Dometic refrigerator
09-23-2005, 01:07
Post: #21
An additional point to check; my Dometic had an
"in-line 12V fuse" located within the outside access
hole compartment that was not shown on the schematics
and that I discovered quite by accident. It was
wrapped with electrician's tape making me believe it
was a butt-splice that had been excessively taped.
Upon unwrapping, it appeared as an original red #12
gauge, stranded wire, in-line, fuse connection and not
someone's afterthought spliced into place.
John Suter
--- Blair wrote:
> One quick point....the board needs a min of 12 volts
> to operater.....check
> your batteries...Blair
> At 08:16 PM 9/22/2005, you wrote:
> >Bill, there are many things that can go wrong but
> if you have power
> >and gas then it gets smaller, you can call Dinasaur
> Electronics
> >directly and they have techs that will talk you
> thru checking the
> >board out and if it is a problem they will
> reference you to a dealer
> >they are not there to sell you anything but will
> spend time helping
> >you. I had a problem with my board they helped me
> troubleshoot. I
> >really appreciate there help and would recomend
> them.
> >John Mann
> >1985 pt40
> >Granbury Tx
> >--- In WanderlodgeForum@yahoogroups.com,
> "bill_brayton"
> > wrote:
> > > In my 78 FC the Dometic 3 way refer won't
> operate as gas only. It
> > > operates as DC and as AC without problem, but
> the flame won't light. I
> > > have recycled the system several times as
> indicated in the manual. I
> > > have bled the system at the back of the refer.
> There is propane
> > > flowing to the burner, but no ignition.
> > > The refer has not been on in a couple of months,
> and the gas only mode
> > > has seldom been used in the past couple of
> years. What is the next
> > > step in finding the problem?
> > > Bill Brayton
> > > 78FC
> > > Nordland, Wa.
> >YAHOO! GROUPS LINKS
> > * Visit your group
"<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum"
> on the web.
> > * To unsubscribe from this group, send an
> email to:
Wanderl\
> > * Your use of Yahoo! Groups is subject to the
> > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of
> Service.
> [Non-text portions of this message have been
> removed]
__________________________________
Yahoo! Mail - PC Magazine Editors' Choice 2005
http://mail.yahoo.com
10-15-2005, 04:41
Post: #22
We just purchased a 1988 FC in September and have put 4000 mostly pleasant
miles on her. She now needs a good vacuuming. My first question is: would
anyone be willing to tell where the built in vac was located on this model?
Slowly learning, John Barry
88FC
Carlsbad, NM
Sent: Friday, September 23, 2005 6:20 AM
Subject: Re: [WanderlodgeForum] Re: Dometic Refrigerator
One quick point....the board needs a min of 12 volts to operater.....check
>Bill, there are many things that can go wrong but if you have power
>and gas then it gets smaller, you can call Dinasaur Electronics
>directly and they have techs that will talk you thru checking the
>board out and if it is a problem they will reference you to a dealer
>they are not there to sell you anything but will spend time helping
>you. I had a problem with my board they helped me troubleshoot. I
>really appreciate there help and would recomend them.
>John Mann
>1985 pt40
>Granbury Tx
>--- In WanderlodgeForum@yahoogroups.com, "bill_brayton"
> > In my 78 FC the Dometic 3 way refer won't operate as gas only. It
> > operates as DC and as AC without problem, but the flame won't light. I
> > have recycled the system several times as indicated in the manual. I
> > have bled the system at the back of the refer. There is propane
> > The refer has not been on in a couple of months, and the gas only mode
> > has seldom been used in the past couple of years. What is the next
> > Bill Brayton
> > 78FC
> > Nordland, Wa.
>YAHOO! GROUPS LINKS
> * Visit your group
> "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the
web.
Wanderl\
SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance
Recreational vehicle dealer Used recreational vehicles Automotive
radiators
YAHOO! GROUPS LINKS
10-16-2005, 20:33
Post: #23
John,
The built-in vacuum is located on the back wall of the driver's side closet
in our WL.
We made the mistake of having a "regular" hose made for our unit. Takes up
too much room so we leave it at home.
Bill & Rita in Roanoke, VA
1987 FC-35 SB
10-17-2005, 03:04
Post: #24
Our 73FC was made before Vacumes were installed, so I went to Sears,
and bought a "Wall Mounted Shop Unit", which is long and skinny. It
is supposed to be rated at FIVE HP. Sounds a bit much!!
Anyway, It mounts well in the back corner of the front closet. With
the 18 foot hose, it will reach both ends of the coach and has a bunch
of attachments, cost was (on Sale) $69.95.....
Jack Smith
1973FC31
SoCal
--- In WanderlodgeForum@yahoogroups.com, racin41@a... wrote:
> John,
side closet
> in our WL.
Takes up
> 1987 FC-35 SB
05-06-2006, 10:09
Post: #25
Hi could anyone tell me if there is a replacement Fridge for model #
RM 1303 For a 1985 Bluebird 40 ft. that would fit the opening..
Everything that I have found are to big or to small..
Thanks in advance
Mario
05-06-2006, 12:34
Post: #26
You can use rm2820 With a small filler at the top. 0r 3862 or 3863
3863 by increasing the cutout height by abut 2".
Allen Powell
88 WBWL40
05-06-2006, 14:18
Post: #27
Hi Mario,
We just got back today with a new frig put in by Camping World. It's
the model RM2862. It's 59" high, 24" wide,24" deep..same dims as old
model. I would think your dims are the same..cost for the Americana
model was $1,183 plus $131 labor for install. Hope this helps.
Bob Lawrence
84 PT36
Tacoma, Wa.
> Thanks in advance
> Mario
05-06-2006, 14:47
Post: #28
--- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence"
> Thanks For the quick reply Bob
Mario
85 pt40
Lunenburg, Ma.
> Hi Mario,
> Bob Lawrence
> 84 PT36
> Tacoma, Wa.
> > Thanks in advance
> > Mario
05-07-2006, 14:13
Post: #29
Mario,
I also replaced my fridge with that model. About 1" shorter than the
original. No problem for the boys at camping world, they made a
piece to go in the bottom. Looks factory, no problem at all.
Jay Darst
85PT40
Springfield, IL
--- In WanderlodgeForum@yahoogroups.com, "bestvalueworcester"
> Mario
> 85 pt40
> Lunenburg, Ma.
> > Hi Mario,
It's
old
Americana
> > Bob Lawrence
> > 84 PT36
> > Tacoma, Wa.
model #
opening..
> > > Thanks in advance
> > > Mario
05-08-2006, 00:12
Post: #30
I just replaced my 29 year old Dometic RM100 with the Dometic Classic Series
RM2820 and it is the same size as the old box. Camping world has a chart that
you take your old model number and it tell you the relpacement model. The
clasic series is designed as a direct replacement. Byrne
77FC35 Louisiana
Jay Darst wrote:
Mario,
Jay Darst
85PT40
Springfield, IL
> Mario
> 85 pt40
> Lunenburg, Ma.
> > Hi Mario,
It's
old
Americana
> > Bob Lawrence
> > 84 PT36
> > Tacoma, Wa.
model #
opening..
> > > Thanks in advance
> > > Mario
SPONSORED LINKS
Recreational vehicles Recreational vehicle financing Recreational
vehicle repair Recreational vehicle rental Recreational vehicle camper
Recreational vehicle rate
YAHOO! GROUPS LINKS
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
