Transmission Upgrade/change
06-03-2005, 00:08
remember you will need a touch pad,wiring harness,computer etc. i considered
putting one in my truck,i was looking in the rv junkyards.i did but 2 trannys out of burned coachs,good trannys,no wiring or touchpads..randydupree93wb ----- Original Message ----- From: Mike Hohnstein To: WanderlodgeForum@yahoogroups.com Sent: Friday, June 03, 2005 12:07 AM Subject: Re: [WanderlodgeForum] Transmission Upgrade/change There in lies the problem, retrofitting to an non electronic engine. I haven't hooked up with any one who is on top of the project. The wiring from the donor vehicle chassis is needed as far as I can tell and at this time I have yet to find a recycling entity that is knowledgeable and skillful enough to put a package together. If you get a handle on the electronic issues, I would like to be kept up to speed as I would like to have one of those double ODs too. I'm not ready to buy a whole truck to get the trans and related components. The converter attachment to the flex plate could be a problem as they never mated to the 3208. I found a couple of MDs on the internet, some place in FL. They wanted 3500 bucks. Dupree turned me on to a place that has Brownie inline ODs, I located one for under a grand and that might make more economic sense. Mike Hohnstein ----- Original Message ----- From: hsaddock To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 02, 2005 12:23 PM Subject: [WanderlodgeForum] Transmission Upgrade/change Folks: I am giving serious thought to changing the transmission in my 83FC35 from the Allison MT641 to an Allison MD3000. The reasons are: 1) current transmission with 112K miles on it shifts a little slowly from 1st to 2nd at full throttle - it shifts just fine if I back off the throttle slightly and in all other gears. (perhaps this is the beginning of a bigger future problem?) 2) I want to travel a little faster at top-end, and the MD3000's 5/6 speeds gives the overdrive(s). 3) I want to pull a little better going up steep hills so if I lower the differential ratio while doing this conversion, I can pull better in the lower gears and still tool down the road faster on the flats with the overdrives. Has anyone tried this conversion? Comments on anticipated issues? The MD3000 appears to be an inch shorter in length than the MT641 and a similar bolt up pattern so I don't expect to see any major issues with mounting. The MD3000 is computer controlled - can it be fooled into working with an older 3208? Harry Saddock 83FC35 South Windsor, CT ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-03-2005, 07:26
Check out Nimco Bus Division (800)526-8055. They dismantle buses. I
know many buss companies that buy used parts from Nimco as well as busnuts. They have conversion kits available for some components. Nick seems to be very knowledgeable... George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD Mike Hohnstein wrote: > There in lies the problem, retrofitting to an non electronic engine. I haven't hooked up with any one who is on top of the project. The wiring from the donor vehicle chassis is needed as far as I can tell and at this time I have yet to find a recycling entity that is knowledgeable and skillful enough to put a package together. If you get a handle on the electronic issues, I would like to be kept up to speed as I would like to have one of those double ODs too. I'm not ready to buy a whole truck to get the trans and related components. The converter attachment to the flex plate could be a problem as they never mated to the 3208. I found a couple of MDs on the internet, some place in FL. They wanted 3500 bucks. Dupree turned me on to a place that has Brownie inline ODs, I located one for under a grand and that might make more economic sense. > Mike Hohnstein > ----- Original Message ----- > From: hsaddock > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, June 02, 2005 12:23 PM > Subject: [WanderlodgeForum] Transmission Upgrade/change > > > Folks: > I am giving serious thought to changing the transmission in my > 83FC35 from the Allison MT641 to an Allison MD3000. The reasons > are: 1) current transmission with 112K miles on it shifts a little > slowly from 1st to 2nd at full throttle - it shifts just fine if I > back off the throttle slightly and in all other gears. (perhaps this > is the beginning of a bigger future problem?) 2) I want to travel a > little faster at top-end, and the MD3000's 5/6 speeds gives the > overdrive(s). 3) I want to pull a little better going up steep > hills so if I lower the differential ratio while doing this > conversion, I can pull better in the lower gears and still tool down > the road faster on the flats with the overdrives. > > Has anyone tried this conversion? Comments on anticipated issues? > The MD3000 appears to be an inch shorter in length than the MT641 > and a similar bolt up pattern so I don't expect to see any major > issues with mounting. The MD3000 is computer controlled - can it be > fooled into working with an older 3208? > > Harry Saddock > 83FC35 > South Windsor, CT > > > > > > ------------------------------------------------------------------------------ > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] > > > > > > Yahoo! Groups Links > > > > > > > > > |
