Bendix cruise control
01-13-2008, 03:08
Post: #21
Ralph & Dick
Yep, I believe most of the parts are behind the black steel box cover. I have looked at this earlier in my Bird ownership, at that time all these parts looked way too complicated for me. But I need to revisit this black box. I will eventually start with lubing the cable, Possibly hanging-up in the high idle mode. Then try to lube the solenoid valves. This will be at a latter date for me, But I will post results. Sometimes a Volt-Ohm meter can lead one astray. Thank Again to All. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Richard Gideon" > > Morning Ralph & Bill: Is there a way to clean or service those two > solenoid valves? Are the replacements available through Bendix? My > understanding is that these valves are mounted inside the approx 12"X > 16" steel case behind the drivers side battery box on the 1988 FC. > > Bill...have you removed the throttle cable to clean & lubricate? > > Thanks from keeping this CC/fast idle discussion going. > > Dick Gideon > Freedom Bird > 1989 35FC35 > On the Road at Canyon Lake, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Morning Bill: > > > > There are 2 valves mounted on or near the control unit. I would > suspect one > > of those are sticking from time to time on you for the high idle. Since > > your cruise is working the cc-5 is working and that is in drive but > when in > > N the air should be metered from those valves to the inversion valve > and > > conversely the cc-5. Back up a step or 2 from the cc-5 and see what you > > come up with is where I would start. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > 84FC35 "Ruff Diamond" > > Duncan, Oklahoma > > > > At 12:56 PM 1/13/2008 +0000, you wrote: > > > > > > >HELLO RALPH, > > > > > > > > >Thank you for posting these precious documents. > > >But, now I am more confused?????? > > > > > >Our Bendix cruise control works great. It is the high idle > > >on our FC that is intermittent, It occationally takes off > > >and really revs up the 3208, So it can not be trusted or used. > > > > > >One of the troubleshooting tips in the manual is to check the > > >resistance of the potentiometer in the CC-5. > > >Well two of the readings show an open circuit and the third reading > > >is in tolerance. > > >Do you have any advice on where to check further?? > > > > > >Thanks again for all your posts. > > > > > >Bill 88 FC Michigan > > > > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > > > > > > > Hello everyone: > > > > > > > > Earlier today, I put some files in a folder in the files section > > >Concerning > > > > the Bendix Cruise Control. It is split up into 3 PDF files and is > > >as > > > > complete a manual as I have been able to put together over the > > >years. The > > > > Manual not only cover advanced trouble shooting, it covers the dip > > >switch > > > > set up of the control module and the math that addresses the "why" > > >of the > > > > dip switch settings. > > > > > > > > Along with these files, I up loaded another PDF file for the 6V and > > >8V air > > > > throttle systems, as these systems on the PT's incorporate the air > > > > throttle. There is another file section that is the text portion > > >explaining > > > > how the air throttle works and the sequence of operation that I > > >wrote a > > > > couple of years ago. > > > > > > > > I hope you find these files helpful. > > > > > > > > Oh for those that have not run across it as yet, on the FC's the > > >high idle > > > > is set with the cruise control where the PT's the cruise is not > > >used but a > > > > separate high idle system comes into play. > > > > > > > > > > > > Safe travels, > > > > > > > > Ralph and Charolette Fullenwider > > > > 84FC35 "Ruff Diamond" (looking good with new oak floors and > > >captains chairs > > > > up front) > > > > Duncan, Oklahoma > > > > > > > > > > |
