Suspect: Mr Donut Charge: Tire Abuse Verdict: Guilty or Not Guilty?
05-17-2005, 07:18
Hay Bob can you get that hammer to straiten your wife out if she's giving to
much trouble about your driving habits also? Jon freewill2008 with a gauge, but an even quicker way to prevent driving off with a soft rear tire is the hammer trick that is quickly learned by watching truckers at a rest stop. Bounce a 3-4 pound hammer off the tread a few times and you will quickly learn when the rebound is "soft". This is not a substitute for maintaining the correct pressure with a gauge, but since it is fast and convenient it can keep you from missing a soft tire. It also makes you walk around the vehicle and observe everything else. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" wrote: > I had tire pressure problems from the day I got my bird, a year and > a half ago. I was constantly airing up the tires. They'd lose a few > pounds a day. > The fronts were new and no problem. The rears were Michelin > 11R 22.5 LRH and lost air. I went to a truck tire place last Fall and > had all the valve stems replaced and that fixed the leaks. I rarely > had to add air after that. > Took a trip a month ago and aired tires before I left. > Went 1400 miles round trip. Tires were fine. I always check > tire temp when I stop. No problems. > Left for a 170 mile trip Friday, didn't check tires before I > left. Mistake #1, won't make that one again. ;o) > 23 miles into the trip, wife wants front heater turned on. I > have to crawl under front to open valve. Notice right rear inner > dual appears to be flat. It is! > Air it up from on-board compressor, have new hose and tire guage. > It was flat. Zero pressure. Push in sidewall easily with hand. Flat. > Checked it with soapy water. No leaks found. Held air fine > for the next 2 days. > Cause for low pressure unknown, no cause can be found, unless > someone let the air out, in which case they laid there for nearly a > half an hour, pushing in the valve stem. > The question is, these are 4 years old, due to be replaced next > Fall. Have I damaged the tires with my actions? I'd rather wait > until Fall to buy tires. I need to drive to Rhode Island in June. > So, Guilty or Not Guilty? > > George Witt > 81 FC 35 WLSB > Lincoln, Nebraska--Huskers Yahoo! Groups Links One of my favorite sayings goes! "You never own anything, everything owns you!" --------------------------------- Yahoo! Mail Mobile Take Yahoo! Mail with you! Check email on your mobile phone. [Non-text portions of this message have been removed] |
05-18-2005, 01:31
Even better, try these:
http://www.alltiresupply.com/Merchant2/m...DMHI-\ F9A1AK810C1&Product_Code=43-098&Category_Code= If that long URL does not work, try this one: http://tinyurl.com/ck4fl Checking tire pressures was never eaiser. No more excuses for not checking pressures. I've been using mine for a few months now and love them. - Rick 87FC35 Rochester, MN --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > I like to check tire pressure regularly with a gauge, but an even > quicker way to prevent driving off with a soft rear tire is the > hammer trick that is quickly learned by watching truckers at a rest > stop. Bounce a 3-4 pound hammer off the tread a few times and you > will quickly learn when the rebound is "soft". > > This is not a substitute for maintaining the correct pressure with a > gauge, but since it is fast and convenient it can keep you from > missing a soft tire. It also makes you walk around the vehicle and > observe everything else. > > Bob Griesel '84 FC31 WLII WA > |
05-18-2005, 01:37
I've had them on two coaches. They work great.
Curt Sprenger â87PT38, Anaheim, Calif. Rick B wrote: > Even better, try these: > > http://www.alltiresupply.com/Merchant2/m...DMHI-\ F9A1AK810C1&Product_Code=43-098&Category_Code= > <http://www.alltiresupply.com/Merchant2/m...MDMHI\ -F9A1AK810C1&Product_Code=43-098&Category_Code=> > > If that long URL does not work, try this one: http://tinyurl.com/ck4fl > > Checking tire pressures was never eaiser. No more excuses for not > checking pressures. I've been using mine for a few months now and > love them. > > - Rick > 87FC35 > Rochester, MN |
