Towing
03-03-2009, 06:13
Post: #21
Towing
This might help: http://www2.dana.com/pdf/AXSM-8942.pdf "AFTER OVERHAUL OR CHANGE INTERVALS Fill the axle assembly to the bottom of housing fill hole as shown in the illustration below. It is recommended that following an overhaul, each side of the axle be jacked up seperately to approximately six inches and held into position for one minute. This procedure will allow adequate lubricant to flow into the wheel ends and help eliminate the possibility of premature damage to wheel bearings and seals. Lower the vehicle to the floor and allow ten minutes for lube to return to normal level. Check and refill assembly to bottom of fill hole to replace the lubricant that was directed into the wheel ends." David '02 LXi, NC timvasqz wrote:
04-13-2010, 12:35
Post: #22
Towing
Anyone towing a Dodge Ram 2500 quad cab 4x4 8' bed diesel PU or similar type
vehicle 4 wheels down? Weighs in at 6000 lbs empty, has been set up to for towing using Roadmaster towbar rated at over 8ooo lbs. Was originally intended to be towed by 2004 Winnebago Journey 32' diesel pusher, a task Winnebago sales people gauranteed was capable of. Winnebago is too short, too light and Dodge too heavy, steering too stiff, result an unsafe combination. Are any 3-axel 40' Bluebird diesel pushers safely capable of such a task? |
04-13-2010, 12:58
Post: #23
Towing
>Are any 3-axle 40' Bluebird diesel pushers safely capable
>of such a task? In a word: Yes. Especially with the 8V92 or Series 60. Keep the rear view camera on so you know it is back there. Don't know about your specific model, but many of our members tow Jeep Grand Cherokees, Suburbans, Hummers, or large trailers. One of our Lone Star Bird members regularly towed a 24 foot enclosed trailer with race car, spare parts, golf cart, etc. (~10k lbs) with no problems. Ernie towed a 1-ton(?) work van full of tools, on a trailer, with his 6V92 PT40, so the weight is not a problem. The hitch receiver assembly on the Birds is 10,000 lb rated as I recall. It is not just the PT models that are capable of this. Many of our FC members are pulling some pretty stout loads. Ralph pulled a 24' enclosed trailer all over the country with his. Welcome to the forum and happy hunting for a Bird. Please sign your posts so we know who we are chatting with. Thanks, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Stuart" > > Anyone towing a Dodge Ram 2500 quad cab 4x4 8' bed diesel PU or similar type vehicle 4 wheels down? Weighs in at 6000 lbs empty, has been set up to for towing using Roadmaster towbar rated at over 8ooo lbs. Was originally intended to be towed by 2004 Winnebago Journey 32' diesel pusher, a task Winnebago sales people gauranteed was capable of. Winnebago is too short, too light and Dodge too heavy, steering too stiff, result an unsafe combination. Are any 3-axel 40' Bluebird diesel pushers safely capable of such a task? > |
04-13-2010, 17:18
Post: #24
Towing
Stuart, I frequently pulled a skidloader and alot of equipment on a double axle trailer. The total trailer and load weighed in at about10,000 pounds and I had a 1985 Wanderlodge PT40. The coach handled it with ease and other than seeingthe trailerin the camera and in the mirrors I could not tell it was back there. I now have a 1996 Wanderlodge PT42 and plan on pulling a Dodge Ram 2500 4x4 quad cab with a short box and based on my previous heavy load towing experience with a Wanderlodge, I think it will be just fine.
Good Luck
Wayne
96PT42
From: Stuart To: WanderlodgeForum@yahoogroups.com Sent: Tue, April 13, 2010 7:35:30 PM Subject: [WanderlodgeForum] Towing Anyone towing a Dodge Ram 2500 quad cab 4x4 8' bed diesel PU or similar type vehicle 4 wheels down? Weighs in at 6000 lbs empty, has been set up to for towing using Roadmaster towbar rated at over 8ooo lbs. Was originally intended to be towed by 2004 Winnebago Journey 32' diesel pusher, a task Winnebago sales people gauranteed was capable of. Winnebago is too short, too light and Dodge too heavy, steering too stiff, result an unsafe combination. Are any 3-axel 40' Bluebird diesel pushers safely capable of such a task? |
04-13-2010, 23:30
Post: #25
Towing
04-13-2010, 23:34
Post: #26
Towing
Ernie,
Is your towing setup the "factory setup" or did you have it altered? I'm just wondering because the owners manual/documents for m 82 list the towing rated at 7500 lbs, not 10,000 lbs. I realize they could have upgraded it from one year to the next, but that would surprise me a little considering 83 was only the second year of the pushers. Markus 82 PT40 ________________________________ > To: WanderlodgeForum@yahoogroups.com > From: ernietex@... > Date: Wed, 14 Apr 2010 04:30:22 -0700 > Subject: Re: [WanderlodgeForum] Towing > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > I know of quite a few that tow some heavy loads behind their pushers- like me. I tow a 1 ton van full of tools on a flatbed car hauler. My coach is rated at 10,000 pounds and I'm close to that. Mike Kane tows his 1 ton Chevy pickup 4 down. > > > Ernie Ekberg > > 83PT40 > > Wanderlodge > > Weatherford, Tx 817-475-3991 > > http://www.ernieekbergflooring.net > > > --- On Tue, 4/13/10, Stuart wrote: > > > From: Stuart > Subject: [WanderlodgeForum] Towing > To: WanderlodgeForum@yahoogroups.com > Date: Tuesday, April 13, 2010, 7:35 PM > > > > > Anyone towing a Dodge Ram 2500 quad cab 4x4 8' bed diesel PU or similar type vehicle 4 wheels down? Weighs in at 6000 lbs empty, has been set up to for towing using Roadmaster towbar rated at over 8ooo lbs. Was originally intended to be towed by 2004 Winnebago Journey 32' diesel pusher, a task Winnebago sales people gauranteed was capable of. Winnebago is too short, too light and Dodge too heavy, steering too stiff, result an unsafe combination. Are any 3-axel 40' Bluebird diesel pushers safely capable of such a task? > > > > > > > > > > > > > > > > _________________________________________________________________ Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. http://www.windowslive.com/campaign/then...WL:en\ -US:WM_HMP:042010_2 |
04-13-2010, 23:56
Post: #27
Towing
04-14-2010, 04:32
Post: #28
Towing
Markus,
82/83 was before they started putting receiver assemblies on the Birds. I think the actual platform hitch assembly was the same on both as I recall. Could be that the load rating difference you are reporting be related to the fact that the 82PT had the 6V92 "Red" engine rated at 300HP and the 83 PT had the 6V92 "Silver: at 330HP (and more torque). Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, Markus Meyer > > > Ernie, > > Is your towing setup the "factory setup" or did you have it altered? I'm just wondering because the owners manual/documents for m 82 list the towing rated at 7500 lbs, not 10,000 lbs. I realize they could have upgraded it from one year to the next, but that would surprise me a little considering 83 was only the second year of the pushers. > > > Markus > 82 PT40 > > > > ________________________________ > > To: WanderlodgeForum@yahoogroups.com > > From: ernietex@... > > Date: Wed, 14 Apr 2010 04:30:22 -0700 > > Subject: Re: [WanderlodgeForum] Towing > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > I know of quite a few that tow some heavy loads behind their pushers- like me. I tow a 1 ton van full of tools on a flatbed car hauler. My coach is rated at 10,000 pounds and I'm close to that. Mike Kane tows his 1 ton Chevy pickup 4 down. > > > > > > Ernie Ekberg > > > > 83PT40 > > > > Wanderlodge > > > > Weatherford, Tx 817-475-3991 > > > > http://www.ernieekbergflooring.net > > > > > > --- On Tue, 4/13/10, Stuart wrote: > > > > > > From: Stuart > > Subject: [WanderlodgeForum] Towing > > To: WanderlodgeForum@yahoogroups.com > > Date: Tuesday, April 13, 2010, 7:35 PM > > > > > > > > > > Anyone towing a Dodge Ram 2500 quad cab 4x4 8' bed diesel PU or similar type vehicle 4 wheels down? Weighs in at 6000 lbs empty, has been set up to for towing using Roadmaster towbar rated at over 8ooo lbs. Was originally intended to be towed by 2004 Winnebago Journey 32' diesel pusher, a task Winnebago sales people gauranteed was capable of. Winnebago is too short, too light and Dodge too heavy, steering too stiff, result an unsafe combination. Are any 3-axel 40' Bluebird diesel pushers safely capable of such a task? > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > _________________________________________________________________ > Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. > http://www.windowslive.com/campaign/then...WL:en\ -US:WM_HMP:042010_2 > |
04-14-2010, 05:21
Post: #29
Towing
Not a Dodge but I tow a Tahoe 5,600lbs loaded with books and work related items AND aplatform 5x4 with two Yamaha scooters tied down on back and mylimit is close. The Bird doesn't know the difference between that set up or nothing to the milage maybe .5 miles per gallon on a M11450 Cummins
Scooter 2000LX Michigan To: WanderlodgeForum@yahoogroups.com From: stuart42@... Date: Wed, 14 Apr 2010 00:35:30 +0000 Subject: [WanderlodgeForum] Towing
04-14-2010, 06:35
Post: #30
Towing
Could very well be. I don't have the coach here to look at it myself, but the
pics I have do make it look more like a "bumper hitch", than the true receiver/tubular style hitch. I'll know better in a few weeks when I can get up close and personal with it. You are right though, mine is the "red" engine from what I can tell in the documentation, although I've been told its "tweaked" and puts out more than 300hp, something I will never verify or care to have verified! Markus 82 PT40 ________________________________ > To: WanderlodgeForum@yahoogroups.com > From: mbulriss@... > Date: Wed, 14 Apr 2010 16:32:59 +0000 > Subject: [WanderlodgeForum] Re: Towing > > > Markus, > > > > 82/83 was before they started putting receiver assemblies on the Birds. I think the actual platform hitch assembly was the same on both as I recall. Could be that the load rating difference you are reporting be related to the fact that the 82PT had the 6V92 "Red" engine rated at 300HP and the 83 PT had the 6V92 "Silver: at 330HP (and more torque). > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, Markus Meyer wrote: > >> > >> > >> Ernie, > >> > >> Is your towing setup the "factory setup" or did you have it altered? I'm just wondering because the owners manual/documents for m 82 list the towing rated at 7500 lbs, not 10,000 lbs. I realize they could have upgraded it from one year to the next, but that would surprise me a little considering 83 was only the second year of the pushers. > >> > >> > >> Markus > >> 82 PT40 > >> > >> > >> > >> ________________________________ > >>> To: WanderlodgeForum@yahoogroups.com > >>> From: ernietex@... > >>> Date: Wed, 14 Apr 2010 04:30:22 -0700 > >>> Subject: Re: [WanderlodgeForum] Towing > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> I know of quite a few that tow some heavy loads behind their pushers- like me. I tow a 1 ton van full of tools on a flatbed car hauler. My coach is rated at 10,000 pounds and I'm close to that. Mike Kane tows his 1 ton Chevy pickup 4 down. > >>> > >>> > >>> Ernie Ekberg > >>> > >>> 83PT40 > >>> > >>> Wanderlodge > >>> > >>> Weatherford, Tx 817-475-3991 > >>> > >>> http://www.ernieekbergflooring.net > >>> > >>> > >>> --- On Tue, 4/13/10, Stuart wrote: > >>> > >>> > >>> From: Stuart > >>> Subject: [WanderlodgeForum] Towing > >>> To: WanderlodgeForum@yahoogroups.com > >>> Date: Tuesday, April 13, 2010, 7:35 PM > >>> > >>> > >>> > >>> > >>> Anyone towing a Dodge Ram 2500 quad cab 4x4 8' bed diesel PU or similar type vehicle 4 wheels down? Weighs in at 6000 lbs empty, has been set up to for towing using Roadmaster towbar rated at over 8ooo lbs. Was originally intended to be towed by 2004 Winnebago Journey 32' diesel pusher, a task Winnebago sales people gauranteed was capable of. Winnebago is too short, too light and Dodge too heavy, steering too stiff, result an unsafe combination. Are any 3-axel 40' Bluebird diesel pushers safely capable of such a task? > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >> __________________________________________________________ > >> Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. > >> http://www.windowslive.com/campaign/then...WL:en\ -US:WM_HMP:042010_2 > >> > > > > > > > > > > > > > > > > > _________________________________________________________________ The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail. http://www.windowslive.com/campaign/then...8326:\ :T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_5 |
