Need help getting with Onan
05-31-2008, 11:54
Try wiggling that white plastic connector at the back of the Onan box
that houses the circuitry. They are notorious for working loose as the wiring makes a sharp turn. You should be able to trace the 110 volt wirning from the genset to find that double breaker box. Mine , like Bill's , is in the cord compartment. Bruce 1988 FC35 |
06-01-2008, 11:54
Thanks for the help. I found the generator AC breaker box. It was
under the queen bed next to the water tank. Not the most obvoius or convenient place, but all is working now. Ron Hazlett 1987 FC Toledo, Ohio --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > Try wiggling that white plastic connector at the back of the Onan box > that houses the circuitry. They are notorious for working loose as the > wiring makes a sharp turn. You should be able to trace the 110 volt > wirning from the genset to find that double breaker box. Mine , like > Bill's , is in the cord compartment. > > Bruce > 1988 FC35 > |
06-01-2008, 13:28
Great!! Glad you found it.
Dick Gideon 1989FC35 --- In WanderlodgeForum@yahoogroups.com, "Ron Hazlett" > > Thanks for the help. I found the generator AC breaker box. It was > under the queen bed next to the water tank. Not the most obvoius or > convenient place, but all is working now. > > Ron Hazlett > 1987 FC > Toledo, Ohio > > --- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > > > > Try wiggling that white plastic connector at the back of the Onan > box > > that houses the circuitry. They are notorious for working loose as > the > > wiring makes a sharp turn. You should be able to trace the 110 volt > > wirning from the genset to find that double breaker box. Mine , > like > > Bill's , is in the cord compartment. > > > > Bruce > > 1988 FC35 > > > |
