Help...Us buy our first motoerhome......
01-19-2010, 04:47
Post: #31
no rivets on the 2000 and beyond I believe
Scooter 2000 LX Ocqueoc,MI To: WanderlodgeForum@yahoogroups.com From: w5sk@... Date: Tue, 19 Jan 2010 08:01:27 -0600 Subject: RE: [WanderlodgeForum] Re: Help...Us buy our first motoerhome...... Good Morning,
On the Prevost side - I think I like the rivited coaches (XL) both from cost and from appearance. Maybe 98 to 2000 with IFS - no slides.
On the BB - I am just learning. Probably 200k $ limit. The cost has been dropping quickly on both - not sure where the bottom is yet or if there will be one.
I note that you suggested LXi 2004 or earlier?
Wave
From: WanderlodgeForum@ Sent: Monday, January 18, 2010 6:08 PM To: WanderlodgeForum@ Subject: Re: [WanderlodgeForum] Re: Help...Us buy our first motoerhome.. HI,
What years or $ are you considering for a coach.
Prevost - best to consider 2004 shell (2005 conversion) or later. Has front axle upgrade
Blue Bird--LXi 2004 or earlier.
Ross
06 LXi
From: wavel To: WanderlodgeForum@ Sent: Mon, January 18, 2010 3:36:30 PM Subject: Re: [WanderlodgeForum] Re: Help...Us buy our first motoerhome.. David, Thanks you for the insight.You are right - I do not have an agenda except to move up to a bus - which means I am looking at Prevost and Bluebird. I am sure that topic has come before the group many times.It appears that BB is the better bargin- but I am not sure about the rest of the equation. I really appreciate the group and what they mean to a prospective owner. Wave SW Oklahoma -----Original Message----- Looking for the perfect gift? Give the gift of Flickr! |
01-19-2010, 05:00
Post: #32
Thanks Brad and Pete for those insights. I don’t have I think my worry was about major systems failures such as While boondocking. |
01-26-2010, 09:51
Post: #33
Mark,
You should be able to drop two or three grand, at will, when necessary. You might do this once or twice a year, or you might do it every two or three years, but the fact is something is going to fail. My air compressor croaked and it cost me about a thousand bucks with labor (I had them replace some deteriorated coolant lines while they were back there). A new alternator was in the $400-500 range. My refrigerator died, that was $1200 (I replaced that myself). Point is, if you have money set aside and can pull a couple grand out to fix something on a whim, and if you can reasonably replenish that fund in a few months just in case you need it again, you will probably be fine. However, people who are living month to month where a $500 repair is a huge problem for them, probably should reconsider buying a coach, especially one like this. It will quickly become an anchor around their neck, deteriorate and turn into a yard ornament. You can do a lot of work yourself. I spent a weekend replacing some parts on my generator. ~$100 worth of parts and saved ~$2000 in labor by doing the work myself. It wasn't even that difficult, as I had forum members here who gave me the necessary advice and virtual hand-holding to get through it (thank you!). This is an excellent resource. I could have replaced the alternator and compressor, too, but I was in a hurry and just wanted it done (and didn't really have a good place to do it myself). I'd plan on $3k to $5k per year in maintenance. If you can handle that, you'll be fine. If you get a good coach and take care of it, you won't have to spend this every year. Some years you might only spend a couple hundred bucks on oil and filters. As long as you are able and willing to spend this much yearly, you shouldn't be disappointed in your new toy. You mentioned "major systems... such as (the) engine." Expect to pay $25,000 give or take if you need to rebuild your engine. That's a huge hit for most of us. I mitigate this potential by keeping up on all engine maintenance, keeping the radiator cleaned, and watching the gauges closely for signs of trouble. Thankfully, a Blue Bird has an abundance of gauges. -Ryan On Tue, Jan 19, 2010 at 9:00 AM, Mark <"summitwolf@comcast.net"> wrote:
01-26-2010, 09:51
Post: #34
Forgot to sign my post with coach information.
-Ryan '86 PT-40 8V92 On Tue, Jan 26, 2010 at 1:51 PM, Ryan Wright > Mark, > > You should be able to drop two or three grand, at will, when necessary. You > might do this once or twice a year, or you might do it every two or three > years, but the fact is something is going to fail. My air compressor croaked > and it cost me about a thousand bucks with labor (I had them replace some > deteriorated coolant lines while they were back there). A new alternator was > in the $400-500 range. My refrigerator died, that was $1200 (I replaced that > myself). > > Point is, if you have money set aside and can pull a couple grand out to fix > something on a whim, and if you can reasonably replenish that fund in a few > months just in case you need it again, you will probably be fine. However, > people who are living month to month where a $500 repair is a huge problem > for them, probably should reconsider buying a coach, especially one like > this. It will quickly become an anchor around their neck, deteriorate and > turn into a yard ornament. > > You can do a lot of work yourself. I spent a weekend replacing some parts on > my generator. ~$100 worth of parts and saved ~$2000 in labor by doing the > work myself. It wasn't even that difficult, as I had forum members here who > gave me the necessary advice and virtual hand-holding to get through it > (thank you!). This is an excellent resource. I could have replaced the > alternator and compressor, too, but I was in a hurry and just wanted it done > (and didn't really have a good place to do it myself). > > I'd plan on $3k to $5k per year in maintenance. If you can handle that, > you'll be fine. If you get a good coach and take care of it, you won't have > to spend this every year. Some years you might only spend a couple hundred > bucks on oil and filters. As long as you are able and willing to spend this > much yearly, you shouldn't be disappointed in your new toy. > > You mentioned "major systems... such as (the) engine." Expect to pay $25,000 > give or take if you need to rebuild your engine. That's a huge hit for most > of us. I mitigate this potential by keeping up on all engine maintenance, > keeping the radiator cleaned, and watching the gauges closely for signs of > trouble. Thankfully, a Blue Bird has an abundance of gauges. > > -Ryan > > > On Tue, Jan 19, 2010 at 9:00 AM, Mark >> >> >> >> Thanks Brad and Pete for those insights. I donât have any problems doing >> stuff like you describe. >> >> I think my worry was about major systems failures such as engine and >> driveline. Stuff that cannot be fixed >> >> While boondocking. >> >> > > |
