Hard to Close Door
03-31-2006, 00:36
Hard to Close Door
Hello to All-
I've been away from the forum for awhile but am continuing to enjoy our '99 LX. One annoying problem, however. My front door does not close tight unless I grab the interior handle with both hands and slam it with all of force I can muster (I weigh 236 lbs. so you can imagine that's quite a bit of force). Otherwise, it will close and latch, but there is a gap that creates wind noise when going down the road. Anyone know how I can adjust the door or latch so that it will close properly? Thanks in advance. Wayne '99 LX Charlotte, NC |
03-31-2006, 00:50
Hard to Close Door
HI Wayne:
First, with the door closed and you standing out side, look along the closure seam and note where the gaps are, top of the lock or below the lock. To adjust the door, you will need a 5 or 6 inch round rolled up carpet, a 2x4 8 feet long Open the door, the carpet roll goes between the door and the jamb at the lock area, the 2 x4 goes up through the awning arm at the top and down across the top of the door at an angle. Some one holds the 2x4 in place tight to the side of the coach and you push the bottom of the door toward the coach until you achieve the right amount of adjustment for the gap. Remove the tools and try the door looking at the gap and door closure. Repeat the process until it is adjusted. This is a common problem on PT's for what ever reason but easily adjusted. OH, yes, be sure to buy your helper a beer. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 01:36 PM 3/31/2006 +0000, you wrote: >Hello to All- > >I've been away from the forum for awhile but am continuing to enjoy >our '99 LX. One annoying problem, however. My front door does not >close tight unless I grab the interior handle with both hands and slam >it with all of force I can muster (I weigh 236 lbs. so you can imagine >that's quite a bit of force). Otherwise, it will close and latch, but >there is a gap that creates wind noise when going down the road. > >Anyone know how I can adjust the door or latch so that it will close >properly? Thanks in advance. > >Wayne >'99 LX >Charlotte, NC > > |
03-31-2006, 04:04
Hard to Close Door
Hi Ralph,
Let me see if I get this advice correctly. Are you suggesting the way Wayne is to fix this, is by bending the door? And doesn't the LX have the air lock wedge mechanism? as well as the regular lock mechanism? John Suter --- rlf > HI Wayne: > > First, with the door closed and you standing out > side, look along the > closure seam and note where the gaps are, top of the > lock or below the lock. > > To adjust the door, you will need a 5 or 6 inch > round rolled up carpet, a > 2x4 8 feet long > > Open the door, the carpet roll goes between the door > and the jamb at the > lock area, the 2 x4 goes up through the awning arm > at the top and down > across the top of the door at an angle. Some one > holds the 2x4 in place > tight to the side of the coach and you push the > bottom of the door toward > the coach until you achieve the right amount of > adjustment for the gap. > Remove the tools and try the door looking at the gap > and door closure. > Repeat the process until it is adjusted. > > This is a common problem on PT's for what ever > reason but easily adjusted. > OH, yes, be sure to buy your helper a beer. > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > At 01:36 PM 3/31/2006 +0000, you wrote: > >Hello to All- > > > >I've been away from the forum for awhile but am > continuing to enjoy > >our '99 LX. One annoying problem, however. My front > door does not > >close tight unless I grab the interior handle with > both hands and slam > >it with all of force I can muster (I weigh 236 lbs. > so you can imagine > >that's quite a bit of force). Otherwise, it will > close and latch, but > >there is a gap that creates wind noise when going > down the road. > > > >Anyone know how I can adjust the door or latch so > that it will close > >properly? Thanks in advance. > > > >Wayne > >'99 LX > >Charlotte, NC > > > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
03-31-2006, 04:55
Hard to Close Door
Hi John:
I am not positive about the air lock mech. I do know that on pre LX series this is how the Factory adjusts the entry doors on PT's. This was explained to me at our last trip to Bird's Nest. It is just a matter of bringing the door back into alignment. Oh and re design or re align,, everything back to where it was really, it is a subtle push. Ralph At 09:04 AM 3/31/2006 -0800, you wrote: >Hi Ralph, > > Let me see if I get this advice correctly. Are you >suggesting the way Wayne is to fix this, is by bending >the door? And doesn't the LX have the air lock wedge >mechanism? as well as the regular lock mechanism? > >John Suter > > >--- rlf > > > HI Wayne: > > > > First, with the door closed and you standing out > > side, look along the > > closure seam and note where the gaps are, top of the > > lock or below the lock. > > > > To adjust the door, you will need a 5 or 6 inch > > round rolled up carpet, a > > 2x4 8 feet long > > > > Open the door, the carpet roll goes between the door > > and the jamb at the > > lock area, the 2 x4 goes up through the awning arm > > at the top and down > > across the top of the door at an angle. Some one > > holds the 2x4 in place > > tight to the side of the coach and you push the > > bottom of the door toward > > the coach until you achieve the right amount of > > adjustment for the gap. > > Remove the tools and try the door looking at the gap > > and door closure. > > Repeat the process until it is adjusted. > > > > This is a common problem on PT's for what ever > > reason but easily adjusted. > > OH, yes, be sure to buy your helper a beer. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > http://home.swbell.net/rlf47/index.htm > > > > At 01:36 PM 3/31/2006 +0000, you wrote: > > >Hello to All- > > > > > >I've been away from the forum for awhile but am > > continuing to enjoy > > >our '99 LX. One annoying problem, however. My front > > door does not > > >close tight unless I grab the interior handle with > > both hands and slam > > >it with all of force I can muster (I weigh 236 lbs. > > so you can imagine > > >that's quite a bit of force). Otherwise, it will > > close and latch, but > > >there is a gap that creates wind noise when going > > down the road. > > > > > >Anyone know how I can adjust the door or latch so > > that it will close > > >properly? Thanks in advance. > > > > > >Wayne > > >'99 LX > > >Charlotte, NC > > > > > > > > > > > > >__________________________________________________ >Do You Yahoo!? >Tired of spam? Yahoo! Mail has the best spam protection around >http://mail.yahoo.com > > > >Yahoo! Groups Links > > > > Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm |
03-31-2006, 05:15
Hard to Close Door
What Ralph is explaining is to GENTLY sprain the door hinge and it
also rearranges the door same thing could be accomplished by Gently lifting on outside corner of door either top or bottom which ever is needed to realign door It is much harder and more time consuming to loosen the hinges and if you it that way make sure you have about twelve arms to help. After readjusting door readjust lock plates on coach body thats how they do it in body shops only there they usually have a Special Service Tool A nice shiny 2 inch nut to jam in the hinge Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, John Suter wrote: > > Hi Ralph, > > Let me see if I get this advice correctly. Are you > suggesting the way Wayne is to fix this, is by bending > the door? And doesn't the LX have the air lock wedge > mechanism? as well as the regular lock mechanism? > > John Suter > > > --- rlf > > > HI Wayne: > > > > First, with the door closed and you standing out > > side, look along the > > closure seam and note where the gaps are, top of the > > lock or below the lock. > > > > To adjust the door, you will need a 5 or 6 inch > > round rolled up carpet, a > > 2x4 8 feet long > > > > Open the door, the carpet roll goes between the door > > and the jamb at the > > lock area, the 2 x4 goes up through the awning arm > > at the top and down > > across the top of the door at an angle. Some one > > holds the 2x4 in place > > tight to the side of the coach and you push the > > bottom of the door toward > > the coach until you achieve the right amount of > > adjustment for the gap. > > Remove the tools and try the door looking at the gap > > and door closure. > > Repeat the process until it is adjusted. > > > > This is a common problem on PT's for what ever > > reason but easily adjusted. > > OH, yes, be sure to buy your helper a beer. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > Ralph's RV Solutions, Duncan, Oklahoma > > http://home.swbell.net/rlf47/index.htm > > > > At 01:36 PM 3/31/2006 +0000, you wrote: > > >Hello to All- > > > > > >I've been away from the forum for awhile but am > > continuing to enjoy > > >our '99 LX. One annoying problem, however. My front > > door does not > > >close tight unless I grab the interior handle with > > both hands and slam > > >it with all of force I can muster (I weigh 236 lbs. > > so you can imagine > > >that's quite a bit of force). Otherwise, it will > > close and latch, but > > >there is a gap that creates wind noise when going > > down the road. > > > > > >Anyone know how I can adjust the door or latch so > > that it will close > > >properly? Thanks in advance. > > > > > >Wayne > > >'99 LX > > >Charlotte, NC > > > > > > > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > |
03-31-2006, 17:12
Hard to Close Door
> I called the factory and was told by someone sitting in for Bennie that the stud for the latch is adjutable. It is mounted in a slot and a slight realignment should do the trick for me. Thanks again to all for the suggestions. Wayne '99 LX Charlotte, NC > What Ralph is explaining is to GENTLY sprain the door hinge and it > also rearranges the door same thing could be accomplished by Gently > lifting on outside corner of door either top or bottom which ever is > needed to realign door It is much harder and more time consuming to > loosen the hinges and if you it that way make sure you have about > twelve arms to help. After readjusting door readjust lock plates on > coach body > thats how they do it in body shops only there they usually have a > Special Service Tool A nice shiny 2 inch nut to jam in the hinge > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com, John Suter > wrote: > > > > Hi Ralph, > > > > Let me see if I get this advice correctly. Are you > > suggesting the way Wayne is to fix this, is by bending > > the door? And doesn't the LX have the air lock wedge > > mechanism? as well as the regular lock mechanism? > > > > John Suter > > > > > > --- rlf > > > > > HI Wayne: > > > > > > First, with the door closed and you standing out > > > side, look along the > > > closure seam and note where the gaps are, top of the > > > lock or below the lock. > > > > > > To adjust the door, you will need a 5 or 6 inch > > > round rolled up carpet, a > > > 2x4 8 feet long > > > > > > Open the door, the carpet roll goes between the door > > > and the jamb at the > > > lock area, the 2 x4 goes up through the awning arm > > > at the top and down > > > across the top of the door at an angle. Some one > > > holds the 2x4 in place > > > tight to the side of the coach and you push the > > > bottom of the door toward > > > the coach until you achieve the right amount of > > > adjustment for the gap. > > > Remove the tools and try the door looking at the gap > > > and door closure. > > > Repeat the process until it is adjusted. > > > > > > This is a common problem on PT's for what ever > > > reason but easily adjusted. > > > OH, yes, be sure to buy your helper a beer. > > > > > > Safe travels, > > > > > > Ralph and Charolette Fullenwider > > > Ralph's RV Solutions, Duncan, Oklahoma > > > http://home.swbell.net/rlf47/index.htm > > > > > > At 01:36 PM 3/31/2006 +0000, you wrote: > > > >Hello to All- > > > > > > > >I've been away from the forum for awhile but am > > > continuing to enjoy > > > >our '99 LX. One annoying problem, however. My front > > > door does not > > > >close tight unless I grab the interior handle with > > > both hands and slam > > > >it with all of force I can muster (I weigh 236 lbs. > > > so you can imagine > > > >that's quite a bit of force). Otherwise, it will > > > close and latch, but > > > >there is a gap that creates wind noise when going > > > down the road. > > > > > > > >Anyone know how I can adjust the door or latch so > > > that it will close > > > >properly? Thanks in advance. > > > > > > > >Wayne > > > >'99 LX > > > >Charlotte, NC > > > > > > > > > > > > > > > > > > > > __________________________________________________ > > Do You Yahoo!? > > Tired of spam? Yahoo! Mail has the best spam protection around > > http://mail.yahoo.com > > > |
