Going to get coach
10-19-2008, 10:56
Post: #21
Going to get coach
Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
10-19-2008, 13:10
Post: #22
Going to get coach
Ernie: When mine was dumping coolant, it was pure pink in color. It
did not have any oil mixed with it, so it was only coming out the air box. Unfortunately some was going into the oil. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Wallace, when Brenda and I arrived right behind you and witnessed the gooey > mess coming from your engine and all over you Durango, I don't recall anything > smelling sweet. As I recall, it was a light brown in color. > > Ernie Ekberg > 83PT40 > Weatherford, Texas > > **************New MapQuest Local shows what's happening at your destination. > Dining, Movies, Events, News & more. Try it out > (http://local.mapquest.com/?ncid=emlcntnew00000002) > |
10-19-2008, 13:10
Post: #23
Going to get coach
included in the coolant level warning there is a sensor/sender with two wires, on puke tank a seperate module unit with five wires, some place?' and wires' .
If the sender makes contactto complete a ground to prove proper coolant level, a short in the sender or module or wires could cause a false OK to operate signal. If the sender loosing contact and not delivering continious ground is the signal that puts the bus in ramp mode ( 4 cylinder power) then the ground to the module could be disconnected. if you remember back toa 94pt postabout loosing one of two DDec computer 12v+powerlinks from the battery to the Ddec and the post claimed that it was the power to 1/2 the cylinders. Ikinda think half the power is a wierd way to wire 1/2 a computer and always wondered why his bus would run on 4 cyls. since ramp mode is 4 cylinders, may have been the ground in the battery area (where the coolant module gets its ground) that when cleaned up( in the blind search for a fix), finaly kept the bus out of ramp???????? Greg94ptCa --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > Based on my personal research and discussions with BB after this event occurred, the coolant level sensor (installed in the highest point of the radiator coolant) should have sent the engine with a DDEC II into Ramp Mode as all 8v92's with DDEC II were sent out from BB with this pre programmed. High coolant temp may not have worked if the water abruptly dumped into the crankcase but one should also expect high tranny temps in this case also. The sensors on my coach which can only safely be checked by hooking up a tester on the DDL are, coolant level, low oil pressure, high water temperature, and low fuel pressure.I have an optional coolant level module also. According to BB all should give an alarm if working properly and initiate Ramp Mode within 15 seconds of an event occurring outside the pre programmed parameters in the DDEC II. The buzzing when the key is turned on checks the circuits integrity, not the integrety of the sensors themselves. I gotta > get my coach to a shop and get it checked out. I know my coolant level is working because I removed fluid from the tank and checked it. > BB emphatically advised me not to go crossing wires on the various sensors as it could severely damage the DDEC II system. > I hope you have great luck from here on out. > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > Royale Conversion > > --- On Sun, 10/19/08, Don Bradner bluethunder@... wrote: > From: Don Bradner bluethunder@... > Subject: Re: [WanderlodgeForum] Re: Going to get coach > To: WanderlodgeForum@yahoogroups.com > Date: Sunday, October 19, 2008, 4:16 PM > > > > > > > > > > > > Correct - the DDECII does not output engine oil temp, or it would be simple to rig an alarm with VMSPC when it reached some temp. > > > > I do have an analog oil temp gauge, but it runs pretty high all of the time - I'm not sure I would notice unless it *really* went high! > > > > On 10/19/2008 at 7:30 PM ronmarabito2002 wrote: > > > > >Only thing I can think of is for the safety sensors to shut it down > > >first. Since the coolant temp did not rise, that sensor didn't do > > >anything. It needs an oil temp sensor, but this model didn't have > > >one. I'm planning to get a hold of Detroit to find out if one can be > > >added. But I think it has to do with the DDEC II > > > > > >R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "Dan Williams" danusa@ > > >wrote: > > >> > > >> Ron, Is there anything that can be done to the engine to keep this from > > >> happening again? > > >> > > >> Dan, 8v92, Jackson, ms > > >> > > >> > > >> > > >> > > >> > > >> _____ > > >> > > >> From: WanderlodgeForum@ yahoogroups. com > > >> [mailto:WanderlodgeForum@ yahoogroups. com] On Behalf Of ronmarabito2002 > > >> Sent: Sunday, October 19, 2008 11:00 AM > > >> To: WanderlodgeForum@ yahoogroups. com > > >> Subject: [WanderlodgeForum] Going to get coach > > >> > > >> > > >> > > >> Hi to all of you. I paid the bill in Calgary yesterday via direct > > >> wire transfer. The good news is: the exchange rate saved me about > > >> $4,000 dollars, so all is not bad. > > >> > > >> I will fly to Calgary in the morning to pick up the coach. I will > > >> have to button up the bedroom, since they wanted to charge me over > > >> $600 labor to do that. I won't leave Calgary until Tuesday morning. > > >> Plan to stop see a friend in Lewistown, MT hopefully the first night > > >> out. Depends on how I have to run with the re-built engine. I will > > >> take a route back home avoiding as much mountain driving as possible. > > >> > > >> Once back in the US and further south, I should be able to get back > > >> on line using my dish and I can give a report on how the engine is > > >> performing. > > >> > > >> Dick: Sorry to hear about you tranny problems. Hope they are minor. > > >> > > >> R.E. (Ron) Marabito, Dallas, TX 92WB40 > > >> > > > > > > > > > > > >----------- --------- --------- ------- > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > |
10-19-2008, 13:35
Post: #24
Going to get coach
----Based on my personal research and discussions with BB after this
event occurred, the coolant level sensor (installed in the highest point of the radiator coolant) should have sent the engine with a DDEC II into Ramp Mode as all 8v92's with DDEC II were sent out from BB with this pre programmed. High coolant temp may not have worked if the water abruptly dumped into the crankcase but one should also expect high tranny temps in this case also.---- Hi, Probably not applicable here with the sensor not set up to shut the engine down, but perhaps the info can be used somehow or for others. A few years ago, my Cummins/onan genset in my boat lost its oil plug. No doubt due to vibration, as the oil changes were always done by suction. The diesel engine was toast. Insurance paid almost all. $8700 minus about $16.00 for the low oil pressure sensor that failed. The insurance wouldn't pay for the failed part, but paid for resultant damage. I didn't bother fighting for the $16.00 ! Ross 06 LXi |
10-19-2008, 14:12
Post: #25
Going to get coach
Ron could you please confirm, IF POSSIBLE, that your coolant leak did or did not result from a failure of one of those two coolant hosesgoing to the compressor. I ask this because I think a lot of people out there have aged coolant lines and a leak up high with these hoses may look like it came from somewhere else.You were there and have the best eyes so if you think it possible the leak came from a compressor coolant line your advice could be priceless.
2008/10/19 ronmarabito2002 <"remarabito@att.net">
-- Rob, Sue & Merlin Robinson 94 WLWB |
10-19-2008, 14:19
Post: #26
Going to get coach
10-19-2008, 15:22
Post: #27
Going to get coach
This is test.Checking to see how long it takes for a reply.
2008/10/19 Leroy Eckert <"jwasnewski@yahoo.com">
10-19-2008, 15:38
Post: #28
Going to get coach
reply
10-19-2008, 15:41
Post: #29
Going to get coach
thank you
2008/10/19 Joyce and Richard Hayden <"rhhayden@msn.com">
10-19-2008, 19:59
Post: #30
Going to get coach
Ron will be out of pocket for a couple days till his coach and satellite service gets further south.
Ernie Ekberg 83PT40 Weatherford, Texas |
User(s) browsing this thread: 6 Guest(s)
