Has anyone here had there vlv rack adjustment here lately?
03-22-2006, 04:04
I have had various cost figures pertaining to this job and they range
from$300 and up. Of course I do not have the swing out radiator but that ok as that would cost another couple of hundred bucks or more to preform this operation. Just would like to check with the rest of FC people as to what they are paying? Thanks Jon |
03-22-2006, 13:31
I haven't paid to have it done, but without a swing radiator I would
estimate around 12hours shop time. I've always done my own, and always with a swing radiator. The guy who's quoting you $300 will probably hate you. If you can do it yourself it will save a lot, mostly labor. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Jon" > > I have had various cost figures pertaining to this job and they range > from$300 and up. Of course I do not have the swing out radiator but > that ok as that would cost another couple of hundred bucks or more to > preform this operation. Just would like to check with the rest of FC > people as to what they are paying? Thanks Jon > |
03-22-2006, 15:35
Jeff
I have a swing radiater and coming up on 100,000 miles this summer. Was planning to do my own valve clearance checking and adjustments. The cat book reads pretty well on this procedure. If you have any tips based on your experience, would appreciate your input. What else should be done while I'm in there? Just finished assembly of the M3 race motor in Feb. Will be at Gingerman in South Haven weekend of June 24 25, stop by if you can. dandarst86fc35rbhuntleyil. >From: "Jeff Miller" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Re: Has anyone here had there vlv rack >adjustment here lately? >Date: Thu, 23 Mar 2006 01:31:50 -0000 > >I haven't paid to have it done, but without a swing radiator I would >estimate around 12hours shop time. I've always done my own, and always >with a swing radiator. The guy who's quoting you $300 will probably >hate you. > >If you can do it yourself it will save a lot, mostly labor. > > - Jeff Miller >in Holland, MI > > >--- In WanderlodgeForum@yahoogroups.com, "Jon" > > > > I have had various cost figures pertaining to this job and they range > > from$300 and up. Of course I do not have the swing out radiator but > > that ok as that would cost another couple of hundred bucks or more to > > preform this operation. Just would like to check with the rest of FC > > people as to what they are paying? Thanks Jon > > > > > > |
03-23-2006, 09:13
Rebuild the breathers, and if you have the time re-insulate the
doghouse while it is off. The valve adjust is pretty simple once the doghouse and radiator are open. Cleaning and painting the engine is tempting at that point also. If you have any interest in having (injector) nozzles checked or rebuilt, this would be the time also. I'll see if I can make Gingerman, ... think my little diesel will tear up the M3? ... Audi did it with their diesel at Sebring. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Dan Darst" > > Jeff > I have a swing radiater and coming up on 100,000 miles this summer. Was > planning to do my own valve clearance checking and adjustments. The cat book > reads pretty well on this procedure. If you have any tips based on your > experience, would appreciate your input. What else should be done while I'm > in there? > > Just finished assembly of the M3 race motor in Feb. Will be at Gingerman in > South Haven weekend of June 24 25, stop by if you can. > > dandarst86fc35rbhuntleyil. |
03-23-2006, 12:46
The diesels are coming!
29,000 psi common rail for good atomization, particlate filters, and ultralow sulfur diesel starting in October 2006. Old high sulfur diesel was 2500 ppm sulfur, in 1993 came low sulfur diesel at 500 ppm, and now we will have 15 ppm sulfur. The lubricity of sulfur will be replaced with an additive that will lube the pump better than the sulfur did. Energy loss of ULSD is expected to be approximately 1%, and the price bump 11 to 15 cents per gallon. I know, too much information. See ya. dandarst86fc35rbhuntleyil. >From: "Jeff Miller" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Re: Has anyone here had there vlv rack >adjustment here lately? >Date: Thu, 23 Mar 2006 21:13:05 -0000 > >Rebuild the breathers, and if you have the time re-insulate the >doghouse while it is off. > >The valve adjust is pretty simple once the doghouse and radiator are >open. Cleaning and painting the engine is tempting at that point also. > >If you have any interest in having (injector) nozzles checked or >rebuilt, this would be the time also. > >I'll see if I can make Gingerman, ... think my little diesel will tear >up the M3? ... Audi did it with their diesel at Sebring. > > - Jeff Miller >in Holland, MI > > >--- In WanderlodgeForum@yahoogroups.com, "Dan Darst" > > > > Jeff > > I have a swing radiater and coming up on 100,000 miles this summer. >Was > > planning to do my own valve clearance checking and adjustments. The >cat book > > reads pretty well on this procedure. If you have any tips based on >your > > experience, would appreciate your input. What else should be done >while I'm > > in there? > > > > Just finished assembly of the M3 race motor in Feb. Will be at >Gingerman in > > South Haven weekend of June 24 25, stop by if you can. > > > > dandarst86fc35rbhuntleyil. > > > |
03-23-2006, 15:56
Run red.
MH ----- Original Message ----- From: Dan Darst To: WanderlodgeForum@yahoogroups.com Sent: Thursday, March 23, 2006 6:46 PM Subject: RE: [WanderlodgeForum] Re: Has anyone here had there vlv rack adjustment here lately? The diesels are coming! 29,000 psi common rail for good atomization, particlate filters, and ultralow sulfur diesel starting in October 2006. Old high sulfur diesel was 2500 ppm sulfur, in 1993 came low sulfur diesel at 500 ppm, and now we will have 15 ppm sulfur. The lubricity of sulfur will be replaced with an additive that will lube the pump better than the sulfur did. Energy loss of ULSD is expected to be approximately 1%, and the price bump 11 to 15 cents per gallon. I know, too much information. See ya. dandarst86fc35rbhuntleyil. >From: "Jeff Miller" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Re: Has anyone here had there vlv rack >adjustment here lately? >Date: Thu, 23 Mar 2006 21:13:05 -0000 > >Rebuild the breathers, and if you have the time re-insulate the >doghouse while it is off. > >The valve adjust is pretty simple once the doghouse and radiator are >open. Cleaning and painting the engine is tempting at that point also. > >If you have any interest in having (injector) nozzles checked or >rebuilt, this would be the time also. > >I'll see if I can make Gingerman, ... think my little diesel will tear >up the M3? ... Audi did it with their diesel at Sebring. > > - Jeff Miller >in Holland, MI > > >--- In WanderlodgeForum@yahoogroups.com, "Dan Darst" > > > > Jeff > > I have a swing radiater and coming up on 100,000 miles this summer. >Was > > planning to do my own valve clearance checking and adjustments. The >cat book > > reads pretty well on this procedure. If you have any tips based on >your > > experience, would appreciate your input. What else should be done >while I'm > > in there? > > > > Just finished assembly of the M3 race motor in Feb. Will be at >Gingerman in > > South Haven weekend of June 24 25, stop by if you can. > > > > dandarst86fc35rbhuntleyil. > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
03-23-2006, 16:39
> > Rebuild the breathers, and if you have the time re-insulate the > doghouse while it is off. > > The valve adjust is pretty simple once the doghouse and radiator are > open. Cleaning and painting the engine is tempting at that point also. > > If you have any interest in having (injector) nozzles checked or > rebuilt, this would be the time also. > > I'll see if I can make Gingerman, ... think my little diesel will tear > up the M3? ... Audi did it with their diesel at Sebring. > > - Jeff Miller > in Holland, MI > > > --- In WanderlodgeForum@yahoogroups.com, "Dan Darst" wrote: > > > > Jeff > > I have a swing radiater and coming up on 100,000 miles this summer. > Was > > planning to do my own valve clearance checking and adjustments. The > cat book > > reads pretty well on this procedure. If you have any tips based on > your > > experience, would appreciate your input. What else should be done > while I'm > > in there? > > > > Just finished assembly of the M3 race motor in Feb. Will be at > Gingerman in > > South Haven weekend of June 24 25, stop by if you can. > > > > dandarst86fc35rbhuntleyil. Got one question what is the breather? Sence I'm having this done I might just ask the mechanic to do this but sure would like to know what this is? Is it the same as a breather on a car? Thanks Jon Brmerton Washington Jipjob@... > |
03-24-2006, 03:49
I can't remember the year coach you have Jon, but if it is a 3208Ta you
have one PCV on each valve cover (not breather, sorry), re-build is a Cat kit which includes the diaphragm and gaskets. - Jeff Miller in Holland, MI <<snip>> > > Got one question what is the breather? Sence I'm having this done I > might just ask the mechanic to do this but sure would like to know > what this is? Is it the same as a breather on a car? Thanks > > Jon > Brmerton Washington > Jipjob@... > > > |
