Do they sell any devices?
10-10-2007, 02:17
Post: #31
Thanks, Don. I will check that website out. Sounds interesting.
Ron Thompson 1995 WLWB 42' Don Bradner VMSpc is software that monitors diesel engines, along with the hardware interface between the engine computer and a laptop. It is a silverleaf product, http://www.silverleafelectronics.com The engine computer outputs fuel flow and also mileage (from the transmission computer), so one of the gauges in the many that VMSpc has is a tank monitor. You reset it at each fill, and it shows three things - miles to empty, gallons remaining, and MPG - the latter can be for the tank, or short-term. Since other VMSpc gauges cover short-term mileage I run it for the tankful. Except when there's a lot of generator usage I find that what the monitor tells me (subtracting gallons-to-empty from capacity) is very close to what will happen when I fill up. Don Bradner 90 PT40 "Blue Thunder" Posting by satellite from the 8000 ft level at Raton Pass on the Colorado/NM border On 10/9/2007 at 9:29 AM Ron Thompson wrote: >Don, > >Dumb question but can you explain what a VMSpc with a tank monitor is? >And where can I get one. > >Ron Thompson >95 WLWB 42' > > >Don Bradner > Running VMSpc with a tank monitor I know within just a few gallons >what I will be taking when I fill. The problem is that I only have one >fill, and it is on the opposite side from the metering pump on 99% of all >fuel islands. Using the satellite pump you can't see how many gallons you >have pumped. I don't really like to leave the nozzle unattended, but that >has not yet been a concern. I watch the meter side until I'm about 20 >gallons shy of expected full, then hurry around and set the nozzle on a >lower setting. Have never experienced splashback that way. > > Don Bradner > 90 PT40 "Blue Thunder" > Posting by satellite from Falcon, Colorado (East of Colorado Springs) > Heading out today for Raton Pass Ron Thompson -Waller, Tx. 1995 WLWB 42'Blue Bird (cockyfox@...) [Non-text portions of this message have been removed] |
10-10-2007, 02:27
Post: #32
Fuel collars are cheap and re-useable if storred in a zip lock bag.
Any marina should have them. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, randymerri@... wrote: > > Hey Macy, > > Do the engineers at Complete Coach Works have any solutions to the fuel > splash back problem nearly every Wanderlodge owner encounters? I know we'd all > appreciate a solution and you'd probably get a standing ovation at RIV if you > come up with something simple. I know it is frustrating to have 18 wheelers > waiting for me to fill a 300 gallon tank when I can only run the nozzle at slow > to medium speed. > > Any input would be greatly appreciated. > > > Randy Merrill > 1993 40' WLWB > Ocala, Fl > > > > ************************************** See what's new at http://www.aol.com > > > [Non-text portions of this message have been removed] > |
