1995 WLWB 42, LPG GAS Main Shut off Valve.
06-18-2009, 00:48
Post: #21
Ron:
I'll see if I can locate a schematic of the LP system for your bird. I can relate to your frustration. When i bought my bird last year, I spent almost a week going through the Bird Box looking at every scrap of paper, manuals etc. I was left with nothing but confusion about everything and was totally ignorant. In spite of this, I drove the beast from Tuscon, AZ to Oneonta, Alabama about 2,000 miles. Scarey, when I think about it. Looking at my frame schematics, the LP tank should be in the center of the coach, just aft and street side of the front storage bulkhead. It would seem to me there is a removable plate on the wall just aft of the front pass-through compartment. That plate should be removable and the main cut-off valve should be behind it. As I understand the law, the government mandates a manual cut off valve and it has to be accessable somehow. I still believe your main manual valve is closed. FYI, as I began to learn about my coach, I would make lables and put them around, over, under and adjacent to every switch, toggle, handle etc. I even placed lables and warnings all over my dash area. That way, if I'm not available anyone would know where the components are and the controls for the same. Someone wisely said, these machimes will still be around after some (if not most of us)are gone. We are therefore stewards and we should make sure those who come after us don't have the same problems we have. I still have one switch on the dash, which is an accessory switch, but no one has a clue as to what it is for. Welcome to the wonderfully frustrating, yet exciting world of Blue Birds. I'll keep looking to see if I can find your LP schematic. Safe travels! Tommy |
06-18-2009, 01:26
Post: #22
06-18-2009, 02:03
Post: #23
OK, Ron:
I called Kenny Rodgers, former BB tech now working for Coachcraft in Columbus, GA. Your manual cut-off valve for your 95 WB is behind a 2'x2' plate midway up the wall in the second compartment street side. Since you do not have a wash station, there should be a bay door where my small wash station door is located. Kenny says, unscrew and remove that plate and right there on the LPG tank will sit your manual cut-off valve. See if you can find this. FYI, In addition to this excellent forum there are two other outstanding forums (or is it forii) - Wanderlodge Owners Online (which I belong to and support - it is a dues paying forum) and Wanderlodge Owners Group is a free forum. I belong to all these groups and read them several times a day. It will speed your learning curve and save you many $$$$$ and sleepless nights. There are numerous articles on these forums about your genny issues. I strong recommend you get on these groups if you have not already done so. Tommy |
06-18-2009, 02:17
Post: #24
06-18-2009, 02:20
Post: #25
06-18-2009, 03:15
Post: #26
Ron: Can you access the space behind your waste cewnter in the second bay?
On my 94, there is a pass through behind wash station that connects the front bay and the bay where my toilet pancake compressor is located. Also, I noticed in your photos there are two plates on the wall behind your pbancake compressor. The big plate could be the one you are looking for. Have you opened it and looked in? I feel like a "blind guide" because I still consider myself a newbie so I hope I am not sending you on a needless search. Tommy |
06-18-2009, 04:14
Post: #27
06-18-2009, 04:21
Post: #28
06-18-2009, 04:58
Post: #29
06-18-2009, 19:15
Post: #30
Is it an all electric coach? what is your cooktop?
Greg of Tim&Greg 94ptCA --- In WanderlodgeForum@yahoogroups.com, Ron Thompson > > I have never used the LPG gas since I have had this coach and I have an absolutely stupid question. Â Where the heck is the main LPG Shut off Valve on a 1995 WLWB 42? > > Does the Master LPG Switch that is located in the counter right in front of the sink the only switch that controls the gas supply on and off. When I turn the Alarm switch on it buzzes. There is no gas leak that I can detect anywhere so it must be buzzing because the gas supply is turned off. > > Oh, the refrigerator is running when the Inverter is on and also when the generator is on or the shore line is hooked up. It is just the Lpg mode on the frig that does not work. When You set it to lpg operation it waits about 45 seconds then the check light comes on. The LPG level indicator shows almost full of gas. The only thing I can think of is that the main shut off valve is off. > > Appreciate any help from someone who is familiar with this coach. > > Ron Thompson -Waller, Tx. > > 1995 WLWB 42' > > (cockyfox@...) > |
