My Tolite Will Not Stop Filling !!!!!
04-22-2006, 02:49
Walked up to the bus this morning and there was water under it. Went
inside to find the tolite bowl full and slowly overflowing. The bowl continues to fill even when the city water is off. Both black and grey tanks are empty. Does anyone have any idea what is happening? HELP !! James 78FC33SB LasVegas NV |
04-22-2006, 03:06
--- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions"
wrote: > > Walked up to the bus this morning and there was water under it. Went > inside to find the tolite bowl full and slowly overflowing. The bowl > continues to fill even when the city water is off. Both black and grey > tanks are empty. > > Does anyone have any idea what is happening? > James, if it is a step fill bowl maybe the value is stuck, does your bowl have two pedals? as far as the water still running maybe the you have rv water pump on, also I never leave water on either city or house while I am not there for that reason. if its a value it is can be replace I just did mine a month ago guy smalley 86 pt 4o |
04-22-2006, 03:25
Ernie, my head has only one pedal. It is a Thetford Aqua-Magic V
model. Thanks for the reply. I'm trying to figure it out, and thought I might find some help on this forum. James 78FC33SB LasVegas NV --- In WanderlodgeForum@yahoogroups.com, "guysmalley" > > --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > wrote: > > > > Walked up to the bus this morning and there was water under it. Went > > inside to find the tolite bowl full and slowly overflowing. The bowl > > continues to fill even when the city water is off. Both black and grey > > tanks are empty. > > > > Does anyone have any idea what is happening? > > > James, > if it is a step fill bowl maybe the value is stuck, does your bowl have two pedals? > as far as the water still running maybe the you have rv water pump on, also I never leave > water on either city or house while I am not there for that reason. if its a value it is can be > replace I just did mine a month ago > > guy smalley > 86 pt 4o > |
04-22-2006, 03:32
James:
As mentioned check the fill valve attached to the foot pedal. Also check the vacuum breaker at the rear of the commode inside the pedestal up high near the top. But it really sounds like the fill valve. Easy replacement. Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 03:25 PM 4/22/2006 +0000, you wrote: >Ernie, my head has only one pedal. It is a Thetford Aqua-Magic V >model. Thanks for the reply. I'm trying to figure it out, and >thought I might find some help on this forum. > > >James >78FC33SB >LasVegas NV > > |
04-22-2006, 03:35
I won't touch this one, but someone else will.
Blair in Oregon At 08:25 AM 4/22/2006, you wrote: >Ernie, my head has only one pedal. >James |
04-22-2006, 03:49
Thanks Ralph. What ever was causing that valve to open is no longer
there. It seems to operate just fine. I guess a solid particle must of fouled it and has now fulshed it's self clean. The bowl is no longer filling. Oh well, alls well that ends well. Thanks. James 78FC33SB LasVegas NV --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > James: > > As mentioned check the fill valve attached to the foot pedal. Also check > the vacuum breaker at the rear of the commode inside the pedestal up high > near the top. But it really sounds like the fill valve. Easy replacement. > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > http://home.swbell.net/rlf47/index.htm > > At 03:25 PM 4/22/2006 +0000, you wrote: > >Ernie, my head has only one pedal. It is a Thetford Aqua-Magic V > >model. Thanks for the reply. I'm trying to figure it out, and > >thought I might find some help on this forum. > > > > > >James > >78FC33SB > >LasVegas NV > > > > > |
04-22-2006, 11:48
Sounds like you should rebuild the inlet valve
Go to manufactureres website they all have parts breakdown and parts number for service parts Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "orbitalsolutions" > > Walked up to the bus this morning and there was water under it. Went > inside to find the tolite bowl full and slowly overflowing. The bowl > continues to fill even when the city water is off. Both black and grey > tanks are empty. > > Does anyone have any idea what is happening? > > HELP !! > > James > 78FC33SB > LasVegas NV > |
