Xantrex RV 3012 /2512M Inverter / Charger $$$$$CHEEP $$$$$
05-20-2008, 16:55
I checked the dims out and its an easy fit in the charger compartment...
As for dirty, the chargers lasted 20 years so I dont think thats an issue... OTOH, its sure easier to put it in place of the Pace1500 as all the wiring is there, so thats where I'd stick it :} Having the old chargers as a backup is a good idea too. One thing I notice looking at the manual for the RV3012 is on page 17 they caution about hooking the battery - term to the inverter instead of chassis ground, Then on page 28 they show the - term hooked to chassis ground... Whats the correct way to wire these?? Thanks, Joe --- In WanderlodgeForum@yahoogroups.com, "Richard Hayden" > > Joe, > Even if it would fit, that compartment is soo dirty. Mine (Freedom 458) had already been upgraded when I got it. It is located where I believe the old 1500 watt inverter was located - 3rd compartment back on curb side, just to the rear of the propane tank compartment. This compartment isn't vented to the outside and I was initially concerned about this. However, lack of venting does not seem to be a problem. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: joepat50 > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, May 20, 2008 7:32 AM > Subject: [WanderlodgeForum] Re: Xantrex RV 3012 /2512M Inverter / Charger $$$$$CHEEP $$$$$ > > > --- In WanderlodgeForum@yahoogroups.com "bumpersbird" > > > > > I'll call Xantrex in the morning to see how these units compare to the > > Freedom 458's. They are simular but the spec sheet on the 458's are a > > little more detailed. > > > > Clik on or paste the link below. I haven't found prices anywhere close > > to these. > > > > $600 + $70 shipping for a 3000 amp unit & $550, $65. shipping for a > > 2500 amp unit! > > > > These are advertised as new, not remans. > > > > They advertise 50 units available. > > > > http://stores.ebay.com/Sun-Electronics-Miami_Inverter-<http://stores.ebaycom/Sun\ -Electronics-Miami_Inverter-> > > Chargers_W0QQcolZ4QQdirZQ2d1QQfsubZ4QQftidZ2QQtZkm > > > > Kurt Horvath > > 95 PT-42 WLWB > > That is a great price! From the Xantrex site it looks like they are > older models. > > Specs are here: > http://www.xantrex.com/support/docdisplayarchive.asp<http://www.xantrex.com/supp\ ort/docdisplayarchive.asp> > look for the RV series. The new ones end in -GS > > Im looking to upgrade from the Pace 1500 in my '87 PT40, do you think > these would fit in the charger compartment?? > > /Joe > |
