Bathroom electricity heater
03-29-2006, 02:36
Bob, I took mine out and cleaned it real good. There is an adjusting alan
screw that you can turn to make it stay on. Ernie-83pt40 in Texas
03-29-2006, 05:33
My electricity heater in the bath room nolonger works.Iam looking for
a replacmrnt.Does any boady know where i could get one for a 1985
PT.
Bob Loomas 1985 PT 36
03-29-2006, 06:00
Hi Robert,
Try here if you can't find one locally.
http://www.cadetco.com/
Rich D. '99LXi43' CT
--- In WanderlodgeForum@yahoogroups.com, "robertnloomas"
for
> PT.
03-29-2006, 08:24
Bob, depending on what is wrong with the heater, there is a reset on the
back I believe.
Ralph
>PT.
Safe travels,
03-29-2006, 08:57
---I want to think you all for your help.
I have not pulled the unit out yet.Ill chech it out in a couple of
weeks.At the present time the unit will not come on so i was just
thinking the worst.
In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider"
on the
> back I believe.
> Ralph
for
> >PT.
> Safe travels,
03-29-2006, 13:06
Don't pull the heater yet. As Ralph mentioned, there is a reset
button, you'll need to poke a small screwdriver through the reset-
button hole in the front panel.
- Jeff Miller
in Holland, MI
on the
> back I believe.
> Ralph
for
> >PT.
> Safe travels,
03-29-2006, 14:31
If you find the reset button tripped and the heater works after a
reset, be sure to find out why it tripped. The newer models have an
internal reset that forces one to open the heater to reset it. This
usually leads to observing the cause of the tripping; a buildup of
dust and lint inside the heater. Constant resetting without
eliminating the cause can be a fire hazard.
My heaters were recalled and changed to identical units with a reset
that is not accessible from the exterior for the reason stated
above.
> - Jeff Miller
> in Holland, MI
reset
> on the
> > back I believe.
> > Ralph
looking
> for
1985
> > >PT.
> > Safe travels,
03-29-2006, 15:22
--- In WanderlodgeForum@yahoogroups.com, "g_man1146"
Sure hope it is only a reset.If it is ill remove the heater and give
it a good cleaning.
Thanks to all.
03-29-2006, 17:19
Bob, on the 94 PT you have to turn on the Dash AC switch for the rear
with the heater turned on for it to work. I guess it is a way for the
driver to turn the heater off from the cockpit.
94PT 40--- In WanderlodgeForum@yahoogroups.com, "robertnloomas"
> it a good cleaning.
> Thanks to all.
03-29-2006, 23:29
> it a good cleaning.
> Thanks to all.
Bob, my heater would only come on for a short period of time thenn cut
off. At one of our lone star rallies, someone was taking theirs apart
and found that allen screw. It made a difference in the length of time
the heater stayed on. Ernie-83pt40 in texas
