FC Generator Replacement
05-08-2006, 13:24
I've just about had my fill of the FC Kohler generator and its
deafening noise. I am considering replacement with an Onan Quiet Diesel. What is the minimum wattage I can get away with? I know the 12.5 was overkill, but do I need a 10kw? Will a 8kw do it? I have roof airs, not cruise airs. Thanks Scott Forman 82 FC35RB Memphis |
05-08-2006, 13:29
Two roof airs? 8kw should do it.
Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Scott Forman wrote: > I've just about had my fill of the FC Kohler generator and its > deafening noise. I am considering replacement with an Onan Quiet > Diesel. > > What is the minimum wattage I can get away with? I know the 12.5 was > overkill, but do I need a 10kw? Will a 8kw do it? I have roof airs, > not cruise airs. > > Thanks > > Scott Forman > 82 FC35RB > Memphis > > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms&k=Recr...vehic\ les&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreati\ onal+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&\ c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> > Recreational vehicle financing > <http://groups.yahoo.com/gads?t=ms&k=Recr...eatio\ nal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4\ =Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehi\ cle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> > Recreational vehicle repair > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> > > Recreational vehicle rental > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> > Recreational vehicle camper > <http://groups.yahoo.com/gads?t=ms&k=Recr...ional\ +vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Re\ creational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle\ +rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> > Recreational vehicle rate > <http://groups.yahoo.com/gads?t=ms&k=Recr...#43;v\ ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recr\ eational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+r\ ate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > |
05-08-2006, 13:44
Scott, I suspect that 8 kw would handle the three a/c units as long as they were
not all started at the same time. But it wouldn't leave a lot of capacity for much else. I know that Gary Miller put a 8 kw quiet diesel in his Bird but I think he only has 2 a/c units. Bruce Morris (919)872-7635 Raleigh, NC Webmaster - Wanderlodge Owners Online 1983 WL FC35RB FMCA: 7142s Ham Radio: KI4ME Vietnam Vet - 1966-67 'Doc' (Navy Corpsman) 3rd MarDiv ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Monday, May 08, 2006 9:24 PM Subject: [WanderlodgeForum] FC Generator Replacement I've just about had my fill of the FC Kohler generator and its deafening noise. I am considering replacement with an Onan Quiet Diesel. What is the minimum wattage I can get away with? I know the 12.5 was overkill, but do I need a 10kw? Will a 8kw do it? I have roof airs, not cruise airs. Thanks Scott Forman 82 FC35RB Memphis SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
05-08-2006, 14:13
Scott I forgot about your problem of noise. If you redo the generator
compartment with the correct soundproofing material, 1" thick , 2# per sq ft composite soundproofing with a lead barrier and foil face you will drastically cut down on the noise where it is just a murmur when sitting in the drivers seat at the front of the coach. I actually replaced mine with the same composite but used the vinyl barrier and it works great but not as good as the lead barrier. If I were to do it again I would use the lead barrier. You can buy cheaper material from JC Whitney but for all of the work you will do in replacing it I would strongly advise you to buy material from http://www.soundown.com. It is no more expensive then the cheaper stuff. In addition you might want to look at the soundproofing suggestions on the site. Soundown has a full range of products for underlayment for the carpet, mufflers and isolation mounts etc. If you really want to quiet down a FC model Bluebird then reline the doghouse with their the 2" thick lead barrier composite with a foil face. You will be amazed at the reduction in noise. In the 1982 FC35 that I just sold, it had factory installed mass loaded vinyl barrier material very much like that offered by soundown. Wonder if it could be their product? Tom Warner Vernon Center,NY 1985 PT 40 ' At 09:24 PM 5/8/2006, you wrote: >I've just about had my fill of the FC Kohler generator and its >deafening noise. I am considering replacement with an Onan Quiet >Diesel. > >What is the minimum wattage I can get away with? I know the 12.5 was >overkill, but do I need a 10kw? Will a 8kw do it? I have roof airs, >not cruise airs. > >Thanks > >Scott Forman >82 FC35RB >Memphis > > > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreat\ ional+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate\ &c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Recr...reati\ onal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w\ 4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+veh\ icle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg>Recreational >vehicle financing ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=R\ ecreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicl\ e+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ>Recreational >vehicle repair ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=R\ ecreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicl\ e+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA>Recreational >vehicle rental ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=R\ ecreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicl\ e+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ>Recreational >vehicle camper ><http://groups.yahoo.com/gads?t=ms&k=Recr...onal+\ vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Rec\ reational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+\ rate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw>Recreational >vehicle rate > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
05-08-2006, 14:54
While Generators are up for discussion, can anyone point me to a good source
for a 12 to 15KW Generator for my home as Hurricane season is about here again A good used unit would be fine. While diesel would work ok, I could also use Nat Gas or LP. I would prefer it to be in the Southeast so I could pick it up myself and save on delivery cost and delay. Jerry MS Gulf Coast Looking _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Curt Sprenger Sent: Monday, May 08, 2006 8:30 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] FC Generator Replacement Two roof airs? 8kw should do it. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. Scott Forman wrote: > I've just about had my fill of the FC Kohler generator and its > deafening noise. I am considering replacement with an Onan Quiet > Diesel. > > What is the minimum wattage I can get away with? I know the 12.5 was > overkill, but do I need a 10kw? Will a 8kw do it? I have roof airs, > not cruise airs. > > Thanks > > Scott Forman > 82 FC35RB > Memphis > > > > > > > SPONSORED LINKS > Recreational vehicles > <http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4= Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v ehicle+rate&c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> &k=Recreational+vehicles&w1=Recreational+vehicles&w2=Recreational+vehicle+fi nancing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5=Rec reational+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=_jXmbh7 qWHD7DSskzUir3w> > Recreational vehicle financing > <http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+financing&w1=Recre ational+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+r epair&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recre ational+vehicle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> &k=Recreational+vehicle+financing&w1=Recreational+vehicles&w2=Recreational+v ehicle+financing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rent al&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.si g=f_xgT1AKZsKXD6CT0_3nwg> > Recreational vehicle repair > <http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+repair&w1=Recreati onal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repa ir&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati onal+vehicle+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> &k=Recreational+vehicle+repair&w1=Recreational+vehicles&w2=Recreational+vehi cle+financing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental& w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=0 EDYS_wXU1aorG4893QXpQ> > > Recreational vehicle rental > <http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rental&w1=Recreati onal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repa ir&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati onal+vehicle+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> &k=Recreational+vehicle+rental&w1=Recreational+vehicles&w2=Recreational+vehi cle+financing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental& w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=L NSmSf785IF1UlbWHRIOLA> > Recreational vehicle camper > <http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+camper&w1=Recreati onal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repa ir&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati onal+vehicle+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> &k=Recreational+vehicle+camper&w1=Recreational+vehicles&w2=Recreational+vehi cle+financing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental& w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=L oIo4UxSgNx-IyPMRku1lQ> > Recreational vehicle rate > <http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rate&w1=Recreation al+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreation al+vehicle+rate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> &k=Recreational+vehicle+rate&w1=Recreational+vehicles&w2=Recreational+vehicl e+financing&w3=Recreational+vehicle+repair&w4=Recreational+vehicle+rental&w5 =Recreational+vehicle+camper&w6=Recreational+vehicle+rate&c=6&s=193&.sig=N3i a10-EgZXwB7kJhwD4dw> > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum>" on the web. > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ > SPONSORED LINKS Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4= Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v ehicle+rate&c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> vehicles Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+financing&w1=Recre ational+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+r epair&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recre ational+vehicle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> vehicle financing Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+repair&w1=Recreati onal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repa ir&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati onal+vehicle+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> vehicle repair Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rental&w1=Recreati onal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repa ir&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati onal+vehicle+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> vehicle rental Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+camper&w1=Recreati onal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repa ir&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati onal+vehicle+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> vehicle camper Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rate&w1=Recreation al+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreation al+vehicle+rate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> vehicle rate _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! <http://docs.yahoo.com/info/terms/> Terms of Service. _____ [Non-text portions of this message have been removed] |
05-08-2006, 18:08
Hey Scott,
The 8k watt onan quiet diesel weighs about 420 lbs. The 12.5k watt onan quiet diesel weights 770 lbs. 350 lbs is quite a difference, even on a heavy Wanderlodge. However, if you look at the specs, they get similar fuel efficiency. Click on http://www.onan.com/onan/rvgenerators/Qu...p?prd\ id=prod90023 If you only have two roof airs, go with 8K watts. I have a FC-35 with 3 cruise air underbelly AC units. I'm also considering a onan quiet diesel. I guess I'm stuck having to buy the large 12.5K watt. Hope that helps. Andy Coleman 83' FC-35 Spring Lake Heights, NJ --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > I've just about had my fill of the FC Kohler generator and its > deafening noise. I am considering replacement with an Onan Quiet > Diesel. > > What is the minimum wattage I can get away with? I know the 12.5 was > overkill, but do I need a 10kw? Will a 8kw do it? I have roof airs, > not cruise airs. > > Thanks > > Scott Forman > 82 FC35RB > Memphis > |
05-08-2006, 19:24
Jerry- i believe there is a generator for sale on the vintage birds forum.
ernie-83pt40 in Texas [Non-text portions of this message have been removed] |
05-09-2006, 00:26
There are other suppliers of composite insulation and less expensive
than either whitney or soundown and a better product too. I would be happy to supply insulation for your project The vinyl barrier is every bit as good as the lead barrier and more cost effective but we can supply both http://www.capeinnovation.com Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, Tom Warner > > Scott I forgot about your problem of noise. If you redo the generator > compartment with the correct soundproofing material, 1" thick , 2# > per sq ft composite soundproofing with a lead barrier and foil face > you will drastically cut down on the noise where it is just a murmur > when sitting in the drivers seat at the front of the coach. I > actually replaced mine with the same composite but used the vinyl > barrier and it works great but not as good as the lead barrier. If I > were to do it again I would use the lead barrier. You can buy > cheaper material from JC Whitney but for all of the work you will do > in replacing it I would strongly advise you to buy material from > http://www.soundown.com. It is no more expensive then the cheaper stuff. In > addition you might want to look at the soundproofing suggestions on > the site. Soundown has a full range of products for underlayment for > the carpet, mufflers and isolation mounts etc. If you really want to > quiet down a FC model Bluebird then reline the doghouse with their > the 2" thick lead barrier composite with a foil face. You will be > amazed at the reduction in noise. > > In the 1982 FC35 that I just sold, it had factory installed mass > loaded vinyl barrier material very much like that offered by > soundown. Wonder if it could be their product? > > Tom Warner > Vernon Center,NY > 1985 PT 40 > > ' At 09:24 PM 5/8/2006, you wrote: > >I've just about had my fill of the FC Kohler generator and its > >deafening noise. I am considering replacement with an Onan Quiet > >Diesel. > > > >What is the minimum wattage I can get away with? I know the 12.5 was > >overkill, but do I need a 10kw? Will a 8kw do it? I have roof airs, > >not cruise airs. > > > >Thanks > > > >Scott Forman > >82 FC35RB > >Memphis > > > > > > > > > > > > > >SPONSORED LINKS > ><http://groups.yahoo.com/gads?t=ms&k=Recr...;vehi\ cles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Recreat\ ional+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+rate\ &c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w>Recreational > >vehicles > ><http://groups.yahoo.com/gads?t=ms&k=Recr...reati\ onal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w\ 4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+veh\ icle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg>Recreational > >vehicle financing > ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=R\ ecreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicl\ e+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ>Recreational > >vehicle repair > ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=R\ ecreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicl\ e+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA>Recreational > >vehicle rental > ><http://groups.yahoo.com/gads?t=ms&k=Recr...tiona\ l+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=R\ ecreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicl\ e+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ>Recreational > >vehicle camper > ><http://groups.yahoo.com/gads?t=ms&k=Recr...onal+\ vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4=Rec\ reational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+vehicle+\ rate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw>Recreational > >vehicle rate > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > odgeForum-unsubscribe@yahoogroups.com > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- > |
05-09-2006, 01:13
10kw should hold it. This will give you the capacity for pretty much
everything at once, of course you wouldn't run electric heat and A/C at the same time, but everything else. I was not happy with 8kw. On the other hand, de-rate for high temperatures, and since the 10kw isn't a turbo-diesel normally, de-rate for anything above sea level, ... and a nice 12.5kw unit would hold pretty much everything on a hot day at moderate altitude. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > I've just about had my fill of the FC Kohler generator and its > deafening noise. I am considering replacement with an Onan Quiet > Diesel. > > What is the minimum wattage I can get away with? I know the 12.5 was > overkill, but do I need a 10kw? Will a 8kw do it? I have roof airs, > not cruise airs. > > Thanks > > Scott Forman > 82 FC35RB > Memphis > |
05-09-2006, 02:41
I have 3 roof airs. I am hoping a 10 will be sufficient.
Scott --- In WanderlodgeForum@yahoogroups.com, "Andy Coleman" > > Hey Scott, > > The 8k watt onan quiet diesel weighs about 420 lbs. > > The 12.5k watt onan quiet diesel weights 770 lbs. 350 lbs is quite a > difference, even on a heavy Wanderlodge. > > However, if you look at the specs, they get similar fuel efficiency. > Click on > http://www.onan.com/onan/rvgenerators/Qu...roductDeta il.jsp?prdid=prod90023 > > If you only have two roof airs, go with 8K watts. > > I have a FC-35 with 3 cruise air underbelly AC units. I'm also > considering a onan quiet diesel. I guess I'm stuck having to buy the > large 12.5K watt. > > Hope that helps. > > Andy Coleman > 83' FC-35 > Spring Lake Heights, NJ > > > > --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@> > wrote: > > > > I've just about had my fill of the FC Kohler generator and its > > deafening noise. I am considering replacement with an Onan Quiet > > Diesel. > > > > What is the minimum wattage I can get away with? I know the 12.5 was > > overkill, but do I need a 10kw? Will a 8kw do it? I have roof airs, > > not cruise airs. > > > > Thanks > > > > Scott Forman > > 82 FC35RB > > Memphis > > > |
