Ride Height
05-05-2007, 08:00
Post: #31
Ride Height
Don
I just repeated the following and against my better judgement stuck
my head under the coach to be sure that the rears were not inflated
when the suspension switch only was on starting at a 100% dump:
1. Air up suspension only, front comes up, rear moves small
amount, similar to Mike's measurement
2. Air up tags, rear goes to ride height.
3. Dump tags, rear goes down about 1" from ride height with all
weight on drives only.
4. Dump suspension coach goes to bottom.
5. Got to #1 to repeat test
Rears definitley are not inflating until the TAG switch is turned on!
Steve Quandt
1993 PT-40
Iron Mountain, MI
> Certainly sounds like it shouldn't be, but add me to the anecdotal
list that says it is working that way. I'm still very new to this,
and have been in some tight campgrounds this trip, so I've tried to
be conscientious about leaving the tag un-aired when departing; I've
noted how low the rear was when I hooked my toad up. It does not drop
when the tag is deflated on arrival.
> The answer on departure appears to be air everything up, then
release the tag air. Why? I don't know.
> Don Bradner
> 90 PT40 "Blue Thunder"
> Posting on the road by satellite from
> Grayland Beach State Park on the WA coast
> On 5/5/2007 at 6:37 AM jim riordan wrote:
> >That should not be! when you pressure up the main both front axle
> >drive axle should come up. Tag should come up with second swtich.
Set up
> >this way for getting coach in tight spots you can lift tag axle!
> > Jim Riordan
> > 88 WBWL XXV
> > Stuart, Fl.
> >smquandt wrote:
> > Mike
> >I discovered that when the suspension and the tag are both dumped
> >you turn on the suspension switch only, the front is the only
thing
> >that inflates. When you turn on the tag switch both tags and rear
> >inflate, strange. Perhaps someone has the answer why.
> >Now that I have the air bags figured out the refrigerator, NDR
1292,
> >quits, questions on that to follow.
05-05-2007, 15:32
Post: #32
Ride Height
Like Steve, I have repeated this process quite a few times over the
last several weeks since I noticed it shortly after purchasing the
coach. And in each case, the same thing occurs, just as Steve has
explained it. The drive axle bags are full and hard before the tags
are brought up as I have verified several times over the last month
or so.
Michael Brundridge
1992 WB40
Georgetown, Tx
--- In WanderlodgeForum@yahoogroups.com, "smquandt"
> Don
stuck
inflated
on!
> Steve Quandt
> 1993 PT-40
> Iron Mountain, MI
Loading...
