M450 Steer Tire BlowOut
01-27-2015, 13:21
Post: #21
RE: M450 Steer Tire BlowOut
(01-27-2015 12:48)davidbrady Wrote: Hi Chuck, Thanks David, I guess I could have looked myself but I never thought it would be in the owners manual. It appears the wheel cut is not that severe. Chuck & Tela Millsap 2003 Prevost Marathon XLII 2000 LXi #2 S/S (Sold) 2004 M380 D/S (Sold) 2000 LXi #1 N/S (Sold |
01-27-2015, 13:27
Post: #22
No problem at all Chuck. I just like to show folks where the numbers came from to add a bit of credibility. I'd like to get some information on the TRW THP-90 power steering gear box; interestingly, the web seems to be scoured of all THP-90 documents or specs.
01-27-2015, 15:15
(This post was last modified: 01-27-2015 16:06 by travelite.)
Post: #23
Just an FYI. Although I can't find a steer axle weight capacity spec for the TRW THP-90 steering gear box, I do see that at some point parts were available for a dual circuit option on the THP-90 allowing for an external power hydraulic assist cylinder similar to the implementation on my H3, as pointed out in post 7 of this thread. Of course hydraulic pump flow rates and pressures need to be up to the task. (Not to convey that this is the issue, but for folks who are interested this might be a lead worth following).
