Price of a Bluebird
01-20-2008, 12:34
Post: #31
Price of a Bluebird
Bill & Howard
I Didn't use any moisture barrier under my wood floor. I don't have the wood in the living room of the coach & I haven't heard any more noise in the driving area. If I was doing it again I think I would bring the wood right up to the seats & then put carpet in the driving area. I think it would be hard to use the wood under the drivers feet. Bill I didn't use wood on the steps because of the fill for the jack's I use the carpet & it looks good but you have to protect it form the outside elements. If I could get the commercial rubber treads like Ernie gets I might try them when this gets bad & my other carpet is still good. Maybe the next time I'll put a walkway of granite down the middle of the living room & carpet on each side. I like to keep improving things. Bill someone gave me another fix for my fridge today. If it works I will post it. Don Spithaler 89 SP 36' Butler, PA 20, 2008 5:59 PM, pattypape > > > > > > > > Don, > > did you cover the steps?? > > Bill 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com, "Donald Spithaler" > > > > > > Hi Howard > > I know I'm not Ernie or Leroy but I have been working with wood > all > > my life. In my 89 SP I put down Bruce 3/8 th inch prefinished when I > > got my coach. I noticed after a year i cold see the wear from a > little > > moisture & general usage. We were particular with it too. I glued it > > down. Two years I put 3/4" X 5-1/8 " with aluminum oxide finish on > it > > in my house. I got rid of all my carpet. I liked it so well I put it > > in my coach. I used a screw called a trim screw. They took a #1 > > square head bit. I predrilled the toung & then screwed it down. It > > isn't as fast as gluing but not near as messy & if you want to take > it > > up all you have to do is unscrew it. When I took up the Bruce floor > it > > came up in splinters other wise good for fire wood. We have had it > > down for two years & it looks like new. > > > > Don Spithaler > > 89 SP 36 > > Butler, PA ------ In Zephyrhills, FL > > n On Jan 19, 2008 11:17 AM, Howard O. Truitt > > > > > > > > > > > > > > > Ernie and Leroy, > > > Will a floating floor work OK in a bird. > > > 3/4 inch thick engineered overall, 1/4 inch top layer aluminum > oxide finish. > > > Howard T., Sowega, 86 PT40 > > > > > > > > > ----- Original Message ----- > > > From: erniecarpet@... > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Friday, January 18, 2008 6:53 PM > > > Subject: Re: [WanderlodgeForum] Price of a Bluebird > > > > > > > > > > > > Leroy-- I wonder if any of them need flooring? > > > > > > Ernie Ekberg > > > 83PT40 > > > Weatherford, Tx > > > I could use some work > > > Leroy-- I wonder if any of them need flooring? > > > > > > Ernie Ekberg > > > 83PT40 > > > Weatherford, Tx > > > I could use some work > > > > > > > > > ________________________________ > > > Start the year off right. Easy ways to stay in shape in the new > year. > > > > > > > > > > > > > > > > > > ________________________________ > > > > > > > > > No virus found in this incoming message. > > > Checked by AVG Free Edition. > > > Version: 7.5.503 / Virus Database: 269.19.2/1224 - Release Date: > 1/14/2008 > > > 5:39 PM > > > > > > > > > > > > > > > > > > > |
01-20-2008, 13:27
Post: #32
Price of a Bluebird
Exactly what I did. 1/4 inch cork underlayment, glued to the plywood sub floor - no vapor barrier. (Actually, there's a steel "vapor barrier" under the plywood anyway.)
Then, in my case, bamboo wood tongue and groove boards glued to the underlayment. The floor is quite solid without any extra noise when walking on it. The underlayment adds sound and insulation to the flooring. With the tongue and groove, the underlayment was optional -- but it also made the surface more uniform as well as adding the insulation and sound deadening. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Jan 20, 2008, at 12:21 PM, Howard O. Truitt wrote:
01-23-2008, 12:21
Post: #33
Price of a Bluebird
On Jan 19, 2008 6:41 AM, brad barton <bbartonwx@...> wrote:
> > An interesting thread to start for guys that have enough spare time to > figure it up would be..."How much has your coach cost you per mile?" I haven't owned my coach a year yet, but I have a comprehensive spreadsheet listing all costs involved. So if anyone wants info, I can get it, just let me know. > You could certainly stay in nice hotels along the way for a lot less. > It's the lifestyle. I'm in agreement here - of course this depends on the length of your trip in both distance and time. Shorter distance trips with longer time spent at one location, you can get off a lot cheaper with a coach - if you ignore the initial cost of purchase. ;-) I just figured my coach was going to cost me tens of thousands of dollars more than staying in hotels would. It's worth it to have my own kitchen, bed, and bathroom with me everywhere I go. For me, though, there is a secondary element to owning a coach that makes it well worth the additional expense: It is the perfect emergency-situation vehicle. We recently had a power outage on a cold, winter night. When the house began cooling down, we retreated to the coach, fired up the generator and watched a movie in warmth and comfort. As a large chunk of the city was out, including all street lights, I turned on the spotlights and flooded our street with light throughout the entire night to deter any potential opportunistic thieves. The neighbors appreciated it as well. The security of having this resource available to my family is worth all of the money I've put into it; the vacations are just a bonus. Most people are not prepared for emergencies - who actually has the recommended amounts of water and food stocked for their family? Well, because of this coach, now I do. At any given time I've got a hundred plus gallons of fresh water, 300 gallons of diesel, and a pantry full of canned food. We can easily outlast any localized or regional emergency in comfort. In a more major, widespread emergency, we have enough fuel, food and water on board to travel halfway across the country, certainly far enough to get to a place where we could restock supplies. If we had to, we could live in the coach as long as we needed. I'm not paranoid but I am self reliant; I don't like the idea of being helpless, relying on outside help to survive. We've always been more prepared than most but having a big coach makes it easy. In my opinion, you can't put a price on that kind of security. -Ryan '86 PT-40 8V92 |
01-23-2008, 13:19
Post: #34
Price of a Bluebird
How much has my coach cost me per mile?
I don't know because I do not keep track of it. I do know it is substantially, way substantially less than the 30' Warlock Offshore I once owned. It's name was "Big Trouble". Last time I checked it was running around Newport Beach. Problem is, there aren't any bikini's around now. They have been outlawed. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA Royale Conversion Ryan Wright
Never miss a thing. Make Yahoo your homepage. |
01-27-2008, 07:24
Post: #35
Price of a Bluebird
On 1/23/08, Ryan Wright
> > I haven't owned my coach a year yet, but I have a comprehensive > spreadsheet listing all costs involved. So if anyone wants info, I can > get it, just let me know. I had enough off-list interest in this that I decided to post some statistics here: I bought my '86 PT-40 in April 2007. Since that time, the coach has been driven 3,446 miles and the genset has been run 138 hours. Expenses are as follows: Fuel: $2,800 Preventative maintenance: $375 - This is for oil changes on both the 8V92 and Yanmar genset, as well as new filters, including fuel filters, all around, and some extra oil & spare filters. Repairs: $2,850 - About $1,500 was for transmission service and another $600 to replace the alternator & belts. Most of the costs on those repairs went to labor. The rest of the repairs were all minor parts expenditures with no labor costs involved (I fixed it myself with the help of the list - thanks guys for giving me free repair advice and saving me thousands more on labor!). Note that I bought a very clean, well cared for coach, so the "$10,000+ for initial fixes" figure that some have thrown around has not applied to me. Misc: $6,200 - These are the various odds and ends we bought to "stock" the coach. It includes $1,200 in air fair to fly my family to Texas and things like pots & pans, dishes, kitchen supplies, linens & bedding, tools to stock the tool chest, etc. I wanted the coach to have it's own set of "everything", like a second home, so we didn't have to waste time "loading up" housing type supplies every time we went somewhere. Most of these are frivolous expenses; about $4,000 of it is in a computer/entertainment system. I expect to continue spending $2,000 - $5,000 a year on maintenance and repairs, plus fuel & licensing costs, figuring most of the labor will be my own with only the occasional outsourced job. I am finicky about maintenance and will spend top dollar on parts to keep the coach in perfect condition and repair even trivial cosmetic blemishes. Someone who is less finicky may be able to get away with spending less. Hope this helps those who were interested in understanding some first year ownership costs. Of course these will be different for every person and every coach. -Ryan '86 PT-40 8V92 |
01-27-2008, 07:53
Post: #36
Price of a Bluebird
Ryan,
That sounds pretty good... and is comparable with my expenses. The "ten thousand" figure for repairs also includes "upgrades" (such as the entertainment system you got -- or the bamboo floor I put in) as it's inevitable that there will be things you just want to change. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA aeonix1@... On Jan 27, 2008, at 12:24 PM, Ryan Wright wrote: > On 1/23/08, Ryan Wright >> >> I haven't owned my coach a year yet, but I have a comprehensive >> spreadsheet listing all costs involved. So if anyone wants info, I >> can >> get it, just let me know. > > I had enough off-list interest in this that I decided to post some > statistics here: > > I bought my '86 PT-40 in April 2007. Since that time, the coach has > been driven 3,446 miles and the genset has been run 138 hours. > Expenses are as follows: > > Fuel: $2,800 > > Preventative maintenance: $375 - This is for oil changes on both the > 8V92 and Yanmar genset, as well as new filters, including fuel > filters, all around, and some extra oil & spare filters. > > Repairs: $2,850 - About $1,500 was for transmission service and > another $600 to replace the alternator & belts. Most of the costs on > those repairs went to labor. The rest of the repairs were all minor > parts expenditures with no labor costs involved (I fixed it myself > with the help of the list - thanks guys for giving me free repair > advice and saving me thousands more on labor!). Note that I bought a > very clean, well cared for coach, so the "$10,000+ for initial fixes" > figure that some have thrown around has not applied to me. > > Misc: $6,200 - These are the various odds and ends we bought to > "stock" the coach. It includes $1,200 in air fair to fly my family to > Texas and things like pots & pans, dishes, kitchen supplies, linens & > bedding, tools to stock the tool chest, etc. I wanted the coach to > have it's own set of "everything", like a second home, so we didn't > have to waste time "loading up" housing type supplies every time we > went somewhere. Most of these are frivolous expenses; about $4,000 of > it is in a computer/entertainment system. > > I expect to continue spending $2,000 - $5,000 a year on maintenance > and repairs, plus fuel & licensing costs, figuring most of the labor > will be my own with only the occasional outsourced job. I am finicky > about maintenance and will spend top dollar on parts to keep the coach > in perfect condition and repair even trivial cosmetic blemishes. > Someone who is less finicky may be able to get away with spending > less. > > Hope this helps those who were interested in understanding some first > year ownership costs. Of course these will be different for every > person and every coach. > > -Ryan > '86 PT-40 8V92 > > > > Yahoo! Groups Links > > > |
01-27-2008, 10:01
Post: #37
Price of a Bluebird
Ryan,
I agree somewhat, but you are just getting started. Once we decided we have a keeper, In addition to your costs, over about a 4 year period: we changed out, the frig, tires, batteries, inverter, charger, radiator rebuild, lots of hoses, fluids, filters, light bulbs, fixtures, gages, wheel seals, wiring, cables, and a high number of miscellaneous parts & hardware. There's more: TV, redue all the maintenance, change some valves, switches, control knobs, tools etc. That is all I can quickly think of , but there is probably more. Once you are bonded, Ya want the Ole Bird to be near NEW. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > On 1/23/08, Ryan Wright > > > > I haven't owned my coach a year yet, but I have a comprehensive > > spreadsheet listing all costs involved. So if anyone wants info, I can > > get it, just let me know. > > I had enough off-list interest in this that I decided to post some > statistics here: > > I bought my '86 PT-40 in April 2007. Since that time, the coach has > been driven 3,446 miles and the genset has been run 138 hours. > Expenses are as follows: > > Fuel: $2,800 > > Preventative maintenance: $375 - This is for oil changes on both the > 8V92 and Yanmar genset, as well as new filters, including fuel > filters, all around, and some extra oil & spare filters. > > Repairs: $2,850 - About $1,500 was for transmission service and > another $600 to replace the alternator & belts. Most of the costs on > those repairs went to labor. The rest of the repairs were all minor > parts expenditures with no labor costs involved (I fixed it myself > with the help of the list - thanks guys for giving me free repair > advice and saving me thousands more on labor!). Note that I bought a > very clean, well cared for coach, so the "$10,000+ for initial fixes" > figure that some have thrown around has not applied to me. > > Misc: $6,200 - These are the various odds and ends we bought to > "stock" the coach. It includes $1,200 in air fair to fly my family to > Texas and things like pots & pans, dishes, kitchen supplies, linens & > bedding, tools to stock the tool chest, etc. I wanted the coach to > have it's own set of "everything", like a second home, so we didn't > have to waste time "loading up" housing type supplies every time we > went somewhere. Most of these are frivolous expenses; about $4,000 of > it is in a computer/entertainment system. > > I expect to continue spending $2,000 - $5,000 a year on maintenance > and repairs, plus fuel & licensing costs, figuring most of the labor > will be my own with only the occasional outsourced job. I am finicky > about maintenance and will spend top dollar on parts to keep the coach > in perfect condition and repair even trivial cosmetic blemishes. > Someone who is less finicky may be able to get away with spending > less. > > Hope this helps those who were interested in understanding some first > year ownership costs. Of course these will be different for every > person and every coach. > > -Ryan > '86 PT-40 8V92 > |
01-27-2008, 15:36
Post: #38
Price of a Bluebird
Bill,
As you know I am new to my BB, it is my ownership of the last year and it is up to what I want in a coach, as I have been looking for a BB for a long time... As you know I have been accused of being tent boy and among others... My BB came with a vast supply of parts that the PO had left with the BB that I have been the benefactor of, which I am very grateful for... The PO owner had changed the oil to synthetic and trans oil also... I have been lucky to get a BB in such good shape, as it was "his Baby" The only thing I had to change were the tires and Batts.. other than that I have only done the basic maintenance... The PO also left me with 5 gallons of Delvac 100 Synthetic oil which he was using in the CAT... Also he included about 15 filters for oil and fuel... Which I am grateful for... Unfortunately, it was due to his death that I acquired this BB... Which I am saddened by, but we have to move on... I am very happy that I have not had to spend alot of money on upgrades, as the PO took care of it it all before I took ownership of it... Sea Ya Larry NYC 84 35FCSB ----- Original Message ----
From: pattypape To: WanderlodgeForum@yahoogroups.com Sent: Sunday, January 27, 2008 5:01:43 PM Subject: [WanderlodgeForum] Re: Price of a Bluebird Ryan, I agree somewhat, but you are just getting started. Once we decided we have a keeper, In addition to your costs, over about a 4 year period: we changed out, the frig, tires, batteries, inverter, charger, radiator rebuild, lots of hoses, fluids, filters, light bulbs, fixtures, gages, wheel seals, wiring, cables, and a high number of miscellaneous parts & hardware. There's more: TV, redue all the maintenance, change some valves, switches, control knobs, tools etc. That is all I can quickly think of , but there is probably more. Once you are bonded, Ya want the Ole Bird to be near NEW. Bill 88 FC Michigan --- In "WanderlodgeForum%40yahoogroups.com", "Ryan Wright" > > On 1/23/08, Ryan Wright > > > > I haven't owned my coach a year yet, but I have a comprehensive > > spreadsheet listing all costs involved. So if anyone wants info, I can > > get it, just let me know. > > I had enough off-list interest in this that I decided to post some > statistics here: > > I bought my '86 PT-40 in April 2007. Since that time, the coach has > been driven 3,446 miles and the genset has been run 138 hours. > Expenses are as follows: > > Fuel: $2,800 > > Preventative maintenance: $375 - This is for oil changes on both the > 8V92 and Yanmar genset, as well as new filters, including fuel > filters, all around, and some extra oil & spare filters. > > Repairs: $2,850 - About $1,500 was for transmission service and > another $600 to replace the alternator & belts. Most of the costs on > those repairs went to labor. The rest of the repairs were all minor > parts expenditures with no labor costs involved (I fixed it myself > with the help of the list - thanks guys for giving me free repair > advice and saving me thousands more on labor!). Note that I bought a > very clean, well cared for coach, so the "$10,000+ for initial fixes" > figure that some have thrown around has not applied to me. > > Misc: $6,200 - These are the various odds and ends we bought to > "stock" the coach. It includes $1,200 in air fair to fly my family to > Texas and things like pots & pans, dishes, kitchen supplies, linens & > bedding, tools to stock the tool chest, etc. I wanted the coach to > have it's own set of "everything" , like a second home, so we didn't > have to waste time "loading up" housing type supplies every time we > went somewhere. Most of these are frivolous expenses; about $4,000 of > it is in a computer/entertainm ent system. > > I expect to continue spending $2,000 - $5,000 a year on maintenance > and repairs, plus fuel & licensing costs, figuring most of the labor > will be my own with only the occasional outsourced job. I am finicky > about maintenance and will spend top dollar on parts to keep the coach > in perfect condition and repair even trivial cosmetic blemishes. > Someone who is less finicky may be able to get away with spending > less. > > Hope this helps those who were interested in understanding some first > year ownership costs. Of course these will be different for every > person and every coach. > > -Ryan > '86 PT-40 8V92 > Be a better friend, newshound, and know-it-all with Yahoo! Mobile. [url=http://us.rd.yahoo.com/evt=51733/*http://mobile.yahoo.com/;_ylt=Ahu06i62sR...o8Wcj9tAcJ ] Try it now.[/url] |
01-28-2008, 03:54
Post: #39
Price of a Bluebird
My experience is very similar as well. Rather interesting that
several of us who purchased last year had so similar results. I paid $18,500 for my coach and I have added about $10,000 to that with $3700 in wheels and tires. Of the rest most of it was improvements with only perhaps another $1000 in routine service. I was told to expect this and I am also expecting to add about another $5000 to the total in the next year. I am particularly happy that the PO was completely honest with me and I have found not one problem which I was not made aware of. These things are not inexpensive but they are not cheap. In other words the money seems to be well spent. I am very pleased with the performance of the bus and if I had any complaints it would be that the FC is a little noisy due to the front engine. I am "working" on that and I feel that I can get it to a level that will be more then tolerable for my use. So I have about 95% of what my heart desires and that my friends is a pretty good buying experience. I on occasion get to thinking about up grading to a newer PT but when I consider the increased costs it doesn't make much sense for me. I have more then enough room and to add the extra length weight and increased fuel costs just doesn't add up to move me in that direction. So I am going to keep working along on the ole '73 and enjoying the trip as well as the destinations. John Heckman central Pa 1973 FC > > Bill, > As you know I am new to my BB, it is my ownership of the last year and it is up to what I want in a coach, as I have been looking for a BB for a long time... As you know I have been accused of being tent boy and among others... My BB came with a vast supply of parts that the PO had left with the BB that I have been the benefactor of, which I am very grateful for... The PO owner had changed the oil to synthetic and trans oil also... I have been lucky to get a BB in such good shape, as it was "his Baby" The only thing I had to change were the tires and Batts.. other than that I have only done the basic maintenance... The PO also left me with 5 gallons of Delvac 100 Synthetic oil which he was using in the CAT... Also he included about 15 filters for oil and fuel... Which I am grateful for... Unfortunately, it was due to his death that I acquired this BB... Which I am saddened by, but we have to move on... I am very happy that I have not had to spend alot > of money on upgrades, as the PO took care of it it all before I took ownership of it... > > Sea Ya > Larry > NYC > 84 35FCSB > > ----- Original Message ---- > From: pattypape > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, January 27, 2008 5:01:43 PM > Subject: [WanderlodgeForum] Re: Price of a Bluebird > > > > > > > > > > > > > > > > > Ryan, > > > > I agree somewhat, but you are just getting started. > > Once we decided we have a keeper, > > In addition to your costs, over about a 4 year period: > > we changed out, the frig, tires, batteries, inverter, charger, > > radiator rebuild, lots of hoses, fluids, filters, light bulbs, > > fixtures, gages, wheel seals, wiring, cables, and a high number of > > miscellaneous parts & hardware. There's more: TV, redue all the > > maintenance, change some valves, switches, control knobs, tools etc. > > That is all I can quickly think of , but there is probably more. > > Once you are bonded, Ya want the Ole Bird to be near NEW. > > > > Bill 88 FC Michigan > > > > --- In WanderlodgeForum@ yahoogroups. com, "Ryan Wright" > > > > > > > > On 1/23/08, Ryan Wright > > > > > > > > I haven't owned my coach a year yet, but I have a comprehensive > > > > spreadsheet listing all costs involved. So if anyone wants info, > > I can > > > > get it, just let me know. > > > > > > I had enough off-list interest in this that I decided to post some > > > statistics here: > > > > > > I bought my '86 PT-40 in April 2007. Since that time, the coach has > > > been driven 3,446 miles and the genset has been run 138 hours. > > > Expenses are as follows: > > > > > > Fuel: $2,800 > > > > > > Preventative maintenance: $375 - This is for oil changes on both the > > > 8V92 and Yanmar genset, as well as new filters, including fuel > > > filters, all around, and some extra oil & spare filters. > > > > > > Repairs: $2,850 - About $1,500 was for transmission service and > > > another $600 to replace the alternator & belts. Most of the costs on > > > those repairs went to labor. The rest of the repairs were all minor > > > parts expenditures with no labor costs involved (I fixed it myself > > > with the help of the list - thanks guys for giving me free repair > > > advice and saving me thousands more on labor!). Note that I bought a > > > very clean, well cared for coach, so the "$10,000+ for initial > > fixes" > > > figure that some have thrown around has not applied to me. > > > > > > Misc: $6,200 - These are the various odds and ends we bought to > > > "stock" the coach. It includes $1,200 in air fair to fly my family > > to > > > Texas and things like pots & pans, dishes, kitchen supplies, linens > > & > > > bedding, tools to stock the tool chest, etc. I wanted the coach to > > > have it's own set of "everything" , like a second home, so we didn't > > > have to waste time "loading up" housing type supplies every time we > > > went somewhere. Most of these are frivolous expenses; about $4,000 > > of > > > it is in a computer/entertainm ent system. > > > > > > I expect to continue spending $2,000 - $5,000 a year on maintenance > > > and repairs, plus fuel & licensing costs, figuring most of the labor > > > will be my own with only the occasional outsourced job. I am finicky > > > about maintenance and will spend top dollar on parts to keep the > > coach > > > in perfect condition and repair even trivial cosmetic blemishes. > > > Someone who is less finicky may be able to get away with spending > > > less. > > > > > > Hope this helps those who were interested in understanding some > > first > > > year ownership costs. Of course these will be different for every > > > person and every coach. > > > > > > -Ryan > > > '86 PT-40 8V92 > > > > > > > > > > > > > > > > > > <!-- > > #ygrp-mkp{ > border:1px solid #d8d8d8;font-family:Arial;margin:14px 0px;padding:0px 14px;} > #ygrp-mkp hr{ > border:1px solid #d8d8d8;} > #ygrp-mkp #hd{ > color:#628c2a;font-size:85%;font-weight:bold;line- height:122%;margin:10px 0px;} > #ygrp-mkp #ads{ > margin-bottom:10px;} > #ygrp-mkp .ad{ > padding:0 0;} > #ygrp-mkp .ad a{ > color:#0000ff;text-decoration:none;} > --> > > > > <!-- > > #ygrp-sponsor #ygrp-lc{ > font-family:Arial;} > #ygrp-sponsor #ygrp-lc #hd{ > margin:10px 0px;font-weight:bold;font-size:78%;line-height:122%;} > #ygrp-sponsor #ygrp-lc .ad{ > margin-bottom:10px;padding:0 0;} > --> > > > > <!-- > > #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;} > #ygrp-mlmsg table {font-size:inherit;font:100%;} > #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} > #ygrp-mlmsg pre, code {font:115% monospace;} > #ygrp-mlmsg * {line-height:1.22em;} > #ygrp-text{ > font-family:Georgia; > } > #ygrp-text p{ > margin:0 0 1em 0;} > #ygrp-tpmsgs{ > font-family:Arial; > clear:both;} > #ygrp-vitnav{ > padding-top:10px;font-family:Verdana;font-size:77%;margin:0;} > #ygrp-vitnav a{ > padding:0 1px;} > #ygrp-actbar{ > clear:both;margin:25px 0;white-space:nowrap;color:#666;text- align:right;} > #ygrp-actbar .left{ > float:left;white-space:nowrap;} > .bld{font-weight:bold;} > #ygrp-grft{ > font-family:Verdana;font-size:77%;padding:15px 0;} > #ygrp-ft{ > font-family:verdana;font-size:77%;border-top:1px solid #666; > padding:5px 0; > } > #ygrp-mlmsg #logo{ > padding-bottom:10px;} > > #ygrp-vital{ > background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;} > #ygrp-vital #vithd{ > font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text- transform:uppercase;} > #ygrp-vital ul{ > padding:0;margin:2px 0;} > #ygrp-vital ul li{ > list-style-type:none;clear:both;border:1px solid #e0ecee; > } > #ygrp-vital ul li .ct{ > font-weight:bold;color:#ff7900;float:right;width:2em;text- align:right;padding-right:.5em;} > #ygrp-vital ul li .cat{ > font-weight:bold;} > #ygrp-vital a{ > text-decoration:none;} > > #ygrp-vital a:hover{ > text-decoration:underline;} > > #ygrp-sponsor #hd{ > color:#999;font-size:77%;} > #ygrp-sponsor #ov{ > padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;} > #ygrp-sponsor #ov ul{ > padding:0 0 0 8px;margin:0;} > #ygrp-sponsor #ov li{ > list-style-type:square;padding:6px 0;font-size:77%;} > #ygrp-sponsor #ov li a{ > text-decoration:none;font-size:130%;} > #ygrp-sponsor #nc{ > background-color:#eee;margin-bottom:20px;padding:0 8px;} > #ygrp-sponsor .ad{ > padding:8px 0;} > #ygrp-sponsor .ad #hd1{ > font-family:Arial;font-weight:bold;color:#628c2a;font- size:100%;line-height:122%;} > #ygrp-sponsor .ad a{ > text-decoration:none;} > #ygrp-sponsor .ad a:hover{ > text-decoration:underline;} > #ygrp-sponsor .ad p{ > margin:0;} > o{font-size:0;} > .MsoNormal{ > margin:0 0 0 0;} > #ygrp-text tt{ > font-size:120%;} > blockquote{margin:0 0 0 4px;} > .replbq{margin:4;} > --> > > > > > > > > > ______________________________________________________________________ ______________ > Never miss a thing. Make Yahoo your home page. > http://www.yahoo.com/r/hs > |
01-28-2008, 06:29
Post: #40
Price of a Bluebird
In a message dated 1/28/2008 3:56:52 P.M. Central Standard Time, ryanpwright@... writes:
nickel and dime stuff (adjusted for inflation, that means $100 The bird is kinda like my old sailing craft-- just a catch all for those 100 dollar bills.
Ernie Ekberg -----Montana bound83PT40 Weatherford, Tx Start the year off right. Easy ways to stay in shape in the new year. |
