Heater rocker switches
06-08-2005, 05:39
They are the same switch, through early '00 I believe. After that,
the change from the original (Chicago?) "shiny" switch to the softer- looking textured-finish. SPDT, Center Off. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > Dan, > A local electronics store should have them. Or, call Bluebird and ask if > they are the same rocker switches as in the 1986 and 1987 PT38. If they > are, the electronics store near my house carries them and I can get them > for you, and cheaper than Bluebird at $8.40 ea. + shipping. Only > difference I found was the finish was bright vs. satin...you can't tell > unless you spend time looking at the them. > > Curt Sprenger `87PT38, Anaheim, Calif. > > Dan Carr wrote: > > > Does anyone know where to find replacements for the off-low-high > > rocker switch for the front heaters and defrosters. The driver's side > > heater switch is defunct and the important (passenger-side) heater > > switch is starting to go (won't turn off without lots of > > manipulation). Switches for the defrosters are also heading south. > > I looked in the parts DB and didn't see anything (but my better half > > says I couldn't find things with two hands and a flashlight) > > > > Any help would be greatly appreciated. > > > > Dan Carr > > 82 PT40 6V92 > > Eastern Ohio > > > > |
