PT36 retarder & other things
08-23-2007, 13:21
Post: #21
Yeah, but a Jake on a 892, whata beautiful noise.
MH ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 23, 2007 4:25 PM Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things Howard, you sure can. I have two verbal bids for a Jake Brake addition on my 8v92 DDEC II. $9,500 and $9,000. Non -DDEC systems may be slightly cheaper, around $6-8,000. I did not want to buy a new bus, I just wanted a Jake brake. lol Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Howard O. Truitt To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 23, 2007 5:10 PM Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things Shane, Could you add a jacob brake and have both a retarder and a jake brake. Howard T., Sowega, 86 PT40 ----- Original Message ----- From: sfedeli3 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 23, 2007 11:31 AM Subject: [WanderlodgeForum] Re: PT36 retarder & other things Hi All, My tranny reading is regularly 230 degrees. Of course, it could be a faulty sending unit, but my engine oil temp is around the same too, if not a little warmer. I would expect both oil sumps to be pretty close in temperature and seem to recall the blue book indicating that 200 to 250 was the normal operating temp for the Allison that I have. In any event, I change the fluid annually. It's relatively cheap and easy to do on the mid-80's PT models. You just need a BIG bucket. Varying brands of tranny fluid have different flash points and additives. I've been using Lubrication Engineers [http://www.le-inc.com] 7500 MONOLEC® Power Fluid in numerous vehicles for a number of years with great results and never smell burned fluid when I drain. If you're really concerned about the tranny temps, or drive the western Rockies, get a Jacobs Engine Retarder. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > I found this on another website: > > Why Atf Wears Out > An automatic transmission creates a lot of internal heat through friction: the friction of the > fluid churning inside the torque converter, friction created when the clutch plates engage, > and the normal friction created by gears and bearings carrying their loads. > > It doesn't take long for the automatic transmission fluid (ATF) to heat up once the vehicle > is in motion. Normal driving will raise fluid temperatures to 175 degrees F., which is the > usual temperature range at which most fluids are designed to operate. If fluid > temperatures can be held to 175 degrees F., ATF will last almost indefinitely -- say up to > 100,000 miles. But if the fluid temperature goes much higher, the life of the fluid begins > to plummet. The problem is even normal driving can push fluid temperatures well beyond > safe limits. And once that happens, the trouble begins. > > At elevated operating temperatures, ATF oxidizes, turns brown and takes on a smell like > burnt toast. As heat destroys the fluid's lubricating qualities and friction characteristics, > varnish begins to form on internal parts (such as the valve body) which interferes with the > operation of the transmission. If the temperature gets above 250 degrees F., rubber seals > begin to harden, which leads to leaks and pressure losses. At higher temperatures the > transmission begins to slip, which only aggravates overheating even more. Eventually the > clutches burn out and the transmission calls it quits. The only way to repair the damage > now is with an overhaul -- a job which can easily run upwards of $1500 on a late model > front-wheel drive car or minivan. > > As a rule of thumb, every 20 degree increase in operating temperature above 175 degrees > F. cuts the life of the fluid in half! > > At 195 degrees F., for instance, fluid life is reduced to 50,000 miles. At 220 degrees, > which is commonly encountered in many transmissions, the fluid is only good for about > 25,000 miles. At 240 degrees F., the fluid won't go much over 10,000 miles. Add another > 20 degrees, and life expectancy drops to 5,000 miles. Go to 295 or 300 degrees F., and > 1,000 to 1,500 miles is about all you'll get before the transmission burns up. > > > Kerry > 82 FC 35 > Denver > > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > wrote: > > > > Those temperatures seem really high to me. I was looking at hose temperature ratings > > and fluid temperature ratings when I was redoing my power steering. My recollection is > > that standard hydraulic hose was rated to 250 degrees and the expensive high > > temperature hose was rated to 325 or 350. I think regular transmission fluid was rated > as > > functional up to about 250 degrees and synthetics up to about 350. These numbers are > > from my memory, If anyone else has knowledge about the functional temperatures of > > transmission fluid, I'd like to know. I'd be quite concerned with temperatures over 300 > > degrees. > > > > Kerry > > 82 FC 35 > > Denver > > > > be sure to keep it below > > > 320-330 degrees or you'll shorten the life of the tranny fluid > > > greatly. Most commercial bus drivers have to change the tranny fluid > > > every 50K miles when using the tranny retarder often. Mine easily goes > > > from 230 to 300 degrees when descending a steep off-ramp. One way to > > > slow the heat is to engage the fan override and let the hydro fan rob > > > 25-30 horses from the engine and cool the tranny fluid a little > > > quicker. On an off-ramp it does not make much difference, but on the 3 > > > or 4 mile grade, you can usually make it to the bottom under 320 > > > degrees if you also use the service brakes along with the tranny brake > > > and fan to slow the coach down. > > > Shane Fedeli > > > 85PT40 > > > Hershey, PA > > > > > > > > > ---------------------------------------------------------- No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.476 / Virus Database: 269.12.2/966 - Release Date: 8/22/2007 9:05 AM [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
08-23-2007, 13:23
Post: #22
Reference using an engine brake and a tranny retarder together, keep in mind
that the engine brake slows the coach by increased engine braking, and the primary connection between the engine and tires is the input shaft on the tranny. The tranny retarder slows the coach at the tranny, no additional strain on the tranny input shaft. Use both and since there is no syncronization (s.p.?) between the braking forces, the transmission may try to "outrun" the engine that is trying to brake, resulting in excess strain on the tranny input shaft and breakage thereof. Simply put, the engine brake does not talk to the tranny retarder, so they may get in a fight and the tranny input shaft will be the loser. Still trying to build a coach up to BB standards, I think I'm losing, but I have posted some new pics. http://ImageEvent.com/reddog/1990thomasbuiltbusdogbus Doug in Colorado Richard Hayden Here's what the Allison Operator's Manual says on page 18, in a Caution box at the bottom of the page: "DO NOT OPERATE THE INPUT OR OUTPUT RETARTDER SIMULTANEOUSLY WITH AN ENGINE EXHAUST BRAKE. Extreme torque loads can be produced in the range section, damaging the transmission". Leroy may have some other information on this. I know he was looking into doing this very thing. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Richard Hayden To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 23, 2007 3:57 PM Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things I don't know Ernie. It's arranged the same on mine. The Allison Operator's Manual simply states not to use them together with no expansion on that. I did operate the bus using both at first until I got my hands on an Operator's Manual, no more. Maybe one of gurus can offer something. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: erniecarpet@... To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 23, 2007 3:45 PM Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things I wonder why the Allison manual says to not use the Jake and transmission retarder together? The jake on my coach is exhaust. The tranny retarder is on the transmission. Ernie Ekberg 83PT40 Livingston, Mt ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour<http://discover.aol.com/memed/aolcom3\ 0tour><http://discover.aol.com/memed/aolcom30tour<http://discover.aol.com/memed/\ aolcom30tour>> [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] Doug Engel, Gunnison, CO. Bird Usta Be, now 1990 Thomas Skoolie, "Hormone Derange" --------------------------------- Be a better Heartthrob. Get better relationship answers from someone who knows. Yahoo! Answers - Check it out. [Non-text portions of this message have been removed] |
08-24-2007, 05:58
Post: #23
Oh boy, Ben might be listening and want that recorded!
Troy ----- Original Message ----- From: Mike Hohnstein To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 23, 2007 8:21 PM Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things Yeah, but a Jake on a 892, whata beautiful noise. MH ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 23, 2007 4:25 PM Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things Howard, you sure can. I have two verbal bids for a Jake Brake addition on my 8v92 DDEC II. $9,500 and $9,000. Non -DDEC systems may be slightly cheaper, around $6-8,000. I did not want to buy a new bus, I just wanted a Jake brake. lol Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Howard O. Truitt To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 23, 2007 5:10 PM Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things Shane, Could you add a jacob brake and have both a retarder and a jake brake. Howard T., Sowega, 86 PT40 ----- Original Message ----- From: sfedeli3 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 23, 2007 11:31 AM Subject: [WanderlodgeForum] Re: PT36 retarder & other things Hi All, My tranny reading is regularly 230 degrees. Of course, it could be a faulty sending unit, but my engine oil temp is around the same too, if not a little warmer. I would expect both oil sumps to be pretty close in temperature and seem to recall the blue book indicating that 200 to 250 was the normal operating temp for the Allison that I have. In any event, I change the fluid annually. It's relatively cheap and easy to do on the mid-80's PT models. You just need a BIG bucket. Varying brands of tranny fluid have different flash points and additives. I've been using Lubrication Engineers [http://www.le-inc.com] 7500 MONOLEC® Power Fluid in numerous vehicles for a number of years with great results and never smell burned fluid when I drain. If you're really concerned about the tranny temps, or drive the western Rockies, get a Jacobs Engine Retarder. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > I found this on another website: > > Why Atf Wears Out > An automatic transmission creates a lot of internal heat through friction: the friction of the > fluid churning inside the torque converter, friction created when the clutch plates engage, > and the normal friction created by gears and bearings carrying their loads. > > It doesn't take long for the automatic transmission fluid (ATF) to heat up once the vehicle > is in motion. Normal driving will raise fluid temperatures to 175 degrees F., which is the > usual temperature range at which most fluids are designed to operate. If fluid > temperatures can be held to 175 degrees F., ATF will last almost indefinitely -- say up to > 100,000 miles. But if the fluid temperature goes much higher, the life of the fluid begins > to plummet. The problem is even normal driving can push fluid temperatures well beyond > safe limits. And once that happens, the trouble begins. > > At elevated operating temperatures, ATF oxidizes, turns brown and takes on a smell like > burnt toast. As heat destroys the fluid's lubricating qualities and friction characteristics, > varnish begins to form on internal parts (such as the valve body) which interferes with the > operation of the transmission. If the temperature gets above 250 degrees F., rubber seals > begin to harden, which leads to leaks and pressure losses. At higher temperatures the > transmission begins to slip, which only aggravates overheating even more. Eventually the > clutches burn out and the transmission calls it quits. The only way to repair the damage > now is with an overhaul -- a job which can easily run upwards of $1500 on a late model > front-wheel drive car or minivan. > > As a rule of thumb, every 20 degree increase in operating temperature above 175 degrees > F. cuts the life of the fluid in half! > > At 195 degrees F., for instance, fluid life is reduced to 50,000 miles. At 220 degrees, > which is commonly encountered in many transmissions, the fluid is only good for about > 25,000 miles. At 240 degrees F., the fluid won't go much over 10,000 miles. Add another > 20 degrees, and life expectancy drops to 5,000 miles. Go to 295 or 300 degrees F., and > 1,000 to 1,500 miles is about all you'll get before the transmission burns up. > > > Kerry > 82 FC 35 > Denver > > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > wrote: > > > > Those temperatures seem really high to me. I was looking at hose temperature ratings > > and fluid temperature ratings when I was redoing my power steering. My recollection is > > that standard hydraulic hose was rated to 250 degrees and the expensive high > > temperature hose was rated to 325 or 350. I think regular transmission fluid was rated > as > > functional up to about 250 degrees and synthetics up to about 350. These numbers are > > from my memory, If anyone else has knowledge about the functional temperatures of > > transmission fluid, I'd like to know. I'd be quite concerned with temperatures over 300 > > degrees. > > > > Kerry > > 82 FC 35 > > Denver > > > > be sure to keep it below > > > 320-330 degrees or you'll shorten the life of the tranny fluid > > > greatly. Most commercial bus drivers have to change the tranny fluid > > > every 50K miles when using the tranny retarder often. Mine easily goes > > > from 230 to 300 degrees when descending a steep off-ramp. One way to > > > slow the heat is to engage the fan override and let the hydro fan rob > > > 25-30 horses from the engine and cool the tranny fluid a little > > > quicker. On an off-ramp it does not make much difference, but on the 3 > > > or 4 mile grade, you can usually make it to the bottom under 320 > > > degrees if you also use the service brakes along with the tranny brake > > > and fan to slow the coach down. > > > Shane Fedeli > > > 85PT40 > > > Hershey, PA > > > > > > > > > ---------------------------------------------------------- No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.476 / Virus Database: 269.12.2/966 - Release Date: 8/22/2007 9:05 AM [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
08-24-2007, 05:59
Post: #24
Have you tried locating a used system from a truck salvage yard?
Troy ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 23, 2007 5:25 PM Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things Howard, you sure can. I have two verbal bids for a Jake Brake addition on my 8v92 DDEC II. $9,500 and $9,000. Non -DDEC systems may be slightly cheaper, around $6-8,000. I did not want to buy a new bus, I just wanted a Jake brake. lol Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Howard O. Truitt To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 23, 2007 5:10 PM Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things Shane, Could you add a jacob brake and have both a retarder and a jake brake. Howard T., Sowega, 86 PT40 ----- Original Message ----- From: sfedeli3 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 23, 2007 11:31 AM Subject: [WanderlodgeForum] Re: PT36 retarder & other things Hi All, My tranny reading is regularly 230 degrees. Of course, it could be a faulty sending unit, but my engine oil temp is around the same too, if not a little warmer. I would expect both oil sumps to be pretty close in temperature and seem to recall the blue book indicating that 200 to 250 was the normal operating temp for the Allison that I have. In any event, I change the fluid annually. It's relatively cheap and easy to do on the mid-80's PT models. You just need a BIG bucket. Varying brands of tranny fluid have different flash points and additives. I've been using Lubrication Engineers [http://www.le-inc.com] 7500 MONOLEC® Power Fluid in numerous vehicles for a number of years with great results and never smell burned fluid when I drain. If you're really concerned about the tranny temps, or drive the western Rockies, get a Jacobs Engine Retarder. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > I found this on another website: > > Why Atf Wears Out > An automatic transmission creates a lot of internal heat through friction: the friction of the > fluid churning inside the torque converter, friction created when the clutch plates engage, > and the normal friction created by gears and bearings carrying their loads. > > It doesn't take long for the automatic transmission fluid (ATF) to heat up once the vehicle > is in motion. Normal driving will raise fluid temperatures to 175 degrees F., which is the > usual temperature range at which most fluids are designed to operate. If fluid > temperatures can be held to 175 degrees F., ATF will last almost indefinitely -- say up to > 100,000 miles. But if the fluid temperature goes much higher, the life of the fluid begins > to plummet. The problem is even normal driving can push fluid temperatures well beyond > safe limits. And once that happens, the trouble begins. > > At elevated operating temperatures, ATF oxidizes, turns brown and takes on a smell like > burnt toast. As heat destroys the fluid's lubricating qualities and friction characteristics, > varnish begins to form on internal parts (such as the valve body) which interferes with the > operation of the transmission. If the temperature gets above 250 degrees F., rubber seals > begin to harden, which leads to leaks and pressure losses. At higher temperatures the > transmission begins to slip, which only aggravates overheating even more. Eventually the > clutches burn out and the transmission calls it quits. The only way to repair the damage > now is with an overhaul -- a job which can easily run upwards of $1500 on a late model > front-wheel drive car or minivan. > > As a rule of thumb, every 20 degree increase in operating temperature above 175 degrees > F. cuts the life of the fluid in half! > > At 195 degrees F., for instance, fluid life is reduced to 50,000 miles. At 220 degrees, > which is commonly encountered in many transmissions, the fluid is only good for about > 25,000 miles. At 240 degrees F., the fluid won't go much over 10,000 miles. Add another > 20 degrees, and life expectancy drops to 5,000 miles. Go to 295 or 300 degrees F., and > 1,000 to 1,500 miles is about all you'll get before the transmission burns up. > > > Kerry > 82 FC 35 > Denver > > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > wrote: > > > > Those temperatures seem really high to me. I was looking at hose temperature ratings > > and fluid temperature ratings when I was redoing my power steering. My recollection is > > that standard hydraulic hose was rated to 250 degrees and the expensive high > > temperature hose was rated to 325 or 350. I think regular transmission fluid was rated > as > > functional up to about 250 degrees and synthetics up to about 350. These numbers are > > from my memory, If anyone else has knowledge about the functional temperatures of > > transmission fluid, I'd like to know. I'd be quite concerned with temperatures over 300 > > degrees. > > > > Kerry > > 82 FC 35 > > Denver > > > > be sure to keep it below > > > 320-330 degrees or you'll shorten the life of the tranny fluid > > > greatly. Most commercial bus drivers have to change the tranny fluid > > > every 50K miles when using the tranny retarder often. Mine easily goes > > > from 230 to 300 degrees when descending a steep off-ramp. One way to > > > slow the heat is to engage the fan override and let the hydro fan rob > > > 25-30 horses from the engine and cool the tranny fluid a little > > > quicker. On an off-ramp it does not make much difference, but on the 3 > > > or 4 mile grade, you can usually make it to the bottom under 320 > > > degrees if you also use the service brakes along with the tranny brake > > > and fan to slow the coach down. > > > Shane Fedeli > > > 85PT40 > > > Hershey, PA > > > > > > > > > ---------------------------------------------------------- No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.476 / Virus Database: 269.12.2/966 - Release Date: 8/22/2007 9:05 AM [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
08-24-2007, 06:59
Post: #25
There was one on eBay a while back. Seems like it sold for around
$1,000. I believe that all the 92 series engines use the same brake, just additional cylinder adapters for the 8V vs the 6V. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Troy Tikalsky wrote: > Have you tried locating a used system from a truck salvage yard? > > Troy > > ----- Original Message ----- > From: Leroy Eckert > To: WanderlodgeForum@yahoogroups.com > > Sent: Thursday, August 23, 2007 5:25 PM > Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things > > Howard, you sure can. I have two verbal bids for a Jake Brake addition > on my 8v92 DDEC II. $9,500 and $9,000. Non -DDEC systems may be > slightly cheaper, around $6-8,000. I did not want to buy a new bus, I > just wanted a Jake brake. lol > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: Howard O. Truitt > To: WanderlodgeForum@yahoogroups.com > > Sent: Thursday, August 23, 2007 5:10 PM > Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things > > Shane, > Could you add a jacob brake and have both a retarder and a jake brake. > Howard T., Sowega, 86 PT40 > > ----- Original Message ----- > From: sfedeli3 > To: WanderlodgeForum@yahoogroups.com > > Sent: Thursday, August 23, 2007 11:31 AM > Subject: [WanderlodgeForum] Re: PT36 retarder & other things > > Hi All, > > My tranny reading is regularly 230 degrees. Of course, it could be > a faulty sending unit, but my engine oil temp is around the same too, > if not a little warmer. I would expect both oil sumps to be pretty > close in temperature and seem to recall the blue book indicating that > 200 to 250 was the normal operating temp for the Allison that I have. > In any event, I change the fluid annually. It's relatively cheap and > easy to do on the mid-80's PT models. You just need a BIG bucket. > Varying brands of tranny fluid have different flash points and > additives. I've been using Lubrication Engineers > [http://www.le-inc.com <http://www.le-inc.com>] 7500 MONOLEC® Power > Fluid in numerous vehicles > for a number of years with great results and never smell burned fluid > when I drain. If you're really concerned about the tranny temps, or > drive the western Rockies, get a Jacobs Engine Retarder. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com > > > > > > I found this on another website: > > > > Why Atf Wears Out > > An automatic transmission creates a lot of internal heat through > friction: the friction of the > > fluid churning inside the torque converter, friction created when > the clutch plates engage, > > and the normal friction created by gears and bearings carrying their > loads. > > > > It doesn't take long for the automatic transmission fluid (ATF) to > heat up once the vehicle > > is in motion. Normal driving will raise fluid temperatures to 175 > degrees F., which is the > > usual temperature range at which most fluids are designed to > operate. If fluid > > temperatures can be held to 175 degrees F., ATF will last almost > indefinitely -- say up to > > 100,000 miles. But if the fluid temperature goes much higher, the > life of the fluid begins > > to plummet. The problem is even normal driving can push fluid > temperatures well beyond > > safe limits. And once that happens, the trouble begins. > > > > At elevated operating temperatures, ATF oxidizes, turns brown and > takes on a smell like > > burnt toast. As heat destroys the fluid's lubricating qualities and > friction characteristics, > > varnish begins to form on internal parts (such as the valve body) > which interferes with the > > operation of the transmission. If the temperature gets above 250 > degrees F., rubber seals > > begin to harden, which leads to leaks and pressure losses. At higher > temperatures the > > transmission begins to slip, which only aggravates overheating even > more. Eventually the > > clutches burn out and the transmission calls it quits. The only way > to repair the damage > > now is with an overhaul -- a job which can easily run upwards of > $1500 on a late model > > front-wheel drive car or minivan. > > > > As a rule of thumb, every 20 degree increase in operating > temperature above 175 degrees > > F. cuts the life of the fluid in half! > > > > At 195 degrees F., for instance, fluid life is reduced to 50,000 > miles. At 220 degrees, > > which is commonly encountered in many transmissions, the fluid is > only good for about > > 25,000 miles. At 240 degrees F., the fluid won't go much over 10,000 > miles. Add another > > 20 degrees, and life expectancy drops to 5,000 miles. Go to 295 or > 300 degrees F., and > > 1,000 to 1,500 miles is about all you'll get before the transmission > burns up. > > > > > > Kerry > > 82 FC 35 > > Denver > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > wrote: > > > > > > Those temperatures seem really high to me. I was looking at hose > temperature ratings > > > and fluid temperature ratings when I was redoing my power > steering. My recollection is > > > that standard hydraulic hose was rated to 250 degrees and the > expensive high > > > temperature hose was rated to 325 or 350. I think regular > transmission fluid was rated > > as > > > functional up to about 250 degrees and synthetics up to about 350. > These numbers are > > > from my memory, If anyone else has knowledge about the functional > temperatures of > > > transmission fluid, I'd like to know. I'd be quite concerned with > temperatures over 300 > > > degrees. > > > > > > Kerry > > > 82 FC 35 > > > Denver > > > > > > be sure to keep it below > > > > 320-330 degrees or you'll shorten the life of the tranny fluid > > > > greatly. Most commercial bus drivers have to change the tranny fluid > > > > every 50K miles when using the tranny retarder often. Mine > easily goes > > > > from 230 to 300 degrees when descending a steep off-ramp. One way to > > > > slow the heat is to engage the fan override and let the hydro > fan rob > > > > 25-30 horses from the engine and cool the tranny fluid a little > > > > quicker. On an off-ramp it does not make much difference, but on > the 3 > > > > or 4 mile grade, you can usually make it to the bottom under 320 > > > > degrees if you also use the service brakes along with the tranny > brake > > > > and fan to slow the coach down. > > > > Shane Fedeli > > > > 85PT40 > > > > Hershey, PA > > > > > > > > > > > > > > > ---------------------------------------------------------- > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.476 / Virus Database: 269.12.2/966 - Release Date: > 8/22/2007 9:05 AM > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
08-24-2007, 07:36
Post: #26
The implications of that are disturbing.
MH ----- Original Message ----- From: Troy Tikalsky To: WanderlodgeForum@yahoogroups.com Sent: Friday, August 24, 2007 11:58 AM Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things Oh boy, Ben might be listening and want that recorded! Troy ----- Original Message ----- From: Mike Hohnstein To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 23, 2007 8:21 PM Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things Yeah, but a Jake on a 892, whata beautiful noise. MH ----- Original Message ----- From: Leroy Eckert To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 23, 2007 4:25 PM Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things Howard, you sure can. I have two verbal bids for a Jake Brake addition on my 8v92 DDEC II. $9,500 and $9,000. Non -DDEC systems may be slightly cheaper, around $6-8,000. I did not want to buy a new bus, I just wanted a Jake brake. lol Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Howard O. Truitt To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 23, 2007 5:10 PM Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things Shane, Could you add a jacob brake and have both a retarder and a jake brake. Howard T., Sowega, 86 PT40 ----- Original Message ----- From: sfedeli3 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, August 23, 2007 11:31 AM Subject: [WanderlodgeForum] Re: PT36 retarder & other things Hi All, My tranny reading is regularly 230 degrees. Of course, it could be a faulty sending unit, but my engine oil temp is around the same too, if not a little warmer. I would expect both oil sumps to be pretty close in temperature and seem to recall the blue book indicating that 200 to 250 was the normal operating temp for the Allison that I have. In any event, I change the fluid annually. It's relatively cheap and easy to do on the mid-80's PT models. You just need a BIG bucket. Varying brands of tranny fluid have different flash points and additives. I've been using Lubrication Engineers [http://www.le-inc.com] 7500 MONOLEC® Power Fluid in numerous vehicles for a number of years with great results and never smell burned fluid when I drain. If you're really concerned about the tranny temps, or drive the western Rockies, get a Jacobs Engine Retarder. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > I found this on another website: > > Why Atf Wears Out > An automatic transmission creates a lot of internal heat through friction: the friction of the > fluid churning inside the torque converter, friction created when the clutch plates engage, > and the normal friction created by gears and bearings carrying their loads. > > It doesn't take long for the automatic transmission fluid (ATF) to heat up once the vehicle > is in motion. Normal driving will raise fluid temperatures to 175 degrees F., which is the > usual temperature range at which most fluids are designed to operate. If fluid > temperatures can be held to 175 degrees F., ATF will last almost indefinitely -- say up to > 100,000 miles. But if the fluid temperature goes much higher, the life of the fluid begins > to plummet. The problem is even normal driving can push fluid temperatures well beyond > safe limits. And once that happens, the trouble begins. > > At elevated operating temperatures, ATF oxidizes, turns brown and takes on a smell like > burnt toast. As heat destroys the fluid's lubricating qualities and friction characteristics, > varnish begins to form on internal parts (such as the valve body) which interferes with the > operation of the transmission. If the temperature gets above 250 degrees F., rubber seals > begin to harden, which leads to leaks and pressure losses. At higher temperatures the > transmission begins to slip, which only aggravates overheating even more. Eventually the > clutches burn out and the transmission calls it quits. The only way to repair the damage > now is with an overhaul -- a job which can easily run upwards of $1500 on a late model > front-wheel drive car or minivan. > > As a rule of thumb, every 20 degree increase in operating temperature above 175 degrees > F. cuts the life of the fluid in half! > > At 195 degrees F., for instance, fluid life is reduced to 50,000 miles. At 220 degrees, > which is commonly encountered in many transmissions, the fluid is only good for about > 25,000 miles. At 240 degrees F., the fluid won't go much over 10,000 miles. Add another > 20 degrees, and life expectancy drops to 5,000 miles. Go to 295 or 300 degrees F., and > 1,000 to 1,500 miles is about all you'll get before the transmission burns up. > > > Kerry > 82 FC 35 > Denver > > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > wrote: > > > > Those temperatures seem really high to me. I was looking at hose temperature ratings > > and fluid temperature ratings when I was redoing my power steering. My recollection is > > that standard hydraulic hose was rated to 250 degrees and the expensive high > > temperature hose was rated to 325 or 350. I think regular transmission fluid was rated > as > > functional up to about 250 degrees and synthetics up to about 350. These numbers are > > from my memory, If anyone else has knowledge about the functional temperatures of > > transmission fluid, I'd like to know. I'd be quite concerned with temperatures over 300 > > degrees. > > > > Kerry > > 82 FC 35 > > Denver > > > > be sure to keep it below > > > 320-330 degrees or you'll shorten the life of the tranny fluid > > > greatly. Most commercial bus drivers have to change the tranny fluid > > > every 50K miles when using the tranny retarder often. Mine easily goes > > > from 230 to 300 degrees when descending a steep off-ramp. One way to > > > slow the heat is to engage the fan override and let the hydro fan rob > > > 25-30 horses from the engine and cool the tranny fluid a little > > > quicker. On an off-ramp it does not make much difference, but on the 3 > > > or 4 mile grade, you can usually make it to the bottom under 320 > > > degrees if you also use the service brakes along with the tranny brake > > > and fan to slow the coach down. > > > Shane Fedeli > > > 85PT40 > > > Hershey, PA > > > > > > > > > ---------------------------------------------------------- No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.476 / Virus Database: 269.12.2/966 - Release Date: 8/22/2007 9:05 AM [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
08-24-2007, 15:07
Post: #27
I have a Jake on my 6v92. When we are coming to the Hoodsport Wa.
rally last year, came down off the hills and put on the Jake. The guys in camp said "Here comes Bob"..seems I'm the only one with a Jake, others have the retarder. Bob Lawrence 84 PT36 Tacky Tacoma, Wa. > Yeah, but a Jake on a 892, whata beautiful noise. > MH > ----- Original Message ----- > From: Leroy Eckert > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, August 23, 2007 4:25 PM > Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things > > > Howard, you sure can. I have two verbal bids for a Jake Brake addition on my 8v92 DDEC II. $9,500 and $9,000. Non -DDEC systems may be slightly cheaper, around $6-8,000. I did not want to buy a new bus, I just wanted a Jake brake. lol > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: Howard O. Truitt > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, August 23, 2007 5:10 PM > Subject: Re: [WanderlodgeForum] Re: PT36 retarder & other things > > Shane, > Could you add a jacob brake and have both a retarder and a jake brake. > Howard T., Sowega, 86 PT40 > > ----- Original Message ----- > From: sfedeli3 > To: WanderlodgeForum@yahoogroups.com > Sent: Thursday, August 23, 2007 11:31 AM > Subject: [WanderlodgeForum] Re: PT36 retarder & other things > > Hi All, > > My tranny reading is regularly 230 degrees. Of course, it could be > a faulty sending unit, but my engine oil temp is around the same too, > if not a little warmer. I would expect both oil sumps to be pretty > close in temperature and seem to recall the blue book indicating that > 200 to 250 was the normal operating temp for the Allison that I have. > In any event, I change the fluid annually. It's relatively cheap and > easy to do on the mid-80's PT models. You just need a BIG bucket. > Varying brands of tranny fluid have different flash points and > additives. I've been using Lubrication Engineers > [http://www.le-inc.com] 7500 MONOLEC® Power Fluid in numerous vehicles > for a number of years with great results and never smell burned fluid > when I drain. If you're really concerned about the tranny temps, or > drive the western Rockies, get a Jacobs Engine Retarder. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > I found this on another website: > > > > Why Atf Wears Out > > An automatic transmission creates a lot of internal heat through > friction: the friction of the > > fluid churning inside the torque converter, friction created when > the clutch plates engage, > > and the normal friction created by gears and bearings carrying their > loads. > > > > It doesn't take long for the automatic transmission fluid (ATF) to > heat up once the vehicle > > is in motion. Normal driving will raise fluid temperatures to 175 > degrees F., which is the > > usual temperature range at which most fluids are designed to > operate. If fluid > > temperatures can be held to 175 degrees F., ATF will last almost > indefinitely -- say up to > > 100,000 miles. But if the fluid temperature goes much higher, the > life of the fluid begins > > to plummet. The problem is even normal driving can push fluid > temperatures well beyond > > safe limits. And once that happens, the trouble begins. > > > > At elevated operating temperatures, ATF oxidizes, turns brown and > takes on a smell like > > burnt toast. As heat destroys the fluid's lubricating qualities and > friction characteristics, > > varnish begins to form on internal parts (such as the valve body) > which interferes with the > > operation of the transmission. If the temperature gets above 250 > degrees F., rubber seals > > begin to harden, which leads to leaks and pressure losses. At higher > temperatures the > > transmission begins to slip, which only aggravates overheating even > more. Eventually the > > clutches burn out and the transmission calls it quits. The only way > to repair the damage > > now is with an overhaul -- a job which can easily run upwards of > $1500 on a late model > > front-wheel drive car or minivan. > > > > As a rule of thumb, every 20 degree increase in operating > temperature above 175 degrees > > F. cuts the life of the fluid in half! > > > > At 195 degrees F., for instance, fluid life is reduced to 50,000 > miles. At 220 degrees, > > which is commonly encountered in many transmissions, the fluid is > only good for about > > 25,000 miles. At 240 degrees F., the fluid won't go much over 10,000 > miles. Add another > > 20 degrees, and life expectancy drops to 5,000 miles. Go to 295 or > 300 degrees F., and > > 1,000 to 1,500 miles is about all you'll get before the transmission > burns up. > > > > > > Kerry > > 82 FC 35 > > Denver > > > > > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > wrote: > > > > > > Those temperatures seem really high to me. I was looking at hose > temperature ratings > > > and fluid temperature ratings when I was redoing my power > steering. My recollection is > > > that standard hydraulic hose was rated to 250 degrees and the > expensive high > > > temperature hose was rated to 325 or 350. I think regular > transmission fluid was rated > > as > > > functional up to about 250 degrees and synthetics up to about 350. > These numbers are > > > from my memory, If anyone else has knowledge about the functional > temperatures of > > > transmission fluid, I'd like to know. I'd be quite concerned with > temperatures over 300 > > > degrees. > > > > > > Kerry > > > 82 FC 35 > > > Denver > > > > > > be sure to keep it below > > > > 320-330 degrees or you'll shorten the life of the tranny fluid > > > > greatly. Most commercial bus drivers have to change the tranny fluid > > > > every 50K miles when using the tranny retarder often. Mine > easily goes > > > > from 230 to 300 degrees when descending a steep off-ramp. One way to > > > > slow the heat is to engage the fan override and let the hydro > fan rob > > > > 25-30 horses from the engine and cool the tranny fluid a little > > > > quicker. On an off-ramp it does not make much difference, but on > the 3 > > > > or 4 mile grade, you can usually make it to the bottom under 320 > > > > degrees if you also use the service brakes along with the tranny > brake > > > > and fan to slow the coach down. > > > > Shane Fedeli > > > > 85PT40 > > > > Hershey, PA > > > > > > > > > > > > > > > ---------------------------------------------------------- > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.476 / Virus Database: 269.12.2/966 - Release Date: 8/22/2007 9:05 AM > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > |
