Generator won't start
03-30-2009, 22:34
Hi Marv
How do you like the hurricane heat system and does it heat the bays? Is the big foot leveling system reliable?
Wayne
From: Marv & Jean To: WanderlodgeForum@yahoogroups.com Sent: Monday, March 30, 2009 7:56:46 PM Subject: [WanderlodgeForum] Re: Generator won't start Hi Wayne: I like the M380 a lot. I have put 58,000 miles on it and have had minimal problems after we got the original issues ironed out. I think a lot of that was operator problems rather than coach problems. Like all computer stuff the coach wants things done in set sequence and if you deviate from the sequence it just won't work. Our coach has two slide and both are working fine. In the flat lands we get about 8.5 mph and driving in the mountains it is about 1 mpg less. There are some good buys on M380s around. I don't think you would regret it. After the 82FCRB it was quite a change. If you have any specific questions I would be glad to try to answer them for you. Marv 2004 M380 Ocean Shores, WA --- In "WanderlodgeForum%40yahoogroups.com", Wayne Kotila > > Marv, how do like your 2004 M380? I have been consideringbuying an M380. > Wayne > 1985 PT40 > > > > > ____________ _________ _________ __ > From: Marv & Jean > To: "WanderlodgeForum%40yahoogroups.com" > Sent: Monday, March 30, 2009 2:39:46 PM > Subject: [WanderlodgeForum] Re: Generator won't start > > > Gary: > > The generator battery on the M380 is not charged from the 110v shore power. For the generator to be charged you have to run the generator. If you have not run it in a couple of months it is likely that the battery is down. I would either put a battery charger on the generator battery or jump start it. Remember if using a charger it is a Gel cell battery so use an appropriate charger. > > Marv > 2004 M380 > Ocean Shores, WA > > --- In WanderlodgeForum@ yahoogroups. com, "garyvant55439" > > > > The generator on my 2004 M380 won't start from any of the starting switches. It's worked over the last two years and I started it about two months ago. > > > > The generator battery appears to be OK. > > > > Any ideas? > > > > Gary Van Tassel > > > |
03-31-2009, 05:02
Wayne
The hurricane system works well and has required minimal maintenance. It is a bit more noisy that I would have liked because i have a vibration when the pump is running that is annoying. It must not be too bad because I have not tried to do anything to fix it. The pump that runs all time is in the hot water side of the system and to fix that problem I put a remote switch on the dash that allows us to turn the water heater on and off. We only leave it on when we need hot water and that stops the pump and saves the batteries. That is an easy fix. There is an antifreeze like fluid in the system that needs to be potable in case of a pin hole developing in the coil that would allow the fluid to enter the fresh water system. The Big Foot levelers have not cause a minute trouble. I spray them 3 or 4 times a year with dry/greaseless silicon and that has been it. I didn't mention the driveability. It is a dream to drive. I don't believe you will find any other coach that drives better. The only problem is that it wants to run faster that I think I should be driving. No speeding tickets yet but I have to keep the cruise control on or I am afraid I would get a ticket. Wayne I would not hesitate to buy another M380 if I was shopping for another coach. Marv 2004 M380 Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, Wayne Kotila > > Hi Marv > How do you like the hurricane heat system and does it heat the bays? Is the big foot leveling system reliable? > Wayne > > > > > ________________________________ > From: Marv & Jean > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, March 30, 2009 7:56:46 PM > Subject: [WanderlodgeForum] Re: Generator won't start > > > Hi Wayne: > > I like the M380 a lot. I have put 58,000 miles on it and have had minimal problems after we got the original issues ironed out. I think a lot of that was operator problems rather than coach problems. Like all computer stuff the coach wants things done in set sequence and if you deviate from the sequence it just won't work. > > Our coach has two slide and both are working fine. In the flat lands we get about 8.5 mph and driving in the mountains it is about 1 mpg less. There are some good buys on M380s around. I don't think you would regret it. After the 82FCRB it was quite a change. > > If you have any specific questions I would be glad to try to answer them for you. > > Marv > 2004 M380 > Ocean Shores, WA > > --- In WanderlodgeForum@ yahoogroups. com, Wayne Kotila wrote: > > > > Marv, how do like your 2004 M380? I have been considering buying an M380. > > Wayne > > 1985 PT40 > > > > > > > > > > ____________ _________ _________ __ > > From: Marv & Jean > > To: WanderlodgeForum@ yahoogroups. com > > Sent: Monday, March 30, 2009 2:39:46 PM > > Subject: [WanderlodgeForum] Re: Generator won't start > > > > > > Gary: > > > > The generator battery on the M380 is not charged from the 110v shore power. For the generator to be charged you have to run the generator. If you have not run it in a couple of months it is likely that the battery is down. I would either put a battery charger on the generator battery or jump start it. Remember if using a charger it is a Gel cell battery so use an appropriate charger. > > > > Marv > > 2004 M380 > > Ocean Shores, WA > > > > --- In WanderlodgeForum@ yahoogroups. com, "garyvant55439" > > > > > > The generator on my 2004 M380 won't start from any of the starting switches. It's worked over the last two years and I started it about two months ago. > > > > > > The generator battery appears to be OK. > > > > > > Any ideas? > > > > > > Gary Van Tassel > > > > > > |
03-31-2009, 09:50
That all sounds good.
Thank You
Wayne
From: Marv & Jean To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, March 31, 2009 12:02:37 PM Subject: [WanderlodgeForum] Re: Generator won't start Wayne The hurricane system works well and has required minimal maintenance. It is a bit more noisy that I would have liked because i have a vibration when the pump is running that is annoying. It must not be too bad because I have not tried to do anything to fix it. The pump that runs all time is in the hot water side of the system and to fix that problem I put a remote switch on the dash that allows us to turn the water heater on and off. We only leave it on when we need hot water and that stops the pump and saves the batteries. That is an easy fix. There is an antifreeze like fluid in the system that needs to be potable in case of a pin hole developing in the coil that would allow the fluid to enter the fresh water system. The Big Foot levelers have not cause a minute trouble. I spray them 3 or 4 times a year with dry/greaseless silicon and that has been it. I didn't mention the driveability. It is a dream to drive. I don't believe you will find any other coach that drives better. The only problem is that it wants to run faster that I think I should be driving. No speeding tickets yet but I have to keep the cruise control on or I am afraid I would get a ticket. Wayne I would not hesitate to buy another M380 if I was shopping for another coach. Marv 2004 M380 Ocean Shores, WA --- In "WanderlodgeForum%40yahoogroups.com", Wayne Kotila > > Hi Marv > How do you like the hurricane heat system and does it heat the bays? Is the big foot leveling system reliable? > Wayne > > > > > ____________ _________ _________ __ > From: Marv & Jean > To: "WanderlodgeForum%40yahoogroups.com" > Sent: Monday, March 30, 2009 7:56:46 PM > Subject: [WanderlodgeForum] Re: Generator won't start > > > Hi Wayne: > > I like the M380 a lot. I have put 58,000 miles on it and have had minimal problems after we got the original issues ironed out. I think a lot of that was operator problems rather than coach problems. Like all computer stuff the coach wants things done in set sequence and if you deviate from the sequence it just won't work. > > Our coach has two slide and both are working fine. In the flat lands we get about 8.5 mph and driving in the mountains it is about 1 mpg less. There are some good buys on M380s around. I don't think you would regret it. After the 82FCRB it was quite a change. > > If you have any specific questions I would be glad to try to answer them for you. > > Marv > 2004 M380 > Ocean Shores, WA > > --- In WanderlodgeForum@ yahoogroups. com, Wayne Kotila > > > > Marv, how do like your 2004 M380? I have been consideringbuying an M380. > > Wayne > > 1985 PT40 > > > > > > > > > > ____________ _________ _________ __ > > From: Marv & Jean > > To: WanderlodgeForum@ yahoogroups. com > > Sent: Monday, March 30, 2009 2:39:46 PM > > Subject: [WanderlodgeForum] Re: Generator won't start > > > > > > Gary: > > > > The generator battery on the M380 is not charged from the 110v shore power. For the generator to be charged you have to run the generator. If you have not run it in a couple of months it is likely that the battery is down. I would either put a battery charger on the generator battery or jump start it. Remember if using a charger it is a Gel cell battery so use an appropriate charger. > > > > Marv > > 2004 M380 > > Ocean Shores, WA > > > > --- In WanderlodgeForum@ yahoogroups. com, "garyvant55439" > > > > > > The generator on my 2004 M380 won't start from any of the starting switches. It's worked over the last two years and I started it about two months ago. > > > > > > The generator battery appears to be OK. > > > > > > Any ideas? > > > > > > Gary Van Tassel > > > > > > |
03-31-2009, 10:58
Hi,
Just for clarity. The 2004 system is better. The 2005-6 system does not have a different fluid for the heater loop.It is ethylene- glycol. It is no longer required to have a potable fluid in that loop as the water heater is double walled. In this "heat sink" system, there is only one pump for the entire system. It does not shut off. There is no valve to cut off the engine /rad from the rest of the system as doing so would pressurize the heating loop in the coach . The only expansion tank is with the rad. Ross --- In WanderlodgeForum@yahoogroups.com, "Marv & Jean" > > Wayne > > The hurricane system works well and has required minimal maintenance. It is a bit more noisy that I would have liked because i have a vibration when the pump is running that is annoying. It must not be too bad because I have not tried to do anything to fix it. The pump that runs all time is in the hot water side of the system and to fix that problem I put a remote switch on the dash that allows us to turn the water heater on and off. We only leave it on when we need hot water and that stops the pump and saves the batteries. That is an easy fix. There is an antifreeze like fluid in the system that needs to be potable in case of a pin hole developing in the coil that would allow the fluid to enter the fresh water system. > > The Big Foot levelers have not cause a minute trouble. I spray them 3 or 4 times a year with dry/greaseless silicon and that has been it. > > I didn't mention the driveability. It is a dream to drive. I don't believe you will find any other coach that drives better. The only problem is that it wants to run faster that I think I should be driving. No speeding tickets yet but I have to keep the cruise control on or I am afraid I would get a ticket. > > Wayne I would not hesitate to buy another M380 if I was shopping for another coach. > > Marv > 2004 M380 > Ocean Shores, WA > > > --- In WanderlodgeForum@yahoogroups.com, Wayne Kotila > > > > Hi Marv > > How do you like the hurricane heat system and does it heat the bays? Is the big foot leveling system reliable? > > Wayne > > > > > > > > > > ________________________________ > > From: Marv & Jean > > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, March 30, 2009 7:56:46 PM > > Subject: [WanderlodgeForum] Re: Generator won't start > > > > > > Hi Wayne: > > > > I like the M380 a lot. I have put 58,000 miles on it and have had minimal problems after we got the original issues ironed out. I think a lot of that was operator problems rather than coach problems. Like all computer stuff the coach wants things done in set sequence and if you deviate from the sequence it just won't work. > > > > Our coach has two slide and both are working fine. In the flat lands we get about 8.5 mph and driving in the mountains it is about 1 mpg less. There are some good buys on M380s around. I don't think you would regret it. After the 82FCRB it was quite a change. > > > > If you have any specific questions I would be glad to try to answer them for you. > > > > Marv > > 2004 M380 > > Ocean Shores, WA > > > > --- In WanderlodgeForum@ yahoogroups. com, Wayne Kotila wrote: > > > > > > Marv, how do like your 2004 M380? I have been considering buying an M380. > > > Wayne > > > 1985 PT40 > > > > > > > > > > > > > > > ____________ _________ _________ __ > > > From: Marv & Jean > > > To: WanderlodgeForum@ yahoogroups. com > > > Sent: Monday, March 30, 2009 2:39:46 PM > > > Subject: [WanderlodgeForum] Re: Generator won't start > > > > > > > > > Gary: > > > > > > The generator battery on the M380 is not charged from the 110v shore power. For the generator to be charged you have to run the generator. If you have not run it in a couple of months it is likely that the battery is down. I would either put a battery charger on the generator battery or jump start it. Remember if using a charger it is a Gel cell battery so use an appropriate charger. > > > > > > Marv > > > 2004 M380 > > > Ocean Shores, WA > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "garyvant55439" wrote: > > > > > > > > The generator on my 2004 M380 won't start from any of the starting switches. It's worked over the last two years and I started it about two months ago. > > > > > > > > The generator battery appears to be OK. > > > > > > > > Any ideas? > > > > > > > > Gary Van Tassel > > > > > > > > > > |
04-03-2009, 07:51
Marv et al,
Thanks. I took your advice and charged the battery. Gen works fine now and I learned a leasson about exercising the generator more frequently. Best regards, Gary Van Tassel 2004 M380 Verde Valley, AZ --- In WanderlodgeForum@yahoogroups.com, "Marv & Jean" > > Gary: > > The generator battery on the M380 is not charged from the 110v shore power. For the generator to be charged you have to run the generator. If you have not run it in a couple of months it is likely that the battery is down. I would either put a battery charger on the generator battery or jump start it. Remember if using a charger it is a Gel cell battery so use an appropriate charger. > > Marv > 2004 M380 > Ocean Shores, WA > > --- In WanderlodgeForum@yahoogroups.com, "garyvant55439" > > > > The generator on my 2004 M380 won't start from any of the starting switches. It's worked over the last two years and I started it about two months ago. > > > > The generator battery appears to be OK. > > > > Any ideas? > > > > Gary Van Tassel > > > |
04-03-2009, 08:09
Glad it works Gary.
Marv 2004 M380 Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, "garyvant55439" > > Marv et al, > > Thanks. I took your advice and charged the battery. Gen works fine now and I learned a leasson about exercising the generator more frequently. > > Best regards, > > Gary Van Tassel > 2004 M380 > Verde Valley, AZ > > > --- In WanderlodgeForum@yahoogroups.com, "Marv & Jean" > > > > Gary: > > > > The generator battery on the M380 is not charged from the 110v shore power. For the generator to be charged you have to run the generator. If you have not run it in a couple of months it is likely that the battery is down. I would either put a battery charger on the generator battery or jump start it. Remember if using a charger it is a Gel cell battery so use an appropriate charger. > > > > Marv > > 2004 M380 > > Ocean Shores, WA > > > > --- In WanderlodgeForum@yahoogroups.com, "garyvant55439" > > > > > > The generator on my 2004 M380 won't start from any of the starting switches. It's worked over the last two years and I started it about two months ago. > > > > > > The generator battery appears to be OK. > > > > > > Any ideas? > > > > > > Gary Van Tassel > > > > > > |
04-04-2009, 16:49
Hi Gary:
How do you like your M380, I am thinking of buying one and was wanting to get a few owner opinions on the M380.
Wayne
From: garyvant55439 To: WanderlodgeForum@yahoogroups.com Sent: Monday, March 30, 2009 10:14:16 AM Subject: [WanderlodgeForum] Re: Generator won't start Ernie, Thanks for your quick reply. Yes there are two fuses - and they are both ok. Gary Van Tassel 2004 M380 Verde Valley, AZ --- In "WanderlodgeForum%40yahoogroups.com", Ernie Ekberg > > Gary- is there a fuse on the generator control panel? Run your generator out and see. > > > Ernie Ekberg > 83PT40 > Wanderlodge > Weatherford, Tx > http://autos. groups.yahoo. com/group/ erniesremodeling andrepair > > --- On Mon, 3/30/09, garyvant55439 > > From: garyvant55439 > Subject: [WanderlodgeForum] Generator won't start > To: "WanderlodgeForum%40yahoogroups.com" > Date: Monday, March 30, 2009, 9:41 AM > > > > > > > The generator on my 2004 M380 won't start from any of the starting switches. It's worked over the last two years and I started it about two months ago. > > The generator battery appears to be OK. > > Any ideas? > > Gary Van Tassel > |
04-07-2009, 14:35
Hi Gary:
How do you like your M380, I am looking for a newer wanderlodge and the M380 is one modelwe are considering.
Wayne
1985 PT40
04-08-2009, 13:52
