Tail light change
03-07-2009, 13:41
Tail light change
I replaced the galvanized conductorboards (steve could you check the spelling on
that) behind the Lenz. aftermarket- $under 40 each. volvo +70 each and there was
not a difference. my dim lights were a result of poor connections in the
conductorboard and wires from the dash.
200% improvement came when I washed the inside of the lenz. Volvo has access to
the lenz in a weather protected trunk but the bus uses a poor sealing molded
plastic cover for the task. I soaked the removed lenz in mild laundry soap and a
bit of simple green. used pipcleaner to scrub the interior. I then polished the
outside of the lenz with a rag and some clearcoat scratch remover. Chances are
that if it looks dull on the outside it is some old wax or floorwax (underhanded
dealers use floorwax for a deep hide all showroom shine) . I would try floorwax
remover or laundrysoap prior to polishing. often the grit in the polish gums up
the bad wax and folks think they ruined the finish .
Greg ofTim&Greg
94ptRomoland
--- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002"
> Mike: The taillight units are not sealed. They have individual replacement
bulbs in them.
> R.E. (Ron) Marabito, Dallas, Tx 92WB40
> --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote:
> > I am going to replace the tail lights on the Texas Minivan. Mine work fine,
but are scratched and not as shiny as new. As I understand it, the 91 WB40
Wanderlodge uses a Volvo 740 (89-92? tail light).
> > The Bird is in a shop about 5 miles away, so I have not inspected them to
see how they are installed yet. Are they a sealed one-piece unit? Or is the
lens separate from the bulb holder?
> > Anything special to be aware of when swapping these out? Any trimming or
connection issues? If it is a sealed unit, I assume it is just pop the bulbs
and connectors out and swap the tail light body?
> > Just checking before looking for and buying replacements.
> > Thanks for any inputs.
> > Mike Bulriss
> > 1991 WB40 "Texas Minivan"
> > San Antonio, TX
03-09-2009, 02:19
Tail light change
You can also try a new product from Mequires I believe that will polish the lenses.
Scooter 2000 LX Ocqueoc, MI
Date: Sat, 7 Mar 2009 14:44:41 -0600
Subject: RE: [WanderlodgeForum] Tail light change
Mike,
My neighbor polished his plastic headlight covers on his S.O. B. last week with a $20.00 kit he got at harbor Freight and they look pretty good. That might be simpler t than replacements. Hope to see you guys at M.B. next month.
Chet Geist
1981 FC33 (In Clyde's shop right now.)
Austin, Texas
-----Original Message-----
From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of mbulriss
Sent: Saturday, March 07, 2009 12:50 PM
Subject: [WanderlodgeForum] Tail light change
I am going to replace the tail lights on the Texas Minivan. Mine work fine, but are scratched and not as shiny as new. As I understand it, the 91 WB40 Wanderlodge uses a Volvo 740 (89-92? tail light).
The Bird is in a shop about 5 miles away, so I have not inspected them to see how they are installed yet. Are they a sealed one-piece unit? Or is the lens separate from the bulb holder?
Anything special to be aware of when swapping these out? Any trimming or connection issues? If it is a sealed unit, I assume it is just pop the bulbs and connectors out and swap the tail light body?
03-09-2009, 02:22
Tail light change
Mike,
I think you can polish them
Jim Riordan
88 WBWL XXV
Date: Saturday, March 7, 2009, 1:49 PM
Loading...
