Dometic refir not cooling well
09-08-2007, 23:57
Post: #31
Pete,
Reduced the setting to "3" after getting to 25 degrees on "5". Now, on the "3" setting, reefer stays around 38-40 degrees. -Shane --- In WanderlodgeForum@yahoogroups.com, Peter T. Arnold > > On Sun, 02 Sep 2007 21:41:18 -0000, you wrote: > > >Scott, > > > > I added 2 12V fans to the back compartment which blow across the > >evaporator coils. They dropped my temp in the 'fridge from 45-50 to > >around 25 degrees when the setting is on "5". It was a cheap fix and > >has worked great for the past few months. Bob Robinson and John Finn > >had similar setups and were kind enough to share the idea with me at > >OshKosh. > > > >Shane Fedeli > >85PT40 > >Hershey, PA > > Why would you want to freeze water in your fridge? Does'nt that make > the beer hard to drink? > > > -- > > Regards, > Pete Arnold > > You only need two things in life....... > Duct tape and WD40 > If it moves and shouldn't...use the duct tape. > If it doesn't move and should...use the WD40! > |
