Synthetic vs. Dino
04-10-2006, 02:47
Synthetic vs. Dino
From the for what it's worth department.
After speaking with one of the members of this forum about the value of synthetic versus dino oil (thanks Bob) for my 1993 8V92 I made the switch from straight Rotella 40W to Amsoil 15W40. The results have been nothing short of amazing as oil consumption went from around 1 quart per 250 miles to about 1 quart per 850 miles when I am pushing it hard, to pretty much nothing when driving 55 or 60 MPH. The 40W used to get that diesel black color within a couple hundred miles of an oil change whereas the synthetic oil is still quite clear even after 3200 miles. The engine used to smoke some when leaving a stop light but now has to be fully floored to put out much smoke at all. The coolant is also not running quite as warm thus the fan is seldom kicking in any more. More than likely fuel consumption has also decreased but since I do not keep track I can't vouch for that. It is quite obvious to me that something good has taken place with my change from dino oil to synthetic. Next step is to change the other lubricants as well. I am not trying to start a war here but am just relaying my experience "for what it's worth". Alvie Miller 1993 WLWB Arthur IL. --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Thank you Tom. I would have put you in the non-believer camp. Enjoy > your Walmart Dino Oil. > > Mike Bulriss - I won the bet! I won the bet! > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > > > Mike you may be correct but I cannot find anywhere that ANY > > syntheitcs are recommended for use in the Detroit diesel 2 cycle > > engine. The statement in sect 3.7 that you quote " only synthetic > > oils which do not contain viscosity improver additives may be used" > > disqualifies all multigrade synthetics since viscosity improvers are > > used. I can buy Rotella T single grade at Walmarts and it is easily > availble. > > > > http://www.shell-lubricants.com/products...llaTSG.pdf > > Tom Warner > > Vernon Center,NY > > 1982 FC35 (for sale soon for $35K or best offer) > > 1985 PT 40 > > > > At 02:04 PM 4/7/2006, you wrote: > > >Ron, > > > > > >Re your comments: > > > > > > > The two stroke Detroits really shouldn't use synthetics, > > > > unless someone starts producing a single weight synthetic. > > > > All that I have seen are multi-grade and they won't hold up under 5 > > > > psi oil pressure at idle. > > > > > >Just FYI, Detroit's current statement on synthetics is as follows: > > >3.7 SYNTHETIC OILS > > >Synthetic oils should be used in Detroit Diesel engines provided they > > >are API licensed and meet the performance and chemical requirements > > >outlined in this publication. The oil should be a PGOS 93K214 approved > > >product for use in EGR equipped engines. For two-stroke cycle > > >engines, only synthetic oils which do not contain viscosity improver > > >additives may be used. > > > > > >I have been using Amsoil 15W-40 Heavy Duty Diesel and Marine Oil in > > >both my Birds. Generally speaking, "W"/multigrade oils have to pass > > >both the low viscosity and high viscosity tests. The Amsoil oil does > > >and passes all tests that are required for straight 40 oil - and all > > >the requirements for a straight 40 oil listed in the Detroit > > >publication. My 8V and my old 6V both had approximately 15lbs at idle > > >on synthetic. > > > > > >You are right that the single weight synthetics are impossible to find > > >any more. The market wasn't big enough for manufacturers to continue > > >to make it. The new generation multi-weight synthetics perform just > > >as well as the straight weights. > > > > > >Generally, synthetic versus non-synthetic debates are split into the > > >true believer and non-believer camps. With the current prices, the > > >price delta is narrowing. If one believes that cheaper dino oil > > >performs as well as synthetics, then that's their comfort factor. If > > >one believes that synthetics don't break down like dino oil, reduce > > >friction, which reduces heat, and are better at protecting an > > >expensive investment, then that is what they will use. All the rest > > >is just rethoric that will convince neither party. Mark me down as > > >true believer/user since 1979. > > > > > >Mike Bulriss > > >1991 WB40 "Texas Minivan" - full of Amsoil > > >San Antonio, TX > > > > > >--- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > > > > > > > I agree mostly with what you say, but with a couple exceptions. > First > > > > with engine oil: The two stroke Detroits really shouldn't use > > > > synthetics, unless someone starts producing a single weight > synthetic. > > > > All that I have seen are multi-grade and they won't hold up under 5 > > > > psi oil pressure at idle. > > > > > > > > I use Transynd in my Allison because I have a transmission retarder. > > > > Since I drive a lot in the mountains, the synthetic holds up better > > > > with the heat stress that is created using the retarder. I > agree with > > > > natural fluids if that were not the case. > > > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner > wrote: > > > > > > > > > > Each of us has to make our own decisions relative to how we will > > > > > service our engines and transmissions, what kind and brand of > tires > > > > > to use etc, etc etc, ad nauseum. But in my experience > starting with > > > > > High Fidelity in the 1950's many bought based on the hype of > > > > > manufacturers taunting the fantastic frequency repsonses of their > > > > > equipment. Of course the better the specifications the higher the > > > > > price. Problem is that many who bought the highest speced > equipment > > > > > and paid sky high prices for it, seldom used it and had no ear to > > > > > differentiate the difference. Yep I was one of those. > > > > > > > > > > And in my opinion this very closely relates to the use of > synthetic > > > > > motor oils and transmission fluids used in motorhomes that are > driven > > > > > very few miles a year. If you notice on the Allison > transmission site > > > > > that was > > > noted > > > > <<http://tinyurl.com/qs3a9>http://tinyurl.com/qs3a9>http://tinyurl.co m/qs3a9, > > > > > and then go to Approved C4 fluids you will note that Dextron 3 > is an > > > > > approved fluid and meets all of Allisons specifications. In other > > > > > words it meets ALL of the Allison specifications..period, as > do over > > > > > 700 other brands! But note that Allison now recommends > changing the > > > > > C4 specification transmission lubricants at 12,000 mile > intervals or > > > > > every 6 months which ever comes first. Isnt it strange that > the over > > > > > the previous 50 years or so truckers all over the world never,ever > > > > > followed this regimine and racked up in excess of 500,000 miles on > > > > > them without a problem? Wonder how many Allison transmissions in > > > > > motorhome service have never had their fluid changed since > > > > > manufacture? And note if you do use Transynd the transmission > fluid > > > > > change interval is 75,000 miles or 36 months. We are not going to > > > > > hit the 75,000 mile in 3 years, at least I dont plan to, so > every 3 > > > > > years I would have to change the transmission fluid after > travelling > > > > > approximately 15,000-20,000 miles. > > > > > > > > > > Now go to the list of approved Allison TES-295 approved > transmission > > > > > fluids, which is a severe duty extended drain interval > transmission > > > > > fluid. Note that Amsoil, that you have noted in > > > > > http://www.syntheticwarehouse.com/drivet....htm#*NEW* is NOT > listed > > > > > as an Allison TES-295 approved fluid. > > > > > > > > > > As I have noted many times previously todays engine oils and > > > > > transmission fluids meet or exceed any kind of service we put our > > > > > motorhomes thru. If you drive sensibly Dextron 3 for the > transmission > > > > > and good dino oil is fine for the diesel engine. > > > > > tom warner > > > > > Vernon center,NY > > > > > 1982 FC35 (for sale soon) > > > > > 1985 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > At 09:24 AM 4/6/2006, you wrote: > > > > > >Bob, > > > > > > > > > > > >I'm no expert, but I am fortunate enough to have a long- time > friend > > > > > >nearby that is an Allison Transmission Specialist, and > services our > > > > > >bus. On his professional recommendation, we changed out the > filters > > > > > >and added TranSynd, synthetic fluid. > > > > > > > > > > > > > > > > > > ><<http://www.allisontransmission.com/>http://www.allisontransmissio > > > n.com/>http://www.allisontransmission.com/ > > > > > ><http://www.syntheticwarehouse.com/drivet....htm#*NEW*>h > > > ttp://www.syntheticwarehouse.com/drivetr....htm#*NEW* > > > > > ><http://tinyurl.com/qs3a9><http://tinyurl.com/qs3a9>http://tiny > > > url.com/qs3a9 > > > > > > > > > > > >Ron, No. California > > > > > >85PT36 > > > > > > > > > > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > > > > > > > > > > > > > > > > > > Is it worth the expense ($8.00 a quart)and how long does > it last > > > > > > > before needing rechanging? > > > > > > > Should I just stay with the conventional stuff in there now > > > > (changing > > > > > > > it out, of course). > > > > > > > What think you? > > > > > > > > > > > > > > Bob Lawrence > > > > > > > 84 pt36 > > > > > > > Tacky Tacoma, Wa. with 556 days till fulltiming on the road. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >---------- > > > > > >YAHOO! GROUPS LINKS > > > > > > > > > > > > * Visit your group > > > > > > > > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yah oo.com/group/WanderlodgeForum>WanderlodgeForum" > > > > on the web. > > > > > > * > > > > > > * To unsubscribe from this group, send an email to: > > > > > > * > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > * > > > > > > * Your use of Yahoo! Groups is subject to the > > > > > > > > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/ >Yahoo! > > > > Terms of Service. > > > > > > > > > > > > > > > > > >---------- > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >---------- > > >YAHOO! GROUPS LINKS > > > > > > * Visit your group > > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" > on the web. > > > * > > > * To unsubscribe from this group, send an email to: > > > * > > > > > > > > > > > * > > > * Your use of Yahoo! Groups is subject to the > > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > > > > >---------- > > > |
04-10-2006, 03:03
Synthetic vs. Dino
Thanks for your insight. How many miles traveled are you basing your report?
In other words, how many miles accumulated since the oil change? Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: whynotam To: WanderlodgeForum@yahoogroups.com Sent: Monday, April 10, 2006 9:47 AM Subject: [WanderlodgeForum] Synthetic vs. Dino From the for what it's worth department. After speaking with one of the members of this forum about the value of synthetic versus dino oil (thanks Bob) for my 1993 8V92 I made the switch from straight Rotella 40W to Amsoil 15W40. The results have been nothing short of amazing as oil consumption went from around 1 quart per 250 miles to about 1 quart per 850 miles when I am pushing it hard, to pretty much nothing when driving 55 or 60 MPH. The 40W used to get that diesel black color within a couple hundred miles of an oil change whereas the synthetic oil is still quite clear even after 3200 miles. The engine used to smoke some when leaving a stop light but now has to be fully floored to put out much smoke at all. The coolant is also not running quite as warm thus the fan is seldom kicking in any more. More than likely fuel consumption has also decreased but since I do not keep track I can't vouch for that. It is quite obvious to me that something good has taken place with my change from dino oil to synthetic. Next step is to change the other lubricants as well. I am not trying to start a war here but am just relaying my experience "for what it's worth". Alvie Miller 1993 WLWB Arthur IL. --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Thank you Tom. I would have put you in the non-believer camp. Enjoy > your Walmart Dino Oil. > > Mike Bulriss - I won the bet! I won the bet! > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > > > Mike you may be correct but I cannot find anywhere that ANY > > syntheitcs are recommended for use in the Detroit diesel 2 cycle > > engine. The statement in sect 3.7 that you quote " only synthetic > > oils which do not contain viscosity improver additives may be used" > > disqualifies all multigrade synthetics since viscosity improvers are > > used. I can buy Rotella T single grade at Walmarts and it is easily > availble. > > > > http://www.shell-lubricants.com/products...llaTSG.pdf > > Tom Warner > > Vernon Center,NY > > 1982 FC35 (for sale soon for $35K or best offer) > > 1985 PT 40 > > > > At 02:04 PM 4/7/2006, you wrote: > > >Ron, > > > > > >Re your comments: > > > > > > > The two stroke Detroits really shouldn't use synthetics, > > > > unless someone starts producing a single weight synthetic. > > > > All that I have seen are multi-grade and they won't hold up under 5 > > > > psi oil pressure at idle. > > > > > >Just FYI, Detroit's current statement on synthetics is as follows: > > >3.7 SYNTHETIC OILS > > >Synthetic oils should be used in Detroit Diesel engines provided they > > >are API licensed and meet the performance and chemical requirements > > >outlined in this publication. The oil should be a PGOS 93K214 approved > > >product for use in EGR equipped engines. For two-stroke cycle > > >engines, only synthetic oils which do not contain viscosity improver > > >additives may be used. > > > > > >I have been using Amsoil 15W-40 Heavy Duty Diesel and Marine Oil in > > >both my Birds. Generally speaking, "W"/multigrade oils have to pass > > >both the low viscosity and high viscosity tests. The Amsoil oil does > > >and passes all tests that are required for straight 40 oil - and all > > >the requirements for a straight 40 oil listed in the Detroit > > >publication. My 8V and my old 6V both had approximately 15lbs at idle > > >on synthetic. > > > > > >You are right that the single weight synthetics are impossible to find > > >any more. The market wasn't big enough for manufacturers to continue > > >to make it. The new generation multi-weight synthetics perform just > > >as well as the straight weights. > > > > > >Generally, synthetic versus non-synthetic debates are split into the > > >true believer and non-believer camps. With the current prices, the > > >price delta is narrowing. If one believes that cheaper dino oil > > >performs as well as synthetics, then that's their comfort factor. If > > >one believes that synthetics don't break down like dino oil, reduce > > >friction, which reduces heat, and are better at protecting an > > >expensive investment, then that is what they will use. All the rest > > >is just rethoric that will convince neither party. Mark me down as > > >true believer/user since 1979. > > > > > >Mike Bulriss > > >1991 WB40 "Texas Minivan" - full of Amsoil > > >San Antonio, TX > > > > > >--- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > > > > > > > I agree mostly with what you say, but with a couple exceptions. > First > > > > with engine oil: The two stroke Detroits really shouldn't use > > > > synthetics, unless someone starts producing a single weight > synthetic. > > > > All that I have seen are multi-grade and they won't hold up under 5 > > > > psi oil pressure at idle. > > > > > > > > I use Transynd in my Allison because I have a transmission retarder. > > > > Since I drive a lot in the mountains, the synthetic holds up better > > > > with the heat stress that is created using the retarder. I > agree with > > > > natural fluids if that were not the case. > > > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner > wrote: > > > > > > > > > > Each of us has to make our own decisions relative to how we will > > > > > service our engines and transmissions, what kind and brand of > tires > > > > > to use etc, etc etc, ad nauseum. But in my experience > starting with > > > > > High Fidelity in the 1950's many bought based on the hype of > > > > > manufacturers taunting the fantastic frequency repsonses of their > > > > > equipment. Of course the better the specifications the higher the > > > > > price. Problem is that many who bought the highest speced > equipment > > > > > and paid sky high prices for it, seldom used it and had no ear to > > > > > differentiate the difference. Yep I was one of those. > > > > > > > > > > And in my opinion this very closely relates to the use of > synthetic > > > > > motor oils and transmission fluids used in motorhomes that are > driven > > > > > very few miles a year. If you notice on the Allison > transmission site > > > > > that was > > > noted > > > > <<http://tinyurl.com/qs3a9>http://tinyurl.com/qs3a9>http://tinyurl.co m/qs3a9, > > > > > and then go to Approved C4 fluids you will note that Dextron 3 > is an > > > > > approved fluid and meets all of Allisons specifications. In other > > > > > words it meets ALL of the Allison specifications..period, as > do over > > > > > 700 other brands! But note that Allison now recommends > changing the > > > > > C4 specification transmission lubricants at 12,000 mile > intervals or > > > > > every 6 months which ever comes first. Isnt it strange that > the over > > > > > the previous 50 years or so truckers all over the world never,ever > > > > > followed this regimine and racked up in excess of 500,000 miles on > > > > > them without a problem? Wonder how many Allison transmissions in > > > > > motorhome service have never had their fluid changed since > > > > > manufacture? And note if you do use Transynd the transmission > fluid > > > > > change interval is 75,000 miles or 36 months. We are not going to > > > > > hit the 75,000 mile in 3 years, at least I dont plan to, so > every 3 > > > > > years I would have to change the transmission fluid after > travelling > > > > > approximately 15,000-20,000 miles. > > > > > > > > > > Now go to the list of approved Allison TES-295 approved > transmission > > > > > fluids, which is a severe duty extended drain interval > transmission > > > > > fluid. Note that Amsoil, that you have noted in > > > > > http://www.syntheticwarehouse.com/drivet....htm#*NEW* is NOT > listed > > > > > as an Allison TES-295 approved fluid. > > > > > > > > > > As I have noted many times previously todays engine oils and > > > > > transmission fluids meet or exceed any kind of service we put our > > > > > motorhomes thru. If you drive sensibly Dextron 3 for the > transmission > > > > > and good dino oil is fine for the diesel engine. > > > > > tom warner > > > > > Vernon center,NY > > > > > 1982 FC35 (for sale soon) > > > > > 1985 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > At 09:24 AM 4/6/2006, you wrote: > > > > > >Bob, > > > > > > > > > > > >I'm no expert, but I am fortunate enough to have a long- time > friend > > > > > >nearby that is an Allison Transmission Specialist, and > services our > > > > > >bus. On his professional recommendation, we changed out the > filters > > > > > >and added TranSynd, synthetic fluid. > > > > > > > > > > > > > > > > > > ><<http://www.allisontransmission.com/>http://www.allisontransmissio > > > n.com/>http://www.allisontransmission.com/ > > > > > ><http://www.syntheticwarehouse.com/drivet....htm#*NEW*>h > > > ttp://www.syntheticwarehouse.com/drivetr....htm#*NEW* > > > > > ><http://tinyurl.com/qs3a9><http://tinyurl.com/qs3a9>http://tiny > > > url.com/qs3a9 > > > > > > > > > > > >Ron, No. California > > > > > >85PT36 > > > > > > > > > > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > > > > > > > > > > > > > > > > > > Is it worth the expense ($8.00 a quart)and how long does > it last > > > > > > > before needing rechanging? > > > > > > > Should I just stay with the conventional stuff in there now > > > > (changing > > > > > > > it out, of course). > > > > > > > What think you? > > > > > > > > > > > > > > Bob Lawrence > > > > > > > 84 pt36 > > > > > > > Tacky Tacoma, Wa. with 556 days till fulltiming on the road. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >---------- > > > > > >YAHOO! GROUPS LINKS > > > > > > > > > > > > * Visit your group > > > > > > > > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yah oo.com/group/WanderlodgeForum>WanderlodgeForum" > > > > on the web. > > > > > > * > > > > > > * To unsubscribe from this group, send an email to: > > > > > > * > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > * > > > > > > * Your use of Yahoo! Groups is subject to the > > > > > > > > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/ >Yahoo! > > > > Terms of Service. > > > > > > > > > > > > > > > > > >---------- > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >---------- > > >YAHOO! GROUPS LINKS > > > > > > * Visit your group > > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" > on the web. > > > * > > > * To unsubscribe from this group, send an email to: > > > * > > > > > > > > > > > * > > > * Your use of Yahoo! Groups is subject to the > > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > > > > >---------- > > > ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-10-2006, 06:53
Synthetic vs. Dino
MY 6V92 has 15-40 amsoil in it and am suprised about the low consumption, have
not added any. I bought it with this oil being used and after reading I think the oil recomended is special straight weight for DD engines. That being said and after much research I ordered some amsoil,[which have never used before] i checked and it is very low in sulfer etc. So will use the marine-diesel amsoil this change and read more, am still not sure if is the right way to go, but these things do not cool the best so maybe?Previous owner was also using syn. tranny fluid so guess will go that route also and diff. syn. 90- 140.which i think has dinno in it now. Wish I new the real answer to this?Marvin SkaggsBuffalo, Ky. 427161984 PT40--- On Mon 04/10, whynotam < aamiller@... > wrote:From: whynotam [mailto: aamiller@...]To: WanderlodgeForum@...: Mon, 10 Apr 2006 14:47:06 -0000Subject: [WanderlodgeForum] Synthetic vs. DinoFrom the for what it's worth department.After speaking with one of the members of this forum about the value of synthetic versus dino oil (thanks Bob) for my 1993 8V92 I made the switch from straight Rotella 40W to Amsoil 15W40. The results have been nothing short of amazing as oil consumption went from around 1 quart per 250 miles to about 1 quart per 850 miles when I am pushing it hard, to pretty much nothing when driving 55 or 60 MPH. The 40W used to get that diesel black color within a couple hundred miles of an oil change whereas the synthetic oil is still quite clear even after 3200 miles. The engine used to smoke some when leaving a stop light but now has to be fully floored to put out much smoke at all. The coolant is also not running quite as warm thus the fan is seldom kicking in any more. More than likely fuel consumption has also decreased but since I do not keep track I can't vouch for that. It is quite obvious to me that something good has taken place with my change from dino oil to synthetic. Next step is to change the other lubricants as well. I am not trying to start a war here but am just relaying my experience "for what it's worth".Alvie Miller1993 WLWBArthur IL.--- In WanderlodgeForum@yahoogroups.com, "mbulriss" wrote:>> Thank you Tom. I would have put you in the non-believer camp. Enjoy> your Walmart Dino Oil.> > Mike Bulriss - I won the bet! I won the bet!> 1991 WB40 "Texas Minivan"> San Antonio, TX> > --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote:> >> > Mike you may be correct but I cannot find anywhere that ANY > > syntheitcs are recommended for use in the Detroit diesel 2 cycle > > engine. The statement in sect 3.7 that you quote " only synthetic > > oils which do not contain viscosity improver additives may be used" > > disqualifies all multigrade synthetics since viscosity improvers are > > used. I can buy Rotella T single grade at Walmarts and it is easily> availble.> > > > http://www.shell-lubricants.com/products...SG.pdf> > Tom Warner> > Vernon Center,NY> > 1982 FC35 (for sale soon for $35K or best offer)> > 1985 PT 40> > > > At 02:04 PM 4/7/2006, you wrote:> > >Ron,> > >> > >Re your comments:> > >> > > > The two stroke Detroits really shouldn't use synthetics,> > > > unless someone starts producing a single weight synthetic.> > > > All that I have seen are multi-grade and they won't hold up under 5> > > > psi oil pressure at idle.> > >> > >Just FYI, Detroit's current statement on synthetics is as follows:> > >3.7 SYNTHETIC OILS> > >Synthetic oils should be used in Detroit Diesel engines provided they> > >are API licensed and meet the performance and chemical requirements> > >outlined in this publication. The oil should be a PGOS 93K214 approved> > >product for use in EGR equipped engines. For two-stroke cycle> > >engines, only synthetic oils which do not contain viscosity improver> > >additives may be used.> > >> > >I have been using Amsoil 15W-40 Heavy Duty Diesel and Marine Oil in> > >both my Birds. Generally speaking, "W"/multigrade oils have to pass> > >both the low viscosity and high viscosity tests. The Amsoil oil does> > >and passes all tests that are required for straight 40 oil - and all> > >the requirements for a straight 40 oil listed in the Detroit> > >publication. My 8V and my old 6V both had approximately 15lbs at idle> > >on synthetic.> > >> > >You are right that the single weight synthetics are impossible to find> > >any more. The market wasn't big enough for manufacturers to continue> > >to make it. The new generation multi-weight synthetics perform just> > >as well as the straight weights.> > >> > >Generally, synthetic versus non-synthetic debates are split into the> > >true believer and non-believer camps. With the current prices, the> > >price delta is narrowing. If one believes that cheaper dino oil> > >performs as well as synthetics, then that's their comfort factor. If> > >one believes that synthetics don't break down like dino oil, reduce> > >friction, which reduces heat, and are better at protecting an> > >expensive investment, then that is what they will use. All the rest> > >is just rethoric that will convince neither party. Mark me down as> > >true believer/user since 1979.> > >> > >Mike Bulriss> > >1991 WB40 "Texas Minivan" - full of Amsoil> > >San Antonio, TX> > >> > >--- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002"> > > wrote:> > > >> > > > I agree mostly with what you say, but with a couple exceptions.> First> > > > with engine oil: The two stroke Detroits really shouldn't use> > > > synthetics, unless someone starts producing a single weight> synthetic.> > > > All that I have seen are multi-grade and they won't hold up under 5> > > > psi oil pressure at idle.> > > >> > > > I use Transynd in my Allison because I have a transmission retarder.> > > > Since I drive a lot in the mountains, the synthetic holds up better> > > > with the heat stress that is created using the retarder. I> agree with> > > > natural fluids if that were not the case.> > > >> > > > R.E. (Ron) Marabito, Dallas, TX 92WB40> > > >> > > >> > > >> > > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner > wrote:> > > > >> > > > > Each of us has to make our own decisions relative to how we will> > > > > service our engines and transmissions, what kind and brand of> tires> > > > > to use etc, etc etc, ad nauseum. But in my experience> starting with> > > > > High Fidelity in the 1950's many bought based on the hype of> > > > > manufacturers taunting the fantastic frequency repsonses of their> > > > > equipment. Of course the better the specifications the higher the> > > > > price. Problem is that many who bought the highest speced> equipment> > > > > and paid sky high prices for it, seldom used it and had no ear to> > > > > differentiate the difference. Yep I was one of those.> > > > >> > > > > And in my opinion this very closely relates to the use of> synthetic> > > > > motor oils and transmission fluids used in motorhomes that are> driven> > > > > very few miles a year. If you notice on the Allison> transmission site> > > > > that was > > > noted > > >> <<http://tinyurl.com/qs3a9>http://tinyu...url.c\ om/qs3a9,> > > > > and then go to Approved C4 fluids you will note that Dextron 3> is an> > > > > approved fluid and meets all of Allisons specifications. In other> > > > > words it meets ALL of the Allison specifications..period, as> do over> > > > > 700 other brands! But note that Allison now recommends> changing the> > > > > C4 specification transmission lubricants at 12,000 mile> intervals or> > > > > every 6 months which ever comes first. Isnt it strange that> the over> > > > > the previous 50 years or so truckers all over the world never,ever> > > > > followed this regimine and racked up in excess of 500,000 miles on> > > > > them without a problem? Wonder how many Allison transmissions in> > > > > motorhome service have never had their fluid changed since> > > > > manufacture? And note if you do use Transynd the transmission> fluid> > > > > change interval is 75,000 miles or 36 months. We are not going to> > > > > hit the 75,000 mile in 3 years, at least I dont plan to, so> every 3> > > > > years I would have to change the transmission fluid after> travelling> > > > > approximately 15,000-20,000 miles.> > > > >> > > > > Now go to the list of approved Allison TES-295 approved> transmission> > > > > fluids, which is a severe duty extended drain interval> transmission> > > > > fluid. Note that Amsoil, that you have noted in> > > > > http://www.syntheticwarehouse.com/drivet....htm#*NEW* is NOT> listed> > > > > as an Allison TES-295 approved fluid.> > > > >> > > > > As I have noted many times previously todays engine oils and> > > > > transmission fluids meet or exceed any kind of service we put our> > > > > motorhomes thru. If you drive sensibly Dextron 3 for the> transmission> > > > > and good dino oil is fine for the diesel engine.> > > > > tom warner> > > > > Vernon center,NY> > > > > 1982 FC35 (for sale soon)> > > > > 1985 PT40> > > > >> > > > >> > > > >> > > > >> > > > > At 09:24 AM 4/6/2006, you wrote:> > > > > >Bob,> > > > > >> > > > > >I'm no expert, but I am fortunate enough to have a long-time> friend> > > > > >nearby that is an Allison Transmission Specialist, and> services our> > > > > >bus. On his professional recommendation, we changed out the> filters> > > > > >and added TranSynd, synthetic fluid.> > > > > >> > > > >> > > >> > > ><<http://www.allisontransmission.com/>h...ransmissio > > > n.com/>http://www.allisontransmission.com/> > > > > ><http://www.syntheticwarehouse.com/drivet...*NEW*>h > > > ttp://www.syntheticwarehouse.com/drivetr...#*NEW*> > > > > ><http://tinyurl.com/qs3a9><http://t...ttp://tiny > > > url.com/qs3a9> > > > > >> > > > > >Ron, No. California> > > > > >85PT36> > > > > >> > > > > >> > > > > >--- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence"> > > > > > wrote:> > > > > > >> > > > > > > Is it worth the expense ($8.00 a quart)and how long does> it last> > > > > > > before needing rechanging?> > > > > > > Should I just stay with the conventional stuff in there now> > > > (changing> > > > > > > it out, of course).> > > > > > > What think you?> > > > > > >> > > > > > > Bob Lawrence> > > > > > > 84 pt36> > > > > > > Tacky Tacoma, Wa. with 556 days till fulltiming on the road.> > > > > > >> > > > > >> > > > > >> > > > > >> > > > > >> > > > > >> > > > > >> > > > > >> > > > > >----------> > > > > >YAHOO! GROUPS LINKS> > > > > >> > > > > > * Visit your group> > > > > > > > >> "<<http://groups.yahoo.com/group/Wanderlodg...hoo.c\ om/group/WanderlodgeForum>WanderlodgeForum"> > > > on the web.> > > > > > *> > > > > > * To unsubscribe from this group, send an email to:> > > > > > *> > > > > >> > > >> >> > _______________________________________________ Join Excite! - http://www.excite.com The most personalized portal on the Web! [Non-text portions of this message have been removed] |
04-10-2006, 08:11
Synthetic vs. Dino
I put eighty thousand miles on a 6v-92 using amsoil 15/40 and have 50
thousand on my 8v-92 using amsoil. I also use the amsoil syn transmission fluid along with the rear dif, fluid. My Dodge diesel pickup truck has 100 thousand with amsoil in it from the first day. No complaint's. I have the oil analysis once a year on all vehicles and no problem's. I would never go back to Dino.. Still snow on the ground here in Jackson, Wy..Bob&Carol. 93pt-40 Bunker Hill, Il... |
04-10-2006, 12:15
Synthetic vs. Dino
Hi Bob,
Your 80k miles on the 6v-92..is that without an oil change? Just put in dino in the engine with synthetic in tranny (Amsoil). I wonder if I decide to switch to Amsoil in engine how many miles I have to have on it before draining the dino oil. At present, I only have 5k miles on the rebuilt engine. Bob Lawrence 84 PT36 (Scratching my head) Tacoma, Wa. > > I put eighty thousand miles on a 6v-92 using amsoil 15/40 and have 50 > thousand on my 8v-92 using amsoil. I also use the amsoil syn > transmission fluid along with the rear dif, fluid. My Dodge diesel > pickup truck has 100 thousand with amsoil in it from the first day. No > complaint's. I have the oil analysis once a year on all vehicles and no > problem's. I would never go back to Dino.. Still snow on the ground > here in Jackson, Wy..Bob&Carol. 93pt-40 Bunker Hill, Il... > |
04-10-2006, 14:05
Synthetic vs. Dino
If your engine rebuilder gave you special break-in oil change
requirements (shorter interval), use the cheap oil to the first change. if not, you can change at any time, breaking in an engine with syn oil in it is fine and recommended by Mobil. Dino is fine, synthetic is better. Holland Motor Express used to run Mobil Delvac 1 in their 6V92 fleet, changed it at 250,000 miles during a major maintenance, filters in-between. I don't know if it has changed, but last I knew the Delvac 1 has no viscosity modifiers. Synthetic trans fluid I highly recommend as it has a higher thermal transmissivity and will run cooler, one reason it is popular with the towable-RV crowd, it made a noticeable improvement in trans temps during retarder use in my '88. ZF allows triple the maintenance interval with synthetic trans fluid over conventional/dino fluid. Lots of money, and as many will argue the coach will run fine without it. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Hi Bob, > Your 80k miles on the 6v-92..is that without an oil change? > Just put in dino in the engine with synthetic in tranny (Amsoil). > I wonder if I decide to switch to Amsoil in engine how many miles I > have to have on it before draining the dino oil. At present, I only > have 5k miles on the rebuilt engine. > Bob Lawrence > 84 PT36 (Scratching my head) > Tacoma, Wa. > > > > I put eighty thousand miles on a 6v-92 using amsoil 15/40 and have > 50 > > thousand on my 8v-92 using amsoil. I also use the amsoil syn > > transmission fluid along with the rear dif, fluid. My Dodge diesel > > pickup truck has 100 thousand with amsoil in it from the first day. > No > > complaint's. I have the oil analysis once a year on all vehicles and > no > > problem's. I would never go back to Dino.. Still snow on the ground > > here in Jackson, Wy..Bob&Carol. 93pt-40 Bunker Hill, Il... > > > |
04-10-2006, 14:16
Synthetic vs. Dino
Bob,
I have been using Amsoil in every internal combustion engine I own since 1979. At 5,000 miles, with modern ring technolgy everything is broken in by now and you are OK to switch, but since you just had the oil changed, switch at 8-10,000 and get your money's worth out of the last oil change. When you switch, make sure you get a good quality synthetic oil filter also: Amsoil, Mobil-1 or the new Donaldson line. The synthetics don't break down, but they will load up with dirt and soot just like dino oil. You need excellent quality filters to preserve your synthetic oil investment. The paper based filters are are a waste of money and synthetic. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Hi Bob, > Your 80k miles on the 6v-92..is that without an oil change? > Just put in dino in the engine with synthetic in tranny (Amsoil). > I wonder if I decide to switch to Amsoil in engine how many miles I > have to have on it before draining the dino oil. At present, I only > have 5k miles on the rebuilt engine. > Bob Lawrence > 84 PT36 (Scratching my head) > Tacoma, Wa. > > > > I put eighty thousand miles on a 6v-92 using amsoil 15/40 and have > 50 > > thousand on my 8v-92 using amsoil. I also use the amsoil syn > > transmission fluid along with the rear dif, fluid. My Dodge diesel > > pickup truck has 100 thousand with amsoil in it from the first day. > No > > complaint's. I have the oil analysis once a year on all vehicles and > no > > problem's. I would never go back to Dino.. Still snow on the ground > > here in Jackson, Wy..Bob&Carol. 93pt-40 Bunker Hill, Il... > > > |
04-10-2006, 14:31
Synthetic vs. Dino
Mike,
How are the synthetic filters different from conventional filters? Do you have part #'s for the proper filter to be used while using synthetic engine oil? Jay Darst 85PT40 Springfield, IL where might be making the switch from dino to synthetic in the DD, startint to make some sense.... --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Bob, > > I have been using Amsoil in every internal combustion engine I own > since 1979. At 5,000 miles, with modern ring technolgy everything is > broken in by now and you are OK to switch, but since you just had the > oil changed, switch at 8-10,000 and get your money's worth out of the > last oil change. When you switch, make sure you get a good quality > synthetic oil filter also: Amsoil, Mobil-1 or the new Donaldson line. > The synthetics don't break down, but they will load up with dirt and > soot just like dino oil. You need excellent quality filters to > preserve your synthetic oil investment. The paper based filters are > are a waste of money and synthetic. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > > > Hi Bob, > > Your 80k miles on the 6v-92..is that without an oil change? > > Just put in dino in the engine with synthetic in tranny (Amsoil). > > I wonder if I decide to switch to Amsoil in engine how many miles I > > have to have on it before draining the dino oil. At present, I only > > have 5k miles on the rebuilt engine. > > Bob Lawrence > > 84 PT36 (Scratching my head) > > Tacoma, Wa. > > > > > > I put eighty thousand miles on a 6v-92 using amsoil 15/40 and have > > 50 > > > thousand on my 8v-92 using amsoil. I also use the amsoil syn > > > transmission fluid along with the rear dif, fluid. My Dodge diesel > > > pickup truck has 100 thousand with amsoil in it from the first day. > > No > > > complaint's. I have the oil analysis once a year on all vehicles and > > no > > > problem's. I would never go back to Dino.. Still snow on the ground > > > here in Jackson, Wy..Bob&Carol. 93pt-40 Bunker Hill, Il... > > > > > > |
04-10-2006, 16:35
Synthetic vs. Dino
Jay,
Regular oil filters tend to cellulose based, commonly referred to as paper. If you ever cut a regular Fram or AC filter open it is typically just pleated paper to increase the total surface area of the paper filter medium. Cellulose is basically broken down soaked wood chips made into a paste and then compressed into sheets and dried to become paper. As a result, cellulose fibers are inconsistent in size, shape and thickness. You have thick spots and shallow spots in the paper. Thick spots result in higher restriction and lower dirt holding capacity. Shallow spots allow more contaminants to pass through and can even rupture into mini-holes allowing unfiltered oil and contaminants through. It is the very small contaminants that cause most of the wear in engines over time. As time goes on, the hot oil will also degrade the resins that bind the cellulose media together, which allows even more unfiltered contaminants to pass through. If you get lucky and get a particular thick piece of cellulose, it can get saturated or totally plugged up with contaminants and then start bypassing unfiltered oil through the filter bypass valves. That's what they are there for, to prevent engine oil starvation in the event of filter restrictions. The synthetic grade filters typically use a manmade synthetic media which has very controlled fiber density of uniform sizes, shapes and smaller diameters. They are then typically layered in various densities with wire screen backing for shape and strength. they are compressed at a consistent rate to eliminate thick or weak spots. They then have consistent flow rates and more fully filter multi-micron size contaminants. Precisely measured tests prove them to be far more efficient at cleaning pre-measured contaminants out of oil passing through them. With synthetic oil, use good synthetic filters and change them half way through your life cycle of usage. For even more efficient cleaning, several manufacturers sell bypass filter systems that use even denser synthetic media that can clean down into the one micron range. These bypass filter systems typically use a restricted oil orifice, typically off the oil pressure gauge sending unit, to pass small amounts of oil at a time through the bypass filtration system. Due to the dense filtering restriction, it typically takes 7-15 miles at highway speeds to pass all of the oil through the bypass filtering system, which cleans the oil back to nearly new state in terms of contaminants. An early version of these deep cleaning bypass filters were commonly found on the mid-80s PT Birds. Many of them have been removed since they were so dirty to change. I know mine was missing on Stagecoach - only the documentation in the Blue Box remained. The new bypass filter systems utilize spin on filters and are much easier to service. Supposedly, you never need to change the synthetic oil again with synthetic filters and a synthetic quality bypass filter system. You just change the filters regularly and top off the synthetic oil supply. I have a bypass system I haven't installed yet. Amsoil has an interesting tear down test on a class 8 diesel with 400,000+ miles that had a bypass system and only changed filters during that time. Ironically, as regards air filters, the most effective air filter tests that I have seen are not cellulose/paper or oil treated synthetic filters, but the old oil bath filters found on the Perkins gen sets. So if you have one of those, keep it. Per your question, the synthetic oil filter cross reference numbers I have for the 6V and 8V are as follows: Amsoil SDF72 Donaldson Endurance ELF7670 Hastings LF262 Fleetguard LF670 LuberFiner P670/LFP911 I have the Perkins oil filter numbers in the old bus log, which I don't have here right now. I believe the Amsoil oil filter # is SDF96. Actually, I think I posted a cross reference list in the forum files if you need them. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" wrote: > > Mike, > > How are the synthetic filters different from conventional filters? > > Do you have part #'s for the proper filter to be used while using > synthetic engine oil? > > Jay Darst > 85PT40 > Springfield, IL where might be making the switch from dino to > synthetic in the DD, startint to make some sense.... > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > wrote: > > > > Bob, > > > > I have been using Amsoil in every internal combustion engine I own > > since 1979. At 5,000 miles, with modern ring technolgy everything > is > > broken in by now and you are OK to switch, but since you just had > the > > oil changed, switch at 8-10,000 and get your money's worth out of > the > > last oil change. When you switch, make sure you get a good quality > > synthetic oil filter also: Amsoil, Mobil-1 or the new Donaldson > line. > > The synthetics don't break down, but they will load up with dirt > and > > soot just like dino oil. You need excellent quality filters to > > preserve your synthetic oil investment. The paper based filters > are > > are a waste of money and synthetic. > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > > > > > > Hi Bob, > > > Your 80k miles on the 6v-92..is that without an oil change? > > > Just put in dino in the engine with synthetic in tranny (Amsoil). > > > I wonder if I decide to switch to Amsoil in engine how many > miles I > > > have to have on it before draining the dino oil. At present, I > only > > > have 5k miles on the rebuilt engine. > > > Bob Lawrence > > > 84 PT36 (Scratching my head) > > > Tacoma, Wa. > > > > > > > > I put eighty thousand miles on a 6v-92 using amsoil 15/40 and > have > > > 50 > > > > thousand on my 8v-92 using amsoil. I also use the amsoil syn > > > > transmission fluid along with the rear dif, fluid. My Dodge > diesel > > > > pickup truck has 100 thousand with amsoil in it from the first > day. > > > No > > > > complaint's. I have the oil analysis once a year on all > vehicles and > > > no > > > > problem's. I would never go back to Dino.. Still snow on the > ground > > > > here in Jackson, Wy..Bob&Carol. 93pt-40 Bunker Hill, Il... > > > > > > > > > > |
04-11-2006, 02:12
Synthetic vs. Dino
Mike,
So far just 3200 miles, thus the disclaimer "for what it's worth". Alvie Miller 1993 WLWB Arthur IL. --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > Thanks for your insight. How many miles traveled are you basing your report? In other words, how many miles accumulated since the oil change? > Mike Hohnstein > Germantown, WI > 83FC35 > ----- Original Message ----- > From: whynotam > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, April 10, 2006 9:47 AM > Subject: [WanderlodgeForum] Synthetic vs. Dino > > > From the for what it's worth department. > > After speaking with one of the members of this forum about the value > of synthetic versus dino oil (thanks Bob) for my 1993 8V92 I made > the switch from straight Rotella 40W to Amsoil 15W40. The results > have been nothing short of amazing as oil consumption went from > around 1 quart per 250 miles to about 1 quart per 850 miles when I > am pushing it hard, to pretty much nothing when driving 55 or 60 > MPH. The 40W used to get that diesel black color within a couple > hundred miles of an oil change whereas the synthetic oil is still > quite clear even after 3200 miles. The engine used to smoke some > when leaving a stop light but now has to be fully floored to put out > much smoke at all. The coolant is also not running quite as warm > thus the fan is seldom kicking in any more. More than likely fuel > consumption has also decreased but since I do not keep track I can't > vouch for that. It is quite obvious to me that something good has > taken place with my change from dino oil to synthetic. Next step is > to change the other lubricants as well. I am not trying to start a > war here but am just relaying my experience "for what it's worth". > > Alvie Miller > 1993 WLWB > Arthur IL. > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > wrote: > > > > Thank you Tom. I would have put you in the non-believer camp. > Enjoy > > your Walmart Dino Oil. > > > > Mike Bulriss - I won the bet! I won the bet! > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner > wrote: > > > > > > Mike you may be correct but I cannot find anywhere that ANY > > > syntheitcs are recommended for use in the Detroit diesel 2 cycle > > > engine. The statement in sect 3.7 that you quote " only > synthetic > > > oils which do not contain viscosity improver additives may be > used" > > > disqualifies all multigrade synthetics since viscosity improvers > are > > > used. I can buy Rotella T single grade at Walmarts and it is > easily > > availble. > > > > > > http://www.shell-lubricants.com/products...llaTSG.pdf > > > Tom Warner > > > Vernon Center,NY > > > 1982 FC35 (for sale soon for $35K or best offer) > > > 1985 PT 40 > > > > > > At 02:04 PM 4/7/2006, you wrote: > > > >Ron, > > > > > > > >Re your comments: > > > > > > > > > The two stroke Detroits really shouldn't use synthetics, > > > > > unless someone starts producing a single weight synthetic. > > > > > All that I have seen are multi-grade and they won't hold up > under 5 > > > > > psi oil pressure at idle. > > > > > > > >Just FYI, Detroit's current statement on synthetics is as > follows: > > > >3.7 SYNTHETIC OILS > > > >Synthetic oils should be used in Detroit Diesel engines > provided they > > > >are API licensed and meet the performance and chemical > requirements > > > >outlined in this publication. The oil should be a PGOS 93K214 > approved > > > >product for use in EGR equipped engines. For two-stroke cycle > > > >engines, only synthetic oils which do not contain viscosity > improver > > > >additives may be used. > > > > > > > >I have been using Amsoil 15W-40 Heavy Duty Diesel and Marine > Oil in > > > >both my Birds. Generally speaking, "W"/multigrade oils have to > pass > > > >both the low viscosity and high viscosity tests. The Amsoil > oil does > > > >and passes all tests that are required for straight 40 oil - > and all > > > >the requirements for a straight 40 oil listed in the Detroit > > > >publication. My 8V and my old 6V both had approximately 15lbs > at idle > > > >on synthetic. > > > > > > > >You are right that the single weight synthetics are impossible > to find > > > >any more. The market wasn't big enough for manufacturers to > continue > > > >to make it. The new generation multi-weight synthetics perform > just > > > >as well as the straight weights. > > > > > > > >Generally, synthetic versus non-synthetic debates are split > into the > > > >true believer and non-believer camps. With the current prices, > the > > > >price delta is narrowing. If one believes that cheaper dino oil > > > >performs as well as synthetics, then that's their comfort > factor. If > > > >one believes that synthetics don't break down like dino oil, > reduce > > > >friction, which reduces heat, and are better at protecting an > > > >expensive investment, then that is what they will use. All the > rest > > > >is just rethoric that will convince neither party. Mark me > down as > > > >true believer/user since 1979. > > > > > > > >Mike Bulriss > > > >1991 WB40 "Texas Minivan" - full of Amsoil > > > >San Antonio, TX > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" > > > > > > > > > > > > > > I agree mostly with what you say, but with a couple > exceptions. > > First > > > > > with engine oil: The two stroke Detroits really shouldn't > use > > > > > synthetics, unless someone starts producing a single weight > > synthetic. > > > > > All that I have seen are multi-grade and they won't hold up > under 5 > > > > > psi oil pressure at idle. > > > > > > > > > > I use Transynd in my Allison because I have a transmission > retarder. > > > > > Since I drive a lot in the mountains, the synthetic holds up > better > > > > > with the heat stress that is created using the retarder. I > > agree with > > > > > natural fluids if that were not the case. > > > > > > > > > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner > > > wrote: > > > > > > > > > > > > Each of us has to make our own decisions relative to how > we will > > > > > > service our engines and transmissions, what kind and brand > of > > tires > > > > > > to use etc, etc etc, ad nauseum. But in my experience > > starting with > > > > > > High Fidelity in the 1950's many bought based on the hype > of > > > > > > manufacturers taunting the fantastic frequency repsonses > of their > > > > > > equipment. Of course the better the specifications the > higher the > > > > > > price. Problem is that many who bought the highest speced > > equipment > > > > > > and paid sky high prices for it, seldom used it and had no > ear to > > > > > > differentiate the difference. Yep I was one of those. > > > > > > > > > > > > And in my opinion this very closely relates to the use of > > synthetic > > > > > > motor oils and transmission fluids used in motorhomes that > are > > driven > > > > > > very few miles a year. If you notice on the Allison > > transmission site > > > > > > that was > > > > noted > > > > > > > <<http://tinyurl.com/qs3a9>http://tinyurl.com/qs3a9>http://tinyurl.co > m/qs3a9, > > > > > > and then go to Approved C4 fluids you will note that > Dextron 3 > > is an > > > > > > approved fluid and meets all of Allisons specifications. > In other > > > > > > words it meets ALL of the Allison specifications..period, > as > > do over > > > > > > 700 other brands! But note that Allison now recommends > > changing the > > > > > > C4 specification transmission lubricants at 12,000 mile > > intervals or > > > > > > every 6 months which ever comes first. Isnt it strange that > > the over > > > > > > the previous 50 years or so truckers all over the world > never,ever > > > > > > followed this regimine and racked up in excess of 500,000 > miles on > > > > > > them without a problem? Wonder how many Allison > transmissions in > > > > > > motorhome service have never had their fluid changed since > > > > > > manufacture? And note if you do use Transynd the > transmission > > fluid > > > > > > change interval is 75,000 miles or 36 months. We are not > going to > > > > > > hit the 75,000 mile in 3 years, at least I dont plan to, so > > every 3 > > > > > > years I would have to change the transmission fluid after > > travelling > > > > > > approximately 15,000-20,000 miles. > > > > > > > > > > > > Now go to the list of approved Allison TES-295 approved > > transmission > > > > > > fluids, which is a severe duty extended drain interval > > transmission > > > > > > fluid. Note that Amsoil, that you have noted in > > > > > > http://www.syntheticwarehouse.com/drivet....htm#*NEW* is > NOT > > listed > > > > > > as an Allison TES-295 approved fluid. > > > > > > > > > > > > As I have noted many times previously todays engine oils > and > > > > > > transmission fluids meet or exceed any kind of service we > put our > > > > > > motorhomes thru. If you drive sensibly Dextron 3 for the > > transmission > > > > > > and good dino oil is fine for the diesel engine. > > > > > > tom warner > > > > > > Vernon center,NY > > > > > > 1982 FC35 (for sale soon) > > > > > > 1985 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > At 09:24 AM 4/6/2006, you wrote: > > > > > > >Bob, > > > > > > > > > > > > > >I'm no expert, but I am fortunate enough to have a long- > time > > friend > > > > > > >nearby that is an Allison Transmission Specialist, and > > services our > > > > > > >bus. On his professional recommendation, we changed out > the > > filters > > > > > > >and added TranSynd, synthetic fluid. > > > > > > > > > > > > > > > > > > > > > > > ><<http://www.allisontransmission.com/>http://www.allisontransmissio > > > > n.com/>http://www.allisontransmission.com/ > > > > > > > ><http://www.syntheticwarehouse.com/drivet....htm#*NEW*>h > > > > ttp://www.syntheticwarehouse.com/drivetr....htm#*NEW* > > > > > > > ><http://tinyurl.com/qs3a9><http://tinyurl.com/qs3a9>http://tiny > > > > url.com/qs3a9 > > > > > > > > > > > > > >Ron, No. California > > > > > > >85PT36 > > > > > > > > > > > > > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > > > > > > > > > > > > > > > > > > > > > > Is it worth the expense ($8.00 a quart)and how long > does > > it last > > > > > > > > before needing rechanging? > > > > > > > > Should I just stay with the conventional stuff in > there now > > > > > (changing > > > > > > > > it out, of course). > > > > > > > > What think you? > > > > > > > > > > > > > > > > Bob Lawrence > > > > > > > > 84 pt36 > > > > > > > > Tacky Tacoma, Wa. with 556 days till fulltiming on the > road. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >---------- > > > > > > >YAHOO! GROUPS LINKS > > > > > > > > > > > > > > * Visit your group > > > > > > > > > > > > > "<<http://groups.yahoo.com/group/WanderlodgeForum>http://groups.yah > oo.com/group/WanderlodgeForum>WanderlodgeForum" > > > > > on the web. > > > > > > > * > > > > > > > * To unsubscribe from this group, send an email to: > > > > > > > * > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > * > > > > > > > * Your use of Yahoo! Groups is subject to the > > > > > > > > > > > > > > <<http://docs.yahoo.com/info/terms/>http://docs.yahoo.com/info/terms/ > >Yahoo! > > > > > > Terms of Service. > > > > > > > > > > > > > > > > > > > > >---------- > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >---------- > > > >YAHOO! GROUPS LINKS > > > > > > > > * Visit your group > > > > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" > > on the web. > > > > * > > > > * To unsubscribe from this group, send an email to: > > > > * > > > > > > > > > > > > > > > > * > > > > * Your use of Yahoo! Groups is subject to the > > > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > > > > > > > >---------- > > > > > > > > > > > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] > |
