Differential oil level SP36
04-18-2006, 01:33
Just completed a lube job on my 90 SP36 and noted only one place
on the differential having what looked like an inspection plug. It appears to be a slotted end shaft with a locknut on it. Is this where the oil level is checked? If so, what should the level be and is there any guidelines for how far the slotted shaft should be screwed back in? Chuck Harrison 90 SP36 Akron, Ohio |
04-18-2006, 01:43
That's the pinion gear preload. It wouldn't be good to disturb
that setting. The road side of the carrier should have a 1/2" npt plug a little below the pinion center line, your lube should be with in 1/2 inch of that opening, coach sitting on a level surface. Mike Hohnstein ----- Original Message ----- From: williamcharrison To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, April 18, 2006 8:33 AM Subject: [WanderlodgeForum] Differential oil level SP36 Just completed a lube job on my 90 SP36 and noted only one place on the differential having what looked like an inspection plug. It appears to be a slotted end shaft with a locknut on it. Is this where the oil level is checked? If so, what should the level be and is there any guidelines for how far the slotted shaft should be screwed back in? Chuck Harrison 90 SP36 Akron, Ohio SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
04-18-2006, 02:37
Thanks Mike.
--- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > That's the pinion gear preload. It wouldn't be good to disturb > that setting. The road side of the carrier should have a 1/2" npt plug a little below the pinion center line, your lube should be with in 1/2 inch of that opening, coach sitting on a level surface. > Mike Hohnstein > ----- Original Message ----- > From: williamcharrison > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, April 18, 2006 8:33 AM > Subject: [WanderlodgeForum] Differential oil level SP36 > > > Just completed a lube job on my 90 SP36 and noted only one place > on the differential having what looked like an inspection plug. > It appears to be a slotted end shaft with a locknut on it. Is this > where the oil level is checked? If so, what should the level be > and is there any guidelines for how far the slotted shaft should be > screwed back in? > > Chuck Harrison > 90 SP36 > Akron, Ohio > > > > > > SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance > Recreational vehicle dealer Used recreational vehicles Automotive radiators > > > ------------------------------------------------------------------- ----------- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ------------------------------------------------------------------- ----------- > > > > [Non-text portions of this message have been removed] > |
