Door repairs
06-13-2008, 04:58
Post: #21
Door repairs
Rattles ... yes, I have 'em... Lots of 'em ...
The previous owner obviously had gone to some trouble chasing after rattles as I've found bits of foam tape on edges of window blinds, and extra leg installed under the dining table (good job, I didn't realize it was an extra until I pulled the table out to install the new flooring), and other efforts noticed on close inspection. However, dishes and other things in cabinets -- and the cabinets themselves -- along with basement items and many other things all can vibrate and rattle.
I'm not particularly pleased to find the occasional screw or washer laying on the floor -- having fallen from who knows where!
But, so long as I can turn up the volume on the radio sufficiently, the rattling isn't too bothersome.
The one variable I've noticed is that prevailing winds can affect the rattles/wind noises. If the wind is generally from the right, one set of windows sings is song of joy ... wind from another direction will set up a different tune. While our car is generally one of the least noisy -- I've grown accustomed to the songs of the road sung by my 'bird and I often consider the comment of a more experienced RVer who reminded me, it's like having a Richter 8 earthquake in your home each time you drive the coach...
El Sobrante CA
"aeonix1@mac.com"
On Jun 13, 2008, at 10:10 AM, David Brady wrote:
Let us know what you find out Pete. I assume that the plastic channel was
installed by Peninsula. It's possible that it was added later by BlueBird. Sure
does work. To cinch the screen I use a pen, or similarly skinny object, and
shift the plastic channel towards the rear of the bus. The channel then rides
up on the curvature of the window, at the corner, and forces the screen
upward "clamping" it into the window. My windows are silent. No high
pitch tones either. The trouble with this fix, as with any rattle fix, is that
we've just peeled the onion; i.e, those rattling screens cover up a lot of
other noises that you didn't know existed.
David Brady
Pete Masterson wrote:
That sounds like exactly what I need. There's a lot of rattling going on with a couple of the windows. But I also get wind noise (high-pitched whistle). Due to the age of my windows, the sealing simply seems to be worn down. It hadn't occurred to me before, but I'll contact Peninsula Glass and see if they have any ideas on how to renew the weather stripping.
El Sobrante CA
"aeonix1@mac.com"
On Jun 13, 2008, at 9:42 AM, David Brady wrote:
What makes noise on my side windows are the screens - they rattle
over bumps. I found that Penisula Glass put a plastic channel at the
base of my screens that slides in another extruded channel in the
window frame. The plastic piece is a few inches shorter than the window
frame. It's purpose is to cinch the screen into the extruded window
frame to prevent rattling. It works. If you don't have such an item,
you can probably get it from Peninsula. It's a simple matter to pop
out the screen, seat the plastic channel, and re-insert the screen.
David Brady,
'02 LXi, NC
I actually only replaced the outside edge, top and bottom but not the hinge-edge of the weather stripping. The hinge edge was more bother, so I put it off. I then noticed that the wind noise I was getting had gone away.
I also got rid of some wind noises in the door window by installing some weather stripping there, too. I used a kind of 'fur' stuff -- stiff fibers about 1/16" long that stick up from a 3/16" sticky tape.
I have a bit of similar wind noise from the driver's side window as well. Installing a bunch more of the fur-stuff is on my to do list.
These kinds of things are endless -- I have several of the other windows that need troubleshooting for rattles and wind noise as well. Difficulty there is that it helps to be able to sit/stand near the window and experiment to find exactly where the noise/air leak is coming from. I can't do that while I'm driving. Wife won't drive the bus. So I need to wait for a day when there's gale force winds blowing so I can fiddle with the windows while parked... (We don't get many of those days around here.)
El Sobrante CA
"aeonix1@mac.com"
On Jun 13, 2008, at 6:46 AM, Gregory OConnor wrote:
The most annoying noise resulting from wind at the entry door comes
from atop the passanger seat. 1- opening up the airvent pressurizes
the cab enough to keep air from entering.(close rear windows also) 2-
Saying "What,,, What,,,, What,,," is effective in reduction of seat
noise.  I don't get the 'skin the cat anology' but these are two of
those other ways.
Less weather strip is needed at the hinge side.  too much will lift
the hinge and soon distort.  hollow strips seem to seal better with
less pressure but when you distort the mechanics, you end up needing
newspaper sticking out the jam.
GregoryO'Connor
94ptRomolandCa
 --- In "WanderlodgeForum@yahoogroups.com", David Brady "dmb993@..."
Yes, that piano hinge doesn't help. It was okay on a school bus
(with 2 doors meeting in the center), but it's not quite good
enough
on a single door motorhome. What we need is a true automotive
style door hinge, which pulls the door out away from the vehicle
rather than a piano hinge which severely pinches the weather
stripping
adjacent to the hinge. Alas, we're probably stuck with it.
David
'02 LXi, NC
I've examined the door geometry very closely. It doesn't seem
like
there's any real solution -- it appears to be a "feature" (as in
"that's not a bug, it's an undocumented feature")... When my
weather
stripping was failing, the door was easier to close, but then
there
were some air leaks and wind noise. Once I renewed the weather
strip
(with a profile that was quite similar to the original) then the
door
was a bit harder to close, but the air leaks and wind noise was
gone.
I've adjusted to it and have become accustomed to using a firm
hand
when closing the door. It's not really an excessive amount of
force,
but it is rather more than is required for most vehicles. I
chalk it
up to being a Blue Bird quirk.
El Sobrante CA
aeonix1@... <"aeonix1"@...>
On Jun 12, 2008, at 6:48 PM, brad barton wrote:
Pete,
That is exactly what happens on mine.  Very frustrating.  Also
no
real way that anyone knows of to adjust it.
Brad Barton 00LXiDFW bbartonwx@... <"bbartonwx"@...>
    <"WanderlodgeForum@yahoogroups.com">
    Date: Thu, 12 Jun 2008 09:56:22 -0700
    Subject: Re: [WanderlodgeForum] Re: Door repairs
    I'll note that the door on my coach must be shut with
authority
    (like you mean it) or the automotive-type lock won't latch
    properly. This was the situation with the original weather
    stripping and with the weather stripping I installed. Once
    automotive latch is properly activated, then the dead bolt
lines
    up properly.
    If you try to open the door with the dead bolt locked, then
when
    the automotive latch releases, the pressure on the dead
bolt is
    sufficient that the solenoid won't move it. Depending on
which
    side of the door you're on, you either have to pull or push
on
    the door to relieve the pressure on the dead bolt, then the
    solenoid will through the bolt.
    El Sobrante CA
    On Jun 11, 2008, at 8:22 PM, Gregory OConnor wrote:
        Ryan, when I use the keyless on my '94 I have to push
on the
        door to
        line up the deadbolt. This is all done blind folded as
I cant
        see or
        feel what is going on in the jamb.  I think someone
replaced the
        seal with a too ambitious foam/rubber  product. fat
seals endup
        causing the door operator to slam and place a hard turn
on the
        lock.  One other issue is that the door on my 94 is
alumnium and
        swells more than the steel frame in the sun. just some
things to
        consider with your project
Instantly invite friends from Facebook and other social
networks to
join you on Windows Live™ Messenger. Invite friends now!
source=TXT_EML_WLH_InviteFriends>
Checked by AVG.
Version: 7.5.524 / Virus Database: 270.3.0/1500 - Release Date:
6/12/2008 4:58 PM
Yahoo! Groups Links
<*> Your email settings:
    (Yahoo! ID required)
Checked by AVG. Version: 7.5.524 / Virus Database: 270.3.0/1500 - Release Date: 6/12/2008 4:58 PM
06-13-2008, 05:10
Post: #22
Door repairs
was
BlueBird. Sure
rides
is that
of
David Brady
El Sobrante CA
"aeonix1@mac.com"
David Brady,
'02 LXi, NC
sticky tape.
list.
El Sobrante CA
"aeonix1@mac.com"
door comes
pressurizes
windows also) 2-
reduction of seat
noise.  I
those other ways.
better with
up needing
GregoryO'Connor
94ptRomolandCa
school bus
good
enough
automotive
vehicle
weather
stripping
it.
David
'02 LXi, NC
doesn't seem
like
"feature" (as in
When my
weather
but then
there
weather
strip
original) then the
door
noise was
gone.
using a firm
hand
amount of
force,
vehicles. I
chalk it
El Sobrante CA
Pete,
no
    Date:
    Subject:
    I'll
authority
    (like
    properly.
    stripping
    automotive
lines
    up
properly.
    If
when
bolt is
    sufficient
which
    side
on
    solenoid
    Pete
Masterson
    '95
    El
Sobrante CA
    aeonix1@...
<"aeonix1"@...>
    On
        Ryan,
on the
        door
to
        line
I cant
        see
or
        feel
think someone
replaced the
        seal
fat
seals endup
        causing
on the
door on my 94 is
alumnium and
        swells
things to
        consider
with your project
social
networks to
now!
Checked by AVG.
Release Date:
6/12/2008 4:58 PM
Yahoo! Groups Links
    Individual
Email | Traditional
    (Yahoo! ID
required)
06-13-2008, 08:08
Post: #23
Door repairs
I did the same thing last year and I think it was at your suggestion,
Pete. Only cost me a couple of bucks and half an hour's worth of my
time to do the door & driver's windows and made a huge difference.
Really quieted things down.
-Ryan
'86 PT-40 8V92
06-13-2008, 10:56
Post: #24
Door repairs
Boy, you got that right. Reality sets in every day it seems.
We are leaving tomorrow to attend a memorial service for my wife's father. While it was not unexpected it still ain't fun. It is a reminder that life is short, we should use the coach as much as possible, because the number will pop up at any time.
My father sat me down 50 years ago and said, "If you live a long life you will experience one or more funerals, if not it is a mute point." I think he was right.
The wife is doing well under the circumstances.
Leroy Eckert
1990 WB-40 Royale
Dahlonega, GA
Royale Conversion
Still reality based
--- On Thu, 6/12/08, George Burke wrote:
Subject: Re: [WanderlodgeForum] Door repairs
Date: Thursday, June 12, 2008, 10:41 PM
Leroy, Welcome to the club. When it all comes down to it, we are all pretty much Whacko. Also don't worry about hearing voices from time to time. A friend once told me that the time to WORRY is when you no longer hear them! LOL!!! George Burke 1977 FC31 Charlotte
On Tue, Jun 10, 2008 at 9:20 PM, Leroy Eckert <"jwasnewski@yahoo.com"> wrote:
As usual I am on the outside looking in on the lock deal but that is ok. I do not use mine even though it works because I am very catastrophic failure or natural disaster superstitious. I have a home fire escape plan which has a basement in a two story home with two exit doors other than the garage. In addition I have 6 smoke detectors.
In a building in case of fire do not use the elevator use the stairs.
In the bus, in case of fire the auto remote lock will not work. There is only one way out except for the windows and the sooner you are out the better. I keep a mini sledge in the bedroom just in case, to hell with depending on the windows to slide even though they do. You just cannot be to careful.
Leroy Eckert
1990 WB-40 Royale
Dahlonega, GA
Smoke N Mirrors
Whacko and hear voices from time to time.
Ryan Wright <"ryanpwright@gmail.com"> wrote:
Two questions,
1. Where can I get a new door seal? Mine is old and falling apart.
2. Any tips on getting the remote lock to work reliably? Mine works
sporadically. Sometimes it's fine, other times it just refuses. Can't
be the switch because both the dash switches and the bedroom switch
work (or don't) at the same time. I want to install a keyless entry,
but need to make the door lock work reliably first.
Thank you,
-Ryan
'86 PT-40 8V92
06-13-2008, 11:03
Post: #25
Door repairs
Howdy, Pete.
> gone away.
This "fur" stuff is what I need for our door window. What is the name of it and where did you get it?
TIA,
Jack Pearce
1993 WLWB 40 ft.
Summering in Buena Vista, CO
06-13-2008, 13:16
Post: #26
Door repairs
I was afraid someone would ask... I found it in the weather stripping department of my local hardware store (Orchard Supply Hardware). They have a variety of rubber, felt, vinyl, and 'furry-looking' weather stripping on adhesive backing -- usually in rolls in square boxes or plastic packs.
I no longer have the original package of the furry stuff -- but I have a few inches left over. Since it's used for windows and a lot of other things, I'd imagine that Lowes or Home Depot would have something similar. The stuff I used was tan in color, but I've seen it in white and black in the past. It was in a display with the various rubber and felt general weather strip products.
El Sobrante CA
"aeonix1@mac.com"
On Jun 13, 2008, at 4:03 PM, Jack and Liz Pearce wrote:
Howdy, Pete.
<snip>
TIA,
Jack Pearce
1993 WLWB 40 ft.
06-13-2008, 13:18
Post: #27
Door repairs
Entry door and basement doors are operated with electric solenoids. I shudder to think that BB used air to drive the locks on the LXI.... especially since the 'air step' has proved to be so durable...
El Sobrante CA
"aeonix1@mac.com"
On Jun 13, 2008, at 6:31 PM, David Brady wrote:
Do you non-LXi owners have air locks on your door?
David
'02 LXi, NC
El Sobrante CA
"aeonix1@mac.com"
those other ways.
GregoryO'Connor
94ptRomolandCa
enough
stripping
David
'02 LXi, NC
like
weather
there
strip
door
gone.
hand
force,
chalk it
El Sobrante CA
Pete,
no
authority
lines
    up properly.
when
bolt is
which
on
    El Sobrante CA
on the
        door to
I cant
        see or
replaced the
seals endup
on the
alumnium and
things to
networks to
Checked by AVG.
6/12/2008 4:58 PM
Yahoo! Groups Links
06-13-2008, 13:31
Post: #28
Door repairs
David
'02 LXi, NC
sticky tape.
El Sobrante CA
"aeonix1@mac.com"
comes
pressurizes
also) 2-
seat
noise.  I don't
those other ways.
needing
GregoryO'Connor
94ptRomolandCa
bus
enough
vehicle
stripping
David
'02 LXi, NC
seem
like
(as in
my
weather
then
there
weather
strip
then the
door
noise was
gone.
firm
hand
of
force,
chalk it
El Sobrante CA
Pete,
no
    Date:
    Subject:
    I'll
authority
    (like
    properly.
    stripping
    automotive
lines
    up
properly.
    If you
when
bolt is
    sufficient
which
    side of
on
    the door
    solenoid
    Pete
Masterson
    '95 Blue
    El
Sobrante CA
    aeonix1@...
<"aeonix1"@...>
    On Jun
        Ryan,
on the
        door
to
        line
I cant
        see
or
        feel
think someone
replaced the
        seal
fat
seals endup
        causing
on the
door on my 94 is
alumnium and
        swells
things to
        consider
with your project
networks to
Checked by AVG.
Date:
6/12/2008 4:58 PM
Yahoo! Groups Links
    Individual
Email | Traditional
    (Yahoo! ID
required)
06-13-2008, 13:40
Post: #29
Door repairs
In a similar discussion in May of last year I posted:
The product used was "Ace Pile Weatherstrip" number 52210. 3/16H pile, 1/4W,
adhesive back. 17 feet was $10 at a large Ace in Kelso, WA.
>plastic packs.
>Pete Masterson
>El Sobrante CA
>aeonix1@...
>> Howdy, Pete.
>> <snip>
>> TIA,
>> Jack Pearce
>> 1993 WLWB 40 ft.
06-13-2008, 15:11
Post: #30
Door repairs
That's fascinating! No wonder you guys are all complaining about
loud air noise around your entry way door. BB fixed this in '99
with the air-lock door. (I know Leroy is gonna love this...). My
entry way door has an air solenoid at the top on the non-hinge
side that propels a steel wedge thru a slot on the top of the door.
Every now and then I ask my wife why the door is making soooo
muuuuch noise, only to realize I forgot to engage the air-lock. I
thought, surely those wonderful, and "superior", Wanderlodges of
yesteryear have air-locks, cause this contraption completely wreaks
of yesterdays-style solutions; I thought it was standard Wanderlodge
fare. Silly me. Go get one, they work. I engage it, it slams down
with an authoritative "clunk" and my door is cinched close to the
steel coach body - no noise. I assume if I lose air the lock
dissengages,
yikes, I better test that!
David Brady
'02 LXi, NC
durable...
El Sobrante CA
"aeonix1@mac.com"
door?
David
'02 LXi, NC
sticky tape.
list.
El Sobrante CA
"aeonix1@mac.com"
door comes
pressurizes
windows also) 2-
reduction of seat
noise.  I
those other ways.
better with
up needing
GregoryO'Connor
94ptRomolandCa
school bus
good
enough
automotive
vehicle
weather
stripping
it.
David
'02 LXi, NC
doesn't seem
like
"feature" (as in
When my
weather
but then
there
weather
strip
original) then the
door
noise was
gone.
using a firm
hand
amount of
force,
vehicles. I
chalk it
El Sobrante CA
Pete,
no
    Date:
    Subject:
    I'll
authority
    (like
    properly.
    stripping
    automotive
lines
    up
properly.
    If
when
bolt is
    sufficient
which
    side
on
    solenoid
    Pete
Masterson
    '95
    El
Sobrante CA
    aeonix1@...
<"aeonix1"@...>
    On
        Ryan,
on the
        door
to
        line
I cant
        see
or
        feel
think someone
replaced the
        seal
fat
seals endup
        causing
on the
door on my 94 is
alumnium and
        swells
things to
        consider
with your project
social
networks to
now!
Checked by AVG.
Release Date:
6/12/2008 4:58 PM
Yahoo! Groups Links
    Individual
Email | Traditional
    (Yahoo! ID
required)
User(s) browsing this thread: 7 Guest(s)
