Gencon Board
05-09-2006, 08:09
Gencon Board
Hi Wes,
On my Blue Bird, the generator often doesn't start the first time. It seems that the pulse to the fuel solenoid is too short. I called Powertech and they said most likely the fuel solenoid is not being held on long enough for the oil pressure to build. If I start the coach manually she starts every time. The gencon board, on the other hand, often has to try 3 or 4 times. Is there a potentiometer or something that I can use to lengthen the pulse on the Start signal? Thanks, David Brady '02 LXi > |
05-11-2006, 12:51
Gencon Board
--- In WanderlodgeForum@yahoogroups.com, David Brady
wrote: > > Hi Wes, > > On my Blue Bird, the generator often doesn't start the first time. > It seems that the pulse to the fuel solenoid is too short. I called > Powertech and they said most likely the fuel solenoid is not being > held on long enough for the oil pressure to build. If I start the > coach manually she starts every time. The gencon board, on the > other hand, often has to try 3 or 4 times. Is there a potentiometer > or something that I can use to lengthen the pulse on the Start > signal? > > Thanks, > David Brady > '02 LXi > > > David, the GenCon board holds the pre-heat (glow plugs) ON for 3 seconds after the generator has started. Holding the glow-plugs ON also keeps the fuel solenoid ON. Ordinarily, by the time the engine has been running for 3 seconds, the oil pressure has risen to operating pressure and that holds the fuel pressure solenoid ON even after the GenCon has turned the glow-plugs OFF. In the event that the generator oil pressure has not risen to operating pressure within 3 seconds of starting, and the GenCon turns the glow-plugs OFF, the generator will stop. Having said all of that, if this sounds like what you are experiencing, we can reprogram your GenCon to keep the glow-plugs ON longer, thus keeping the fuel solenoid ON until the oil pressure comes up to proper operating pressure. Are you running PTSCON-F.HEX firmware on your GenCon board? I'll have to ask Westhaver Sr. what the fee is for the reprogramming. I'll let you know something as soon as you confirm what firmware you are running on your GenCon. Wes Westhaver 443-538-7819 Westhaver Associates, Inc. Recreational Vehicle Products http://www.westhaverassociates.com |
05-11-2006, 23:11
Gencon Board
Hi David,
I just read Wes's response and wanted to pass on another experience to you. As one or more glow plugs on the Gen burn out, the Gen takes increasingly longer to start. In my case, simply checking for and replacing a burned out plug solved the problem. I should have guessed the GenCon had a pre-heat role, but it never dawned on me, so I'm glad you asked and Wes answered. One more "bit" to add to ye ole knowledge base. John Suter 2000LXi --- David Brady > Hi Wes, > > On my Blue Bird, the generator often doesn't start > the first time. > It seems that the pulse to the fuel solenoid is too > short. I called > Powertech and they said most likely the fuel > solenoid is not being > held on long enough for the oil pressure to build. > If I start the > coach manually she starts every time. The gencon > board, on the > other hand, often has to try 3 or 4 times. Is there > a potentiometer > or something that I can use to lengthen the pulse on > the Start > signal? > > Thanks, > David Brady > '02 LXi > > > > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com |
05-12-2006, 05:14
Gencon Board
Thanks John, I think I'll start by replacing the glow plugs.
Are they easily accessible and replaced by a shade-tree mechanic? David Brady '02 LXi, Smokey Va John Suter wrote: > Hi David, > > I just read Wes's response and wanted to pass on > another experience to you. > As one or more glow plugs on the Gen burn out, the > Gen takes increasingly longer to start. In my case, > simply checking for and replacing a burned out plug > solved the problem. > I should have guessed the GenCon had a pre-heat > role, but it never dawned on me, so I'm glad you asked > and Wes answered. One more "bit" to add to ye ole > knowledge base. > > John Suter > 2000LXi > > > > > |
05-12-2006, 05:15
Gencon Board
Thanks Wes, this helps a great deal.
best regards, David Brady '02 LXi, Smokey Va lwesthaver1958 wrote: > --- In WanderlodgeForum@yahoogroups.com, David Brady > wrote: > >> Hi Wes, >> >> On my Blue Bird, the generator often doesn't start the first time. >> It seems that the pulse to the fuel solenoid is too short. I called >> Powertech and they said most likely the fuel solenoid is not being >> held on long enough for the oil pressure to build. If I start the >> coach manually she starts every time. The gencon board, on the >> other hand, often has to try 3 or 4 times. Is there a potentiometer >> or something that I can use to lengthen the pulse on the Start >> signal? >> >> Thanks, >> David Brady >> '02 LXi >> > > David, the GenCon board holds the pre-heat (glow plugs) ON for 3 > seconds after the generator has started. Holding the glow-plugs ON > also keeps the fuel solenoid ON. Ordinarily, by the time the engine > has been running for 3 seconds, the oil pressure has risen to > operating pressure and that holds the fuel pressure solenoid ON even > after the GenCon has turned the glow-plugs OFF. > > In the event that the generator oil pressure has not risen to > operating pressure within 3 seconds of starting, and the GenCon > turns the glow-plugs OFF, the generator will stop. > > Having said all of that, if this sounds like what you are > experiencing, we can reprogram your GenCon to keep the glow-plugs ON > longer, thus keeping the fuel solenoid ON until the oil pressure > comes up to proper operating pressure. > > Are you running PTSCON-F.HEX firmware on your GenCon board? > > I'll have to ask Westhaver Sr. what the fee is for the > reprogramming. I'll let you know something as soon as you confirm > what firmware you are running on your GenCon. > > Wes Westhaver > 443-538-7819 > Westhaver Associates, Inc. > Recreational Vehicle Products > http://www.westhaverassociates.com > > > > > > > > > > Yahoo! Groups Links > > > > > > > > |
