Rebuilld Flourescent Lights
02-09-2009, 03:11
Why is this under the flourescent heading?
New topic, new heading. Bob Lawrence 84 PT36 Texas > > Is there a source for windshields for a 77fc35 other than the factory? I > have some moderate cracks and rock chips in my windshields. Not enough that > I wanted to replace them today, but I had been planning to buy a set or two > to put aside for a future replacement. > > Dorn Hetzel > 77fc35 > Hogansville, ga > > On Feb 9, 2009 7:28 AM, "Stephen Birtles" > > WE have many Bluebird parts Ballast, inverters, pumps Primus parts > Dump valve parts both new complete and replacement parts > Stainless Exhausts for selected coaches > > Give me a call 888 668 4288 or look on our website dupreeproducts.com > > Thanks Stephen 77 fc35 > > > --- In WanderlodgeForum@yahoogroups.com > "Jack & Donna Smith" > > Flourescent > lights did not > work, ... > |
02-09-2009, 03:40
With respect to the fluorescent light thread, I am about to replace the guts of some of mine with arrays of LED's.
I am going to install the LED's in place of the existing ballast and tubes, but keep the fixture and front diffuser lens, so the process should be reversible if it does not work out. I will report back on results once it's done... Dorn Hetzel 77FC35 Hogansville, GA On Mon, Feb 9, 2009 at 10:11 AM, Bob Lawrence <"bobandarlene@earthlink.net"> wrote:
02-09-2009, 04:21
Stephen has all parts , 888 668 4288
dupreeproducts.com Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Jon" > > Could someone give me the name of the party and his phone number that > deals with light balas fixtures. Thanks Jon > |
02-09-2009, 08:02
the guts > of some of mine with arrays of LED's. > > I am going to install the LED's in place of the existing ballast and tubes, > but keep the fixture and front diffuser lens, so the process should be > reversible if it does not work out. I will report back on results once it's > done... Hey Don, I've been pretty intent on replacing the fluorescents with LEDs for battery life and dry camping reasons. There may however be reliability problems as someone earlier pointed out. LEDs are (forward biased) diodes The power consumed in forward biased diodes goes up very substantially with only moderate increases in voltage. The voltage drop across the LED only increases a little but the current can more than double with a voltage increase from 12v to 14v. This results in a doubling of the power consumed (and heat) with this relatively small voltage increase. This doesn't happen with conventional or fluorescent bulbs. The power only increases a little Depending on what type of charger, inverter set-up you have, you may get as high as 15+volts on your 12 volt lines. Most smart chargers regularly cycle up to 14.5v and 15+ occassionally. At "equalization" voltage, the power dissipated by some LED assemblies could be 4-5 times the 12v they were designed for. Therefore if you want to get reasonable life from the LEDs you have to do one of two things; 1. Segregate your lighting circuits so you don't get the higher voltages that some of the more sophisticated battery charges put out. or 2. Buy voltage tolerant LEDs. I haven't figured out how to segregate the circuits without a LOT of work so, I'm searching for voltage tolerant LEDs' There are two ways LEDs can be voltage tolerant. By putting miltiple LEDs in series the voltage tolerance of each individual LED is improved. The voltage drop across an individual LED is between 0.7-1.2 volts so led lamps that have 8 - 15 individual LEDs are PROBABLY (but no assurance) reasonable voltage tolerant. These have 12 LEDs in each bulb. I've bought a few and they are working well so far. http://www.buylighting.com/LED-1383-R12-...lb-2-Watt- p/led1383-50k.htm I've run across at least one LED module that has a voltage limiting IC incorporated http://www.superbrightleds.com/products/...M-xLX1/1W- Sign_ModulesSC-NHM2.pdf I haven't bought these yet but they should also be highly voltage tolerant. I'm going to try them in the fluorescent fixtures behind the defuser. Regards, GPSGary 1984FC35SB |
