A lock smith, safe cracker is very expensive, The best idea someone posted is to remove the safe, cut a hole in the back, and Yes, I have opened the rear cover of the combination lock and reset the combination. I did not have a safe combination , but fortunately our safe was not locked. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "tims_rv" > > Hi, I'm new here. I've been lurking about reading posts for a couple > days and posted some pix in the photo gallery last night. I don't own > a bird, but have been hired to help restore and upgrade one. I'm on a > quest to eventually be an expert on these, so reading through these > informative posts is very helpful. > > My customer has the same problem with his safe. I'd love to be the > hero and get it open for him. Neither one of us have any info on this > unit & don't even know how many number sequences to look for, nor do > we know whether to start by turning CW or CCW. If I remove and open > from the back, can the tumblers be observed & correct combination be > figured out then? Who knows, maybe I'll find a million dollars in > there & can retire early . Tim> > --- In WanderlodgeForum@yahoogroups.com, Doug Engel > wrote: > > > > Dale, If all else fails, I can walk you through removing the safe > and opening it from the back. A little involved, but it will work. > Best Wishes, Doug Engel, Gunnison, CO, 1981 FC35SB "Pokey" > > > > dbcooper98 > combination, previous owner never got it to > > open. > > > > Dale Cooper > > 85FC35sb > > > > > > > > > > > > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" > > > > --------------------------------- > > Never miss an email again! > > Yahoo! Toolbar alerts you the instant new Mail arrives. Check it > out. > > > > [Non-text portions of this message have been removed] > > > |
01-19-2007, 06:57
Safe
Tim, E-mail me at reddog@... with a phone # and I'll give you a call. Doug
n' Pokey tims_rv lurking about reading posts for a couple days and posted some pix in the photo gallery last night. I don't own a bird, but have been hired to help restore and upgrade one. I'm on a quest to eventually be an expert on these, so reading through these informative posts is very helpful. My customer has the same problem with his safe. I'd love to be the hero and get it open for him. Neither one of us have any info on this unit & don't even know how many number sequences to look for, nor do we know whether to start by turning CW or CCW. If I remove and open from the back, can the tumblers be observed & correct combination be figured out then? Who knows, maybe I'll find a million dollars in there & can retire early . Tim--- In WanderlodgeForum@yahoogroups.com, Doug Engel wrote: > > Dale, If all else fails, I can walk you through removing the safe and opening it from the back. A little involved, but it will work. Best Wishes, Doug Engel, Gunnison, CO, 1981 FC35SB "Pokey" > > dbcooper98 combination, previous owner never got it to > open. > > Dale Cooper > 85FC35sb > > > > > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" > > --------------------------------- > Never miss an email again! > Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out. > > [Non-text portions of this message have been removed] > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" --------------------------------- TV dinner still cooling? Check out "Tonight's Picks" on Yahoo! TV. [Non-text portions of this message have been removed] |
01-19-2007, 06:58
Safe
Thanks! The link didn't work, but I found it where you said (in the
files section). I printed it up and will try it next time I'm there. Wish me luck. Tim --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > > Tim, > > There is some info. on the safe in the files section of this forum. > Try this link. cut & paste > > http://f1.grp.yahoofs.com/v1/EPmwRYm6SJZ...6nipehs0b7 > FotuxusKFXtpZBV1qvg1dGFZN6UoNKn8mm5TJ8G88hlN5RTUnzvekgf/Safe_Combinati > on_doc.pdf > > A lock smith, safe cracker is very expensive, The best idea someone > posted is to remove the safe, cut a hole in the back, and Yes, I > have opened the rear cover of the combination lock and reset the > combination. I did not have a safe combination , but fortunately our > safe was not locked. > > Bill 88 FC > > > > --- In WanderlodgeForum@yahoogroups.com, "tims_rv" > > > > Hi, I'm new here. I've been lurking about reading posts for a > couple > > days and posted some pix in the photo gallery last night. I don't > own > > a bird, but have been hired to help restore and upgrade one. I'm on > a > > quest to eventually be an expert on these, so reading through these > > informative posts is very helpful. > > > > My customer has the same problem with his safe. I'd love to be the > > hero and get it open for him. Neither one of us have any info on > this > > unit & don't even know how many number sequences to look for, nor > do > > we know whether to start by turning CW or CCW. If I remove and open > > from the back, can the tumblers be observed & correct combination > be > > figured out then? Who knows, maybe I'll find a million dollars in > > there & can retire early . Tim> > > > --- In WanderlodgeForum@yahoogroups.com, Doug Engel > > wrote: > > > > > > Dale, If all else fails, I can walk you through removing the safe > > and opening it from the back. A little involved, but it will work. > > Best Wishes, Doug Engel, Gunnison, CO, 1981 FC35SB "Pokey" > > > > > > dbcooper98 > > combination, previous owner never got it to > > > open. > > > > > > Dale Cooper > > > 85FC35sb > > > > > > > > > > > > > > > > > > > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" > > > > > > --------------------------------- > > > Never miss an email again! > > > Yahoo! Toolbar alerts you the instant new Mail arrives. Check it > > out. > > > > > > [Non-text portions of this message have been removed] > > > > > > |
01-19-2007, 07:34
Safe
I'd bet on the money being in D.B. Cooper's safe. He's been roaming around in a
Bird since he jumped out of that jet plane. success opening your safe. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: pattypape To: WanderlodgeForum@yahoogroups.com Sent: Friday, January 19, 2007 11:55 AM Subject: [WanderlodgeForum] Re: safe Tim, There is some info. on the safe in the files section of this forum. Try this link. cut & paste http://f1.grp.yahoofs.com/v1/EPmwRYm6SJZ...6nipehs0b7 FotuxusKFXtpZBV1qvg1dGFZN6UoNKn8mm5TJ8G88hlN5RTUnzvekgf/Safe_Combinati on_doc.pdf A lock smith, safe cracker is very expensive, The best idea someone posted is to remove the safe, cut a hole in the back, and Yes, I have opened the rear cover of the combination lock and reset the combination. I did not have a safe combination , but fortunately our safe was not locked. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "tims_rv" > > Hi, I'm new here. I've been lurking about reading posts for a couple > days and posted some pix in the photo gallery last night. I don't own > a bird, but have been hired to help restore and upgrade one. I'm on a > quest to eventually be an expert on these, so reading through these > informative posts is very helpful. > > My customer has the same problem with his safe. I'd love to be the > hero and get it open for him. Neither one of us have any info on this > unit & don't even know how many number sequences to look for, nor do > we know whether to start by turning CW or CCW. If I remove and open > from the back, can the tumblers be observed & correct combination be > figured out then? Who knows, maybe I'll find a million dollars in > there & can retire early . Tim> > --- In WanderlodgeForum@yahoogroups.com, Doug Engel > wrote: > > > > Dale, If all else fails, I can walk you through removing the safe > and opening it from the back. A little involved, but it will work. > Best Wishes, Doug Engel, Gunnison, CO, 1981 FC35SB "Pokey" > > > > dbcooper98 > combination, previous owner never got it to > > open. > > > > Dale Cooper > > 85FC35sb > > > > > > > > > > > > > > Doug Engel, Gunnison, CO. 1981 FC35SB "Pokey" > > > > --------------------------------- > > Never miss an email again! > > Yahoo! Toolbar alerts you the instant new Mail arrives. Check it > out. > > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed] |
. Tim
