Door repairs
06-12-2008, 07:09
Door repairs
Ditto!!
This is an word for word description of the door on my coach.
I had a wind noise from around the door. I had to adjust the latch
bar in somewhat. I ground a small flat spot in the large washer to
get it adjusted in towards the jam.
I takes a little authority to get the it to latch but there is no
door movement when closed and according to the wife no more wind
noise.
Kurt Horvath
95 PT-42
10AC
> I'll note that the door on my coach must be shut with authority
(like
> you mean it) or the automotive-type lock won't latch properly.
This
> was the situation with the original weather stripping and with the
> weather stripping I installed. Once the automotive latch is
properly
> activated, then the dead bolt lines up properly.
> If you try to open the door with the dead bolt locked, then when
> automotive latch releases, the pressure on the dead bolt is
> sufficient that the solenoid won't move it. Depending on which
side
> of the door you're on, you either have to pull or push on the door
to
> relieve the pressure on the dead bolt, then the solenoid will
through
> the bolt.
> Pete Masterson
> '95 Blue Bird Wanderlodge WBDA 42
> El Sobrante CA
> aeonix1@...
> On Jun 11, 2008, at 8:22 PM, Gregory OConnor wrote:
> > Ryan, when I use the keyless on my '94 I have to push on the door
to
> > line up the deadbolt. This is all done blind folded as I cant see
or
> > feel what is going on in the jamb. I think someone replaced the
> > seal with a too ambitious foam/rubber product. fat seals endup
> > causing the door operator to slam and place a hard turn on the
> > lock. One other issue is that the door on my 94 is alumnium and
> > swells more than the steel frame in the sun. just some things to
> > consider with your project
06-12-2008, 13:48
Door repairs
Pete,
That is exactly what happens on mine. Very frustrating. Also no real way that anyone knows of to adjust it.
BradBarton00LXiDFW bbartonwx@...
Date: Thu, 12 Jun 2008 09:56:22 -0700
Subject: Re: [WanderlodgeForum] Re: Door repairs
I'll note that the door on my coach must be shut with authority (like you mean it) or the automotive-type lock won't latch properly. This was the situation with the original weather stripping and with the weather stripping I installed. Once the automotive latch is properly activated, then the dead bolt lines up properly.
If you try to open the door with the dead bolt locked, then when the automotive latch releases, the pressure on the dead bolt is sufficient that the solenoid won't move it. Depending on which side of the door you're on, you either have to pull or push on the door to relieve the pressure on the dead bolt, then the solenoid will through the bolt.
El Sobrante CA
"aeonix1@mac.com"
Ryan, when I use the keyless on my '94 I have to push on the door to
line up the deadbolt. This is all done blind folded as I cant see or
Instantly invite friends from Facebook and other social networks to join you on Windows Live™ Messenger. Invite friends now!
06-12-2008, 14:41
Door repairs
Leroy, Welcome to the club. When it all comes down to it, we are all pretty much Whacko. Also don't worry about hearing voices from time to time. A friend once told me that the time to WORRY is when you no longer hear them! LOL!!! George Burke 1977 FC31 Charlotte
On Tue, Jun 10, 2008 at 9:20 PM, Leroy Eckert <"jwasnewski@yahoo.com"> wrote:
As usual I am on the outside looking in on the lock deal but that is ok. I do not use mine even though it works because I am very catastrophic failure or natural disaster superstitious. I have a home fire escape plan which has a basement in a two story home with two exit doors other than the garage. In addition I have 6 smoke detectors.
In a building in case of fire do not use the elevator use the stairs.
In the bus, in case of fire the auto remote lock will not work. There is only one way out except for the windows and the sooner you are out the better. I keep a mini sledge in the bedroom just in case, to hell with depending on the windows to slide even though they do. You just cannot be to careful.
Leroy Eckert
1990 WB-40 Royale
Dahlonega, GA
Smoke N Mirrors
Whacko and hear voices from time to time.
Ryan Wright <"ryanpwright@gmail.com"> wrote:
Two questions,
1. Where can I get a new door seal? Mine is old and falling apart.
2. Any tips on getting the remote lock to work reliably? Mine works
sporadically. Sometimes it's fine, other times it just refuses. Can't
be the switch because both the dash switches and the bedroom switch
work (or don't) at the same time. I want to install a keyless entry,
but need to make the door lock work reliably first.
Thank you,
-Ryan
'86 PT-40 8V92
06-13-2008, 00:33
Door repairs
I've examined the door geometry very closely. It doesn't seem like there's any real solution -- it appears to be a "feature" (as in "that's not a bug, it's an undocumented feature")... When my weather stripping was failing, the door was easier to close, but then there were some air leaks and wind noise. Once I renewed the weather strip (with a profile that was quite similar to the original) then the door was a bit harder to close, but the air leaks and wind noise was gone.
I've adjusted to it and have become accustomed to using a firm hand when closing the door. It's not really an excessive amount of force, but it is rather more than is required for most vehicles. I chalk it up to being a Blue Bird quirk.
El Sobrante CA
"aeonix1@mac.com"
On Jun 12, 2008, at 6:48 PM, brad barton wrote:
Pete,
Brad Barton 00LXiDFW "bbartonwx@hotmail.com"
El Sobrante CA
"aeonix1@mac.com"
06-13-2008, 01:46
Door repairs
The most annoying noise resulting from wind at the entry door comes
from atop the passanger seat. 1- opening up the airvent pressurizes
the cab enough to keep air from entering.(close rear windows also) 2-
Saying "What,,, What,,,, What,,," is effective in reduction of seat
noise. I don't get the 'skin the cat anology' but these are two of
those other ways.
Less weather strip is needed at the hinge side. too much will lift
the hinge and soon distort. hollow strips seem to seal better with
less pressure but when you distort the mechanics, you end up needing
newspaper sticking out the jam.
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, David Brady
> Yes, that piano hinge doesn't help. It was okay on a school bus
> (with 2 doors meeting in the center), but it's not quite good
enough
> on a single door motorhome. What we need is a true automotive
> style door hinge, which pulls the door out away from the vehicle
> rather than a piano hinge which severely pinches the weather
stripping
> adjacent to the hinge. Alas, we're probably stuck with it.
> David
> '02 LXi, NC
like
weather
there
strip
door
gone.
hand
force,
chalk it
> > Pete Masterson
> > El Sobrante CA
> > aeonix1@...
> >> Pete,
no
> >> Brad Barton 00LXiDFW bbartonwx@...
> >> From: aeonix1@...
authority
lines
> >> up properly.
when
bolt is
which
on
> >> Pete Masterson
> >> El Sobrante CA
> >> aeonix1@...
on the
> >> door to
I cant
> >> see or
replaced the
seals endup
on the
alumnium and
things to
networks to
> >> <https://www.invite2messenger.net/im/?
source=TXT_EML_WLH_InviteFriends>
> > No virus found in this incoming message.
> > Checked by AVG.
> > Version: 7.5.524 / Virus Database: 270.3.0/1500 - Release Date:
6/12/2008 4:58 PM
06-13-2008, 02:30
Door repairs
(with 2 doors meeting in the center), but it's not quite good enough
rather than a piano hinge which severely pinches the weather stripping
David
'02 LXi, NC
El Sobrante CA
"aeonix1@mac.com"
Pete,
properly.
the bolt.
El Sobrante CA
"aeonix1@mac.com"
the door to
cant see or
fat seals endup
things to
Checked by AVG. Version: 7.5.524 / Virus Database: 270.3.0/1500 - Release Date: 6/12/2008 4:58 PM
06-13-2008, 02:53
Door repairs
That's right, adjacent to the hinge the factory installed a layer of
double sided tape and then weather stripping on top of that. To
thin that combo I got rid of the tape and installed a thin self adhesive
rubber weather strip. It works, my door actually closes pretty
easily compared to how it worked before my magic.
David Brady
'02 LXi, NC (I never did like cats)
comes
those other ways.
GregoryO'Connor
94ptRomolandCa
David Brady "dmb993@..."
enough
stripping
> David
> '02 LXi, NC
like
in
weather
there
weather
strip
door
was
gone.
firm
hand
force,
chalk it
> > Pete Masterson
> > El Sobrante CA
> > aeonix1@... <"aeonix1@"...>
> >> Pete,
Also
no
<"bbartonwx@"...>
> >> To: "WanderlodgeForum%40yahoogroups.com"
> >> From: aeonix1@... <"aeonix1@"...>
authority
Once
bolt
lines
> >> up properly.
then
when
bolt is
which
push
on
> >> Pete Masterson
> >> El Sobrante CA
on the
> >> door to
I cant
> >> see or
replaced the
seals endup
on the
alumnium and
things to
networks to
> > Checked by AVG.
Date:
6/12/2008 4:58 PM
06-13-2008, 03:29
Door repairs
I actually only replaced the outside edge, top and bottom but not the hinge-edge of the weather stripping. The hinge edge was more bother, so I put it off. I then noticed that the wind noise I was getting had gone away.
I also got rid of some wind noises in the door window by installing some weather stripping there, too. I used a kind of 'fur' stuff -- stiff fibers about 1/16" long that stick up from a 3/16" sticky tape.
I have a bit of similar wind noise from the driver's side window as well. Installing a bunch more of the fur-stuff is on my to do list.
These kinds of things are endless -- I have several of the other windows that need troubleshooting for rattles and wind noise as well. Difficulty there is that it helps to be able to sit/stand near the window and experiment to find exactly where the noise/air leak is coming from. I can't do that while I'm driving. Wife won't drive the bus. So I need to wait for a day when there's gale force winds blowing so I can fiddle with the windows while parked... (We don't get many of those days around here.)
El Sobrante CA
"aeonix1@mac.com"
those other ways.
GregoryO'Connor
94ptRomolandCa
 --- In "WanderlodgeForum@yahoogroups.com", David Brady
enough
stripping
David
'02 LXi, NC
like
weather
there
strip
door
gone.
hand
force,
chalk it
El Sobrante CA
aeonix1@... <"aeonix1"@...>
Pete,
no
Brad Barton 00LXiDFW bbartonwx@... <"bbartonwx"@...>
    <"WanderlodgeForum@yahoogroups.com">
authority
lines
    up properly.
when
bolt is
which
on
    El Sobrante CA
on the
        door to
I cant
        see or
replaced the
seals endup
on the
alumnium and
things to
networks to
Checked by AVG.
6/12/2008 4:58 PM
Yahoo! Groups Links
<*> Your email settings:
    (Yahoo! ID required)
06-13-2008, 03:53
Door repairs
That sounds like exactly what I need. There's a lot of rattling going on with a couple of the windows. But I also get wind noise (high-pitched whistle). Due to the age of my windows, the sealing simply seems to be worn down. It hadn't occurred to me before, but I'll contact Peninsula Glass and see if they have any ideas on how to renew the weather stripping.
El Sobrante CA
"aeonix1@mac.com"
On Jun 13, 2008, at 9:42 AM, David Brady wrote:
What makes noise on my side windows are the screens - they rattle
over bumps. I found that Penisula Glass put a plastic channel at the
base of my screens that slides in another extruded channel in the
window frame. The plastic piece is a few inches shorter than the window
frame. It's purpose is to cinch the screen into the extruded window
frame to prevent rattling. It works. If you don't have such an item,
you can probably get it from Peninsula. It's a simple matter to pop
out the screen, seat the plastic channel, and re-insert the screen.
David Brady,
'02 LXi, NC
El Sobrante CA
"aeonix1@mac.com"
those other ways.
GregoryO'Connor
94ptRomolandCa
 --- In "WanderlodgeForum@yahoogroups.com", David Brady "dmb993@..."
enough
stripping
David
'02 LXi, NC
like
weather
there
strip
door
gone.
hand
force,
chalk it
El Sobrante CA
Pete,
no
authority
lines
    up properly.
when
bolt is
which
on
    El Sobrante CA
on the
        door to
I cant
        see or
replaced the
seals endup
on the
alumnium and
things to
networks to
Checked by AVG.
6/12/2008 4:58 PM
Yahoo! Groups Links
06-13-2008, 04:42
Door repairs
David Brady,
'02 LXi, NC
sticky tape.
El Sobrante CA
"aeonix1@mac.com"
comes
pressurizes
also) 2-
seat
noise.  I don't
those other ways.
needing
GregoryO'Connor
94ptRomolandCa
bus
enough
vehicle
stripping
David
'02 LXi, NC
seem
like
(as in
my
weather
then
there
weather
strip
then the
door
noise was
gone.
firm
hand
of
force,
chalk it
El Sobrante CA
Pete,
no
    Date:
    Subject:
    I'll
authority
    (like
    properly.
    stripping
    automotive
lines
    up
properly.
    If you
when
bolt is
    sufficient
which
    side of
on
    the door
    solenoid
    Pete
Masterson
    '95 Blue
    El
Sobrante CA
    aeonix1@...
<"aeonix1"@...>
    On Jun
        Ryan,
on the
        door
to
        line
I cant
        see
or
        feel
think someone
replaced the
        seal
fat
seals endup
        causing
on the
door on my 94 is
alumnium and
        swells
things to
        consider
with your project
networks to
Checked by AVG.
Date:
6/12/2008 4:58 PM
Yahoo! Groups Links
    Individual
Email | Traditional
    (Yahoo! ID
required)
User(s) browsing this thread: 7 Guest(s)
