Installing new guage.
06-09-2007, 12:04
Post: #31
Recently My Happy Mouse trigger finger sent a few replys direct to an
e-mail address rather than to the forum posting.
So, I hope this answer to Leroy can help someone, This has worked on
our 88 FC using the replacement BB/Teleflex oil temp gage # 9153278.
This sensor will work correctly with the oil temp gage.It has
several different bushings with various thread sizes to fit the
engine block ports. Stewart-Warner part # SW280 EE-F
Available at a big truck parts store or I purchased from South West
Brake, 248-486-9866 about $15 to 20.00.
I do not know about the water temp gages or sensors. And Yes, the
bezels can be exchanged with the new gage to match the other dash
gages.
Bill 88 FC Michigan
> Ok. Jim in FL and Bill in MI
> I received the gauges from BB. The engine oil temp gauge is
Teleflex pn 9153278 and is a substitute for the original gauge. The
index begins with 140 and the bezel is different. I believe the
original bezel can be placed on this gauge but I have decided to
paint the elevated ring silver with a paint stick. The genset water
temp gauge has the same index (from memory I will verify this w/e)
and the same bezel as the engine oil temp gauge. The genset oil
pressure gauge has the same index and the same bezel as the original
gauge. Go figure that out. All of them have new Teleflex pn's. The
faces are virtually identical.
> BB sent me a tranny sender for the engine oil pressure gauge. I
will put that on the tranny.
> Jim, based on your post should I call Teleflex and order the sender
for the new configuration gauge?
> Thanks;
> Leroy Eckert
> 1990WB-40"Smoke N Mirrors"
> Niceville, FL
> From: jim riordan
> Sent: Tuesday, June 05, 2007 8:16 AM
> Subject: Re: [WanderlodgeForum] Installing new guage.
> Leroy,
> I just replaced many flaky guages on my coach. I got the new
guage from BB. the indexing was different and better. I called BB
(earl) to get the correct (new) sending unit he sent me the wrong one!
an 028 I then called teleflex Joe Federsal and spoke to him he sent
the correct one an 032, i called earl and told him that he needed to
check with Teleflex about stocking the correct sending unit for this
guage. The guage is better because it is more presise than the old
one.
> Jim Riordan
> 88 WBWL XXV
> Leroy Eckert wrote:
> Thanks Howard:
> I'll give them a call.
> Leroy Eckert
> Niceville, FL
> From: truitt44@...
> Sent: Monday, June 04, 2007 9:25 AM
> Subject: [WanderlodgeForum] Installing new guage.
> Leroy,
> Contact Chuck at APT Instruments in Bloomington, Mn. about
servicing Teleflex gauges 952-881-7095.
> Howard Truitt
> Camilla, Ga.
> 86 PT40
> > From: "Leroy Eckert"
> > Date: 2007/06/04 Mon AM 09:59:05 EDT
> > To:
> > Subject: Re: [WanderlodgeForum] Re: Installing new guage.
> > I want to pass along information I am receiving from Teleflex,
Bluebird and other suppliers I e-mailed over the weekend. Oil
Temperature gauge 54438 Bluebird part number 3865334 shows to be in
stock at Bluebird today. I will see if the indexing is the same when
I receive it. According to Teleflex this and other Teleflex gauges
Bluebird used are no longer in production and are no longer available
if Bluebird does not have inventory. I am replacing 3 flakey gauges
now while they are available.
> > Steve Birtles and I are searching for an instrument shop to
rebuild the original gauges. I would like to keep my bird dash
looking original. In the long term that may be difficult to do.
> > Leroy Eckert
> > Niceville, FL
> > From: pattypape
> > Sent: Saturday, May 12, 2007 9:36 AM
> > Subject: [WanderlodgeForum] Re: Installing new guage.
> > Jim,
> > Yep, that is the correct gage, Teleflex # 9153278.
> > The BB# 54438 was still a good number, But
> > they shipped the updated 9153278 gage , Then the temp would read
> > really high, That is why there is a lot of confusion , when
> > replacing gages, the sensor must be replaced also.
> > I like the new scale for the oil temp,200 to 230
> > Not so good for the rear axle because, it only heats up to
about
> > 140 to 170. lowest part of the gage.
> > Bill 88 FC Michigan
> > --- In WanderlodgeForum@yahoogroups.com, jim riordan
> > wrote:
> > > Thanks,
> > > The new guage is not a 54438 Earl said the did not maske it
> > anymore. He sent me a "superseded" one the index numbers were
> > different. He sent me a new sensor it was for the old type
guage it
> > was reading 40% high. I called Teleflex spoke to Joe Federsal
(great
> > help) he sent me the correct sensor for the guage that I got
from
> > earl, everything seems to work now. This new guage 9153278 is
> > improved in that it first register point is at 140 rather than
100,
> > top is 320 like the old one. the end result is that the gauge
will
> > provide more accurate readings in the operational range than
the old
> > one. I hope!
> > > Jim RIordan
> > > 88 WBWL XXV
> > > Stuart, Fl.
> > > pattypape wrote:
> > > Jim,
> > > I replaced both oil temp gages on our 88 FC ( 3208 oil and
rear
> > axle
> > > temps) BB gage part number 54438, It is a Teleflex gage.
> > > If this is your gage the temp sensor is a Stewart-Warner,
part
> > > number 280EEF . It is available at truck parts stores. It has
> > > several threaded bushings for all thread sizes, One will
match the
> > > original threads. BB did not have the correct sensor.
> > > Bill 88 FC Michigan
> > > wrote:
> > > > I have just replace my oil temp guage. I got it from BB and
it is
> > > indexed differently from the original one. I needed to get a
new
> > temp
> > > sending switch also...
> > > > Jim Riordan
> > > > 88 WBWL XXV
> > > > Stuart, Fl.
> > > > "Ralph L. Fullenwider" wrote:
> > > > Hi Art:
> > > > **CAUTION** **CAUTION**
> > > > Remove the 4 bottom out side covers of the lower dash. If
> > lower
> > > dash
> > > > has been out before then it should lift up from the front
edge
> > and
> > > slip
> > > > forward a little. If it has not been out before then on the
left
> > > side of
> > > > the lower dash, under one of the blank covers, will be a
screw
> > that
> > > has to
> > > > come out.
> > > > Now, with the lower dash panel slid forward, remove the cb
mic
> > from
> > > the
> > > > holder and take the long screw out that holds the cb mic
holder.
> > > Now the
> > > > upper lower dash should be free on that side and if it has
been
> > > removed it
> > > > will probably be free to tilt forward. If it has not been
out
> > > before then
> > > > you need a looooong phillips screwdriver, hold the right
side of
> > > the upper
> > > > lower dash out and reach in with the long phillips and un
screw
> > the
> > > far
> > > > left L bracket. In the bottom center of the upper lower
dash,
> > after
> > > the
> > > > lower panel is moved forward you should see a screw that
needs to
> > > come out
> > > > as well. Now your upper lower dash panel should be free to
tilt
> > > forward.
> > > > **CAUTION** Do NOT force it, if it won't come out enough to
> > replace
> > > the
> > > > gauge, find what is holding it. I cannot stress **CAUTION**
> > enough
> > > on this.
> > > > While your in there, remove the light sockets with the
lamps from
> > > the other
> > > > gauges and clean or replace them.
> > > > Your going to find a "rats nest" of wiring under and behind
both
> > > panels.
> > > > Remember if you drill, spindle or pierce any of those
panels,
> > they
> > > are shot
> > > > and cannot be brought back. Use only holes provided for
screws
> > and
> > > such.
> > > > Good luck
> > > > Safe travels,
> > > > Ralph and Charolette Fullenwider
> > > > 84FC35
> > > > Ralph's RV Solutions, Duncan, Oklahoma
> > > > At 06:44 PM 5/10/2007 +0000, you wrote:
> > > > >I have recieved a new engine oil temp guage from the
fellow I
> > > bought
> > > > >my coach from. Now to install it. The guage is on the
verticle
> > > part of
> > > > >the dash panel.Has anyone been into that panel? Any advise
will
> > be
> > > > >better than me going in there blind!
> > > > >Art Weatherly
> > > > >Riverside Ca.
> > > > >'85 PT36
> > > > Moody friends. Drama queens. Your life? Nope! - their life,
your
> > > story.
> > > > Play Sims Stories at Yahoo! Games.
> > > > [Non-text portions of this message have been removed]
> > > Be a PS3 game guru.
> > > Get your game face on with the latest PS3 news and previews
at
> > Yahoo! Games.
> Yahoo! oneSearch: Finally, mobile search that gives answers, not
web links.
06-09-2007, 13:52
Post: #32
Thanks Bill. I received your e-mail and answered it. You didn't receive my
response so here it is. Smile Seems like the electronic world doesn't always get r
done. They gotta dig up some more cable to keep it going.
I e-mailed the company and they do not stock the parts. I suppose I can order
them. I also contacted Teleflex and have a list of senders by part number and ID
that will work . I e-mailed Earl at BB and have not heard back. I expect to hear
form him on Monday. I have found I get a very rapid response from BB via e-mail.
One would concluded that senders would be available for the gauges. What I have
determined is this. The International Line is shipped primarily to
manufacturers. Boats, motorhomes etc. That is the market.
I certainly appreciate your help.
Leroy Eckert
1990 WB-40"Smoke N Mirrors"
Niceville, FL
Sent: Saturday, June 09, 2007 7:04 PM
gages.
Bill 88 FC Michigan
> Thanks;
> Leroy Eckert
> Niceville, FL
> From: jim riordan
> Leroy,
one.
> Jim Riordan
> 88 WBWL XXV
> Leroy Eckert wrote:
> Thanks Howard:
> Leroy Eckert
> Niceville, FL
> From: truitt44@...
> Leroy,
> Howard Truitt
> Camilla, Ga.
> 86 PT40
> > To:
> > Leroy Eckert
> > Niceville, FL
> > From: pattypape
> > Jim,
about
> > Bill 88 FC Michigan
> > wrote:
> > > Thanks,
guage it
(great
from
100,
will
the old
> > one. I hope!
> > > Jim RIordan
> > > 88 WBWL XXV
> > > Stuart, Fl.
> > > pattypape wrote:
> > > Jim,
rear
> > axle
part
match the
> > > Bill 88 FC Michigan
it is
new
> > temp
> > > > Jim Riordan
> > > > 88 WBWL XXV
> > > > Stuart, Fl.
> > > > Hi Art:
> > lower
> > > dash
edge
> > and
> > > slip
left
> > > side of
screw
> > that
> > > has to
> > > > come out.
mic
> > from
> > > the
holder.
> > > Now the
been
> > > removed it
out
> > > before then
side of
> > > the upper
screw
> > the
> > > far
dash,
> > after
> > > the
needs to
> > > come out
tilt
> > > forward.
> > replace
> > > the
> > enough
> > > on this.
lamps from
> > > the other
both
> > > panels.
panels,
> > they
> > > are shot
screws
> > and
> > > such.
> > > > Good luck
> > > > Safe travels,
> > > > 84FC35
fellow I
> > > bought
verticle
> > > part of
will
> > be
> > > > >Art Weatherly
> > > > >Riverside Ca.
> > > > >'85 PT36
your
> > > story.
> > > Be a PS3 game guru.
at
> > Yahoo! Games.
web links.
06-09-2007, 14:06
Post: #33
Haha , Ernie
Ya can't turn your clock back ,
not the speedo/odometer nor the hour meter.
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote:
> Bill- How come our fingers get too fast- too fat when we age? It
seems that
> my laptop keys are closer together then in years past.
> Ernie Ekberg
> 83PT40
> Livingston, Mt
> ------expecting Mike Hoehnstein to call on his arrival in
Livingston, Mt
> ************************************** See what's free at
http://www.aol.com.
06-09-2007, 14:13
Post: #34
Leroy,
We are learning, I have not found a dealer that stocks the Teleflex
gages, West Marine will special order ,But your part numbers must be
correct, or you may own the mistake.
BB has gages , but as of my last experiences their sensors do not
match. So it is best to get the correct part numbers from Joe at
Teleflex Marine tech support.
Bill 88 FC
receive my response so here it is. Smile Seems like the electronic
world doesn't always get r done. They gotta dig up some more cable to
keep it going.
can order them. I also contacted Teleflex and have a list of senders
by part number and ID that will work . I e-mailed Earl at BB and have
not heard back. I expect to hear form him on Monday. I have found I
What I have determined is this. The International Line is shipped
primarily to manufacturers. Boats, motorhomes etc. That is the
market.
> Leroy Eckert
> Niceville, FL
> From: pattypape
to an
on
9153278.
West
> gages.
> Bill 88 FC Michigan
The
water
w/e)
original
The
sender
> > Thanks;
> > Leroy Eckert
> > Niceville, FL
> > From: jim riordan
> > Leroy,
one!
sent
to
this
old
> one.
> > Jim Riordan
> > 88 WBWL XXV
> > Leroy Eckert wrote:
> > Thanks Howard:
> > Leroy Eckert
> > Niceville, FL
> > From: truitt44@
> > Leroy,
> > Howard Truitt
> > Camilla, Ga.
> > 86 PT40
> > > To:
Teleflex,
in
when
gauges
available
gauges
> > > Leroy Eckert
> > > Niceville, FL
> > > From: pattypape
> > > Jim,
read
> about
> > > Bill 88 FC Michigan
> > > wrote:
> > > > Thanks,
> guage it
> (great
> from
than
> 100,
> will
> the old
> > > one. I hope!
> > > > Jim RIordan
> > > > 88 WBWL XXV
> > > > Stuart, Fl.
> > > > pattypape wrote:
> > > > Jim,
> rear
> > > axle
> part
has
> match the
> > > > Bill 88 FC Michigan
> it is
a
> new
> > > temp
> > > > > Jim Riordan
> > > > > 88 WBWL XXV
> > > > > Stuart, Fl.
> > > > > Hi Art:
> the
> > > lower
> > > > dash
> edge
> > > and
> > > > slip
> left
> > > > side of
> screw
> > > that
> > > > has to
> > > > > come out.
cb
> mic
> > > from
> > > > the
> holder.
> > > > Now the
has
> been
> > > > removed it
> out
> > > > before then
> side of
> > > > the upper
> screw
> > > the
> > > > far
> dash,
> > > after
> > > > the
> needs to
> > > > come out
to
> tilt
> > > > forward.
to
> > > replace
> > > > the
**CAUTION**
> > > enough
> > > > on this.
> lamps from
> > > > the other
behind
> both
> > > > panels.
> panels,
> > > they
> > > > are shot
> screws
> > > and
> > > > such.
> > > > > Good luck
> > > > > Safe travels,
> > > > > 84FC35
> fellow I
> > > > bought
> verticle
> > > > part of
advise
> will
> > > be
> > > > > >Art Weatherly
> > > > > >Riverside Ca.
> > > > > >'85 PT36
life,
> your
> > > > story.
> > > > Be a PS3 game guru.
> at
> > > Yahoo! Games.
not
> web links.
06-09-2007, 14:28
Post: #35
You are correct based on what I have learned. Teleflex does not have a retail
department. The Teleflex tech department has been very helpful as has West
Marine here in Fort Walton Beach. BB sent me a tranny sender for the oil temp
gauge . I will install that because I am sure mine is the original. Problem is,
if the computer doesn't have the info, substituted product or otherwise, no one
knows. That is not a knock on BB, that is the electronic world in which we live.
Not necessarily a perfect world.
I will post all the pn's when I get it figured out.
Leroy Eckert
Niceville, FL
Power went down this afternoon in a Thunderstorm and everything blacked out
including the computer. Same thing happened during Hurricane Katrina for 7 days.
I learned to like cold water. Smile
----- Original Message --.---
Sent: Saturday, June 09, 2007 9:13 PM
Leroy,
Bill 88 FC
keep it going.
market.
> Leroy Eckert
> Niceville, FL
> From: pattypape
to an
on
9153278.
West
> gages.
> Bill 88 FC Michigan
The
water
w/e)
original
The
sender
> > Thanks;
> > Leroy Eckert
> > Niceville, FL
> > From: jim riordan
> > Leroy,
one!
sent
to
this
old
> one.
> > Jim Riordan
> > 88 WBWL XXV
> > Leroy Eckert wrote:
> > Thanks Howard:
> > Leroy Eckert
> > Niceville, FL
> > From: truitt44@
> > Leroy,
> > Howard Truitt
> > Camilla, Ga.
> > 86 PT40
> > > To:
Teleflex,
in
when
gauges
available
gauges
> > > Leroy Eckert
> > > Niceville, FL
> > > From: pattypape
> > > Jim,
read
> about
> > > Bill 88 FC Michigan
> > > wrote:
> > > > Thanks,
> guage it
> (great
> from
than
> 100,
> will
> the old
> > > one. I hope!
> > > > Jim RIordan
> > > > 88 WBWL XXV
> > > > Stuart, Fl.
> > > > pattypape wrote:
> > > > Jim,
> rear
> > > axle
> part
has
> match the
> > > > Bill 88 FC Michigan
> it is
a
> new
> > > temp
> > > > > Jim Riordan
> > > > > 88 WBWL XXV
> > > > > Stuart, Fl.
> > > > > Hi Art:
> the
> > > lower
> > > > dash
> edge
> > > and
> > > > slip
> left
> > > > side of
> screw
> > > that
> > > > has to
> > > > > come out.
cb
> mic
> > > from
> > > > the
> holder.
> > > > Now the
has
> been
> > > > removed it
> out
> > > > before then
> side of
> > > > the upper
> screw
> > > the
> > > > far
> dash,
> > > after
> > > > the
> needs to
> > > > come out
to
> tilt
> > > > forward.
to
> > > replace
> > > > the
**CAUTION**
> > > enough
> > > > on this.
> lamps from
> > > > the other
behind
> both
> > > > panels.
> panels,
> > > they
> > > > are shot
> screws
> > > and
> > > > such.
> > > > > Good luck
> > > > > Safe travels,
> > > > > 84FC35
> fellow I
> > > > bought
> verticle
> > > > part of
advise
> will
> > > be
> > > > > >Art Weatherly
> > > > > >Riverside Ca.
> > > > > >'85 PT36
life,
> your
> > > > story.
> > > > Be a PS3 game guru.
> at
> > > Yahoo! Games.
not
> web links.
06-09-2007, 17:03
Post: #36
Bill,
Thank you for your call a few days back...and your insite is right on.
Folks, pay attention...me too.
Curt Sprenger
Anaheim Hills, Calif.
pattypape wrote:
> Leroy,
> Bill 88 FC
> , "Leroy Eckert"
> keep it going.
> market.
> > Leroy Eckert
> > Niceville, FL
> > From: pattypape
> to an
> on
> 9153278.
> West
> > gages.
> > Bill 88 FC Michigan
> , "Leroy Eckert"
> The
> water
> w/e)
> original
> The
> sender
> > > Thanks;
> > > Leroy Eckert
> > > Niceville, FL
> > > From: jim riordan
> > > Leroy,
> one!
> sent
> to
> this
> old
> > one.
> > > Jim Riordan
> > > 88 WBWL XXV
> > > Leroy Eckert wrote:
> > > Thanks Howard:
> > > Leroy Eckert
> > > Niceville, FL
> > > From: truitt44@
> > > Leroy,
> > > Howard Truitt
> > > Camilla, Ga.
> > > 86 PT40
> > > > To: > >
> Teleflex,
> in
> when
> gauges
> available
> gauges
> > > > Leroy Eckert
> > > > Niceville, FL
> > > > From: pattypape
> > > > Jim,
> read
> > about
> > > > Bill 88 FC Michigan
> , jim riordan
> > > > wrote:
> > > > > Thanks,
> > guage it
> > (great
> > from
> than
> > 100,
> > will
> > the old
> > > > one. I hope!
> > > > > Jim RIordan
> > > > > 88 WBWL XXV
> > > > > Stuart, Fl.
> > > > > pattypape wrote:
> > > > > Jim,
> > rear
> > > > axle
> > part
> has
> > match the
> > > > > Bill 88 FC Michigan
> , jim riordan
> and
> > it is
> a
> > new
> > > > temp
> > > > > > Jim Riordan
> > > > > > 88 WBWL XXV
> > > > > > Stuart, Fl.
> > > > > > Hi Art:
> > the
> > > > lower
> > > > > dash
> > edge
> > > > and
> > > > > slip
> the
> > left
> > > > > side of
> > screw
> > > > that
> > > > > has to
> > > > > > come out.
> cb
> > mic
> > > > from
> > > > > the
> > holder.
> > > > > Now the
> has
> > been
> > > > > removed it
> > out
> > > > > before then
> > side of
> > > > > the upper
> > screw
> > > > the
> > > > > far
> > dash,
> > > > after
> > > > > the
> > needs to
> > > > > come out
> to
> > tilt
> > > > > forward.
> to
> > > > replace
> > > > > the
> **CAUTION**
> > > > enough
> > > > > on this.
> > lamps from
> > > > > the other
> behind
> > both
> > > > > panels.
> > panels,
> > > > they
> > > > > are shot
> > screws
> > > > and
> > > > > such.
> > > > > > Good luck
> > > > > > Safe travels,
> > > > > > 84FC35
> > fellow I
> > > > > bought
> > verticle
> > > > > part of
> advise
> > will
> > > > be
> > > > > > >Art Weatherly
> > > > > > >Riverside Ca.
> > > > > > >'85 PT36
> life,
> > your
> > > > > story.
> > > > > Be a PS3 game guru.
> > at
> > > > Yahoo! Games.
> not
> > web links.
06-10-2007, 11:06
Post: #37
Curt,
Thanks and you are welcome, Good to hear your voice.
On another note; I think we aided in an ACE hardware inventory
shortage. No fuzzy pile in the Mid-West.
Amazing what an impact this Forum has on the world. Smile
and possibly the financial community,,,, Smile Smile
Bill 88 FC Michigan.
> Bill,
on.
> Curt Sprenger
> pattypape wrote:
> > Leroy,
Teleflex
be
> > Bill 88 FC
> > , "Leroy Eckert"
cable to
> > keep it going.
suppose I
senders
have
I
gauges.
> > market.
> > > Leroy Eckert
> > > Niceville, FL
> > > From: pattypape
> > to an
worked
> > on
> > 9153278.
> > West
dash
> > > gages.
> > > Bill 88 FC Michigan
> > , "Leroy Eckert"
> > The
> > water
> > w/e)
> > original
> > The
I
> > sender
> > > > Thanks;
> > > > Leroy Eckert
> > > > Niceville, FL
> > > > From: jim riordan
> > > > Leroy,
BB
wrong
> > one!
> > sent
needed
> > to
> > this
> > old
> > > one.
> > > > Jim Riordan
> > > > 88 WBWL XXV
> > > > Leroy Eckert wrote:
> > > > Thanks Howard:
> > > > Leroy Eckert
> > > > Niceville, FL
> > > > From: truitt44@
> > > > Leroy,
> > > > Howard Truitt
> > > > Camilla, Ga.
> > > > 86 PT40
> > > > > To: > > >
> > Teleflex,
> > in
> > when
> > gauges
> > available
> > gauges
> > > > > Leroy Eckert
> > > > > Niceville, FL
> > > > > From: pattypape
> > > > > Jim,
> > read
> > > about
> > > > > Bill 88 FC Michigan
> > , jim riordan
> > > > > wrote:
> > > > > > Thanks,
it
were
> > > guage it
Federsal
> > > (great
> > > from
is
> > than
> > > 100,
gauge
> > > will
> > > the old
> > > > > one. I hope!
> > > > > > Jim RIordan
> > > > > > 88 WBWL XXV
> > > > > > Stuart, Fl.
> > > > > > pattypape wrote:
> > > > > > Jim,
> > > rear
> > > > > axle
> > > part
> > has
> > > match the
> > > > > > Bill 88 FC Michigan
> > , jim riordan
> > and
> > > it is
> > a
> > > new
> > > > > temp
> > > > > > > Jim Riordan
> > > > > > > 88 WBWL XXV
> > > > > > > Stuart, Fl.
> > > > > > > Hi Art:
If
> > > the
> > > > > lower
> > > > > > dash
front
> > > edge
> > > > > and
> > > > > > slip
> > the
> > > left
> > > > > > side of
> > > screw
> > > > > that
> > > > > > has to
> > > > > > > come out.
> > cb
> > > mic
> > > > > from
> > > > > > the
> > > holder.
> > > > > > Now the
> > has
> > > been
> > > > > > removed it
been
> > > out
> > > > > > before then
> > > side of
> > > > > > the upper
un
> > > screw
> > > > > the
> > > > > > far
> > > dash,
> > > > > after
> > > > > > the
> > > needs to
> > > > > > come out
> > to
> > > tilt
> > > > > > forward.
> > to
> > > > > replace
> > > > > > the
> > **CAUTION**
> > > > > enough
> > > > > > on this.
> > > lamps from
> > > > > > the other
> > behind
> > > both
> > > > > > panels.
> > > panels,
> > > > > they
> > > > > > are shot
> > > screws
> > > > > and
> > > > > > such.
> > > > > > > Good luck
> > > > > > > Safe travels,
> > > > > > > 84FC35
> > > fellow I
> > > > > > bought
> > > verticle
> > > > > > part of
> > advise
> > > will
> > > > > be
> > > > > > > >Art Weatherly
> > > > > > > >Riverside Ca.
> > > > > > > >'85 PT36
> > life,
> > > your
> > > > > > story.
> > > > > > Be a PS3 game guru.
previews
> > > at
> > > > > Yahoo! Games.
> > not
> > > web links.
