air chuck from engine air compressor
10-13-2008, 04:06
One of the reason truckers use a stick to bounce test air pressure
is thy dont want to end up with a stuck valve leaking. Many truckers and trucking companies wont use add on devices due to possible failure of that device. Kinda like the air pressure protection valve in the engine compartment of many Pt's that protect the bulk oil appliance from leaking. Seems that everyone ends up with a leak in the protection valve!!. I check a.p. once a trip and stick/bounce tires every walk around during a typical 5 day trip. other reason Truckers use the stick is it is a good excuse to have a tool for personal protection that without reason to pack, would be considered a wepon. My fovorite personal protection device is a fire extinguisher, I keep one insight anyplace I go. Greg94ptCa --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > I am a little confused. I have an air chuck in the left roadside bay forward of the drive wheel. I use it to fill the tires when needed. I say when needed only because I changed to dually valves and have not added air in months. Perhaps the new bird does not have this chuck. The engine driven or twin piston aux air pump supplies the air, my choice through the aux air system. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > > --- On Sun, 10/12/08, Bob Lawrence > From: Bob Lawrence > Subject: [WanderlodgeForum] Re: air chuck from engine air compressor > To: WanderlodgeForum@yahoogroups.com > Date: Sunday, October 12, 2008, 9:32 PM > > > > > > > > > > > > We have a 12v compressor from Viair. > > It was recommended by Livingston of Good Sam Club. > > They have several models, 110 or 12v. We have the 12v model and it > > pumps up our 120 psi tires nooo problem. > > Google them and see if it will work for you. > > Bob Lawrence > > 84 PT36 > > Branson, Mo > > > > > Am getting tired of waiting in line at truck stops to air up the > > > tires. I think I remember someone pointing out an air chuck coming > > > from the engine air compressor but I'm not sure where it would be. Is > > > there an air chuck coming from the engine air compressor on the 2000 > > > LXI? If so, does it have sufficient 'torque', like the truck stop > > > compressors, to quickly air up the tires? > > > > > > Yup, we do have the 110 vt auxilliary compresser but it doesn't have > > > the 'torque' when you are talking 95 to 115 psi. > > > > > > Ron 'n Ruth, still in MN in 2000 LXI > > > > |
