I really don't know how long it takes to air my coach up with the engine because I never do it that way. My startup procedure involves using both block heater and aux air pump from the time I get up on any morning I'm going to travel - that way I can just start and almost immediately roll.
Don Bradner
90 PT40 "Blue Thunder"
My location:
http://www.bbirdmaps.com/user2.cfm?user=1
On 1/10/2011 at 2:44 PM jamiejbrandt wrote:
>THANKS IT WAS VERY HELPFUL IM GOING TO GET THE PARTS TODAY
>DON HOW LONG DOSE IT TAKE FOR YOUR RV TO REACH FULL PRESSURE
>I HEAR AIR FROM UNDER THE FRONT RIGHT BEHIND THE GENNY ABOUT IN THE CENTER
>AND I LOOKED AND I DO SEE SOME KIND OF VALVES BUT IM LEARY OF GETTING TO
>FAR UNDER THE RV AND SCREWING WITH THEM I NEED TO FIND A COMPANY THAT
>DOSE THIS I GUESS ANYWAY THANKS AGAIN
>JAMIE BRANDT
>1990 WB40
>FLORIDA
>--- In
WanderlodgeForum@yahoogroups.com, "Don Bradner"
>wrote:
>> The switch/valves are Clippard MJTV-4, still available from the
>manufacturer:
>> http://www.clippard.com/store/display_de...sku=MJTV-4
>> I've replaced both of mine as they leaked in increasing fashion.
>> Those small leaks, though, won't cause the problem you are seeing. You
>have a significant leak somewhere, probably in the air bag system, or in
>the brakes.
>> You have two air gaugues. One is for the tag-axle air bags, and the
>other is for the brakes front and rear (two needles). If you shut down,
>both of those should hold air for a significant amount of time. If they
>do, then the problem is elsewhere.
>> When I first got mine, the front air bags would significantly drop in
>less than 15 minutes. I'm not the one who fixed it, but I'm told that the
>leveler valve was actually coming apart. Point, though, is that one way or
>another shutting down when you have full air should show a symptom
>somewhere.
>> Don Bradner
>> My location: http://www.bbirdmaps.com/user2.cfm?user=1
>> On 1/8/2011 at 8:40 PM jamiejbrandt wrote:
>> >I HAVE A 1990 WB40 AND WHEN I START IT IT TAKES ALONG TIME TO BUILD UP
>> >AIR ATLEAST I THINK ITS ALONG TIME ITS NEW TO ME AND IM NOT SURE HOW
>LONG
>> >IT SHOULD TAKE
>> >ALSO I HAVE TO PUT IT IN HIGH RPM TO GET IT TO GO UP
>> >AFTER I GET IT UP TO ABOUT 115 WHEN I BACK OUT OF DRIVEWAY BY THE TIME I
>> >GET IT TO THE ROAD IT DROPS TO 80 THE ONLY TIME IT STAYS HIGH IS ON THE
>> >ROAD AT A GOOD SPEED IS THIS NORMAL
>> >ALSO THE HOSES AND THE SWITCH PLATE FOR THE GREY AND BLACK WATER DUMP IS
>> >LEAKING A BIT NOT THAT BAD DOES ANYONE KNOW WHERE TO GET REPLACMENT
>PARTS
>> >ALL HELP IS APPRCIATED THANKS
>> >JAMIE BRANDT
>> >1990 WB40
>> >FLORIDA
>Yahoo! Groups Links
