ATTENTION ALL PT-42 OWNERS!!!!!!!!!!!!!!!
10-01-2008, 07:31
Post: #21
Kurt, thanks for all your efforts
83PT40
currently in North Platte, Nebraska
Looking for simple solutions to your real-life financial challenges? Check out WalletPop for the latest news and information, tips and calculators.
10-07-2008, 14:35
Post: #22
I would like one
Jim Riordan
851 Johnson av
Suite 100
Stuart, fl 34994
772 260 1328
Kurt Horvath wrote:
I sent out 23 disks today. I have burnt 50 disks. Who Wants one?
In my zeal to get this done I neglected to index the files. When you
open the disk you will see lots of PDF's and TIFF files. I have
compiled an index that will direct you to what your searching for. I
didn't realize it until after
I mailed the disks and was looking at
some files did I realize that you have to open each file and look at
the legend to tell what the heck you've opened. A poor way to search
at best. This index is not perfect but it will facilitate your search
of the files. The Index is pasted below.
BAD SCANS are incomplete scans that are viewable, an edge or a side
wasn't scanned. There will be several duplicates. Some are duplicates
some are revisions or updates. One important revision is the one
addressing the Jake Brake / Engine Brake Modification. Look at scan
501, 502 , there may be another but it's eluding me at the moment.
I have had many offers to help deter the cost of this project. A few
are exempt from any obligation due to their help, donation and
participation in this project, specifically Wallace and Bruce. I have
forwarded a disk to all three web sites and will send a few out to
our BIRD GURU'S. I have one
offer to host this inf. free of charge,
available to all who have an interest, we'll see how this progresses
and another forum member with a complete set of diagrams that when
time allows will cross check these diagrams against his to fill in
any gaps. If you are compelled to help with the cost of this project
I would appreciate it. I have over 60 hours and $'S in it and this
entire week was devoted to it. KNOWLEDGE IS POWER!!!!!
INDEX OF 1995 -1996 PT 42 & some 1997 PT 43 FILES
16 pgs. Ref. - Wire Reference -From - To - Color - #
SCAN NUMBERS 439 to 527
439 Diagram Asst., Plumbing, Fresh Water, bad scan
440 1729813EEEDiagram, WRG. Chassis, DDEC III, End BRK 4203WL bad
scan
441 6083778 Diagram, Wiring, Load Center, Lower Front
442 6083729 Diagram Wiring, Charging Circuit
444 6080956 Diagram, Installation, Aquahot
445 6083729 Diagram, Wiring, Charging Circuit
446 6088652 bad scan
447 1782267A 2 of 2 bad scan
449 1782259 1 of 2 Diagram, Dual, Air Brake,
448 Bad Scan
450 Bad Scan
451 Bad Scan
452 Bad Scan
455 1729813EEE Diagram, WAG, Chassis, DDEC III, Eng. Brake. BS
456 Bad Scan
457 Diagram Fresh Water System Legend not scanned
458 6083711 Diagram Electrical System bad scan
459 6051999 Diagram Assy, Electrical Component Panel, Rear, 12V
460 6080956 Diagram, Installation, Aquahot
461 6080956 Same As Above
462 6053227 Diagram Assy, Electrical Component Panel, Overhead Front
463 6068670 Diagram, L.P. Gas Piping, State
464 6053227 Diagram Assy, Electrical Component Panel, Overhead Front
465 6046422 Diagram Wiring, Charging Circuit
466 6068670 Diagram, L.P. Gas Piping,
State
467 6046445 Diagram, Electrical Systems top edge bad scan
468 6083729 Diagram Charging Circuit, Bad Scan
469 6049100 1 of 11Diagram Harness, Wiring, 12VDC. RH
470 2 of 11
471 3 of 11
472 4 of 11
473 5 of 11
474 6 of 11
475 7 of 11
476 8 of 11
477 9 of 11
478 10 of 11
479 11 of 11
480 Copy 5 of 11
481 Copy 5 of 11
482 6049076 2 of 3 Harness, Wiring 120VAC, LH
483 3 of 3
484 1 of 3
485 2 of 3
486 3 of 3
487 3 of 3
488 6049092 1 of 14 Harness, Wiring, 12VDC, LH
489 2 of 14
490 3 of 14
491 4 of 14
492 5 of 14
493 6 of 14
494 7 of 14
495 8 of 14
496 9 of 14
497 10 of 14
498 11 of 14
499 6049100 7 of 11 Harness, Wiring, 12VDC, RH
500 " " 6 of 11
501 1729813 Diagram, Wiring, Chassis, DDEC III, Engine Brake
502 1729813 Diagram, Wiring, Chassis, DDEC III, Engine Brake
503 6051981 Diagram, Assy, Electrical Component Panel, Overhead Front
504 1729813 Diagram,
505 6083778 Diagram, Wiring, Load Center, Lower Front - Superseded by
# 6087878
506 Same As Above
507 6083075 Diagram, Assy, Plumbing, Fresh Water
508 6080956 Diagram, Installation, Aquahot
509 6083729 Diagram, Wiring, Charging Circuit
510 1782259 Diagram, Dual Air Brake, Sheet 1 of 2
511 6083711 Diagram, Electrical Systems
512 6053227 Diagram, Assy, Electrical, Overhead Front
513 6083711 Diagram, Electrical Systems
514 1782259 Diagram, Dual Air Brake, Sheet 1 of 2
515 6053227 Diagram, Assy, Electrical Component Panel, Overhead Front
516 1782267 Diagram, Dual Air Brake, Sheet 2 of 2
517 6068670 Diagram, L.P. Gas Piping, State
518 Unknown Diagram, Electrical Systems 120/220?????
519 6083729 Diagram, Wiring, Charging Circuit
520 6053227 Diagram, Assy, Electrical Component Panel, Overhead Front
521 6046122 Diagram, Wiring, Charging Circuit
522 6083075 Diagram, Assy, Plumbing,
Fresh Water
523 6051999 Diagram Assy, Electrical Component Panel, Rear, 12VDC
524 6080956 Diagram Installation, Aquahot
525 6080956 Duplicate Print
526 6068670 Diagram, L.P. Gas Piping, State
527 6053227 Diagram Assy, Electrical Component Panel, Overhead Front
TIFF FILES ARE NUMBERED THE SAME AS THE PDF FILES.
Kurt Horvath
95 PT 42 WLWB
10AC
--- In "WanderlodgeForum%40yahoogroups.com", "Kurt Horvath"
...> wrote:
> David,
> I need an address. By the way Chris Miller @ Prevost in Nashville
sez
> Hello.
> Kurt Horvath
> 95 PT 42
> 10AC
0
10-08-2008, 13:54
Post: #23
Has anyone determined if these are in any way germane to older PT's, even partially? If so, I would like one as well.
Thanx
Dick Hayden - '87 PT 38'
11709 122nd St N.E.
Lake Stevens, WA 98258
Sent: Tuesday, October 07, 2008 7:35 PM
Subject: Re: [WanderlodgeForum] ATTENTION ALL PT-42 OWNERS!!!!!!!!!!!!!!!
I would like one
Jim Riordan
851 Johnson av
Suite 100
Stuart, fl 34994
772 260 1328
didn't realize it until after I mailed the disks and was looking at
our BIRD GURU'S. I have one offer to host this inf. free of charge,
scan
448 Bad Scan
450 Bad Scan
451 Bad Scan
452 Bad Scan
456 Bad Scan
466 6068670 Diagram, L.P. Gas Piping, State
470 2 of 11
471 3 of 11
472 4 of 11
473 5 of 11
474 6 of 11
475 7 of 11
476 8 of 11
477 9 of 11
478 10 of 11
479 11 of 11
480 Copy 5 of 11
481 Copy 5 of 11
483 3 of 3
484 1 of 3
485 2 of 3
486 3 of 3
487 3 of 3
489 2 of 14
490 3 of 14
491 4 of 14
492 5 of 14
493 6 of 14
494 7 of 14
495 8 of 14
496 9 of 14
497 10 of 14
498 11 of 14
500 " " 6 of 11
504 1729813 Diagram, Wiring, Chassis, DDEC III, Engine Brake
# 6087878
506 Same As Above
522 6083075 Diagram, Assy, Plumbing, Fresh Water
Kurt Horvath
95 PT 42 WLWB
10AC
...> wrote:
> David,
sez
> Hello.
> Kurt Horvath
> 95 PT 42
> 10AC
0
10-09-2008, 01:58
Post: #24
Kurt,
I've tried emailing you 3 times over the last couple of weeks, and I continually
get a
Mailer-Demon notice that it failed.
Anyways,
I definitely would love a CD if you still have some available. I will gladly
help you offset
cost anyway you need.
Corey Graham
3367 Preston Hills Circle
Prosper, TX 75078
Corey@...
Thanks so much for this effort!
Corey and Jenni Graham
1996 PT42 Series60
Prosper, TX/ Osage Beach, MO
--- In WanderlodgeForum@yahoogroups.com, jim riordan wrote:
> I would like one
> Jim Riordan
> 851 Johnson av
> Suite 100
> Stuart, fl 34994
> 772 260 1328
> scan
> 448 Bad Scan
> 450 Bad Scan
> 451 Bad Scan
> 452 Bad Scan
> 456 Bad Scan
> 470 2 of 11
> 471 3 of 11
> 472 4 of 11
> 473 5 of 11
> 474 6 of 11
> 475 7 of 11
> 476 8 of 11
> 477 9 of 11
> 478 10 of 11
> 479 11 of 11
> 480 Copy 5 of 11
> 481 Copy 5 of 11
> 483 3 of 3
> 484 1 of 3
> 485 2 of 3
> 486 3 of 3
> 487 3 of 3
> 489 2 of 14
> 490 3 of 14
> 491 4 of 14
> 492 5 of 14
> 493 6 of 14
> 494 7 of 14
> 495 8 of 14
> 496 9 of 14
> 497 10 of 14
> 498 11 of 14
> 500 " " 6 of 11
> # 6087878
> 506 Same As Above
> Kurt Horvath
> 95 PT 42 WLWB
> 10AC
> --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath"
> > David,
> sez
> > Hello.
> > Kurt Horvath
> > 95 PT 42
> > 10AC
> 0
10-09-2008, 04:01
Post: #25
Corey,
There's one on the way.
Kurt Horvath
95 PT 42
10AC
--- In WanderlodgeForum@yahoogroups.com, "coreyg67" wrote:
> Kurt,
I continually get a
> Anyways,
will gladly help you offset
> Corey Graham
> Prosper, TX 75078
> Corey@...
> 1996 PT42 Series60
> > I would like one
> > Jim Riordan
> > 851 Johnson av
> > Suite 100
> > Stuart, fl 34994
> > 772 260 1328
you
for. I
at
at
search
search
side
duplicates
scan
few
have
to
charge,
progresses
when
in
project
this
> > scan
> > 448 Bad Scan
> > 450 Bad Scan
> > 451 Bad Scan
> > 452 Bad Scan
> > 456 Bad Scan
Front
Front
> > 470 2 of 11
> > 471 3 of 11
> > 472 4 of 11
> > 473 5 of 11
> > 474 6 of 11
> > 475 7 of 11
> > 476 8 of 11
> > 477 9 of 11
> > 478 10 of 11
> > 479 11 of 11
> > 480 Copy 5 of 11
> > 481 Copy 5 of 11
> > 483 3 of 3
> > 484 1 of 3
> > 485 2 of 3
> > 486 3 of 3
> > 487 3 of 3
> > 489 2 of 14
> > 490 3 of 14
> > 491 4 of 14
> > 492 5 of 14
> > 493 6 of 14
> > 494 7 of 14
> > 495 8 of 14
> > 496 9 of 14
> > 497 10 of 14
> > 498 11 of 14
> > 500 " " 6 of 11
Front
Superseded by
> > # 6087878
> > 506 Same As Above
Front
Front
Front
> > Kurt Horvath
> > 95 PT 42 WLWB
> > 10AC
> > wrote:
> > > David,
Nashville
> > sez
> > > Hello.
> > > Kurt Horvath
> > > 95 PT 42
> > > 10AC
> > 0
10-09-2008, 04:27
Post: #26
I have 7 CD's left over from the 50 I made and packaged for mailing.
If you would like one I need your mailing address. My e-mail is
KGUNS@... Or you can post it here.
Most everyone has asked if they can help out with the cost. I have
let you set the cost, the folks that have just gone ahead and sent a
little help has averaged $20.00. You are under no obligation to
contribute.
The little lady didn't quit understand why I did this. I did it
because I could, and if you've ever been up to your ass in
Alligators, you need to know where the red #8 wire in the front of
the coach ends up in the back of the coach, and your feed up with
paying to teach these techs how to work on your coach then you'll
understand my madness. You'll understand why this web site and the
others are PRICLESS!!!
Knowledge is Power!
Kurt Horvath
95 PT 42
10AC
08-18-2012, 05:25
Post: #27
great job did you send me disk..
Wallace & Faye Craig
95 WLWB 42
Azle, Texas
To:
Sent: Friday, September 26, 2008 10:45 PM
Subject: [WanderlodgeForum] ATTENTION ALL PT-42 OWNERS!!!!!!!!!!!!!!!
at the moment.
scan
448 Bad Scan
450 Bad Scan
451 Bad Scan
452 Bad Scan
456 Bad Scan
461
470 2 of 11
471 3 of 11
472 4 of 11
473 5 of 11
474 6 of 11
475 7 of 11
476 8 of 11
477 9 of 11
478 10 of 11
479 11 of 11
480 Copy 5 of 11
481 Copy 5 of 11
483 3 of 3
484 1 of 3
485 2 of 3
486 3 of 3
487 3 of 3
489 2 of 14
490 3 of 14
491 4 of 14
492 5 of 14
493 6 of 14
494 7 of 14
495 8 of 14
496 9 of
14
497 10 of 14
498 11 of 14
500 " " 6 of 11
# 6087878
506 Same As Above
516 1782267
Kurt Horvath
95 PT 42 WLWB
10AC
--- In "WanderlodgeForum@yahoogroups.com", "Kurt Horvath"
David,
sez
> Hello.
> Kurt Horvath
> 95 PT 42
> 10AC
0
Yahoo! Groups Links
<*> Your email settings:
(Yahoo! ID required)
mailto:"WanderlodgeForum-digest@yahoogroups.com"
mailto:"WanderlodgeForum-fullfeatured@yahoogroups.com"
User(s) browsing this thread: 13 Guest(s)
