Most miles before engine rebuild/replacement
01-01-2009, 08:59
I had my rad done last summer. New core, fabrication of a new bottom
tank, and all new lines, hoses, etc. in that rea while the rad was
out. The total bill came in at about $7,300.
Scott Forman
86 PT38
Memphis
--- In WanderlodgeForum@yahoogroups.com, "Joyce and Richard Hayden"
> If I might jump in here with my experiences on this subject.
Summer before last I found that our radiator needed to be replaced.
I had had good experiences with Performance Radiator in Everett, WA
when our FC needed radiator attention. As I recall the new core,
using the old tanks, cost around $3800 for the radiator work only. I
delivered to their shop and picked it up. I did the removal and
installation myself in the "Birdhouse" which has a nice flat floor.
I point that out because the thing is very heavy and not something I
could have managed alone were it not for the nice floor. I used a
ATV jack to do the heavy lifting. I just had to balance it.
> While the radiator was out I replaced all of the 1 inch heater
hoses in the engine room with silicone hose, removed and replaced all
of the insulation and cleaned and painted the surfaces that I
couldn't get to when the radiator was in place. I don't remember
what the total came to with all of the extra work and can't look it
up just now since the bus is in Yuma and I'm at home.
> The radiator was necessary and the hoses were to the point of
needing replaced as they were getting hard and brittle due to the
heat. As with most of our coaches the insulation was completely shot
and a mess and badly needed attention. The painting was not really
necessary and involved mostly my time but it sure looks nice.
> I believe Performance Radiator is a west coast operation and I've
seen their ads in Yuma.
> Good luck Bob.
> Dick Hayden - '87 PT 38 - Lake Stevens, WA
> From: Pete Masterson
> To:
WanderlodgeForum@yahoogroups.com om>
> Sent: Thursday, January 01, 2009 10:13 AM
> Subject: Re: [WanderlodgeForum] Re: Most miles before engine
rebuild/replacement
> Well, in that case, it seems a rather high. When I researched the
matter, there was a radiator core place (they manufactured radiator
cores, whom I no longer remember*) that referred me to several
northern California radiator shops, including the one I eventually
used.
> * I _think_ I got the name from one of the Blue Bird lists, way
back when... I don't see any references in my saved files, though.
> A price of $800 plus shipping comes to mind for what my core
cost. Even with the considerable increase in some materials prices, a
400+ percent increase doesn't seem reasonable.
> You might discuss what core manufacturer they're using and it
might be worth searching the Internet for radiator cores for busses.
I found these:
<http://www.completeradiators.com/radiatorcores.asp<http://www.complet
eradiators.com/radiatorcores.asp>> with a specific mention of the DD
Series 60...
> and
<http://radiatorgroup.com/238559bluebirdbusradiator.aspx<http://radiat
orgroup.com/238559bluebirdbusradiator.aspx>> but this one looks more
like what you'd put in an FC...
> This link has Blue Bird "truck" radiators:
<http://detroitradiatorcorp.com/11_2_1.htm<http://detroitradiatorcorp.
com/11_2_1.htm>>
> This outfit has a radiator assembly (rebuilt and used) for 6v92:
<http://www.capbusparts.com/Sec06/s6p4a.html<http://www.capbusparts.co
m/Sec06/s6p4a.html>>
> I'm wondering if the price differential might be in part due to
the 6v92 being so long out of production...?
> Pete Masterson
> '95 Blue Bird Wanderlodge WBDA 42 (For Sale)
<http://www.aeonix.biz/BBforsale.html<http://www.aeonix.biz/BBforsale.
html>>
> El Sobrante CA
> aeonix1@...
> On Dec 31, 2008, at 7:32 PM, Bob Lawrence wrote:
> Hi Pete,
> No, the price of $3,500 was just for the rad. No labor. Altho,
> Richard, who did mine works for $35 per hour. Can't beat that!
> Bob Lawrence
> 84 PT36
> Padre Island,Tex
> It's been 2-1/2 years since I had to work done, so my
recollection
> is
> a bit sketchy. (I have the receipt somewhere, but I really
don't
> want
> to look for it.)
> The bill ended up costing about $4600 -- with $1000 being
work on
> the
> AC system (that wasn't related to the R&R of the radiator).
Most
> of
> the cost was labor (at SF Bay Area rates) and I believe that
> new
> core was about $1000 with about $2600 labor to remove and
replace
> all
> the stuff -- the air charge radiator had to come out as it's
part
> of
> the same assembly.
> I expect that a core might be a lot more expensive now
(aluminum?
> brass?) -- and I'd think that labor in Corpus Christi is a
bit
> lower
> than here. I think the S-60 radiator is a little larger (but
big
> is
> big) -- and other costs of the R&R might be different in an S-
60
> vs.
> an 8v92.
> So, if the $3,500 includes R&R plus the new radiator core --
it's
> probably a fair price.
> Pete Masterson
html>>
> El Sobrante CA
> aeonix1@
> On Dec 30, 2008, at 2:44 PM, Bob Lawrence wrote:
> Pete,
> How much did you pay for the radiator?
> I'm trying to get an answer for a Powell Brown and his 88
8v92.
> He is
> new to this and needs to replace his rad.
> He has been quoted $3,500 for one in Corpus Christi.
> Is this out of line?
> Bob Lawrence
> 84 PT36
> Padre Island, Tx.
> I noted (on my maiden trip) that it had an overheating
problem. A
> trip to a heavy-duty bus/truck radiator shop quickly
found the
> reason
> and I had a new radiator core installed. Excessive heat
kills
> engines, probably the quickest of any abuse an owner can
give.
> I've
> also added regular cleaning of the (external) radiator
fins
> (which
> were clogged with oily-dirt) to my maintenance list.
> Pete Masterson
> El Sobrante CA
> aeonix1@
> Yahoo! Groups Links
> Yahoo! Groups Links
01-01-2009, 09:35
I had priced out radiator cores just before X-Mass for my coach PT 42
S-60 DD The core from Detroit Radiator was $2100.00 That was with the
dimpled tubes. Dan at Chicago Radiator said he could ship me a Core
the next day for $ 1495.00 Prolience is the Co who took over the G&O
Co. the was my coaches OEM Mfg. Old number for the Rad was G & O, X-
3190. I'm not sure but the new Prolience Number is X226894 for
$1890.22 It seems as the price of $3500.00 doesn't sound out of line.
When labor is thrown in. My core has a top and bottom tank 72 bolts
on each, there's a few hours labor just there. 7K does sound a bit
high, for me anyway. My coach will get hot if the Aux. Fan is off.
When on she runs 190 engine coolant 202 engine oil all day long. If I
switch it off she creeps up to 225 coolant and 250 oil temp. Then the
dreaded check engine lights up. Not real sure what my problem is,
Water pump, old coolant, radiator, just getting into it, any ideas?
Kurt Horvath
95 PT 42
10AC
--- In WanderlodgeForum@yahoogroups.com, "Scott Forman"
bottom
> Scott Forman
> 86 PT38
> Memphis
replaced.
I
floor.
I
all
shot
> > Good luck Bob.
> > To:
> WanderlodgeForum@yahoogroups.com > om>
> rebuild/replacement
radiator
> used.
a
busses.
> I found these:
DD
> Series 60...
> > and
more
> com/11_2_1.htm>>
> > Pete Masterson
> html>>
> > El Sobrante CA
> > aeonix1@
> > Hi Pete,
Altho,
> > Bob Lawrence
> > 84 PT36
> > Padre Island,Tex
> recollection
> > is
> don't
> > want
> > to look for it.)
> work on
> > the
> Most
> > of
that
> the
> > new
> replace
> > all
it's
> part
> > of
> > the same assembly.
> (aluminum?
> bit
> > lower
(but
> big
> > is
S-
> 60
> > vs.
> > an 8v92.
> it's
> > Pete Masterson
> html>>
> > El Sobrante CA
> > aeonix1@
> > Pete,
> 8v92.
> > He is
> > Bob Lawrence
> > 84 PT36
> > Padre Island, Tx.
> problem. A
> found the
> > reason
> kills
can
> give.
> > I've
> fins
> > (which
> > Pete Masterson
> > El Sobrante CA
> > aeonix1@
> > Yahoo! Groups Links
> > Yahoo! Groups Links
01-01-2009, 10:00
Sounds like your fan does not come on automatically. Don't know if you have an
alarmstat, but if you do, it is probably bad.
With the Aux fan on manually, my engine runs in the low 180s (180 degree
thermostat). If I have manual fan off, it comes on at 196 and off at 190, and
will show a range of 189 to 197 (overshoot, presumably). Since the climb from
189 to 197 is steady, I can imagine hitting 225 sooner or later if the fan did
not come on.
Don Bradner
90 PT40 "Blue Thunder"
Home in Eureka, CA
01-01-2009, 10:06
Kurt,
My guess is your radiator is plugging up (internal). Drain out a few gallons of coolant...remove the radiator top hose...using a light and mirror look inside the top ...looking for plugged or partial plugged radiator tubes. Somewhere on this site are photos or our radiator prior to roding it out...UGLY.
Curt Sprenger
Anaheim Hills, CA
Kurt Horvath
95 PT 42
10AC
--- In "WanderlodgeForum%40yahoogroups.com", "Scott Forman"
bottom
> Scott Forman
> 86 PT38
> Memphis
> --- In "WanderlodgeForum%40yahoogroups.com", "Joyce and Richard Hayden"
replaced.
I
floor.
I
all
shot
> > Good luck Bob.
> > To:
> om>
> rebuild/replacement
radiator
> used.
a
busses.
> I found these:
DD
> Series 60...
> > and
more
> com/11_2_1.htm>>
> > Pete Masterson
> html>>
> > El Sobrante CA
> > aeonix1@
> > Hi Pete,
Altho,
> > Bob Lawrence
> > 84 PT36
> > Padre Island,Tex
> recollection
> > is
> don't
> > want
> > to look for it.)
> work on
> > the
> Most
> > of
that
> the
> > new
> replace
> > all
it's
> part
> > of
> > the same assembly.
> (aluminum?
> bit
> > lower
(but
> big
> > is
S-
> 60
> > vs.
> > an 8v92.
> it's
> > Pete Masterson
> html>>
> > El Sobrante CA
> > aeonix1@
> > Pete,
> 8v92.
> > He is
> > Bob Lawrence
> > 84 PT36
> > Padre Island, Tx.
> problem. A
> found the
> > reason
> kills
can
> give.
> > I've
> fins
> > (which
> > Pete Masterson
> > El Sobrante CA
> > aeonix1@
> > Yahoo! Groups Links
> > Yahoo! Groups Links
01-01-2009, 12:00
Your radiator probably needs a very thorough cleaning. Your heating sounds like what I experienced on my maiden trip -- engine would creep up to 210-220 (and eventually the check engine light would come on)... Oil temp would creep up to 240-250. On the gentle, but constant grade from Kansas into Denver, CO on I-70, the temperature held at about 205-210 with aux. fan on. I recall constantly watching it -- but it was never quite beyond the "normal" operating range as listed in the owner's manual. On the maiden trip, I had to stop several times while dealing with long grades in eastern Nevada to let it cool down.
When my radiator was inspected in place (shining a bring light through it), it looked clean. But you can't see well from the outside -- because the air-charge cooler (a type of radiator) is in front (and it doesn't collect the oily-dirt). Looking from the inside, the chassis AC condenser and the fan shroud blocked a good view. But when the radiator was pulled out, only the area swept by the fan was clear -- everywhere else was completely blocked by oily-dirt (it was pretty solid in there). The oily dirt builds up slowly over time.
If it's heavily impacted, it will be difficult to clean. I spray simple green into the radiator and use a garden hose to wash it out before each big trip. (Take off the grill.) I've also had the radiator steam cleaned when I've had the engine and undercarriage steam cleaned.
If you use a pressure washer, take care to not damage the fins, they bend really easy so that's why I only use a relatively low pressure garden hose spray.
After getting my radiator core replaced, I now run all day at 180 water and oil goes to about 210 with the aux fan switch OFF. Only heavy grades will bring the temperature up (and then I switch on the aux fan) -- water will go above 190 (but rarely reaches 200) and the oil will come up to 220-230. If the oil gets above 230, I take measures to control heat (slow down, use a lower gear ... or pull off in a shoulder/wide spot for 3 or 4 minutes to get the oil temperature down). Most grades I can hold about 45 mph -- but on longer grades (or on very warm afternoons) 35 to 40 becomes the speed where temperatures remain under better control. (I've never seen the transmission fluid temperature get above 175 and it usually hangs around 150-160.)
If possible, when I know a route has a long, heavy grade, I try to plan my schedule to run it before noon when ambient temperatures are usually more moderate. (But the grades approaching the Oregon-California border on I-5 are almost always encountered late in the day...)
El Sobrante CA
"aeonix1@mac.com"
Kurt Horvath
95 PT 42
10AC
--- In "WanderlodgeForum@yahoogroups.com", "Scott Forman"
bottom
Scott Forman
86 PT38
Memphis
--- In "WanderlodgeForum@yahoogroups.com", "Joyce and Richard Hayden"
replaced.
I
floor.
I
all
shot
Good luck Bob.
  To:
WanderlodgeForum@yahoogroups.com<"WanderlodgeForum"@...
om>
rebuild/replacement
radiator
used.
a
busses.
I found these:
DD
Series 60...
more
com/11_2_1.htm>>
html>>
  El Sobrante CA
  aeonix1@<"aeonix1"@>
    Hi Pete,
Altho,
    Bob Lawrence
    84 PT36
    Padre Island,Tex
recollection
    is
don't
    want
      to look for it.)
work on
Most
    of
that
    new
replace
    all
it's
part
    of
      the same assembly.
(aluminum?
bit
    lower
(but
big
    is
S-
60
    vs.
      an 8v92.
it's
html>>
      El Sobrante CA
      aeonix1@
        Pete,
8v92.
    He is
        Bob Lawrence
        84 PT36
        Padre Island, Tx.
problem. A
found the
        reason
kills
can
give.
        I've
fins
    (which
          El Sobrante CA
          aeonix1@
        Yahoo! Groups Links
    Yahoo! Groups Links
Yahoo! Groups Links
<*> Your email settings:
    (Yahoo! ID required)
01-01-2009, 12:15
Thanks, Pete.
Bob Lawrence
84 PT36
Padre Island, Tx
> It's been 2-1/2 years since I had to work done, so my recollection
is
> a bit sketchy. (I have the receipt somewhere, but I really don't
want
> to look for it.)
> The bill ended up costing about $4600 -- with $1000 being work on
> AC system (that wasn't related to the R&R of the radiator). Most
of
> the cost was labor (at SF Bay Area rates) and I believe that the
new
> core was about $1000 with about $2600 labor to remove and replace
all
> the stuff -- the air charge radiator had to come out as it's part
of
> the same assembly.
> I expect that a core might be a lot more expensive now (aluminum?
> brass?) -- and I'd think that labor in Corpus Christi is a bit
lower
> than here. I think the S-60 radiator is a little larger (but big
is
> big) -- and other costs of the R&R might be different in an S-60
vs.
> an 8v92.
> So, if the $3,500 includes R&R plus the new radiator core -- it's
> Pete Masterson
> <http://www.aeonix.biz/BBforsale.html>
> El Sobrante CA
> aeonix1@...
> > Pete,
> > I'm trying to get an answer for a Powell Brown and his 88 8v92.
He is
> > Bob Lawrence
> > 84 PT36
> > Padre Island, Tx.
> >> I noted (on my maiden trip) that it had an overheating problem. A
> >> trip to a heavy-duty bus/truck radiator shop quickly found the
> > reason
> >> and I had a new radiator core installed. Excessive heat kills
> >> engines, probably the quickest of any abuse an owner can give.
> > I've
> >> also added regular cleaning of the (external) radiator fins
(which
> >> Pete Masterson
> >> El Sobrante CA
> >> aeonix1@
> > Yahoo! Groups Links
01-01-2009, 12:19
Thanks, Dick, will pass it on to Powell.
Bob
> Good luck Bob.
> To:
rebuild/replacement
used.
I found these:
Series 60...
> and
com/11_2_1.htm>>
> Pete Masterson
html>>
> El Sobrante CA
> aeonix1@...
> Hi Pete,
> Bob Lawrence
> 84 PT36
> Padre Island,Tex
recollection
> is
don't
> want
> to look for it.)
work on
> the
Most
> of
> new
replace
> all
part
> of
> the same assembly.
(aluminum?
bit
> lower
big
> is
60
> vs.
> an 8v92.
it's
> Pete Masterson
html>>
> El Sobrante CA
> aeonix1@
> Pete,
8v92.
> He is
> Bob Lawrence
> 84 PT36
> Padre Island, Tx.
problem. A
found the
> reason
kills
give.
> I've
fins
> (which
> Pete Masterson
> El Sobrante CA
> aeonix1@
> Yahoo! Groups Links
> Yahoo! Groups Links
01-02-2009, 08:42
I've got an extra FC radiator for a cat 250hp if anyone needs one. I
know you guys are talking about DD radiators but thought I would throw
this out there for archive searches. It's the radiator that came off
of Rick Archie's '84 FC33 with about 75k miles on it. Contact me
offline for more info.
Thomas Eastham
Houston, TX
1983 FC35
Loading...
