Antifreeze
04-29-2006, 12:57
Antifreeze
I'd start getting my mind right for a reman engine.
Mike Hohnstein ----- Original Message ----- From: mjzakowski To: WanderlodgeForum@yahoogroups.com Sent: Saturday, April 29, 2006 7:34 PM Subject: [WanderlodgeForum] antifreeze I have antifreeze in my oil. How did it get there?? If it is a head gasket, what head could it be? Symptons?? Could it be the oil cooler? How can you tell? or could it be a cylinder gasket? How can one pinpoint the leak of antifreeze into the engine? I would like some input before I take it into a garage so I don't get taken down the pee patch. I live in northern Indiana and would like a good honest garage in or around the area. Joe 1984 1/2 PT 40 SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-29-2006, 14:01
Antifreeze
Joe sorry to hear. My two cents is go to an autheized DD repair place, go to a
number of them talk over the problem see how the shops are run, you may pay more but nothing worse than going thourgh a rebuld twice good luck guy smalley 86 pt 40 --- In WanderlodgeForum@yahoogroups.com, "mjzakowski" <mjzakowski@...> wrote: > > I have antifreeze in my oil. How did it get there?? If it is a head > gasket, what head could it be? Symptons?? Could it be the oil cooler? > How can you tell? or could it be a cylinder gasket? How can one > pinpoint the leak of antifreeze into the engine? > I would like some input before I take it into a garage so I don't get > taken down the pee patch. > I live in northern Indiana and would like a good honest garage in or > around the area. > Joe 1984 1/2 PT 40 > |
04-29-2006, 15:51
Antifreeze
Joe, If you and the previous owners kept a check on the PH I would do
the cheapest gasket repair first. Then test for a leak. If it is a simple gasket prob you got to wonder what event caused the gasket to fail?? Good luck with the leak I hope it is an easy fix. Greg 94pt40 Romoland ca --- In WanderlodgeForum@yahoogroups.com, "mjzakowski" <mjzakowski@...> wrote: > > I have antifreeze in my oil. How did it get there?? If it is a head > gasket, what head could it be? Symptons?? Could it be the oil cooler? > How can you tell? or could it be a cylinder gasket? How can one > pinpoint the leak of antifreeze into the engine? > I would like some input before I take it into a garage so I don't get > taken down the pee patch. > I live in northern Indiana and would like a good honest garage in or > around the area. > Joe 1984 1/2 PT 40 > |
04-29-2006, 16:40
Antifreeze
several possibilities but first do a check. Run a transparent tube
from the overflow tube into a glass jug full of water and watch for bubbles. Bubbles indicate you have leakage between the engine oil and coolant. First check the PH of the coolant now. If its alright then the chances are that either you or the previous owner ran the engine two hot and you have one or more cylinder head sealing rings that are bad. These seal the cylinder liners from the crankcase. If this is the problem you need an inframe rebuilt. tom warner Vernon Center,NY 1985 PT40 r 1. Blown head gasket At 08:34 PM 4/29/2006, you wrote: >I have antifreeze in my oil. How did it get there?? If it is a head >gasket, what head could it be? Symptons?? Could it be the oil cooler? >How can you tell? or could it be a cylinder gasket? How can one >pinpoint the leak of antifreeze into the engine? >I would like some input before I take it into a garage so I don't get >taken down the pee patch. >I live in northern Indiana and would like a good honest garage in or >around the area. >Joe 1984 1/2 PT 40 > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wand...w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Auto...3;veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used...ional\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Auto...vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
04-29-2006, 23:55
Antifreeze
places to look. question,how long ago did you use the coach?has it been sitting all winter in a cold barn or otherwise? detroits when sitting in cold winters can leak past the liners,when it warms up they don't leak.i have a canadian friend that has coolant in his oil every spring,he drains the coolant out of the oil and drives it all summer,no problems. BUT! you need to drain all that coolant out of the oil pan before you run the engine,coolant and oil do not mix and coolant does not lube well,you can ruin your engine,be very careful. randy dupree > > Joe, If you and the previous owners kept a check on the PH I would do > the cheapest gasket repair first. Then test for a leak. If it is a > simple gasket prob you got to wonder what event caused the gasket to > fail?? Good luck with the leak I hope it is an easy fix. > > Greg > 94pt40 Romoland ca > > --- In WanderlodgeForum@yahoogroups.com, "mjzakowski" <mjzakowski@> > wrote: > > > > I have antifreeze in my oil. How did it get there?? If it is a head > > gasket, what head could it be? Symptons?? Could it be the oil > cooler? > > How can you tell? or could it be a cylinder gasket? How can one > > pinpoint the leak of antifreeze into the engine? > > I would like some input before I take it into a garage so I don't get > > taken down the pee patch. > > I live in northern Indiana and would like a good honest garage in or > > around the area. > > Joe 1984 1/2 PT 40 > > > |
04-30-2006, 14:30
Antifreeze
What engine? cat or Detroit?
re brake 1983 FC-35 sb "sagecoach" -------------- Original message from "Mike Hohnstein" <MHOHNSTEIN@...>: -------------- > I'd start getting my mind right for a reman engine. > Mike Hohnstein > ----- Original Message ----- > From: mjzakowski > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, April 29, 2006 7:34 PM > Subject: [WanderlodgeForum] antifreeze > > > I have antifreeze in my oil. How did it get there?? If it is a head > gasket, what head could it be? Symptons?? Could it be the oil cooler? > How can you tell? or could it be a cylinder gasket? How can one > pinpoint the leak of antifreeze into the engine? > I would like some input before I take it into a garage so I don't get > taken down the pee patch. > I live in northern Indiana and would like a good honest garage in or > around the area. > Joe 1984 1/2 PT 40 > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive > radiators > > > ------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------------------ > > > > [Non-text portions of this message have been removed] > > > > > Yahoo! Groups Links > > > > > > [Non-text portions of this message have been removed] |
04-30-2006, 14:58
Antifreeze
Tom, how about explaining your statement ". Bubbles indicate you have
leakage between the engine oil and coolant. ". I am not a diesel mechanic especially a two stroke type, but, I am a pretty good gas burner mechanic. Bubbles in the coolant of a gas burner almost always indicates a blown head gasket allowing compression pressure to overcome the 7# or so coolant pressure and escape into the coolant. You can usually see these bubbles of gas excaping in the coolant overflow container. Depending on the configuration of the cylinder head for oil drainback and distribution to the valve train, you could see some pressure and or blow by in the crankcase from the compression gases. Not being familiar with the two stroke DD configuration, I will not venture an opinion on Joe's problem other than "stay away from the shade trees". Jerry MS Gulf Coast Looking _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Tom Warner Sent: Saturday, April 29, 2006 11:41 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] antifreeze several possibilities but first do a check. Run a transparent tube from the overflow tube into a glass jug full of water and watch for bubbles. Bubbles indicate you have leakage between the engine oil and coolant. First check the PH of the coolant now. If its alright then the chances are that either you or the previous owner ran the engine two hot and you have one or more cylinder head sealing rings that are bad. These seal the cylinder liners from the crankcase. If this is the problem you need an inframe rebuilt. tom warner Vernon Center,NY 1985 PT40 r 1. Blown head gasket At 08:34 PM 4/29/2006, you wrote: >I have antifreeze in my oil. How did it get there?? If it is a head >gasket, what head could it be? Symptons?? Could it be the oil cooler? >How can you tell? or could it be a cylinder gasket? How can one >pinpoint the leak of antifreeze into the engine? >I would like some input before I take it into a garage so I don't get >taken down the pee patch. >I live in northern Indiana and would like a good honest garage in or >around the area. >Joe 1984 1/2 PT 40 > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> &k=Recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automoti ve+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles& w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> &k=Wanderlodge&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotive+mainten ance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w6=Automot ive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>Wanderlodge ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> &k=Automotive+maintenance&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automot ive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles &w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy34cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> &k=Recreational+vehicle+dealer&w1=Recreational+vehicles&w2=Wanderlodge&w3=Au tomotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+veh icles&w6=Automotive+radiators&c=6&s=163&.sig=z6_XahaeYHfELr6o72IW1A>Recreati onal >vehicle dealer ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> &k=Used+recreational+vehicles&w1=Recreational+vehicles&w2=Wanderlodge&w3=Aut omotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehi cles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L-kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> &k=Automotive+radiators&w1=Recreational+vehicles&w2=Wanderlodge&w3=Automotiv e+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recreational+vehicles&w 6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnMq_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > derlodgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- SPONSORED LINKS Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dea ler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAU kCKkU7Dzhn_ObWmSYTw> vehicles Wanderlodge <http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2 =Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Use d+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLP j9U0JvqYQ> Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+ vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+de aler&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF 4u_5wI8Pmy34cC1O9CxA> maintenance Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreati onal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehic le+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.s ig=z6_XahaeYHfELr6o72IW1A> vehicle dealer Used <http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreatio nal+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicl e+dealer&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.si g=UGEY5km4L-kXbDI4ZSadEw> recreational vehicles Automotive <http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+ve hicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNV MmISsCWgTnMq_4GlXA> radiators _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed] |
07-27-2006, 11:29
Antifreeze
When changing antifreeze in a DD 8V92 what is best Ethylene Glycol or Propylene
Glycol and what is the difference. Thanks, Howard Truitt Camilla, Ga. 86 8V92 PT40 [Non-text portions of this message have been removed] |
09-21-2007, 13:58
Antifreeze
Is it OK to use premix (Peak) 50/50 glycol antifreeze in a series 60 if
I add the proper amount of Nalcool 3000 (SCA's) to the mix? I will confirm freeze, and nitrites with a test strip. I want to change coolant. Any pros, or cons with my intentions? Thanks |
09-21-2007, 14:36
Antifreeze
You may want to take a look at:
http://www.detroitdiesel.com/pdf/vocatio...ctions.pdf Many automotive antifreeze mixtures contain phosphorus and silicates. As the above document decribes, these components are not suitable for Series 60 applications. David Brady '02 LXi, NC somervillebus wrote: > > Is it OK to use premix (Peak) 50/50 glycol antifreeze in a series 60 if > I add the proper amount of Nalcool 3000 (SCA's) to the mix? I will > confirm freeze, and nitrites with a test strip. I want to change > coolant. Any pros, or cons with my intentions? > > Thanks > > __. > [Non-text portions of this message have been removed] |
