Now Here's A Dumb Question...
04-15-2006, 09:37
My isle light, under the dinnet table, stoped working. I feel rather
dim-whitted but after buying a new bulb I can not make the light work. I suspect that it is not grounded correctly. When I took the fitting apart the ground wire just fell out like it was loose. Does anyone know how this light works? Man, I feel foolish! Oh, there are two other isle lights on the same circuit and they both work fine. James 78FC33SB LasVegas NV |
04-15-2006, 13:03
James,
To make those lights work, you have to put that ground wire against the metal part of the lamp holder. I made them work by putting the ground wire where the metal "prongs" that hold the light to the square metal and pressing it all together. David Hollis Spfld,IL James has my bus --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > My isle light, under the dinnet table, stoped working. I feel rather > dim-whitted but after buying a new bulb I can not make the light work. > > I suspect that it is not grounded correctly. When I took the fitting > apart the ground wire just fell out like it was loose. > > Does anyone know how this light works? > > Man, I feel foolish! > > Oh, there are two other isle lights on the same circuit and they both > work fine. > > > James > 78FC33SB > LasVegas NV > |
04-15-2006, 17:31
Thanks Dave, that was easy. I'm having a blast with the bus !! I
hope all is well with you and yours, thanks for the reply. James 78FC33SB LasVegas NV --- In WanderlodgeForum@yahoogroups.com, "dthollis1961" > > James, > > To make those lights work, you have to put that ground wire against > the metal part of the lamp holder. I made them work by putting the > ground wire where the metal "prongs" that hold the light to the > square metal and pressing it all together. > > David Hollis Spfld,IL James has my bus > > > --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > > > > My isle light, under the dinnet table, stoped working. I feel > rather > > dim-whitted but after buying a new bulb I can not make the light > work. > > > > I suspect that it is not grounded correctly. When I took the > fitting > > apart the ground wire just fell out like it was loose. > > > > Does anyone know how this light works? > > > > Man, I feel foolish! > > > > Oh, there are two other isle lights on the same circuit and they > both > > work fine. > > > > > > James > > 78FC33SB > > LasVegas NV > > > |
