water heater replacment
10-15-2007, 05:52
--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
>Glenn, thanks a lot. Sounds like it is going to be a pretty big job. We are in Mt. now and it is freezing, hopefully I can wait a month till I am in Warner Robins to do the job. Robert Rahn Kalispell, Mt. 88 PT40 > Glen, nice write up. Please add this to the forum so others can locate it > when in need. > > On 10/15/07, ragster_ga > > > > Robert, > > > > One of the first projects on my PT-40 after purchasing last July was > > to replace the leaking water heater. While I knew there was a leak, > > the damage was hidden and not easy to identify. When I pulled apart > > the water heater shelf area, there was softness in the wood below. > > So it was clear that it had been sitting wet for a long time. > > > > In my case, I decided to do a total bed/rear decking replacement. I > > spread the work out over a week. My queen bed is centered and > > against the rear cabinets. > > > > I used the Atwood EHM11SST tank to replace the original. It has all > > the connections on one side and stainless steel housing. You can > > find them for around $425 if you shop. > > > > On the '86 PT-40, there are two pieces of wood on top of the engine > > housing. One goes from the queen all the way to the rear under the > > cabinets. It has a cut out for an access door to the engine > > compartment. The wood is on top of a small felt pad which is on top > > of the steel engine housing. > > > > You should pull the wood over the engine access door to determine if > > the felt pad underneath has any moisture. If it does, it will be > > trapped between the wood and the steel and never escape. Eventually > > you will have mold and dry-rot. If this pad is dry...you are a step > > ahead. > > > > I removed all the rear cabinets below the overhead. The overhead is > > self supporting and can remain. There is a heat exchange in the > > center-bottom of the cabinets that is used for bedroom heat. I did > > not remove the heat-exchanger, but I did remove the screws holding it > > down and removed the wood from under it. This kept me from having to > > undo the hot water hoses from the engine. I might be easier to > > remove it if you have to. > > > > Hopefully, when you remove the HWH, you will not have had any water > > get under the wood. If you did, and it is contained to just one > > local area, you could possibly cut out the damaged section and leave > > the remaining. > > > > In my case, I wanted to be sure I got out all the moisture so I > > removed everything. I touched up the steel housing (a few > > scratches). Sealed all the existing screw holes from the old plywood > > mount holes. Put down a thin foil insulation pad. Then put down the > > plywood. I pre-drilled each hole through the wood / engine housing > > and attached the new wood with stainless steel screws. > > > > Take plenty of pictures to remember how it goes back together if you > > have to disassemble anything. There are a lot of very similar parts > > in removing the cabinets, that took me a few extra minutes to > > remember how to get it back together...however it will only go back > > one way. > > > > The best choice for wood in my opinion is a Marine Grade Plywood. > > Expensive, but it has glues that will not break down to water > > exposure. You can special order it through Lowes here in my town. > > > > Another choice that might be OK would be to use a copper based > > pressure treated plywood. Do not use the arsenic based wood, unless > > you want to expose someone to the arsenic ![]() > > > > When I put the wood back down, I did it in three sections. One > > section was the width of the coach, and went from the back wall to > > about one inch forward of the rear cabinet wall (just about 1/2 inch > > to the rear of the engine access door). Then I put a piece to the > > left of the access door and another piece to the right of the access > > door. I used 3/4" plywood. I also put down new wood for the access > > door. For it, I used a 1/2" piece because the steel access door is > > raised about 1/4" from the rest of the housing. > > > > Hopefully in your case, you won't have to remove any of the decking. > > Be sure that no water has gotten between the wood and the steel > > housing. If that happens, it will not be apparent by looking at the > > top of the wood, but hidden problems will arise over time. > > > > If you don't have to replace any wood and not remove the cabinets, 1 > > day should be no problem. It will be tight getting the HWH out and > > the new one back in, but it will fit through the door opening. You > > will need to remove the door and the shelving/panel above, in the > > rear, and to the driver's side of the HWH to make it easier. > > > > I tried to find a pan to put under the HWH but could not find one to > > fit. I still would like to custom make a pan and set it under the > > HWH and have a drain out the rear through the engine compartment in > > case of a leak. I did use 3M 4200 marine caulking to seal the seams > > to prevent water penetration. > > > > The biggest thing you will need is moral support if you have to pull > > it all apart. My old body complained for a few days afterwards from > > all the bending and weird positions required to remove the rear > > cabinets. > > > > Glenn Allen > > 1986 PT-40 > > Marietta, GA > > > > --- In WanderlodgeForum@yahoogroups.com > > "Robert & Teri Rahn" > > > > > > > > I was able to get back to the water heater and check for leaks. It > > is > > > not leaking out of the pressure relief valve and there is no > > leaking at > > > any of the pipes. It is a little wet way back at the corner back > > there > > > which must be directly above the hole where the water is dripping > > out. > > > I turned the water heater off a few days ago and water is still > > > dripping slowly out of the hole in the engine compartment. So the > > water > > > heater must be rusted out and the leak is coming from below it. > > Where > > > is the best place to buy one of these heaters and what is the best > > way > > > to remove it? It looks like it is going to be quite a chore to get > > it > > > out of there. > > > > > > Robert Rahn > > > Kalispell, Mt. > > > 1988 PT 40 > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > > > [Non-text portions of this message have been removed] > |
10-15-2007, 07:50
Robert,
One last thought. Since it will be a while till you get to the repair, try to always park with the driver's side rear end a little low. This will keep the leaking water from the HWH from draining forward. If the water drains forward, problems will multiply. Glenn --- In WanderlodgeForum@yahoogroups.com, "Robert & Teri Rahn" > > --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > >Glenn, thanks a lot. Sounds like it is going to be a pretty big job. > We are in Mt. now and it is freezing, hopefully I can wait a month > till I am in Warner Robins to do the job. > Robert Rahn > Kalispell, Mt. > 88 PT40 > > Glen, nice write up. Please add this to the forum so others can > locate it > > when in need. > > |
